Footbag
Reged: 04/13/09
Loc: Scranton, PA
V-groove casters & inverted angle iron?
      #5916926 - 06/12/13 12:55 PM
I'm at the point where I need to acquire the angle iron and v-groove caster wheels.
I'll likely go with these. They are 4in ductile steel wheels. I'm just wondering if there would be a benefit to using another material, or to stick with the plan.
As for the angle iron, I don't know whether should have a local machine shop weld an inverted angle iron to some flat stock so I can easily mount it. Or whether I should just buy the angle iron drill it and invert it onto the top plate of my observatory. Also what size and thickness angle iron?
I'd love any insight from anyone who has done this. Also, what is the typical length of angle iron stock? Lowe's maxes out at 6'. I saw one online for 240" for $50. Even if that is without shipping it's pretty cheap.
Galaxyhunter
Reged: 01/02/06
Loc: Northern Illinois
Re: V-groove casters & inverted angle iron? new [Re: Footbag]
      #5917624 - 06/12/13 08:01 PM
Adam, Those casters will do just fine. If you went with some kind of plastic composite, It will increase the effort to roll the roof. I used 1.5 x 3/16 angle iron. I could of used 1/8" thick, but I have never been accused of building anything wimpy. I welded the angle iron to 3/16 x 3” flat stock. This aided in the ease of mounting. If you just use the iron on your top plate, your screws will be at an angle. I have found that this is a royal PITA to keep the iron straight. As a side benefit of using a flat plate is the this will stiffen up the top of the wall. The link below shows how I made the end of the iron. I put a stop at the end & put a capture rod on it so when the roof closes, it will automatically be locked down. No need for turn buckles or chains to hold the roof.
http://hawkeye-observatory.com/ob-2/retain.html
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: V-groove casters & inverted angle iron? new [Re: Galaxyhunter]
      #5917646 - 06/12/13 08:18 PM
You just gave me a whole lot more to think about. The capture rod is genius. But I don't think it will work with my roof design.
I should probably order the casters so I can bring them to the machine shop. Hmmm. Thinking.
*skyguy*
Reged: 12/31/08
Loc: Western New York
      #5917695 - 06/12/13 08:48 PM Attachment (46 downloads)
Hi Adam ... The v-groove casters look good ... very similar to the ones I used in my observatory. For my track ... I welded the inverted angle iron onto square steel tubing. Inside the observatory, mounting brackets were welded onto the tubing to attach the track to the wood top plate. Outside the observatory, the combined angle iron and square tubing created a track so strong that all I needed was a single welded support frame ... made from left-over angle iron ... to hold the very heavy ROR. I also welded small steel plate "wheel stops" at the end of both roof tracks. The system has worked great over the past 12 years with absolutely no problems and no repairs.
LoveChina61
Reged: 06/20/09
      #5917709 - 06/12/13 08:56 PM
I am using 6 steel wheels that I purchased from Grainger for about $30-$35 apiece. The wheels have bearings and it is a good thing too. My 1/2hp garage door opener could barely budge the roof till I squirted a bunch of grease in each wheel's grease hole. Then the roof slid along effortlessly. I just need to regrease the wheels one time each year and it is good to go.
tim53
Reged: 12/17/04
Loc: Highland Park, CA
Re: V-groove casters & inverted angle iron? new [Re: LoveChina61]
      #5917785 - 06/12/13 09:38 PM
I wonder if something like a full extension drawer slide would work for a rolloff roof. Pier Tech does something almost like this with their rolloffs. My Hatch Observatory hatch cover uses 4.5 ft long industrial drawer slides that we had the contractor use when we were rebuilding the roof of our house after a fire in 2001. I looked them up several years ago, and found they make them up to 5 feet, but they cost $500 each. Ouch! Nice thing is that they're completely hidden when the roof is closed. Bad thing is that, to make a 10' wide rolloff, you'd need to split the roof in the middle and use 4 slides. Expensive!
But I wonder if a similar apparatus could be made using channel iron and wheels?
-Tim
CharlesW
Reged: 11/02/12
Loc: Chula Vista & Indio, CA
Re: V-groove casters & inverted angle iron? new [Re: tim53]
      #5917893 - 06/12/13 10:38 PM
I would imagine that you might find a steel supplier in Scranton that specializes in rolling-gate casters and angle. You could get a lot of ideas there.
Starhawk
Space Ranger
Reged: 09/16/08
Loc: Tucson, Arizona
Re: V-groove casters & inverted angle iron? new [Re: CharlesW]
      #5918124 - 06/13/13 01:59 AM
I've been wondering about using garden railway track and wheels.
