Pages: 1 | 2 | 3 | (show all)
Pinbout
Reged: 02/22/10
Loc: Montclair
Re: Can this be a good mirror? new [Re: Mirzam]
      #5355486 - 08/06/12 09:05 PM
In your set of 4 images above there are obvious indications of turned edge and marked surface roughness.
milk bone - dog biscuits I'd say. I always got that when I cold pressed.
I don't cold press any more.
Savio Fong
Vendor (Galaxy Scientific)
Reged: 10/05/09
Loc: Hong Kong
Re: Can this be a good mirror? new [Re: ed_turco]
      #5355523 - 08/06/12 09:31 PM
you mean my last image? yes, it's hand polished by one of the 17yr old student. I do have the figure and just for the 3 zones (30, 70, 90%), the measurement is within 1/8 PV or so, but removing the mask, the shadowgram shows that the paraboloid is not perfect of course. Allowing certain margin for error, I would say this mirror is good being a first handmade mirror, and I encourage them to use it more under real sky. They can always strip the coating and refigure it some time later if they really want to.
Edited by Savio Fong (08/06/12 09:32 PM)
Savio Fong
Reged: 10/05/09
Loc: Hong Kong
Re: Can this be a good mirror? new [Re: mark cowan]
      #5355533 - 08/06/12 09:35 PM
thanks for your encouragements.
I still remember that early days when i wan 11 or 12 yr old, put together a Foucault testers with light bulb, battery, shaver knife.... it was terrible
Slitless testers tend to make very good Foucaultgrams - IF the edge itself is clean and sharp.
Best wishes in your ATM endeavors - sounds very promising to me!
Best,
Mark
Nils Olof Carlin
Reged: 07/26/04
Re: Can this be a good mirror? new [Re: Savio Fong]
      #5355965 - 08/07/12 06:02 AM
Mine is slit-less, and I use a good and very hard steel knife edge, so the contrast and brightness is good I think.
The edge should be straight and smooth but it needs not be sharp or hard to cut into a bundle of light!
It might be a good idea to add a second knife edge to form a kind of slit - the extra edge will not affect measurement but make the fully illuminated parts of the mirror less confusingly bright. Easy to experiment...
And the brightness is easy to control, by adding an extra resistor or potentiometer (1 kohm would likely work) in series with the LED.
While you gan get a good idea of general smoothness and reveal a number of possible problems, you can not readily decide the correction (conic constant) without measuring it, with a Couder mask.
Nils Olof
Savio Fong
Reged: 10/05/09
Loc: Hong Kong
Re: Can this be a good mirror? new [Re: Nils Olof Carlin]
      #5356108 - 08/07/12 09:05 AM
yes, I am doing measure with Couder mask, and based on my experience, I found for medium focal ratio, like f/4 to f/6 mirrors, 1/10PV is more or less the limit, any beyond that is very subjective judgement, is that true?
ed_turco
Reged: 08/29/09
Loc: Lincoln, RI
      #5356579 - 08/07/12 02:24 PM
There may be some minor defects without the zonal mask, but that mirror looks darned good to me. If it is an f/5 like yours, I'd say that mirror is sure good to go.
You can tell that 17 year old ATM for me that he has done a very nice job and that he should get that mirror into a telescope and some starlight as soon as possible.
1/8 wave PV is a nice standard; the Foucault Test, in spite of what others may say, can show defects that have little or no consequence under the stars.
Trust me
Pinbout
Reged: 02/22/10
Loc: Montclair
      #5356582 - 08/07/12 02:29 PM Attachment (17 downloads)
you can always make your students construct the masks thru geometric construction instead of using the computer, it works everytime.
saemark30
Reged: 02/21/12
Re: Can this be a good mirror? new [Re: Pinbout]
      #5356658 - 08/07/12 03:13 PM
Put it in a tube and see how well it works. That's more educational.
mark cowan
Vendor (Veritas Optics)
Reged: 06/03/05
Loc: salem, OR
      #5356696 - 08/07/12 03:47 PM Attachment (22 downloads)
Yes, I was a little too condensed there - the edge should be a blunt facet, as Texereau describes. But for Foucaultgrams and in general it needs to be defect free (under high magnifcation) and it needs to be straight. Both of these conditions can be achieved by lapping the edge of the "knife" on ground glass with some AlOx slurry, "rolling" it over through vertical as you go.
A regular straight-edge razor blade, under high magnification, isn't terribly smooth, although it is sharp. These can be blunted and lapped easily into a much better edge. Here's a picture of the slit I use on my tester over the light source, it's approx 150 micron gap with two sections of a modified (as described) razor blade snapped to the length I needed and then superglued into a washer and carefully aligned parallel.
