PhotoGazer
Reged: 09/26/07
Round Wooden Tubes?
      #4220001 - 11/30/10 09:56 PM
Has anyone here made an OTA tube out of wood and made it round? If so, do you have any tips or ideas you want to hand down. I am thinking of doing this for my 5.5" OA Newt, and would appreciate any insight.
rboeAdministrator
Reged: 03/16/02
Loc: Phx, AZ
Re: Round Wooden Tubes? new [Re: PhotoGazer]
      #4220038 - 11/30/10 10:15 PM
We had a tread on that started by cocobolo (sp?) around here somewhere. Might be in the Archive section. He was unable to finish due to health problems. But it's a great start.
tim53
Reged: 12/17/04
Loc: Highland Park, CA
Re: Round Wooden Tubes? new [Re: rboe]
      #4220108 - 11/30/10 11:01 PM
Ron:
I remember that thread, and wondering what happened to it. I'm sorry to hear he wasn't able to finish it.
I've been cogitating about how to go about this. It does seem as though the best way to get a round tube would be to start with a coopered tube and sand it round.
I've always made faceted tubes out of plywood so I wouldn't need to build a form before building the tube - I just tape up the slats on a flat surface, put glue in the joints, and roll it up to dry. This is fine if you don't need to rotate your tube. But if you do, fitting rotating rings to a polygonal tube is harder than it might sound (see my own recent experiences with this here .
Of course, if you don't need to rotate, polygonal tubes aren't a problem at all.
So, I'm thinking that I might try making a coopered tube for a small refractor project I have waiting around. The tube would be small enough that I could turn it on my Harbor Freight wood lathe (12x36).
I'd also be interested in hearing others' experiences making round wood tubes.
-Tim.
plyscope
Reged: 11/23/06
Loc: Perth, West Australia
Re: Round Wooden Tubes? new [Re: tim53]
      #4220158 - 11/30/10 11:30 PM
Check out this webpage by Dave Gault, an Aussie ATM.
wood tube reflector
Andy
rboeAdministrator
Reged: 03/16/02
Loc: Phx, AZ
Re: Round Wooden Tubes? new [Re: plyscope]
      #4220577 - 12/01/10 08:47 AM
You could make a couple grooves that are round in the areas you want the rings in. But sanding it round after the fact would work too. Just a lot of work!
rboeAdministrator
Reged: 03/16/02
Loc: Phx, AZ
      #4220580 - 12/01/10 08:49 AM
Pretty cool website there Andy.
tim53
Reged: 12/17/04
      #4220647 - 12/01/10 09:42 AM
I agree. Probably a better way would be to make a jig to support a router, and turn it round with a router instead of a sander.
I thought of using thin, bendable plywood, too. But the cost would have been 3 or 4 times that of a single sheet of 1/4" plywood.
-Tim.
JohnH
Reged: 10/04/05
Loc: Squamish BC Moved!!!!!
      #4220696 - 12/01/10 10:15 AM
I plan for a 10" f/6 to make a round wood tube out of maple staves.
I bought a router bit designed to cut a bird's mouth in one side and then you can glue it up from there.
rboeAdministrator
Reged: 03/16/02
Loc: Phx, AZ
Re: Round Wooden Tubes? new [Re: JohnH]
      #4220786 - 12/01/10 11:00 AM
John, keep us posted on the birds mouth bit project. I see those bits for sale and I'm always tempted but have not pulled the trigger.
Tim; jig and router sounds like the cat's meow.
Achernar
Reged: 02/25/06
Loc: Mobile, Alabama, USA
      #4220822 - 12/01/10 11:13 AM
I made the shell in my 15-inch Dob's upper cage from 1-inch beveled wide slats of plywood. I used blue painter's tape to hold them together on the outside, then put glue in the gaps. Then I wrapped the assembly around a mandrel made of wooden disks of the desired inside diameter and used web clamps to hold the slats in place until the glue dried. All you need do is figure out the circumference of the tube on the outside, how many slats you will need and their width, then the angle of the bevel necessary. Use a table saw and push sticks to make the slats. Titebond or any other similiar yellow wood glue is an good choice for bonding the slats together. If you want to stain and varnish the tube, use a solid hardwood such as oak or cherry, and be careful to remove all traces of glue on the outside before staining. Always use an exterior grade polyurethane if you opt to varnish it, because other varnishes, shellacs and lacquers will rapidly degrade and fail.
