Pages: 1 | 2 | 3 | (show all)
dawziecat
Reged: 10/20/10
Loc: Rural Nova Scotia
Re: ROR Tracks Stuck by Frost on First Night new [Re: Raginar]
      #6242512 - 12/09/13 12:03 PM
Hi Guys:
Thanks for the suggestions. Holes in track are drilled. Won't help with frost though.
I will get some spray machine oil and give the wheels a good shot.
Contractor left today but will get me steel flashing to cover the rails against snow. Same stuff as the roofing end pieces . . . seems almost "made to order," it fits the 4X4 and rail assembly so well. They will have to be removed before and replaced after each session though. Fortunately, only an issue in winter . . . and when precipitation is forecast.
Mary B
Reged: 05/21/10
Loc: Minnesota
Re: ROR Tracks Stuck by Frost on First Night new [Re: dawziecat]
      #6242974 - 12/09/13 03:52 PM
WD40 is horrible stuff, attracts dust and dirt and evaporates away fast. They make a windshield defrost spray that could be used if they freeze, and a good low temp lube like SuperLube on the wheels and maybe in the track?
dawziecat
Reged: 10/20/10
Re: ROR Tracks Stuck by Frost on First Night new [Re: Mary B]
      #6243010 - 12/09/13 04:05 PM
WD40 is horrible stuff . . .
WHAT?
Sacrilege!
What's next? A slur against duct tape??
Seriously. Thanks for the hint. I will be looking for this stuff at the local hardware store.
dawziecat
Reged: 10/20/10
      #6249192 - 12/12/13 02:20 PM
Roof was seized shut this morning. I am pretty sure it is the bearings in the steel roller wheels. I squirted liquid grease into them, rolled the roof back and forth a few times to distribute the gunk and closed back up. Checked back a few hours later and all was well. Temperature is currently minus 8C (17F). Won't be sure until tomorrow morning I suppose.
Norm Meyer
Reged: 02/08/09
Loc: Warren, ME 04864
      #6249570 - 12/12/13 05:36 PM
WD40 displaces water I would think it would help eliminate
moisture to prevent freeze up. But then again what do I know!
Norm
Ian Robinson
Reged: 01/29/09
Loc: 33S , 151E
      #6249585 - 12/12/13 05:44 PM
Ian, got any product ideas to make this happen?
In industry the heat tracing is simply run along the pipe / tube you want to warm.
http://www.thermon.com/catalog/us_pdf_files/TEP0059.pdf
dawziecat
Reged: 10/20/10
Re: ROR Tracks Stuck by Frost on First Night new [Re: Norm Meyer]
      #6249652 - 12/12/13 06:28 PM
Well, I am still shocked at Mary's heresy! I considered contacting a mod to have her heinous post expunged!
I did the WD40 thing . . and the roof still locked up on me. I am now all but positive it was caused by a thin layer of moisture on the ball bearings? Why the WD40 was not sufficient I don't know but it could have been I did not get it into the bearing races as I lost my little straw applicator and just used a wide spray. Truth is, I did not really understand how those wheels were constructed and wasted a lot of WD-40 on fittings that have no effect on the wheels rolling freely in the first place.
This morning, I did my best with a straw applicator to get the "liquid grease" right into the bearing races. It has not seized up since. I was out there this evening, it's -12C(10F) and the roof behaved very well. So, I think I have the problem licked.
Mary B
Reged: 05/21/10
Loc: Minnesota
      #6249690 - 12/12/13 06:43 PM
WD40 displaces water but also evaporates rapidly leaving little lubrication behind. It also attracts dirt and makes it stick, we banned it in the shop at the casino because of that. Guys used it on coin hoppers and gummed them up badly with coin dust, we ended up having to rebuild over 100 of them.
thesungazer
Sungazer
Reged: 05/06/03
Loc: Maryland
      #6249815 - 12/12/13 08:12 PM
Another idea is white lithium grease. I put it on twice a year and lube the exposed metal parts too. Works great.
Greg
John Fitzgerald
In Focus
Reged: 01/04/04
Loc: AR
Re: ROR Tracks Stuck by Frost on First Night new [Re: thesungazer]
      #6249829 - 12/12/13 08:19 PM
IMO the only way to go especially in freeze prone areas is inverted v track and matching wheels. Garage door wheels are a problem when not totally shielded.
