Mark Harry
Reged: 09/05/05
Loc: Northeast
interference pattern examples
      #3372310 - 10/05/09 10:29 AM Attachment (47 downloads)
I'll post the pics. First one is a centered pattern, and the other allows the "bullseye" to be offset. The area of interest is in the central 3" 8mm thick glass, A Schott equivalent borosilicate similar to pyrex, blocked up with pitch on a 1" thick aluminum plate.
So many projects, so little time!
Mark Harry
Reged: 09/05/05
Loc: Northeast
Re: interference pattern examples new [Re: Mark Harry]
      #3372312 - 10/05/09 10:31 AM Attachment (34 downloads)
This second pattern shows the fit fairly well, at just slightly concave. About 1 set of fringe colors evident. It also shows an offset pattern, with a slight hook on the edge.
Mark Harry
Reged: 09/05/05
Loc: Northeast
      #3372322 - 10/05/09 10:38 AM
The maker of these ~3" secondaries made a groove on the front/polished face, which seems to leave a residual issue with the edge of the groove. I assess the error at about 1/8th wave surface, overall. ROC is a convex 214". Comments welcome!
The testplate is from an old Yolo project. Central 3.5"
of it are just about a perfect null.
I would have preferred a thicker glass to start with, and no groove on the front face. I think that would have helped avoid the edge defect better. I have 2 of these finished. I can post 2 more pics of the second one.
Mark
Mark Harry
Reged: 09/05/05
Loc: Northeast
      #3372326 - 10/05/09 10:43 AM Attachment (29 downloads)
here's the first from the second piece
Mark Harry
Reged: 09/05/05
Loc: Northeast
      #3372329 - 10/05/09 10:43 AM Attachment (23 downloads)
The second pic:
Mark Harry
Reged: 09/05/05
Loc: Northeast
      #3372341 - 10/05/09 10:51 AM
These 2 depict a convex fit of about 1 fringe. Still depicts an edge issue, seems to go with the way these were prepared initially. I give this one an approximate 1/8th wave as well. When touching the testplate, there is a certain amount of distortion to account for. In this case, the angle viewed at seems to counter the effect of touching the testplate, and shows a fairly round center to the bullseye.
One of the key things to note, is how just a fringe or so visible from manipulating the test plate makes the edge defect blatantly obvious on this second example. It's "almost" invisible with the many lines showing with the first picture on this second example. Beware of more than about 3-5 fringes visible in any interference test!(IFgrams included!)
Mark
Mark Harry
Reged: 09/05/05
Loc: Northeast
      #3373252 - 10/05/09 07:16 PM
Can anyone guess why a convex fit (2nd pr. pics) are not as desireable to judge errors?
Mark
Biff
Reged: 09/04/05
Loc: Courtice, Ontario
      #3373469 - 10/05/09 10:01 PM
Just a WAG (but I love guessing) if you have a concave fit you can at least measure the ROC of the piece in question accurately, and you can be reasonably sure of its quality.
Ryan
Antares 200mm f/6 Dob & 130mm f/5 Travel Dob.
Projects on the go...
- a couple 80mm SS refractors on the back burner.
- a few small mirrors awaiting polishing
- 260mm f/7.15 mirror... still polishing
Member of DRAA
My house.
DRAACO
Mark Harry
Reged: 09/05/05
Loc: Northeast
Re: interference pattern examples new [Re: Biff]
      #3374006 - 10/06/09 07:19 AM
Most of the time, the task of a smooth regular surface with these smaller items isn't an issue; but edges still are. With a concave fit, the bands curve the opposite way that the turned edges do, therefore far easier to detect.
With a convex fit, the general direction is the same, making it much harder to tell its presence, or magnitude. A little study of these pics illustrates the aspects very well.
Mark
Mark Harry
Reged: 09/05/05
Loc: Northeast
      #3374015 - 10/06/09 07:32 AM
You can also find the ROC of the convex example. Having the testplate curvature well established, just add half a wavelength to the sag of the testplate which will result in an overall greater value, and a shorter ROC. Remember, one fringe is half a wave. Testplate ROC is 5443mm, and after going through the whole mess, I get 5430mm for the convex fit secondary.
M.
Mike I. JonesModerator
Reged: 07/02/06
Loc: Fort Worth TX
      #3374068 - 10/06/09 08:38 AM Attachment (18 downloads)
Hi Mark,
I built a sodium interferometer that might be of interest to you. It gives much higher contrast fringes and a normal incidence view of the part under test. I used a piece of 1/4" thick 50/50 glass from PPG that's used for office buildings to reduce light and heat into the building. The uncoated back side faces up, and the coated side faces down, giving a ghost-free image. The low-pressure 18W sodium light and ballast cost about $65, the glass was about $35, and the rest is scrap plywood.
Here's the design, then I'll post the pictures.