Best,
Mark
Savio Fong
Reged: 10/05/09
Loc: Hong Kong
      #5357151 - 08/07/12 09:15 PM
thanks Mark for the info. Yes, slitless test is very easy to build and sensitive, the only challenge is high quality knife edge, and only until recently I found the best solution is to buy a high quality lathe bed blade, it cost me $20 for this little piece of steel blade, but the knife edge is near mirror finish. See my tester here, the XY micro-positioner is used equipment I got it for $30, quite a good deal.
http://www.astrocafe.hk/download/file.php?id=1265
Savio Fong
Reged: 10/05/09
Loc: Hong Kong
Re: Can this be a good mirror? new [Re: saemark30]
      #5357169 - 08/07/12 09:22 PM Attachment (28 downloads)
yes, that's what I normally do, e.g, this is a mirror from a school in Macau (a city near Hong Kong), we assemble it and imaged the M8 in heavily light polluted Hong Kong. The student is amazed with what they can achieve with bare hands, and forget whether it's 1/4 or 1/20 wave.
there is no harm for perfect, but helping most students get it done is #1 priority.
Savio Fong
Reged: 10/05/09
Loc: Hong Kong
      #5357174 - 08/07/12 09:24 PM Attachment (26 downloads)
another image from this telscope, I can say the image is solid at 200x or so, not comparable to real high quality telescope, but students are very happy already. At least this can keep them going in this hobby.
Savio Fong
Reged: 10/05/09
Loc: Hong Kong
      #5357178 - 08/07/12 09:26 PM Attachment (22 downloads)
yes, this is the one we made, like our self-made Bahtinov Focusing Mask, even though it's ugly, but works....
Savio Fong
Reged: 10/05/09
Loc: Hong Kong
      #5357205 - 08/07/12 09:44 PM Attachment (23 downloads)
Thanks Ed for your encouragements, I also send them this thread and let them know. I am sure they are happy to know that.
I agree putting together everything and use it under real sky is very important - we need to finish the work started.
Side track a little bit, this is a 4" f7 Newtonian, which I grind and polish the mirror when I was 11 year old, but only finish parabolizing in recent years, then I want to order a curve base for my Feather Touch focuser and use on this telescope. Wayne of Starlight instruments puzzled with what I am doing, so he reconfirm with me, whether I am ordering a curve base for 5.5" diameter tube or 5.5" radius tube, apparently no one is using Feather Touch on 4" Newtonian in US....
I told him I am finishing my 30year long, cross-century project, I am mounting this telescope on Paramount ME, guidescope is a 8" APO refractor, so get me the base quick..
And this is the M42 taken with this 4" Newtonian, under heavily light polluted Hong Kong - brighter than white zone.
Edited by Savio Fong (08/07/12 10:53 PM)
coinboy1
Reged: 05/03/11
Loc: Oklahoma City, OK
      #5357693 - 08/08/12 09:10 AM
Nice picture!
ed_turco
Reged: 08/29/09
Loc: Lincoln, RI
Re: Can this be a good mirror? new [Re: coinboy1]
      #5358345 - 08/08/12 04:00 PM
I think that there is a point to be made here. While it is fun and educational to discuss the theory of optical testing, it is equally important for an ATM to get a finished mirror and a telescope to look through.
Discussing the theory to the point that one might believe that the Foucault Test is next to useless (another thread) could lead a person to conclude that it is next to impossible for an amateur to make a useful telescope.
Nothing can be further from the truth.
kfrederick
Reged: 02/01/08
      #5358690 - 08/08/12 07:44 PM
ED you are 100% correct The Foucault Test is very accurate and all that is needed for any one to make a great newt primary .I think Mark C is posting some knife edge tips .I like to use ronchi then if it looks good then check center to edge for total correction . Dr Henery Malic showed me how to take good readings. It is all that is needed to know how much and where to polish.
mark cowan
Reged: 06/03/05
Loc: salem, OR
Re: Can this be a good mirror? new [Re: kfrederick]
      #5358758 - 08/08/12 08:36 PM
Yeah, I'm working on a post about Foucault procedure and analysis accuracy, still putting it together...
Best,
Mark
Savio Fong
Reged: 10/05/09
Loc: Hong Kong
      #5358759 - 08/08/12 08:36 PM
Can't agree more. I did tried Ronchi testing, and more inclined to Foucault testing. I believe there are limitation and advantage of every test, so have its value.
My understanding is Foucault test did help deliver some of the very best mirror in history, including the 200" mirror of Hale telescope?
If professional can do that 80 years ago, then we can make a mirror not bad nowadays with same method.
The reason I love Foucault test is, it's very very sensitive, and I still remember the day I was in the class learn how to read such shadow-gram, when I was 11 or 12 years old.
mark cowan
Reged: 06/03/05
Loc: salem, OR
      #5359086 - 08/09/12 01:20 AM
Not the Hale 200" - Hartmann mask testing was used on it, photography of bright star inside and outside focus through mask onto photographic plates, then micrometer measurements of star image displacements vs ideal values. And (I looked it up, pg 96) knife edge testing (photography) at focus against a star to interpolate the wide spacing of the mask. Final figuring (for the raised edge) was done inside the dome, with the mirror sitting on the aluminizing tank.
Best,
Mark
14 registered and 30 anonymous users are browsing this forum.
