astrobug
Reged: 10/31/06
Loc: Portland, OR
Ball Scope Project--Source for 22-24" sphere
      #5915321 - 06/11/13 03:52 PM
I'm going to be rebuilding my 13" f/4.5 into a ball scope. Steve Swayze is refiguring the mirror right now, and I'm hoping to get it back from the coater in a month or two.
The old mechanics were fairly crude and left the mirror too exposed (as evidenced by my daughter's handprints). My plan is to build it into a ball scope for now, and then make a trackball base down the road. I'm now looking for a reasonably priced 22-24" plastic sphere. I've read that polycarbonate is preferable to acrylic for a ball scope, but it still may require reinforcing (in which case, I will add a layer or two of fiberglass to the inside). So far, this is the cheapest source I've come across:
Formed Plastics 24" spheres
They want $190 for a 24" polycarbonate sphere, plus another $65 for shipping, which seems a bit much for this project. I could go a little smaller and/or switch to acrylic to save some money, but this will mean more counterweight and/or reinforcing.
Does anyone know of any cheaper sources for a 24" polycarbonate sphere? Any other ideas about what might work (aluminum, etc.)?
Thanks.
-Brett
mark cowan
Vendor (Veritas Optics)
Reged: 06/03/05
Loc: salem, OR
Re: Ball Scope Project--Source for 22-24" sphere new [Re: astrobug]
      #5915363 - 06/11/13 04:12 PM
Have you looked at the large animal toys (like zoo supplies) - these are durable spheres. I don't know where to find them but I've seen them online so I know somebody linked them at some point. Also there are buoys and other floatation spheres that might work, again, no links.
Best,
Mark
Mike I. Jones
Reged: 07/02/06
Loc: Fort Worth TX
Re: Ball Scope Project--Source for 22-24" sphere new [Re: mark cowan]
      #5915406 - 06/11/13 04:38 PM
Google "large plastic spheres", "large acrylic spheres", "large polycarbonate spheres", etc.
This looks interesting, though comparable in price.
mconnelley
Reged: 03/14/06
Loc: Hilo, HI
Re: Ball Scope Project--Source for 22-24" sphere new [Re: Mike I. Jones]
      #5915441 - 06/11/13 04:58 PM Attachment (29 downloads)
Hello:
For my 20" ballscope, I needed a 30" sphere. I went with an aluminum hemisphere, such that the 'equator' is tilted to the optical axis by 30 degrees to allow the scope to point to the horizon without coming off of the ground pads. I used a spun aluminum hemisphere. The key is to find a shop that does metal spinning and already has an appropriate tool. One lesson I learned is not to underestimate the need for the ball to be stiff. Even though I reinforced the hemisphere, the scope still 'bounces' quite a bit, which is especially noticeable at high power in windy conditions. I believe that this is due to flexure in the hemisphere itself. Regardless of what kind of ball you go with, make sure you know the wall thickness.
Cheers
Mike Connelley
bremms
Reged: 08/31/12
Loc: SC
      #5915442 - 06/11/13 04:58 PM
acrylic is lousy compared to polycarbonate. Lousy to machine and not very strong. Any situation requiring any mechanical strength acrylic is not a great material. It will work, but poly carbonate is much better.
astrobug
Reged: 10/31/06
Loc: Portland, OR
      #5916209 - 06/12/13 01:31 AM
Mark-
Thanks for the tips. I found these: Boomer Balls . If they can stand up to a polar bear, they should be sturdy enough for a telescope. Cons for my project are weight and size (20" will be too small, 30" is probably too big).
astrobug
Reged: 10/31/06
Loc: Portland, OR
      #5916241 - 06/12/13 01:47 AM
Mike-
That's quite a scope...I like it. IIRC, there was going to be an 18" Portaball with a similar configuration (tilted hemisphere). I think I'll use a fuller sphere on mine, though, as part of the appeal of this design for me is the ability to change the eyepiece orientation, depending on where the telescope is pointed. Spun aluminum might be a better choice if I can get it thick enough.