56 mirrors, lenses, 16" f/6 Newt, 6" f/10 refractor, TOA-130S, Tinsley 5" f/15 Mak, 6" f/4 RFT, Coronado PST. Still to build: 24" f/10 Modified Dall-Kirkham, 10" f/26 Mak, 8" f/12 apo, spectrohelioscope, Herrig, Schupmann, and others.
Reged: 07/02/06
Loc: Fort Worth TX
Re: interference pattern examples new [Re: Mike I. Jones]
      #3374071 - 10/06/09 08:40 AM Attachment (20 downloads)
This is the finished interferometer. I can put 24" diameter parts under it. This is before I put the rubber mat on the test table.
Reged: 07/02/06
Loc: Fort Worth TX
      #3374078 - 10/06/09 08:43 AM Attachment (20 downloads)
This is what the fringes look like. The fringes have very high contrast due to the very narrow line emission from the low pressure sodium light. 18 watts doesn't sound like much, but when it's fully warmed up (takes about 10 minutes), it is blinding to look at, and plenty bright through the white Plexiglass diffuser and 50/50 beamsplitter glass for photography.
This particular part is just a dummy shined 5" Pyrex piece I grabbed to take the picture, tested against a 1/20 wave 6" master flat.
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #3374086 - 10/06/09 08:51 AM
One can also filter the light from a CFL light bulb to obtain a monochrome view or image by looking through a filter or holding it in front of the camera. Eyepiece filters work well and so do just inexpensive plastic gel filters used for stage lighting.
Mike's box with the beam splitter window is a very nice feature since it allows one to view the fringes straight down and on the optical axis. If you view the fringes on an angle there will be false curvature introduced.
- Dave
Homemade 'scopes 8"f/7,6" f/5", 6"f/4, 4.25" Schief. 60mm Coronagraph,60mm H-alpha system, 4.25" White-light Solar Newtonian,solar spectroscope, 4.5" f/16 Schupmann Medial refractor, 14 Stellafane awards 7 in optics
Engineering = Taking what you have and making what you need.
Mark Harry
Reged: 09/05/05
Loc: Northeast
Re: interference pattern examples new [Re: DAVIDG]
      #3374227 - 10/06/09 10:29 AM
"One can also filter the light from a CFL light bulb to obtain a monochrome view "
That's what I used, though unfiltered. My camera shots are fairly good, but not what really is present with naked eye.
"If you view the fringes on an angle there will be false curvature introduced."
Yes, as I noted above. Practice makes perfect in such a situation.
Nice light box, Mike! Maybe you & Kevin will come up with something big enough to place in there!
M.
Mark Harry
Reged: 09/05/05
Loc: Northeast
      #3374242 - 10/06/09 10:39 AM
I like to see the colors, personally. If you note the last pic, what normally borders the pink as you get a thinner airspace is yellow, to green. What's visible nearest the center, is an orange, and the very center; almost clear. This signifies that the parts are getting very close. If you fool around and press indescriminately, you can contact the testplate to the part. If I recall, the attraction is about 3x atmospheric pressure. You'd never get them separated by hand. These "first series" colors are always very stark and obvious. Simply the colors alone can be used to judge the accuracy of the fit. I remember the tolerance exibited when the colors just disappear, and it's clear prior to contacting- 1/10th wave or better if I recall correctly.
M.
kfrederick
Reged: 02/01/08
      #3374393 - 10/06/09 12:01 PM Attachment (16 downloads)
here is my grain bin fringe tester
kfrederick
Reged: 02/01/08
Re: interference pattern examples new [Re: kfrederick]
      #3374400 - 10/06/09 12:03 PM Attachment (14 downloads)
here is the light source
kfrederick
Reged: 02/01/08
      #3374599 - 10/06/09 01:37 PM
just a joke i started seeing fringes in the windows after building the bin
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #3374790 - 10/06/09 03:14 PM
As one knows the spacing bewteen fringes is 1/2 the wavelength of light used. With pure monochrome light one knows the exact wavelength so one can determine accuractly the difference in radius between the test plate and the piece being tested. In Mike's image, he is using Sodium light at 589nm. If one uses a multi-wavelength source, what wavelength do you use for the calculation ? It's not the average of the different wavelengths since if it was one would only see one color in the test, but your seeing multiple colors. For example there is no pink emission from a monochrome source so this color is some combination of wavelengths but which ones ?
Also the shorter the wavelength of light used the more accurate the test. For critical flat work the Helium emission at 471nm is preferred over longer wavelengths like Mercury at 546nm or HeNe at 632nm. One can see finer departures from flatness since the wavelength is shorter.
By filtering the light coming from a CFL bulb by using a simple filter, like an eyepiece filter of piece of colored plastic (red, green or yellow), one will improve the accuracy of the test by defining the wavelength of light used and increasing the contrast of fringes so errors are more easily seen.
- Dave
8 registered and 3 anonymous users are browsing this forum.
