Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
Eq Platform for $29.5
      #2418954 - 05/25/08 04:13 PM Attachment (454 downloads)
My latest scope needs a new eq platform because of the high CG. I'm almost done with this one except for some sanding, varnishing and bolting down the motors but so far it's cost only $29.5. That doesn't count the maple plywood I already had, ball bearings I had and some screws and leveling feet I need to get yet. It'll be done before the scope!
2 motors from Apogee @ $4 each
2 3 inch Newport SS rods @ $6.60 each
maple from Home Depot $8.30
Ed Jones
rmcpb
Reged: 11/16/04
Loc: Blue Mountains, NSW, Australia
Re: Eq Platform for $29.5 new [Re: Ed Jones]
      #2419379 - 05/25/08 08:29 PM
Ed,
What is the layout on the bottom board?
Looking good
Rob Browne
8" & 13" Dobs
Equatorial Platform
Couple of Panoptics and a handful of BO/TMBs
9x60 binocs
The bear
Reged: 02/11/08
Loc: rushville, indiana
Re: Eq Platform for $29.5 new [Re: rmcpb]
      #2419383 - 05/25/08 08:31 PM
yes ed enlighten us to your good owrk this would be ideal for a poor child like me.
doc
might have the motors already hehe
Longitude -85.42786 Latitude 39.59153
"current build 6 inch F6.5 "Little Toe"
"if all else fails use duct tape "works for me"
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
Re: Eq Platform for $29.5 new [Re: The bear]
      #2419466 - 05/25/08 09:01 PM Attachment (335 downloads)
Here is the bottom board. The 1/15 rpm motors from Apogee are CCW so they must go behind the north bearing. I drilled our the smaller tapped hole on th post to 4 mm to match the motor shafts on a lathe. The SS posts from Newport are 1/2 inch so the radius of the north bearing is 23.93. The CG above the middle of the board is 17.6 inches. Total height 4.25 in. If you want I can start another thread on how I made it.
Ed Jones
The bear
Reged: 02/11/08
      #2419475 - 05/25/08 09:06 PM
yes please this would be very informative and excellent instructional to us all.
doc
Jason D
Reged: 10/21/06
Loc: California
      #2419512 - 05/25/08 09:18 PM
How well does it perform?
Jason
XT10 classic with premium optics
Tri-knob CR2 with compression rings
Round Table Platform
4.5" StarBlast
6" StarBlast6
TV EPs
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
Re: Eq Platform for $29.5 new [Re: Jason D]
      #2419590 - 05/25/08 09:52 PM
As you see it isn't finished yet but it's almost exactly like my first platform (which tracks great)except that I'm not going to knurl the Newport posts. I don't think it'll be necessary. I can always knurl it later if need be.
Ed Jones
Biff
Reged: 09/04/05
Loc: Courtice, Ontario
      #2419632 - 05/25/08 10:14 PM
Isn't this that thread? And yes I'd like to see all the details too, namely how you setup to cut a VNS with such a tight tolerance for the radius!
Ryan
Antares 200mm f/6 Dob & 130mm f/5 Travel Dob.
Projects on the go...
- a couple 80mm SS refractors on the back burner.
- a few small mirrors awaiting polishing
- 260mm f/7.15 mirror... still polishing
Member of DRAA
My house.
DRAACO
Edited by Biff (05/25/08 10:16 PM)
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
Re: Eq Platform for $29.5 new [Re: Biff]
      #2419781 - 05/25/08 11:34 PM Attachment (295 downloads)
OK well I'll start from this thread.
My latitude is 39.25 degrees and my rocker box is 18 inches square so I started with a platform 19 inches wide and long.. Shown below is the cross section layout. The south bearing is 11.91 inches radius spaced 18 inches from the north bearing. The mid platform CG is 17.6 inches from the platform but my computation for the scope CG is 14 inches, 3.6 inches lower but I don’t think it’s a problem at all.
Ed Jones
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #2419782 - 05/25/08 11:36 PM Attachment (218 downloads)
I cut two boards with a 50.75 degree bevel about 4.5 inches X 20 inches. On the back side I tacked a ¼ inch scrap piece of plywood and measured from about where the tape is to a 23.93 inch arc from each side. I drilled a hole for a finishing nail to pivot on at that point
Ed Jones
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #2419786 - 05/25/08 11:37 PM Attachment (221 downloads)
On my table saw I bolted a ¾ inch piece of wood with my finishing nail pivot a little more than 24 inches from the blade. The blade was tipped at 50.75 degrees and lowered all the way down. I raised the blade a 1/16 of an inch at a time and swung the board into the blade slowly pivoting on the nail. I raised it another 1/16 th and repeated. Eventually the blade was above the board and it was roughed out. I then switched to a sanding disk and continued, moving the part a small distance into the disk each time until the radius was 23.93 at the midpoint. This makes beautiful smooth bearings (and I have fun doing this as well).
Ed Jones
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #2419791 - 05/25/08 11:38 PM Attachment (173 downloads)
I made a trapezoid board 19 in. long by 16 in . on one side and 19 in. on the other. I drew a mid-line perpendicular to the middle of the small side (on the bottom).
Ed Jones
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #2419794 - 05/25/08 11:40 PM Attachment (159 downloads)
I glued a block with a 50.75 deg. angle on the mid line for support.
Ed Jones
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #2419803 - 05/25/08 11:41 PM Attachment (168 downloads)
The south bearing comes out pointed so finding the mid-point is easy. I align the midpoint with the mid-line and glue and screw it together.
Ed Jones
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #2419805 - 05/25/08 11:42 PM Attachment (147 downloads)
With a square set to intersect the curve on the north bearing near the edge, I mark both sides then find the mid-point.
Ed Jones
Edited by Ed Jones (05/25/08 11:53 PM)
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
Re: Eq Platform for $29.5 [Re: Ed Jones]
      #2419807 - 05/25/08 11:44 PM Attachment (150 downloads)
I made an obtuse triangle to support the back, lined up the mid-point and glued and screwed it together as before. A support block on the other side would have been easier.
Ed Jones
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #2419811 - 05/25/08 11:45 PM Attachment (158 downloads)
I glued a 1.5 X 4.5 inch piece of maple to the inside of two 24 X 2.5 inch pieces. This is for mounting the motor. I drilled a ½ inch hole in two pieces of teflon and cut them into for bearings. 2 cross-pieces of maple were glued for strength. (I taped the posts and bearings in place temporarily to figure out where the cross pieces should go.)
Ed Jones
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #2419813 - 05/25/08 11:46 PM Attachment (176 downloads)
3 pieces of maple were cut to hold the bearings. The rear bearing block was easy, the other two were compound angles and it took a number of tries cutting pieces on a band saw to get the angles right so that the ball bearings races ran flat to the bearings. These little pieces were the trickiest part of the project.
Ed Jones
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #2419825 - 05/25/08 11:50 PM
The rest is sanding, varnishing, screwing the teflon and motors down, wiring etc.
Ed Jones
ZachK
Reged: 08/21/05
Loc: Israel
      #2420013 - 05/26/08 02:35 AM
Thank you, I was planning something exactly like that and I think you gave me what I need to get going. I need to figure out how to do this without a table saw though. I have a jigsaw and a router.
Zach Kessin
Ariel Israel
Meade ETX 127 Mak-Cass
15x70 Celestron Skymaster Binoculars
Sinar F 4x5 view camera
Rolliflex Camera 80mm F2.8
Pentax K-1000 Camera 35,50 and 60--300mm zoom
4 kids
14 registered and 15 anonymous users are browsing this forum.
