careysub
Reged: 02/18/11
Loc: Rancho Cucamonga, CA
Surplus Shed Special on 6.1" Triplet F/1.25
      #5904026 - 06/05/13 02:04 PM
Surplus Shed has a special on those 6.1" F/1.25 wide field camera objectives.
There was a lengthy thread on this, but such lengthy threads get tedious to peruse to dig out and piece together the conclusions.
It might be helpful as a buyers guide considering taking Surplus Shed up on this offer for someone to summarize their experience with these.
IIRC, the upshot was that these are fast all right, a bit too fast for visual work - the very steep light cone makes constructing a visual system that exploits it apparent potential impractical.
If anyone with actual experience could weigh in here that would be good. Especially anyone who has found an effective application for them.
Could a secondary lens be used to lengthen the effective FL for easier use?
rdandrea
Reged: 06/13/10
Loc: Colorado, USA DM59ra
Re: Surplus Shed Special on 6.1" Triplet F/1.25 new [Re: careysub]
      #5904047 - 06/05/13 02:19 PM
Burning ants on the sidewalk?
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: Surplus Shed Special on 6.1" Triplet F/1.25 new [Re: rdandrea]
      #5904375 - 06/05/13 05:17 PM
I may be mistaken, but I thought this item is merely the front part of a lens system. If so, it can't be expected to form a good image by itself...
KevinS
Reged: 12/27/11
Re: Surplus Shed Special on 6.1" Triplet F/1.25 new [Re: GlennLeDrew]
      #5905349 - 06/06/13 07:33 AM
Their price just dropped to $75 on this lens. I assume their customer base is not too interested in such a short FL. Looks like a very nice lens but I can't think of an easy way to make it useful for observing without stopping it way down.
bremms
Reged: 08/31/12
Loc: SC
      #5905375 - 06/06/13 07:47 AM
Yes it is part of a system. I believe there is a negative element behind the objective. I have a 5" cemented exotic glass doublet that needs a rear element as well. A $45 ant burner.
Chuck Hards
Reged: 05/03/10
Loc: The Great Basin
Re: Surplus Shed Special on 6.1" Triplet F/1.25 new [Re: bremms]
      #5905558 - 06/06/13 09:34 AM
I think Fred's remaining stock on these are "seconds", i.e., light scratches or staining present.
The oft-mentioned negative element is sub-diameter, but not required for imaging. I took some terrestrial test images with the triplet alone and it showed promise. It might actually have use for wide-field "patrol" imaging. But it's such a weird lens that such a project is way down on my list of things to investigate and build.
Get yourself a 6" PCX lens and make the world's largest ortho eyepiece.
highfnum
Reged: 09/06/06
Loc: NE USA
Re: Surplus Shed Special on 6.1" Triplet F/1.25 new [Re: Chuck Hards]
      #5941339 - 06/26/13 12:06 PM Attachment (62 downloads)
I finally made 'some' progress with this lens after almost two years - took this test shot
will wait for good weather for deep sky shot
GlennLeDrew
Reged: 06/18/08
Re: Surplus Shed Special on 6.1" Triplet F/1.25 new [Re: highfnum]
      #5941870 - 06/26/13 06:19 PM
Clouds are hardly a good test target. Why didn't you just aim the thing lower in order to capture some landscape details, which would certainly have provided a subject having vastly better definition and contrast.
highfnum
Reged: 09/06/06
Loc: NE USA
      #5941997 - 06/26/13 07:14 PM Attachment (62 downloads)
fair enough
test 1a
GlennLeDrew
Reged: 06/18/08
      #5942006 - 06/26/13 07:23 PM
Is that at full aperture (f/1.25)? There seems to be more depth of focus than expected? And why the circular frame?
highfnum
Reged: 09/06/06
Loc: NE USA
      #5942016 - 06/26/13 07:31 PM Attachment (49 downloads)
one more with lodestar above was webcam
highfnum
Reged: 09/06/06
Loc: NE USA
      #5942027 - 06/26/13 07:38 PM
I don't know (there is other lens(s) in train -yet once I get deep sky shot and timing
ill ask for your help or if fails I will go away on this
I had many dead ends before
but so far this is the best
I got a lens train on back based on what was said on this thread plus talking to Fred at SS
plus some of my cobbling of stuff
compared to other shots that were pure mush
this is the best yet
GlennLeDrew
Reged: 06/18/08
      #5942103 - 06/26/13 08:47 PM
Indeed, there would seem to be promise in this optic, based on these shots.
