Dick Jacobson
Reged: 12/22/06
Loc: Plymouth, Minnesota, USA
Spray painting a 70" mirror??
      #5541876 - 11/27/12 11:10 AM
A Utah amateur is building a 70-inch telescope (see 70" scope). Believe it or not, he plans to use a spray gun to apply the reflective coating. Quote from the article: "Although the mirror has been ground and polished, it still needs its reflective coating. Clements, with Dodds' help, plans to do this with a special metallic liquid and an automotive spray gun."
Has anyone heard of coating a mirror with a spray gun? I don't see how you could get a smooth surface.
Lynnblac
Reged: 04/06/09
Loc: Arizona
Re: Spray painting a 70" mirror?? new [Re: Dick Jacobson]
      #5541892 - 11/27/12 11:20 AM
This coating method is generally used temporarily to test optics. It is incredibly cheap and easily removed.
Mike I. Jones
Reged: 07/02/06
Loc: Fort Worth TX
      #5541905 - 11/27/12 11:27 AM
What??? The surface ripple will be so bad that mirror couldn't even be used for millimeter-wave work. But, nothing teaches better than personal hands-on experience. He'll find out soon enough.
A truly "smooth" optical surface polish and coating should introduce no phase errors across the power spectral density curve of the wavefront roughness exceeding around 10-15 degrees. The equates to about 1/20 wave max roughness, and 1/40 wave would be even better. This holds true across the EM spectrum, from radar to MMW to infrared to visible and shorter.
rboe
Reged: 03/16/02
Loc: Phx, AZ
Re: Spray painting a 70" mirror?? new [Re: Mike I. Jones]
      #5541921 - 11/27/12 11:36 AM
If he uses static charge he can mist the area above the mirror and let the electric field carry the coating to the mirror and avoid much of that ripple. Not ideal, but better than your typical spraying technique.
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
Re: Spray painting a 70" mirror?? new [Re: rboe]
      #5541969 - 11/27/12 12:01 PM
What is most likely going to happen is that they are going to use the typical chemicals used to silver a mirror. Companies like Peacock Labs http://www.peacocklabs.com/products.htm sells the premixed solutions that they recommend be applied with a typical paint spray guns. At one time Peacock sold these solutions in spray can kits that contained the three solutions that one sprayed on, one after the other, to apply a silver coating just like one would do if they followed the typical Brashear method to silver coat a mirror in a solution bath. I believe Ed Jones used the spray can method to silver coat a flat for his "window" telescope.
Happy Holidays,
- Dave
Darren Drake
Reged: 10/09/02
Loc: Chicagoland
Re: Spray painting a 70" mirror?? new [Re: DAVIDG]
      #5542224 - 11/27/12 02:20 PM
Wasn't the Hubble coated in a similar maner???
tcmzodiac
Reged: 11/11/11
Re: Spray painting a 70" mirror?? new [Re: Darren Drake]
      #5542255 - 11/27/12 02:41 PM
"Honey, I will not be home for dinner; I have to wet-sand the mirror"....
mark cowan
Vendor (Veritas Optics)
Reged: 06/03/05
Loc: salem, OR
      #5542452 - 11/27/12 04:40 PM
That would explain the IR overcoat of magnesium fluoride then.
http://en.wikipedia.org/wiki/Hubble_Space_Telescope#Optical_Telescope_Assembl...
Best,
Mark
polaraligned
Reged: 12/26/08
Re: Spray painting a 70" mirror?? new [Re: mark cowan]
      #5542536 - 11/27/12 05:43 PM
At 70" you don't need a coating for testing.
Maybe someone should contact either Steve or the scope builder for more info. Steve Dodds is a professional optician and would know better. The article could be wrong.
EJN
Reged: 11/01/05
Loc: Highway 61
      #5542541 - 11/27/12 05:47 PM
The Hubble mirror was sprayed with Krylon Ultra-Chrome.