Taras
ed_turco
Reged: 08/29/09
Loc: Lincoln, RI
      #4220829 - 12/01/10 11:16 AM Attachment (81 downloads)
A wood lathe would be a great saver of time, if you know how to use one. I recall an article in the Gleanings section of S&T from the 1950's (Anyone got the DVDs?) where an ATM made his own approximation of a wood lathe with the centers staked into the ground, a motor attached to the ground and some ropes to pulley the polygonal thing along. I think he did a 7" tube (or so) about 5 ft long.
Please remember that I am drawing upon something I read in the early 1970's.
I did make a tube out of cherry in the early 90's out of a 16 sided polygon that I cobbled together.
I have a industrial wood lathe and used a rasp to get the roundness about right, and successive grades of files and then sandpapers to complete the job.
The cherry was 3/4" thick. The tube 7.5" in diameter and 20" long.
I disassembled and refigured a 6" f/6 portrait lens and made an RFT refractor out of it. Still works great.
eric moerman
Reged: 11/08/03
Loc: belgium
Re: Round Wooden Tubes? new [Re: ed_turco]
      #4220903 - 12/01/10 11:57 AM Attachment (110 downloads)
i have made several wooden round tubes for newtons of 6" up to 16".
Here are a couple of picture of a 15" tube.
I use normal plywood for the rings and "airgraft plywood"(thats how they call it here) of 1mm thick.
For the piece that need to be stronger (mirror cell ,focuser) i use 2 layers of 1mm.
Very strong and lightweight.
eric
eric moerman
Reged: 11/08/03
Loc: belgium
Re: Round Wooden Tubes? new [Re: eric moerman]
      #4220905 - 12/01/10 11:58 AM Attachment (91 downloads)
2 picture
tim53
Reged: 12/17/04
Re: Round Wooden Tubes? new [Re: Achernar]
      #4220909 - 12/01/10 11:58 AM Attachment (65 downloads)
Taras
That's similar to what I did with my 10" f/6's tube, but I should have made mandrels to force it rounder than it is.
-Tim.
tim53
Reged: 12/17/04
      #4220942 - 12/01/10 12:15 PM Attachment (84 downloads)
Here's one I made in a similar manner to the 10"er's tube, but using solid stock vermillion padauk, resawn on my bandsaw and thickness planed to 1/4" thick. This was to be for a 5" f/5 refractor, but I'm starting to think I should leave the lens in the PVC tube it came in (probably dates to the 50's or 60's).
-Tim.
JohnH
Reged: 10/04/05
      #4220992 - 12/01/10 12:40 PM
I got the wood two years back at a store. They were blowing it out because it had gotten water-damaged. It turned out to be spalted maple. The fungus creates interesting patterns in the wood.
Its all ripped and planed to the right thickness, I just have to get my ambition together to work in my cold shop for a few days.
The bit came from Lee Valley. They come in different types. Mine can do either 6 or 12 sides. To do 6 or 16 sided objects, you need separate bit for each.
You can also do conical forms using tapered staves.
JohnH
Reged: 10/04/05
      #4220994 - 12/01/10 12:42 PM
-Tim.
Do you have photos inside the ends? I always like seeing how wooden constructs are put together inside.
tim53
Reged: 12/17/04
      #4221012 - 12/01/10 12:51 PM Attachment (89 downloads)
It's ridiculously simple. When I made the first tube like this, I was worried it wouldn't be strong enough, but glues these days!...
tim53
Reged: 12/17/04
Re: Round Wooden Tubes? [Re: tim53]
      #4221019 - 12/01/10 12:54 PM
...but I like the idea of the birdsmouth bits for a stronger joint. They'll also "control" the angle without needing a form.
One could make more or fewer-sided tubes by building a jig to feed the work into the router bit at an angle to the table. I've thought about doing something like this, since I like odd-numbered polygons.
-Tim.
ZeroID
Reged: 04/21/10
Loc: Auckland, New Zealand
      #4222064 - 12/01/10 08:03 PM
Have a look at this Japanese Astronomers site
http://www.geocities.jp/toshimi_taki/index.htm
Lots of other interesting stuff there as well
13 registered and 15 anonymous users are browsing this forum.