It would defeat the degree of freedom overconstraint problem two v tracks cause.
-Rich
HenryB
Reged: 01/11/13
      #5918285 - 06/13/13 07:26 AM
I went with V-casters intended for an automatic fence. They have nice sealed roller bearings and make opening and closing a 12'x12' effortless. Another point is to provide capability for a small amount of lateral movement of the roller, since it is difficult to get the tracks perfectly straight and parallel. I was concerned about needing a motorized roof, but I can move my 12'x12' roof easily with one hand. For my 60+ year body, opening the roof is the least of my worries.
Bryan
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: V-groove casters & inverted angle iron? new [Re: HenryB]
      #5918395 - 06/13/13 09:15 AM
I have looked at both the fence track and angle iron. I like the fence track because it is simpler, but I didn't have much luck finding it locally.
I actually found someone to weld the angle iron for me and it's very reasonable. It seems like I'll get out for around $200 for two 20ft tracks.
Edited by Footbag (06/13/13 09:26 AM)
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #5918424 - 06/13/13 09:36 AM
Is anyone actually using the rigid plates for the casters? Or have you fabricated the caster into your roof design. I'd love to see or hear about some solutions.
If I could mount the casters to the roofs top plate without using the plate, then I could keep the roof lower. Otherwise, the rigid plated have slightly under a 6" rise.
DeanS
Reged: 07/12/05
Loc: Central Kentucky
      #5926210 - 06/17/13 07:39 PM Attachment (34 downloads)
I used cast iron V groove rollers from McMaster Carr. Angle iron was welded to 5" steel plate.
DeanS
Reged: 07/12/05
Re: V-groove casters & inverted angle iron? new [Re: DeanS]
      #5926216 - 06/17/13 07:41 PM Attachment (35 downloads)
Here is a drawing with my roller details. A little hard to read but you can see what I did.
Mirzam
Reged: 04/01/08
Loc: Lovettsville, VA
      #5926988 - 06/18/13 08:20 AM
Nicely done.
How do you protect the exposed angle iron on the outside rails? The initial paint was rubbed off mine pretty quickly. I usually lather the rails with spray protectant every year or so. But there still is considerable rust formation.
JimC
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
Re: V-groove casters & inverted angle iron? new [Re: Mirzam]
      #5927006 - 06/18/13 08:34 AM
The paint that BYO used on my rails has held up extremely well over the years! I've got to ask Scott what paint it is, for when I do touch up the rails.
You might try the Rustoleum paint.
DeanS
Reged: 07/12/05
Re: V-groove casters & inverted angle iron? new [Re: csa/montana]
      #5927021 - 06/18/13 08:39 AM
The top of the angle iron is cleaned of rust each time it opens, but the welds are rusty now. This is on my summer project list, wire brush it well, and use some kind of rust inhibiting paint. But I doubt I will live long enough for the rust to ever be anything more than a cosmetic issue.
Dean
Mirzam
Reged: 04/01/08
      #5927146 - 06/18/13 09:59 AM
Seems like there is a Neil Young song along those lines...
Maybe I am too optimistic!
JimC
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #5927187 - 06/18/13 10:32 AM
Light surface rust actually becomes a protective coating in and of itself. Mike
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #5927269 - 06/18/13 11:05 AM
JimC
Now thats funny! I can almost hear it in Neil Youngs voice.
Thanks for all the info. I got it all ordered, now I just hace to assemble it. I went with rigid casters, but may just remove them From the plates and mount them within the roofs top plate. I want that as rigid as possible, but with as low a rise as possible.
Edited by Footbag (06/18/13 01:29 PM)
Lord Beowulf
Reged: 10/13/08
Loc: Cedar Park, TX
      #5928408 - 06/18/13 11:11 PM
Hi Adam,
The "usual" sources like McMaster Carr and Grainger are certainly viable for this sort of thing, but they aren't the most economical. I built my roll-off based on the concept used by Scott at Backyard Observatories. For that I bought these wheels by themselves off Amazon from SmallParts.com (now apparently Amazon Supply) and used half inch bolts from Home Depot for the axles. The wheels were under $11 each delivered and while they don't have these in stock, they have some 1.5" wide ones for $8.39. The nuts and bolts were a couple bucks each.
As for the angle iron, I bought seven 20' pieces of 1" angle for under $20 each (less than $1/foot) from a local pipe supplier. It just comes down to finding the right suppliers.
