Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | (show all)
Sean Cunneen
Let Me Think
Reged: 08/01/07
Loc: Blue Island Illinois
Re: My 16" f7.2 Newt project code named "Grace" new [Re: Jeff Morgan]
      #5783632 - 04/07/13 11:49 AM
Thanks Jeff, I am going to have my trusses fasten semi-permenantly to the top baffle which will then bolt to my LTA. Because of the overall size of the scope, I had to think about construction and transportationo in terms of sub-assembly, so the scope will break down into 3 main pieces that should *just* fit in the back of my Caravan. If I should be forced to carry passengers or another scope, then the truss assembly will break down more traditionally and I'll assemble the trusses on the field. When the trusses look to be in the 7'-8' long range, I think you should evaluate traditional dob set up and breakdown proceedures very carefully. I'll be putting this thing together myself in low-light conditions and since the weights and moments of these long pieces will bend or snap their mounting points if something bad happens, I have to have some options!
Sean Cunneen
Let Me Think
Reged: 08/01/07
Re: My 16" f7.2 Newt project code named "Grace" new [Re: Sean Cunneen]
      #5789261 - 04/09/13 10:26 PM Attachment (40 downloads)
Some more progress:
The cell support is built from angle iron scavenged from the chair and some 3/4" square iron stock. I can't weld, so some drilling, tapping and pretty stainless steel socket head screws. The cell and mirror will ride on this frame and I am going to hinge the assembly so that I can insert the mirror easily once the whole scope is assembled on the field.
Edited by Sean Cunneen (04/09/13 10:29 PM)
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5789269 - 04/09/13 10:34 PM Attachment (37 downloads)
Now, here is where we get to some fun stuff. Lets be honest, there is not a whole lot you can do with a newt these days, so I had to have some fun somewhere! Bear in mind, the pictures that follow are only rough-fit, nothing is glued yet so things look pretty rough, but you'll get the idea soon enough!
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5789273 - 04/09/13 10:36 PM Attachment (34 downloads)
Here is the underside to show some structure. The mirror is pretty hefty, so the pieces are all stiff and thick. I'm not going to go into any detail about what the next few posts will show...
Scanning4Comets
Markus
Reged: 12/26/04
Loc: Ontario, Canada
      #5790629 - 04/10/13 04:09 PM
Sean Cunneen
Let Me Think
Reged: 08/01/07
Re: My 16" f7.2 Newt project code named "Grace" new [Re: Scanning4Comets]
      #5885741 - 05/26/13 03:05 PM Attachment (26 downloads)
Another update! Starting to feel the progress coming along. Worked through some mistakes and some miscalulations. I found some others but I'll keep those to myself
The mirror cell is now roughed in and glued up... The Mirror supports have been reinforced, everything sanded and plenty of holes drilled.
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5885747 - 05/26/13 03:08 PM Attachment (15 downloads)
Here is the shot of the underside. I am looking for a third clamp knob, turns out the two I have are a weird size so the search is on for that one! I had to make a couple of trips to the hardware store to find stiff enough springs. The three I have now will provide a nice cushion for that big mirror!
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5885753 - 05/26/13 03:13 PM Attachment (16 downloads)
Next up is the framing of the lower OTA. Each pine panel is trimmed with 3/4' rounded red oak. I started with gluing in reinforcing strips of 2x2.
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5885756 - 05/26/13 03:15 PM Attachment (16 downloads)
Then the first baffle is glued in with a partial assembly of the rest of the components to make sure the clearances are nice and tight. My daughter thought I was building her the castle she always wanted. I'll let her down easy when she turns 5.
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5885759 - 05/26/13 03:16 PM Attachment (23 downloads)
A final shot of everything coming together.
cpr1
Reged: 03/24/12
Loc: Louisiana
      #5885858 - 05/26/13 04:34 PM
It is really a joy watching you build this scope. Congrats on the progress, looks great. I will definitely follow your build progress. Thanks for posting.
Sean Cunneen
Let Me Think
Reged: 08/01/07
Re: My 16" f7.2 Newt project code named "Grace" new [Re: cpr1]
      #5902852 - 06/04/13 10:47 PM
Thanks Christopher! It has been a fun build with some interesting challenges. Things are starting to work themselves out, so the build should progres fairly quickly in the next few weeks.
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5902855 - 06/04/13 10:51 PM Attachment (16 downloads)
My youngest stayed home sick today so I snuck away for 20 minutes here and there to make some more progress. One gimmick I wanted to try out was a hinged mirror cell so that I can easily install the mirror when traveling. The mechanism is very simple, two carriage bolts through the side of the mirror box straight to the cell rails to act as hinges. Two small clamping knobs to hold the cell rails in the box. Here is the rail assembly getting the holes marked and drilled.
Edited by Sean Cunneen (06/04/13 10:52 PM)
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5902860 - 06/04/13 10:53 PM Attachment (14 downloads)
Test fit...
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5902863 - 06/04/13 10:54 PM Attachment (12 downloads)
I made folding hangers for each side to hold the cell rails out of thin aluminum strips.
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5902867 - 06/04/13 10:57 PM Attachment (15 downloads)
Each end was rounded and holes drilled. It took me a couple of iterations to figure out where the hangers would be mounted so they could move freely and fold up and out of the way. They ended up working out really well! I thought these would be much more finicky... Here the back end is just you know; hanging out...
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5902878 - 06/04/13 11:01 PM Attachment (14 downloads)
Another thing I wanted to try was to make the clamping knobs for the rails captive. I rummaged through the parts bin at the hardware store to find a couple of "E" clips that fit the 1/4-20 shaft(tip, they were NOT the 1/4' ones, go figure). I mounted a cutting wheel in my drill, slipped a washer on the knob shaft and ground down one turn of thread.
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5902887 - 06/04/13 11:06 PM Attachment (19 downloads)
Whaddya'know, worked like a charm! The trick is to drill the hole for the shaft a size larger, in this case 5/16" so that the knob has plenty of wiggle room.
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5902891 - 06/04/13 11:08 PM Attachment (19 downloads)
Here is a beauty shot right down the OTA
Sean Cunneen
Let Me Think
Reged: 08/01/07
      #5902901 - 06/04/13 11:12 PM Attachment (19 downloads)
I made one panel removeable via screws, the other three sides are glued in. That way I can get good access to add fans or anything else I need to do inside.
My last step of the night was to add some trim to the top. I'll use the coping saw to rough the corners and finish up with the belt sander.
Edited by Sean Cunneen (06/04/13 11:13 PM)
18 registered and 33 anonymous users are browsing this forum.