DeanS
Reged: 07/12/05
Loc: Central Kentucky
Re: ROR Tracks Stuck by Frost on First Night new [Re: John Fitzgerald]
      #6249856 - 12/12/13 08:36 PM
When I first built mine I had pulleys and rope to open the roof. Thought it would be fine even though it took a bit of effort to pull. First night that it could real cold, down in the 20's or so and I went to close up, it was like pulling a car with fishing line. The grease in the wheels must have thickened up and it was vey difficult to move which could be part of your issue as well. I had the 12 volt winches on it the next day
Now I am close to having the Backyard Observatory motor and rack installed so I will be able to automate it.
Dean
thesungazer
Sungazer
Reged: 05/06/03
Loc: Maryland
Re: ROR Tracks Stuck by Frost on First Night new [Re: DeanS]
      #6249865 - 12/12/13 08:42 PM
Installing a motor is a worthwhile investment, Dean. I love it.
Greg
dawziecat
Reged: 10/20/10
      #6250531 - 12/13/13 09:36 AM Attachment (13 downloads)
It went to -17C(+1F) here last night. It had risen to -10C(+15F) by morning. A good "cold soak" for the lubricated rollers. The roof rolls readily! Anyone else having trouble with garage door rollers in sub-freezing weather should try lubing them and understand better than I did just where to get the lube. Not sure all rollers are built the same but I attach a close up of mine. The free play for lateral movement is not likely a problem in freezing temps although I suppose it's possible if your tracks are out of parallel. The lube needs to get into the bearing races in the hub, as pictured.
I doubt I will install any electric openers. Even a hand winch seems unnecessary, if the roof continues to roll as well as it does right now. A simple push stick is fine. Full automation, as in a remotely located observatory is not a goal for me.
Edited by dawziecat (12/13/13 09:44 AM)
Agatha
Reged: 06/04/12
Loc: Coulee Region, Wisconsin
      #6250777 - 12/13/13 11:49 AM
At the risk of committing sacrilege of WD 40, I must agree with Mary.
I love WD 40...always have a can around. It's good for many things. It is great for cleaning grease. It eats it for lunch. It is so thin to penetrate and will fix a squeaky hinge among other things. It has no real lubrication properties, especially for heavy use. I'm so glad that you got some proper lube in those wheels. Sounds like it is working beautifully.
Your observatory is absolutely beautiful. It's been fun watching your threads.
I have a question about your siding. Does it need to be painted or can it be left as is with maybe a sealer? I love the look of it as is.
Best,
dawziecat
Reged: 10/20/10
Re: ROR Tracks Stuck by Frost on First Night new [Re: Agatha]
      #6250797 - 12/13/13 12:01 PM
Thanks, Linda.
I have learned the error of my ways with WD-40 and "see the light" Thanks to Mary for that. (I do cling to my religious fervor when it come to duct tape though! )
The siding is pine. It will weather to a rather unsightly, dingy black in this climate. It looks pretty now but that will change with time. I could indeed seal it with a transparent stain although my experience is so-so with that stuff. It looks great for a year or three and then not so great. Of course it comes down to personal preference. My late wife would want it to match the colours she picked out for our garden shed. I like them too and plan to use an opaque stain on the siding and paint on the trim to match that shed. Those colours have stood up very well these past ten years.
Mary B
Reged: 05/21/10
Loc: Minnesota
      #6251038 - 12/13/13 02:34 PM
Duct tape is a must! I have rolls all over the place.
jazle
Reged: 05/20/10
Loc: California, USA
      #6251139 - 12/13/13 03:24 PM
Waiting to see who creates the first duct tape dew shield on a SCT.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: ROR Tracks Stuck by Frost on First Night new [Re: jazle]
      #6251145 - 12/13/13 03:25 PM
My dew shield is reinforced with duct tape. Does that count?
tim57064
Reged: 08/23/12
Loc: Southeast South Dakota,USA
Re: ROR Tracks Stuck by Frost on First Night new [Re: Footbag]
      #6251180 - 12/13/13 03:43 PM
+1 for the Duct Tape Dew Shield, Red G. would be proud.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: ROR Tracks Stuck by Frost on First Night [Re: Raginar]
      #6253243 - 12/14/13 07:15 PM
The slipping sound was indeed due to the carriage assembly being stripped out. It looked like the spring that holds it together had somehow cracked the plastic. I dunno if it was just general misuse or a cheap part. The new one is working flawlessly.
I might just have one sitting around in case it happens again.
9 registered and 10 anonymous users are browsing this forum.