The addition of an additional lens (or lenses) must certainly alter the focal length/ratio. Given the depth of field seen here, it must certainly be rather slower than f/1.25.
If you know the sensor size, you can image a yard stick placed at a measured distance from the camera and thereby directly determine the focal length.
highfnum
Reged: 09/06/06
Loc: NE USA
      #5942482 - 06/27/13 03:15 AM
Cool ill try that
highfnum
Reged: 09/06/06
Loc: NE USA
      #5942542 - 06/27/13 05:40 AM Attachment (44 downloads)
took this before work
look up lodestar by starlight express color camera
highfnum
Reged: 09/06/06
Loc: NE USA
Re: Surplus Shed Special on 6.1" Triplet F/1.25 [Re: highfnum]
      #5942865 - 06/27/13 10:38 AM
spec on camera
CCD type: ICX429AK Sony Exview interline CCD with low dark current and vertical anti-blooming.
■CCD Full resolution Pixel data: Pixel size: 8.6uM x 8.3uM, Image format: 752 x 580 pixels
■CCD Image area: 6.4mm (Horizontal) x 4.75mm (Vertical).
GlennLeDrew
Reged: 06/18/08
      #5943383 - 06/27/13 04:26 PM
Not the best image to work from; a tiny, somewhat de-focused target in a big field. But here goes, with an uncertainty of about 5%.
The 30 arcminute Moon occupies 1/20 the field width, which tells us the FOV is ~10 degrees.
The CCD width is 6.4mm, and so
FL = CCD / TAN(FOV)
= 6.4 / TAN(10)
= 6.4 / 0.1763
= 36.3mm
(Technically, we should first calculate the half angle, the double it, but for a 10 degree field angle the error will be smaller than the measurement error of the target dimension.)
If this is indeed that 6.1" lens at work here, a 36mm f.l. is remarkably small! Is there a positive lens/group behind it, working like a focal reducer? Did you supply the correct chip dimensions?
I've been assuming a 6.1" aperture, but now wonder if that figure referrs to the focal length, either as-is, or nominal for the manufactured (and complete) unit. What is the clear aperture?
highfnum
Reged: 09/06/06
Loc: NE USA
      #5943562 - 06/27/13 06:14 PM
Is there a positive lens/group behind it, working like a focal reducer? - wow you are smart!
there is pair of lens(s) that shrinks image down like condenser
like focal reducer
you think it would make things worse right - like when I put a strong reducer in my dob you get more coma
but with this lens it acts like a corrector
those ccd numbers are from spec
btieman
Reged: 07/24/08
      #5943723 - 06/27/13 08:00 PM Attachment (44 downloads)
I bought one of these from the recent sale. Sample image is below. This is from the full unstopped lens. There is no baffling at all in the system and no additional optics.
Camera is a QSI520: 1600x1200 pixels at 7.4um/pixel. Not exactly a rules, but the image is a vent grate. The full width of the grate is just a hair larger than the field of view. The grate is 7 1/4" with so Use 7" for easier math The grate is almost exactly 9' from the front of the lens. My math computed that this is indeed at f/1.25 but somebody please double check it
The biggest problem I'm having with further developing this thing is the images are just too darn bright! This image was taken in a darkened room and is still only a 0.15s exposure. I've got it pointed out my kitchen window at some houses up the hill...it's cloudy out and I still can't expose short enough to not saturate! The other night I had to wait until about 30 minutes after sunset to finally get some distance focus images. I was even able to focus at infinity and get some stars, but transparency was really poor so other than feeling pretty comfortable I was in the range of infinity focus, I didn't get much else.
The images I got of the houses that are about 1km away did show some promise though! Focused well enough to count shingles on the roofs anyway...
btieman
Reged: 07/24/08
Re: Surplus Shed Special on 6.1" Triplet F/1.25 new [Re: btieman]
      #5943737 - 06/27/13 08:09 PM Attachment (47 downloads)
And here's the entire system. The focuser is basically a 6" helical focuser It feels plenty sensitive enough...but then again, experience is limited at this point.
Again, no baffeling yet...there's some black construction paper wrapping the inside of the tube, but that's it. Also, the camera is just pressed flush against the sawed off hole left where the nut on the blank was removed. I'm sure it leaks light like a sieve!
I'm hoping to clean up the camera mount and secure the lens and everything well enough to start thinking about putting it on my CGEM so I can try and take some real sky shots! I'm hopeful it will reach a tight focus, but my plans are more to try some photometry with it so I can live with a soft focus--will probably even want one on purpose!
12 registered and 26 anonymous users are browsing this forum.
