rwiederrich
Goldfinger
Reged: 11/17/05
Loc: Bremerton Washington
Cincinnati mill co. pier base
      #2436398 - 06/03/08 01:01 AM Attachment (63 downloads)
I picked this mill base up and am going to make it into a pier base for either a large refractor or a newtonian.
What do you thinkers think?
Rob
www.goldmtobservingcenter.com
Providing a great place for amateur astronomers, and ATM's to come and enjoy their hobby.
rwiederrich
Goldfinger
Reged: 11/17/05
Re: Cincinnati mill co. pier base new [Re: rwiederrich]
      #2436404 - 06/03/08 01:03 AM Attachment (33 downloads)
This 5" solid steel pier base has a nice top plate for any EQ mount I wish to place there.
Thanks for peeking.
Rob
Adventurer
Reged: 11/22/07
Loc: Planet Earth
      #2436461 - 06/03/08 02:05 AM
it looks v. heavy unless mobility is not an issue!
"man is not made for defeat....A man can be destroyed but not defeated"
Regards
Adventurer
Meade ETX125 Telescope.
Home made 10 inches reflector.
John Jarosz
I'm being watched...
Reged: 04/25/04
Loc: Chicago area, IL
      #2436673 - 06/03/08 07:41 AM
What did you pick is up with? That sucker is heavy.
It will be great as a pier. I assume it's permanent in an observatory.
Are you going to remove the big casting that moves on the cylindrcal column? You'll prolly need a crane.
John
6" F4.6(w/Paracorr) GEM reflector, 8" F11 Dall Relay Scope
6" F5 RFT Refractor, Garrett Gemini 20x80 LW
rwiederrich
Goldfinger
Reged: 11/17/05
Re: Cincinnati mill co. pier base new [Re: Adventurer]
      #2436799 - 06/03/08 09:23 AM
OH no this base will not be mobile. It's kinda like what is used for an OB.
The great thing about it is it is heavy, and it has that table built in for EP's and such. The heavy table as you can see from each image rotates. The steel pier is solid steel 5" thick, with a removable top plate that can easily be used to bolt a bottom plate of an EQ head to.
This base is exactly what I was looking for for a nice heavy Newt or refractor.
It's sitting on a roll dolly at this time..so I can roll it around the shop..slean it, and de-rust it.
Rob
rwiederrich
Goldfinger
Reged: 11/17/05
Re: Cincinnati mill co. pier base new [Re: John Jarosz]
      #2436826 - 06/03/08 09:42 AM
John
John...yes it was heavy, but not that bad. We just tipped it back, rolled the dolley under one edge, and pushed it back on it. Then pushed/rolled it up a ramp onto my trailor. It took three of us to do it.
I will most likely be leaving the *casting* on the steel column. It rotates, and can act as a table or part of some unknon aspect I'm not currently aware of..
It used to be the elevating base for the mill table.
The top plate is cast aluminum, and has a large bolt securing it to the steel column. It has tapped holes on each corner, and it can be loosened and removed. it will work nicely as a top plate for an EQ to be bolted to. Its spot on level, and really requiring very little modifying.
It has a power conduit running up through its base as well.
I could put casters on the bottom, and leveling bolts...so I could roll it out of the scope garage like all my other scopes.
Way too many options......it's fun..way fun. Great find.
Rob
Gary Fuchs
Reged: 05/22/06
Loc: Easton, PA, USA
      #2436844 - 06/03/08 09:51 AM
Neat find Rob!
The bear
Reged: 02/11/08
Loc: rushville, indiana
Re: Cincinnati mill co. pier base new [Re: Gary Fuchs]
      #2436868 - 06/03/08 10:07 AM
looks like it will meet your specs real good its nice when you can reuse things like this for what we do. this is what i try and do all the time your mirror seems to be taking a lot longer than you expected but looks like this may work out to your benefit else you would not have found the base for your scope "the universe provides".
doc
Longitude -85.42786 Latitude 39.59153
when all else fails use duct tape "works for me"
rwiederrich
Goldfinger
Reged: 11/17/05
Re: Cincinnati mill co. pier base new [Re: The bear]
      #2436930 - 06/03/08 10:50 AM Attachment (28 downloads)
Here is one idea for the Mill base. I can use the adjustible table, and the 5" steel column top to afix a polar axis/drive for a fork mount. What's slick about this idea is that the table raises....with the polar axis built with articulating mounts...you can simply crank up or down on the large cast table and adjust the elevation of the polar axis. Since also...the top plate and the cast table rotate...I can have azymuth control as well.