Beo
Visit the corresponding Orion Ranch Observatory web page.
hjd1964
Reged: 05/24/12
      #5928853 - 06/19/13 09:33 AM
I used 1-1/2"x3/16" angle iron also, except outside I used aluminum not steel. The v-groove casters (really wheels) were from mcmaster-carr, 600# rated x 10. The angle came from metalsdepot.com, shipping was pricey. Remember snow when estimating your loads.
http://www.stellarjourney.com/index.php?r=site/observatory_construction
Howard
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: V-groove casters & inverted angle iron? new [Re: hjd1964]
      #5932120 - 06/20/13 09:46 PM
I just got my casters... Very nice and heavy. They ride nicely along the bearings as well.
I think I'm going to leave them on the plates. But how should I mount the caster plates to a top 2x6? 1 1/2"Lag bolts or drill the 2x6 for a hex head bolt? Lags would probably be easier, but they may split the wood a bit.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #5932340 - 06/21/13 12:14 AM
If you use 5/16" lag screws just use a 3/16" inch pilot hole and you won't split any wood....guaranteed. Mike
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: V-groove casters & inverted angle iron? new [Re: mikey cee]
      #5932649 - 06/21/13 08:44 AM
I was dreaming about the caters last night. I'm now up in the air over whether to remove them from the plates or not. I know people do it both ways, but by removing them, the roof may be slightly more rigid.
I need to do a mockup, but I'm not getting my rail until Monday afternoon. Too much time to think.
I also think I will have some help on Monday as well, I'd love to get the roof done Monday and Tuesday. But it's definitely a tough one. I figure we'll have to lift 200LBS over our heads and onto the track.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #6076886 - 09/12/13 12:19 PM
I'm just bumping this up because it works so well. But I've discovered something that would've been easier to work on before it was mounted...
Water has a tendency to get under the angle iron and follow it back into the observatory. The solution is to fully caulk the angle iron to the flat stock, but it's been tough 16 feet above the ground. If I could do it all over again, I would've done it all before mounting it. Live and learn, or read this and know.
John Fitzgerald
In Focus
Reged: 01/04/04
Loc: AR
      #6077570 - 09/12/13 06:34 PM
I left my 10 casters on the plates, and lag screwed them into the bottom of the triple 2x12 roof side wall.
rlandsboro
Reged: 02/23/12
Loc: Scottsdale, AZ. USA
Re: V-groove casters & inverted angle iron? new [Re: John Fitzgerald]
      #6078074 - 09/13/13 12:27 AM
If you plan to leave the casters on the plates, check them for sideways movement on the axles. If you have a lot of play, you may want to use some washers to minimize any unwanted sideways movement.
John Fitzgerald
In Focus
Reged: 01/04/04
Loc: AR
Re: V-groove casters & inverted angle iron? new [Re: rlandsboro]
      #6079650 - 09/13/13 11:59 PM
You need a little sideways movement, around 1/8 inch per wheel. Otherwise, the rails will have to be perfectly aligned, and it is nearly impossible to get and keep the rails exactly parallel, especially in a long run. Mine are 33 feet long. The rails initially were parallel to less than 1/8 inch, but it has now been 5 years, and they still work well. The side play helps a lot.
BYoesle
Reged: 06/12/04
Loc: Goldendale, Washington USA
      #6089725 - 09/19/13 11:03 AM Attachment (5 downloads)
Ditto.
I just welded up four 16 foot sections of inverted angle iron track, and it is virtually impossible to get it perfectly straight (or the metal plate it was attached to). Having enough play on the wheel axle will prevent significant binding up as the roof is moved, although by virtue of using V grove wheels you are not locked in as much as other wheels would cause - the wheel will also have some vertical movement in which to "ride up" a little as well.
BTW, Amazon has a great deal on 4 inch 700 lbs. load V groove caters for <$11.00 each: http://www.amazon.com/RWM-Casters-V-Groove-Bearing-Capacity/dp/B00426CB5U/ref...
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: V-groove casters & inverted angle iron? new [Re: BYoesle]
      #6089735 - 09/19/13 11:08 AM
I payed close to $300 for mine. They look very similar.
tim57064
Reged: 08/23/12
Loc: Southeast South Dakota,USA
      #6090051 - 09/19/13 02:12 PM
I had done a google search trying to find casters similar to these and could not find them at the price these are.I just bought 4 of them for my Observatory build. With having a 700 lb capacity for each,4 of them should be enough for my 10'x12'observatory,seeing I am intending on using steel roofing which will be much lighter than your typical asphalt shingles. Bob, a big Thanks for the link.
Edited by tim57064 (09/19/13 02:13 PM)
4 registered and 13 anonymous users are browsing this forum.
Moderator:  Christopher Erickson, Mitchell Duke