kfrederick
Reged: 02/01/08
      #5916447 - 06/12/13 07:30 AM
http://engineeronline.ws/spheres.htm
kfrederick
Reged: 02/01/08
Re: Ball Scope Project--Source for 22-24" sphere new [Re: kfrederick]
      #5916450 - 06/12/13 07:33 AM
http://www.hooksandlattice.com/large-fiberglass-spheres.html
kfrederick
Reged: 02/01/08
      #5916454 - 06/12/13 07:35 AM
http://www.alibaba.com/product-gs/579170460/1m_large_metal_sphere.html
kfrederick
Reged: 02/01/08
      #5916460 - 06/12/13 07:39 AM
http://www.cn-sphere.com/
kfrederick
Reged: 02/01/08
      #5916694 - 06/12/13 10:51 AM
The fiberglass ones come in two halves .and 1/8 thick should be easy to beef it up on the inside
coinboy1
Reged: 05/03/11
Loc: Tulsa, OK
      #5917311 - 06/12/13 04:32 PM Attachment (21 downloads)
Here is an interesting idea that I thought of while checking out my friends new composter. Its a 27
or 32" diamater sphere and has an opening... You can pick it up for about $150-$200 online. Google: compost sphere The 50 gallon is 27" dia, 70 gallon is 32" diameter
don clement
Vendor (Clement Focuser)
Reged: 02/02/11
Loc: Running Springs, California
Re: Ball Scope Project--Source for 22-24" sphere new [Re: coinboy1]
      #5920509 - 06/14/13 12:29 PM
In May 1930 R.W. Porter had pencil on vellum concept plans using a 50 ft. diameter sphere mounting for proposed 200" telescope. Looked amazingly like a scaled up version of the ball scope except in Porter's version the 200" tube assembly fit inside the 50 ft. diameter sphere.
Don Clement
kfrederick
Reged: 02/01/08
Re: Ball Scope Project--Source for 22-24" sphere new [Re: don clement]
      #5920574 - 06/14/13 01:05 PM
Machine a 50ft ball that would hold the 200 inch and track might not be easy.
don clement
Reged: 02/02/11
      #5920599 - 06/14/13 01:27 PM
Actually a sphere is one of the few geometric forms that can be automatically generated, precision ball bearings for example or the sphere generated before parabolizing.
Porter's ball mounting was only a concept in 1930 however Porter's split-ring mount was used in the final design for the 200". In addition Porter had plans for tracking his 200" ball scope on the same drawing in one of his cutaway views.
Don Clement
orlyandico
Reged: 08/10/09
Loc: Singapore
      #5920600 - 06/14/13 01:30 PM
I tried making a ball scope before using a lighting fixture. What I learned:
1) acrylic is too soft, I ended up reinforcing the interior with fibreglass tape and lots of epoxy
2) if the ball is too small, you will need lots of weight inside the ball to balance the UTA. When the insides of the ball gets heavy, the ball surface "dents" where it touches the teflon contact pads
3) no matter what you do, balance is only achieved with a small range of top weights (and the UTA must be as light as possible)
4) this guy - http://www.sff.net/people/j.oltion/trackball_mount.htm - has a very nice refinement of the ball scope: he adds tracking!
he's got some discussion on spheres to use here - http://www.sff.net/people/j.oltion/trackball_optics.htm - and mentions a 16" mussel float that's only $17. That would have been big enough for my 10" mirror, but it's obviously too small for yours.
don clement
Reged: 02/02/11
Re: Ball Scope Project--Source for 22-24" sphere new [Re: orlyandico]
      #5922518 - 06/15/13 04:38 PM
R.W. Porter's May 1930 Ball mount concept for the proposed 200" with 50 ft. diameter ball note the OTA is totally enclosed by the ball:
careysub
Reged: 02/18/11
Loc: Rancho Cucamonga, CA
      #5924872 - 06/17/13 05:02 AM
Their hemispheres might be the right thing - a 24" (suitable for a 16" mirror?) is $133, a 36" hemisphere is $300, but they are thin (as little as 1/16" at the apex) and need serious reinforcing.
One idea for reinforcing I am throwing out for consideration is to use sheets of Divinycell, foamed PVC, that is heat formable and with good compressive strength (87 psi). The idea is to cut pieces of the foam sheet to tile the inner surface, then heat each one and press into place with epoxy resin adhesive, doing just one tile at a time.
1/4" thick Divinycell costs about $2.40 per square foot, a small incremental cost.
When the tiling is complete then finishing the inner surface with fiberglass and resin. Perhaps a weather balloon inflated could press the fiberglass in place while the resin sets.
kfrederick
Reged: 02/01/08
Re: Ball Scope Project--Source for 22-24" sphere new [Re: careysub]
      #5924966 - 06/17/13 07:43 AM Attachment (14 downloads)
If the contact points could have a triangle and the one point be three like on a mirror cell.Then the ball could be thinner . A fiberglass layup could beef up the inside . Here is a pic of a tracking mount for a ball
15 registered and 26 anonymous users are browsing this forum.
