neo
Reged: 02/12/08
Loc: Iasi, Romania
Hi everyone!
Here's my little big summer project which is still an on going process to redo a small refractor I have. The scope is based on a 70mm f/6 Rodenstock Rotelar lens found on ebay at West Coast Camera if I remmember corectly. Very good lens, pretty much an Apo, some time ago I did a ronchi test on it and came out very nice. As for the fabrication itself I tried to keep things simple and I used usual materials found on my local hardware store. So for the tube I used a 110mm PVC pipe reinforced with plywood rings treated with epoxy to seal them from moisture and for stiffness. The lens had initially an aluminum ring which I used now to make the push&pull collimation system. The focuser it's all custom made Crayford style fitted inside the OTA because the focusing distance is short, in fact quite critical so no room for a classic one.
-------------------- Russian 15x50 binos
Home made 8" f/5 Newton on eq mount
Home made 70mm f/6 (Rodenstock Rotelar lens) Apo refractor
www.astronomy.ro
neo
Reged: 02/12/08
Loc: Iasi, Romania
The collimation ring seats on a thick plywood ring.
www.astronomy.ro
Edited by neo (09/09/09 06:20 PM)
neo
Reged: 02/12/08
Loc: Iasi, Romania
Collimation screws...
www.astronomy.ro
neo
Reged: 02/12/08
Loc: Iasi, Romania
The focuser was pretty tricky cause without special tools was quiet difficult tu allign the four bearings to get an even contact with the focuser's tube. So VIVA epoxy
www.astronomy.ro
neo
Reged: 02/12/08
Loc: Iasi, Romania
www.astronomy.ro
neo
Reged: 02/12/08
Loc: Iasi, Romania
Focuser...still some details to finish, like the screw that press the brass rod over the focuser's tube and the lock screw.
www.astronomy.ro
rwiederrich
Goldfinger
Reged: 11/17/05
Loc: Bremerton Washington
Well Neo....that is pretty nifty. I like your application of epoxy.....It's tough stuff.
How does the little guy take magnification?
Rob
-------------------- www.goldmtobservingcenter.com
A great place for amateur astronomers, and ATM's to come and enjoy their hobby.
http://tech.groups.yahoo.com/group/HomemadeRefractorTelescopes/ My homemade refractor group.
www.vimeo.com/6014031
neo
Reged: 02/12/08
Loc: Iasi, Romania
Thanks buddy!
Fun stuff epoxy.
The magnification goes amazingly well for a photo lens ( assuming that is a photo lens..I'm not very sure) about twice its diameter if it's very well collimated..so about 140X. But I expect that its true strength stands on astroimaging cause it has a super flat field. To bad i don't have one of those fancy SBIGs to take some pics.
www.astronomy.ro
Edited by neo (09/09/09 07:19 PM)
magic612
Reged: 09/30/08
Loc: Somewhere south of Chicago, IL
neo - that looks great! And I'm with you on the epoxy thing; that's great stuff.
-------------------- - Celestron C8+, Orion 90mm f/10, Orion ST-80, 5" f/8 Dob, 127mm f/9.4 refractor, 114mm f/8 on DS GoTo, 60mm Sears 6333-A, 127mm f4.4 refractor lens (current project), 12" f/5 mirror (future project)
- Orion Vista 10x50s (5 deg), Sears #6207 7x35 (7 deg), Jason #138 Statesman 7x35 (11.5 deg)
Yes, I'm addicted to telescopes and binoculars. I am getting help. Every time I look at the heavens, it helps.
http://www.eyesonthesky.com
neo
Reged: 02/12/08
Loc: Iasi, Romania
Thanx magic
I've just learned something new today...a fellow ATM guy from our local astronomy forum suggested mixing aluminum filings (or other powders...I guess) with epoxy. The new composite material could be poured in molds to get different parts. A very exiting ideea anyway.
www.astronomy.ro
Owen
Reged: 06/21/07
I know guys who have been doing this with diamond powder. The resulting part is 'very' durable....
Owen
neo
Reged: 02/12/08
Loc: Iasi, Romania
A small update:
I've put up some detailes on the focuser like the locking screw and the tension screw. The focusing axle being on ball bearings I added a small teflon piece from a CD-rom to act as a break. Also I prepared the thumbscrews made out from aluminum potentiometer knobs which will be screwed on the brass axel. I plan to add a planetary reduction knob..sort of ... well...in fact a ball bearing atached to the thumbscrew from the right side which will be tightened against a rubber washer causing some friction, so when I turn the ball bearing's outer ring (with another knob on top) a few times the focusing axle turns ones. Ah...I guess you got the idea
www.astronomy.ro
neo
Reged: 02/12/08
Loc: Iasi, Romania
The focusing knobs
www.astronomy.ro
neo
Reged: 02/12/08
Loc: Iasi, Romania
Today I've assembled the focuser, mounted the thumbscrews after I threded the both ends of the brass axle.
Also I experimented some more with my improvised planetary gear which....shamefully I realized that the principle is a bit wrong. After some research I've learned that I could build such a gizmo with 3 small ball bearings so I'll see how it turns out...I hope I still have some tiny bearings.
Anyway ..pictures...so here's the focuser..
www.astronomy.ro
Edited by neo (09/16/09 04:51 PM)
neo
Reged: 02/12/08
Loc: Iasi, Romania
www.astronomy.ro
neo
Reged: 02/12/08
Loc: Iasi, Romania
Just a quick assemble of the scope.
www.astronomy.ro
neo
Reged: 02/12/08
Loc: Iasi, Romania
www.astronomy.ro
David Castillo
Reged: 09/09/06
Loc: Carmel Valley, Ca
That is SWEET, eo. I like your idea of rigging a vernier reduction knob- puts it up there on another level  ---- Dave
neo
Reged: 02/12/08
Loc: Iasi, Romania
Thanx Dave ! I've found (finally) a Chinese site where was explained with tons of pictures the design of those vernier reduction knobs from GSO, I guess. So now everything is clear; still I need to try to build it with the materials in hand.
http://bbs.astron.ac.cn/thread-54988-1-3.html
Here's some paint job I've done today, in fact only the primer, tomorrow I have to buy a paint can to finish.
www.astronomy.ro
neo
Reged: 02/12/08
Loc: Iasi, Romania
Today I've received from my local work shop the focusers tube after some adjustments on lathe and now it's all nice and shiny ( good old table leg ). I've drilled three holes at 120 degrees and threaded them to be sure it holds my 2" Meade UHTC diagonal which is surprisingly heavy. Because the tube is quiet thinn and I can't grind it flat for more grip with the focusing axle, I cut a narrow piece of fine sand paper (320#) and glued it with a double sided duct tape on the fousers tube. This way the axle will hold tight the focusing tube even with a heavy load.
www.astronomy.ro
