kfrederick
Reged: 02/01/08
Timer for Cerium
      #6004994 - 08/03/13 03:20 PM
Looking for a timer that can come on two sec every two min for a cerium drip . I plan on using a blender with a hole near the top of the bowl .So when it kick on it would mix and some would splash out the hole . I need a control that does seconds .Most are only one min times . Any help would be great
Jeff Phinney
Reged: 02/20/13
Loc: CA
Re: Timer for Cerium new [Re: kfrederick]
      #6005001 - 08/03/13 03:23 PM
Would an IV pump fill the need or am I not understanding you correctly?
kfrederick
Reged: 02/01/08
Re: Timer for Cerium new [Re: Jeff Phinney]
      #6005009 - 08/03/13 03:25 PM
I need something to mix the Cerium so I thought a blender night work.Just need a drop or two .
Pinbout
Reged: 02/22/10
Loc: nj
      #6005611 - 08/03/13 11:34 PM
you can have two realys, one for time off, one for time on.
time off triggers time on and drip. time on triggers time off when goes off.
or you could get an IV bag hang it above the machine and use its drip control.
Happy Birthday John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
      #6005858 - 08/04/13 04:38 AM
On our workshop diamond drill we had a bucket, a 1/4" hose and a small tap from the aquarium shop. We could set the drip rate as required. The stirrer sounds a good idea, maybe 2 magnets? one outside the bucket, one inside?
wiseone
Vendor (Zerochromat)
Reged: 01/07/08
Loc: North Wales, UK
      #6005860 - 08/04/13 04:42 AM
My machine had a pump (actually an old central heating pump) which circulated the cerium oxide slurry in a large tank, and part of the flow was diverted to the polisher. The flow was controlled by a small water tap. Worked a treat!
kfrederick
Reged: 02/01/08
Re: Timer for Cerium new [Re: wiseone]
      #6005891 - 08/04/13 06:24 AM
Thanks for the help .I found a timer that does seconds but costs 100 dollars . I keep looking .I like maybe two seconds on and three min off . The bender mixes good and should splash some out a hole close the top . Just wont a drop or two. Built a new large polishing machine and am tricking it out .For a water drip a pop bottle with the lid loose works good .
Don H
Reged: 12/28/06
Loc: Midwest US
      #6006316 - 08/04/13 05:28 PM
My friend and I put a hot water heater pan under our turtable. Slurry was continually pumped up from it by a small pond pump. In order to keep the slurry mixed, we screwed a wndshield snow brush under the turntable, which stirred it up nicely. We would let mirrors run on that machine over night all the time... The whole set up was probably less than fifty dollars, but it did take a lot of slurry to get it going the first time. We would strain it from time to time with a nylon or very fine screen, and add more cerium sometimes for a new mirror. We used to like to think the CeO was breaking down over time and becoming even finer for polish. That machine did make some very smooth mirrors.
Don
rwiederrich
Goldfinger
Reged: 11/17/05
Loc: Always Dark skies of Belfair W...
      #6006559 - 08/04/13 08:16 PM
Frederick...simply use a fish tank bubbler machine. drop an air house into the cerium tank(2 if the pump has them)..and the cerium is agitated....in the bubbles...then use capillary action with an extremely small hose or IV clamp..it isn't rocket science.
Rob
Pinbout
Reged: 02/22/10
Loc: nj
Re: Timer for Cerium new [Re: rwiederrich]
      #6006772 - 08/04/13 10:38 PM
It probably isn't rube goldberg enough for the farm boy in kevin.
kfrederick
Reged: 02/01/08
Re: Timer for Cerium new [Re: Pinbout]
      #6007123 - 08/05/13 07:02 AM
I love Rube Goldberg .
steveastrouk
Reged: 08/01/13
Loc: Rochdale, UK
      #6007134 - 08/05/13 07:13 AM
What you need is a simple timer chip, called a 555, a transistor and a relay. PM me if you can handle a schematic.
kfrederick
Reged: 02/01/08
Re: Timer for Cerium new [Re: steveastrouk]
      #6007155 - 08/05/13 07:31 AM
Sent a PM thanks If you can post it here others might wont to see
EyeSage
Reged: 06/08/12
Loc: Canukistan
      #6007207 - 08/05/13 08:29 AM
There's a video out there (sorry if I can't come up with the link right now) that details a system to do just what you're after. It uses a small sort of oblong shaped magnet inside a beaker containing the cerium. Under the beaker is a DC powered cooling fan with another magnet affixed to the hub. The fan is triggered to run for a few seconds every couple of minutes with the sort of basic 555 timer circuit suggested above, and the magnet on the hub causes the magnet in the slurry to spin, keeping the cerium well mixed. Seems pretty elegant to me and it's much easier to trigger a small DC fan with a timer than something that runs on AC like a blender.
ccaissie
Reged: 09/13/10
Loc: Whitefield, Maine
Re: Timer for Cerium new [Re: EyeSage]
      #6008901 - 08/06/13 07:55 AM
Omron H3CR at Mouser.com
http://www.mouser.com/ProductDetail/Omron-Industrial/H3CR-F8N-AC100-240/?qs=s...
I spec'd one out for a centrifuge timer. Repeat cycle. Milliseconds, seconds minutes hours days. dual contacts, i.e. N.O and N.C.
There are simpler ones for less, like $40. Automationdirect.com
c
steveastrouk
Reged: 08/01/13
Loc: Rochdale, UK
Re: Timer for Cerium new [Re: ccaissie]
      #6009499 - 08/06/13 01:31 PM
What I proposed to Kevin would cost him about 20 bucks, tops.
kfrederick
Reged: 02/01/08
      #6009546 - 08/06/13 01:59 PM
Got a guy who is sending me a timer . Good help here thanks
rwiederrich
Goldfinger
Reged: 11/17/05
      #6009991 - 08/06/13 05:42 PM
What I proposed costs about $2 at a second hand store.
But if you like spending money to make what is simple, complex.....it's your money. Gravity and capillary action do more then what is expected..and they are free.
Rob
Pinbout
Reged: 02/22/10
Loc: nj
      #6012326 - 08/07/13 08:42 PM
I was trying to find it but i found this old one...
http://www.youtube.com/watch?v=p_5M-qjIRIw
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #6033001 - 08/18/13 02:40 PM Attachment (3 downloads)
I badly needed a more dependable cerium delivery system for both work and home. I had made a gravity drip system which worked by pinching the tubing to control the flow. However sometimes larger particles would accumulate at the pinch point and stop the flow. So I wanted a more dependable system and bought this inexpensive aquarium pump. It an way too fast on 12 volts so I bought a PMW speed control. Even slowed down it was too fast so I needed an interval timer. I tried a 555 timer circuit and got it working on a project board but then the chip just burnt while running, and I couldn't get another to work again. (electronics and me don't do well) So I just got a 7 rpm DC motor and used a cam to push a limit switch every revolution. Maybe not elgant but I'm no longer tied to a machine with a squirt bottle of polish.
12 registered and 27 anonymous users are browsing this forum.
