watcher
Reged: 11/21/07
Loc: St. Louis, MO
Ultimate planetary scope?
      #5620046 - 01/13/13 12:01 AM
I think in small to medium apertures, the ultimate planetary scope would be a long focus achro, a longish APO, or a Mak Cass. Once you get over about 10 inches though, things change.For planetary and small DSO's, I'm thinking something like the Parallax (Royce Optics)Cassegrains would be the best in 14 to 16 inches. Assuming that either could be made to an F/20 spec, is there any advantage to a Classical Cass over a Dall-Kirkham for a strictly narrow field instrument?
Eddgie
Reged: 02/01/06
Re: Ultimate planetary scope? new [Re: watcher]
      #5620555 - 01/13/13 11:21 AM
First, it is difficult to exploit apertures over about 10" to 12" for planetary work unless your seeing is routinely pretty good. I do a lot of planetary observing in my C14, but it is rare for me to work at close to the full potential of the scope. When I can, I see clear detail on Ganymede, but that is a couple of times a year.
But to your question.
The problem with the scopes you mention is that if they are made to f/20, they get very large and very difficult to mount.
The 14.5" Parallex DK is 56 inchs long and weighs 85 Lbs.
The secondary obstruction is a pretty large 25%.
The mirror is made by Royce (one of the best).
The scope will have about 275mm of clear aperture.
It will cost about $13,000 and you will spend another $7K on a mount for it.
For about $4000, you could buy an Orion Go-To dob and have someone refigure the mirror and put in an optimized size (18%) secondary mirror.
If you were serious about planets, you could do as well with a 12" Go-To dob
This would give you motorized tracking, and would negate the need for a 6 foot high saddle for your 85 LB cass.
And if you plot the MTF curves for the two scopes, you will quiclky see that the contrast performace of the 12" scope with 18% obstruction will be equal to the 25% obstructed 14" Cass.
Contrast transfer is everything for a planetary scope, and the 12" optimized Newt would be the winner here.
It costs less, is lighter, provides a better viewing position, and provides better contrast transfer.
A small obstruction Newtonian gives performance that is difficult to distinguish from an equal sized APO. The APO owners might disagree, but having owned both a 6" 18% obstructed reflector and a 6" APO, I would call the difference in performnce to be within a cat's wisker.
To me, ultimate planetary scope is 12" Go-To Newt with 18% obstruction. You still come up against seeing though, but you will get a better planetary scope out of a custom 12" Newt.
If you were really serious about this, you would do an MTF plot and see quickly that the Newt is on par at a fraction of the price.
Eddgie
Reged: 02/01/06
Re: Ultimate planetary scope? new [Re: Eddgie]
      #5620601 - 01/13/13 11:44 AM Attachment (68 downloads)
Here is a rough MTF plot showing the 25% obstructed 14.5" scope vs the 12" 18% obstructed scope.
The left plot shows a perfect aperture (red, the 25% obsturction contrast loss vs perfect, and a hand drawn approximation of the 18% 12" obstruction.
Notice that the MTF curves suggest similar contrast performance at the low and mid frequency detail.
The bigger scope pulls ahead for the finest level of detail, but since this is hard to exploit visually due to the very small exit pupil, for planatery observing, the low and mid frequencies are considered more important.
Also, detail represented on the right side is the very smallest detail that is the very first to suffer unless seeing is virtually perfect.
In 40 years of planeatry observing, I have never had a night of absolutely perfect seeing. Not in a larger aperture. Not one. Not Ever.
The plot on the right shows the actual MTF unadjused for max spatial frequency. The "1" on the horizontal axis would be .75 on the plot on the left indicating that the 12" scope only has .75 of fs/max of the 14.5" scope.
An 18" obstruction looses so little contrast that it is almost impossible to see.
I will concede that on paper, the 14.5" scope has an advantage, but from a practical standoint, you will spend 4 times the money and never see it at the eyepeice.
And of course if you wanted to build a custom 14" Newt with an 18% obstruction, you could have an even better planetary telescope on paper, but once again, you would never see the benefit even when standing on the ladder. LOL.
Edited by Eddgie (01/13/13 11:49 AM)
titanio
Reged: 02/15/09
Loc: Alicante, Spain
      #5620650 - 01/13/13 12:07 PM
Hi watcher
Do not forget the maksutov Newton for plantery.
I am building a super planetary telescope with Royce mirrors, as for the mount, I have changed te arms of my CPC mount, it sems to work pretty Well.
http://img716.imageshack.us/img716/813/monturaytelescopio.jpg
Toni
kfrederick
Reged: 02/01/08
Re: Ultimate planetary scope? *DELETED* new [Re: Eddgie]
      #5620653 - 01/13/13 12:12 PM
Post deleted by kfrederick
Mirzam
Reged: 04/01/08
Loc: Lovettsville, VA
Re: Ultimate planetary scope? new [Re: kfrederick]
      #5621065 - 01/13/13 03:31 PM
I have a Parallax 12.5" f/15 cassegrain with Royce optics and it is an excellent planetary and lunar scope when conditions allow. It also takes terrific photos.
