Pages: 1 | 2 | 3 | (show all)
dawziecat
Reged: 10/20/10
Loc: Rural Nova Scotia
Metal roof color?
      #6221135 - 11/28/13 10:56 AM
Decision time on the color for the metal roof.
I am not sure I find the white attractive. I am leaning toward a dark red.
Latitude is 44N. Not subtropical desert.
Bad idea? Should I stick with white or off-white to keep heat down?
Edited by dawziecat (11/28/13 11:32 AM)
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Metal roof color? new [Re: dawziecat]
      #6221181 - 11/28/13 11:18 AM
Red is pretty. I went with green in my neck of he woods.
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
      #6221228 - 11/28/13 11:37 AM
I have a white roof; but I really wouldn't worry much about the color, choose what appeals to you!
dawziecat
Reged: 10/20/10
Re: Metal roof color? new [Re: csa/montana]
      #6221252 - 11/28/13 11:47 AM
Thanks, Chris and Carol. I got hung up somewhere thinking it had to be "white-ish."
tim57064
Reged: 08/23/12
Loc: Southeast South Dakota,USA
      #6221295 - 11/28/13 12:05 PM Attachment (30 downloads)
Well Terry you know what I like.
Edited by tim57064 (11/28/13 12:12 PM)
tim57064
Reged: 08/23/12
      #6221317 - 11/28/13 12:17 PM
Terry,One thing about white,or any bright color.If the Obs is within the constant view of the house,and the sun is ever behind or above it,you will be shading your eyes quite often.Just a thought.
tim57064
Reged: 08/23/12
Re: Metal roof color? new [Re: tim57064]
      #6221319 - 11/28/13 12:19 PM
Another thing is if the ceiling is finished and is insulated,that will help keep the heat to a minimum inside.
Edited by tim57064 (11/28/13 12:20 PM)
P26
Vendor - Peterson Engineering
Reged: 05/02/12
Loc: RI, USA
      #6221493 - 11/28/13 01:32 PM
The obvious reason for white is to minimize radiant solar heating. Even though a roll-off roof cools the building more quickly than a dome when opened, the telescope will take longer to reach ambient temperature if it starts off warmer than it could be. I'm in RI (41N) and the interior of my white structure stays pretty close to ambient even when closed on a hot summer day. So there's a slight trade-off between function and aesthetics.
Clear skies,
Pete Peterson
Wishing Star Observatory I15
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
      #6221517 - 11/28/13 01:44 PM
I have not found this to happen with mine. The sun doesn't seem to reflect off the white metal roof to cause any problem.
dawziecat
Reged: 10/20/10
      #6221569 - 11/28/13 02:08 PM
The shed guy brought a roof sample and I decided on an off-white color that looks nice.
Aquarist
Reged: 08/27/12
Loc: Illinois
      #6221929 - 11/28/13 04:44 PM
I have white. No reflections from the sun.
Lord Beowulf
Reged: 10/13/08
Loc: Cedar Park, TX
Re: Metal roof color? new [Re: Aquarist]
      #6222178 - 11/28/13 07:08 PM
Green standing seam metal roof.
Beo
pstarr
Reged: 09/17/04
Loc: NE Ohio
      #6222280 - 11/28/13 08:23 PM Attachment (21 downloads)
I went with white. My main concern was keeping the building as cool as possible, not about how it looks. When the roof was raw galvanized metal it got quite hot in the sun. I also used white aluminum siding on the exterior walls. All that white does a good job keeping the building cool. I also installed ridge vent material the length of roof. The overhang on the sides are opened and screened the length of the roof to aide ventilation.
JJK
Reged: 04/28/08
Re: Metal roof color? new [Re: P26]
      #6222401 - 11/28/13 09:40 PM
Clear skies,
Pete Peterson
Color isn't the only factor determining heat transfer into the observatory.
Calypte
Reged: 03/20/07
Loc: Anza, California
Re: Metal roof color? new [Re: JJK]
      #6222684 - 11/29/13 01:22 AM
Mine is a deep red. It's very attractive with the gray walls (plastic siding) and white trim.
LoveChina61
Reged: 06/20/09
Re: Metal roof color? new [Re: Calypte]
      #6223021 - 11/29/13 09:20 AM
the standard galvanized metal roofing sheets (silver-colored) are usually coated with a thin layer of oil that needs to be washed off well if you decided to paint over it. Otherwise you will be re-painting the roof every 3 years or so because the paint was not able to bond solidly with the metal.
I am told the best way to get it off is to have it professionally spray-washed.
Any others have experience with this?
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: Metal roof color? new [Re: LoveChina61]
      #6223117 - 11/29/13 10:33 AM
I love my red roof.
pstarr
Reged: 09/17/04
Loc: NE Ohio
      #6223177 - 11/29/13 11:08 AM
Even if you wash the oil off, paint still has a hard time sticking to galv., much like painting aluminum. You need to use a primer/paint made for use on Galv. surfaces. I worked in Sheet metal for 36 years. We used to wash it down with a diluted mixture of muriatic acid to etch the surface. We also would buy a galvanized metal called paint grip. It was already treated to make painting easy.
read here This is rather extream but you get the idea that you can't just paint it without some prep work. I bought a paint/priner in one at sears that was made for Galvanized. I just washed the surface with acetone on a rag to remove any oil. The paint has been on there almost 20 years and hasn't peeled. Once you get a good base coat, you can pretty much put any paint over it. Your no longer painting galvanized, your painting the paint that's already on there.
StarStuff1
Reged: 04/01/07
Re: Metal roof color? new [Re: pstarr]
      #6223464 - 11/29/13 01:47 PM
Almost 20 years ago I built a 10x12 ROR using plans from a British astro book. It recommended using translucent fiberglass panel for the roof so light would come in.
The problem was that so much light came in the building got unbearably hot. I soon painted the roof except for a small 2-ft square in the middle left as a "skylight".
A few years later we sold the house. The guy that bought it turned the observatory into a doghouse for his large dog that was blind.
bremms
Reged: 08/31/12
Loc: SC
Re: Metal roof color? new [Re: StarStuff1]
      #6223573 - 11/29/13 02:49 PM
White or silver for reasons of emissivity and heating. Ever wonder why ALL observatories are white or silver..
9 registered and 11 anonymous users are browsing this forum.