This is turning out to be a pretty cool mill base....
See artists(me) drawing.
Rob
Edited by rwiederrich (06/03/08 11:55 AM)
Sky Captain
Scope Builder
Reged: 11/07/04
Loc: Seattle Washington
      #2437105 - 06/03/08 12:20 PM
Thanks for peeking.
Rob
Looks pretty beefy Rob!
If it were me....I'd loose the "square base" and build a steel tube 3 leg tripod. You could make it a little shorter for your Newt. I'll show you what I mean later when I get there.
Equipment Overload!
http://scopebuilder.webs.com/
Kerry.
rwiederrich
Goldfinger
Reged: 11/17/05
Re: Cincinnati mill co. pier base new [Re: Sky Captain]
      #2437719 - 06/03/08 05:18 PM
Thanks for peeking.
Rob
Don't you have some driving to do?
Rob
rwiederrich
Goldfinger
Reged: 11/17/05
      #2462658 - 06/16/08 12:49 AM Attachment (19 downloads)
Some updating on the pier.
Here is an image of the axis sitting on the pier.
Rob
rwiederrich
Goldfinger
Reged: 11/17/05
      #2462661 - 06/16/08 12:51 AM Attachment (13 downloads)
Closer view of the ring gear.
rwiederrich
Goldfinger
Reged: 11/17/05
      #2462663 - 06/16/08 12:52 AM Attachment (16 downloads)
Machining brass bearing
rwiederrich
Goldfinger
Reged: 11/17/05
      #2462666 - 06/16/08 12:54 AM Attachment (18 downloads)
aand finally the brass bearing fitted on the shaft with a grease bib fitted.
Rob(now onto the upper bearing)
Sky Captain
Scope Builder
Reged: 11/07/04
      #2462680 - 06/16/08 01:10 AM
Looking good Rob.
Equipment Overload!
Kerry.
rwiederrich
Goldfinger
Reged: 11/17/05
      #2463099 - 06/16/08 10:45 AM
I spent some time this morning cutting the 1" aluminum for the side walls that will be bolted to the alumimum top plate and the brass bearing housing. I luv my new metal band saw.....
Once the side plates are done..I will fashion a front plate and work on some kind of round top cover. The fork will be bolted to the threaded end of the shaft.
I picked up a very nice wire feed mig welder this weekend...so I will be welding the folk later this summer.
I hit pay dirt this weekend for Father's day. My sweety baught me a new air compressor, and a roll away air hose assembly with about 30 ft of rolled air hose. I spent much of Saturday hooking everything up. Now My air lines are permenant to the shop, and I can reach any part. Fun thing is..it all winds up away on the hose spool. Sweeet! It's all stored under the work bench..outta the way.
All in all...I got a new air compressor system, a new mig welder...Oh..Oh..and she got me new milling tools too.....
Oh to be married to a woman who adores me........
Rob(muscle flex...grrrrrrr)
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #2463421 - 06/16/08 01:40 PM
She probably wants to keep you out in the shop away from her longer!! Mike
Mike 10x50 sears tower binocs, 3" f/10 edmunds reflector, 2.4" f/11.7 manon refractor, 6" f/8 jaegers refractor, "The 8 Ball" 8" f/13.3 brandt refractor, 3" f/15.8 sans&streiffe refractor, 3.1" f/15 selsi refractor(towa 339), 2.4" f/15 sears refractor, selsi 30x30mm spyglass, criterion 5-draw 25x45x75x spyglass(1957).
rwiederrich
Goldfinger
Reged: 11/17/05
Re: Cincinnati mill co. pier base new [Re: mikey cee]
      #2463557 - 06/16/08 03:05 PM
I only wish that was the case(not really).
She knows that me building my own scopes is waaay cheeper then buying them finished. I'm saving thousands on that 18" mirror alone. This mill base was a great find...cuz I'm saving another bucket of thousands of dollars......
She likes that.
Rob
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #2464011 - 06/16/08 07:14 PM
Well as long as you two are happy that's really all that matters. The rest of us will muddle thru although I have few wants in regards to my equipment. Getting the observatory finished with chart racks and corner storage etc. Motorization of the roof etc. New painting and CD changer and wired for XM radio etc. Mike
14 registered and 6 anonymous users are browsing this forum.
Moderator:  Don W, Joe Cipriano
Home