Bob Myler
Reged: 05/18/06
Loc: St Louis, MO
Re: Spray painting a 70" mirror?? new [Re: EJN]
      #5542964 - 11/27/12 10:22 PM
Lynnblac
Reged: 04/06/09
Loc: Arizona
Re: Spray painting a 70" mirror?? new [Re: polaraligned]
      #5543678 - 11/28/12 11:26 AM
This is the best solution for an ATM, just crating and shipping this mirror would cost a fortune, plus the risk of shipping damage. Where could one have a 70" coated? I doubt it could be coated for the standard cost of $10/inch, $700+. In the past all mirrors were silvered, before aluminizing was available.
"In 1935 the silver coating used since 1917 on the Hooker 100 inch mirror was replaced with a more modern and longer lasting aluminum metallic coating that reflected 50% more light than the older silver method of coating. The newer method of coating for the telescope mirrors was first tested on the older 60 inch mirror telescope."
You might remember that Hubble established the scale of the universe with the silver coated 100" Hooker telescope.
Yes, I think Steve Dobbs does know better and this is why he is helping silver coat this mirror.
Edited by Lynnblac (11/28/12 11:28 AM)
EJN
Reged: 11/01/05
Loc: Highway 61
Re: Spray painting a 70" mirror?? new [Re: Lynnblac]
      #5543881 - 11/28/12 01:17 PM
How many coaters even have a vacuum chamber able to handle a 70" mirror?
orlyandico
Reged: 08/10/09
Loc: Singapore
      #5543905 - 11/28/12 01:31 PM
if an aluminum coating reflects 50% more light.. then that 70" with a silver coating would reflect as much light as a 57" with an aluminum coating...
and whether its 40" 60" or 70" I don't think you're getting any more resolving power, due to the atmosphere - so it's all about brightness, and the silver coating really kills it.
Project Galileo
Reged: 11/14/07
Loc: Jefferson County, Colorado
Re: Spray painting a 70" mirror?? new [Re: orlyandico]
      #5543929 - 11/28/12 01:49 PM
Wow! That is a huge mirror. Neat stuff. He looks like he is having fun with it too. Rock on!
Mike I. Jones
Reged: 07/02/06
Loc: Fort Worth TX
Re: Spray painting a 70" mirror?? new [Re: Project Galileo]
      #5543961 - 11/28/12 02:14 PM
Might contact the University of Arizona Optical Sciences Center at http://www.arizona.edu/colleges/college-optical-sciences. I think they have coater tanks plenty large enough, and their price might actually be affordable. It would be good practice for a grad student.
rboe
Reged: 03/16/02
Loc: Phx, AZ
      #5544036 - 11/28/12 02:59 PM
Thanks Mike; was going to suggest that myself. Might be other universities that can do the same.
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #5544059 - 11/28/12 03:16 PM
A fresh silver coating reflects about 98% of visible spectrum vs about 90% for aluminum. One of the issues with the chemically deposited silver coatings were they were burnished to remove the white haze that would sometimes form when the silver coating was first deposited on the glass. The burnishing process produced sleeks which scattered light. So for a telescopes like the 100" Hooker, when the switch was made from silver to aluminum, the aluminum coating scattered much less light then the burnished silvered one. The lack of stray light allows about 1/2 magnitude fainter to be seen and imaged.
- Dave
Mark Harry
Vendor
Reged: 09/05/05
Loc: Northeast USA
      #5544085 - 11/28/12 03:26 PM
Heard of the Peacock coating process-
Let 'em spray it, and look at the full moon!!! Maybe go "moonblind" for the next day!!!!!
We could call it being "moonshined"!
At that diameter, I believe a good appraisal could be gotten from the bare glass alone.
M.
TxStars
Reged: 10/01/05
Loc: Lost In Space
      #5544161 - 11/28/12 04:15 PM
You don't have a company ship something like this.
You rent a truck and drive it yourself.
8 registered and 31 anonymous users are browsing this forum.