The best way to observe planets is seated using a quality binoviewer and with tracking of course.
If you can obtain a custom alt-az newtonian that is designed for binoviewing and tracking, I think that this is a very good solution. Newts on equatorial mounts are very inconvenient in larger apertures.
Otherwise, the cassegrain will work well, and avoids the thermal problems associated with closed tubes.
JimC
watcher
Reged: 11/21/07
Loc: St. Louis, MO
Re: Ultimate planetary scope? new [Re: titanio]
      #5621152 - 01/13/13 04:22 PM
I have a small set of my two scope solution already. My 6" F/5 R35 refractor for wide field deep sky, and my IM715 for the narrow stuff and planets. In a few years, though, I would like to get out from under the jet stream and to a darker place to live out my life. I wouldn't consider a Mak-Newt for the same reason I wouldn't want a Mak-Cass in larger apertures. They just have a rough time keeping up with temperature changes. That, and I just plain don't like Dobs and Newts. A fork mounted Cass sounds like a really nice ride. Is that mount going to be enough When the scope is complete?
titanio
Reged: 02/15/09
      #5621629 - 01/13/13 08:41 PM
Hi Watcher,
So far the fork mount will be enough for my 16” cassegrain, the telescope is almost finished and the total weigh is around 20 kg. Nevertheless if God wants I would like to buy a nice mount for it in a few years.
Toni
orion61
Vendor(Clear Edge Optical)
Reged: 10/20/07
Loc: NW Iowa BURRRR
      #5623235 - 01/14/13 06:59 PM
My experience after 42 years, the large scope 10-12" have given me good results, I must say I have had far greater success with 6-8" scopes. The reason being (in MY area)
Midwest, there arent that many nights of good seeing that supports larger scopes.
I had a 6" F10 Newtonian once that was killer for Planetary.
Secondary was only about 1/2" I mounted a DC fan on rubber bands, no currents.
Also The Meade 8" F6 was superb as was my F7 8" Cave.
I still have my old RV6 F8, and it still make people gasp!
GeneT
Ely Kid
Reged: 11/07/08
Loc: South Texas
      #5623460 - 01/14/13 09:29 PM
In my opinion, a 12 incher is a great planetary. I own a 12.5 inch, F5 Dob. It yields great planetary images. Large enough to resolve detail, yet so large where I am dealing with cool down and other issues.
Glen A W
Reged: 07/04/08
Loc: WEST VIRGINIA USA
Re: Ultimate planetary scope? new [Re: GeneT]
      #5624876 - 01/15/13 05:50 PM
The VMC-260 by Vixen is excellent on planets. It's the only visual use I'd recommend it for, though, due to long focal length and other factors. It regularly gives me views of Jupiter which are just awesome, and with lower-cost eyepieces, too.
That said, I too had a Meade 8" f/6 Newt with a USA made mirror which was a killer. Most times, it would beat larger scopes and the color was much more pure than the Vixen, which effectively has a filter in it as the views are very warm. But on a good night, the bigger scope will still prove its worth.
mistyridge
Reged: 10/28/05
Loc: Loomis, CA
      #5624965 - 01/15/13 06:55 PM
Same here 12.5" f/5 Dob. with a high quality mirror cools rapidly. I have a 8"edge HD that has very good optics that is very good on planets. it is small enough that cooling is not an issue. The only drawback is the large CO.
azure1961p
Reged: 01/17/09
Loc: USA
Re: Ultimate planetary scope? new [Re: mistyridge]
      #5625432 - 01/15/13 11:20 PM
Ed very interesting graphs. It made sense when I understood how to overlay the two in my head, the .75 being 1, etc. . The seeing has its own cap of course. It d be interesting to compare the two if they were space telescopes essentially than the finest details and exit pupils could be exploited, sans the floaters and space suit.
Interesting how real world practicality shapes the graph, or what to extract from it.
Pete
Reged: 06/16/04
      #5625465 - 01/15/13 11:46 PM
For planetary, GOTO is unnecessary, tracking is handy...
There are those who believe/find that an Equatorial mount is superior to a Dob mount for planetary viewing... Tubes seem to be the way to go... thermal control, fans...
There are those who believe/find that any most scope is a good planetary scope if the seeing is excellent.
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
Re: Ultimate planetary scope? new [Re: Jon Isaacs]
      #5625579 - 01/16/13 02:18 AM
Well, my vote is for the Yerkes 40" refractor.
watcher
Reged: 11/21/07
Loc: St. Louis, MO
      #5625593 - 01/16/13 02:53 AM
I think for my purposes, goto would be a big benefit. I like a 2 scope solution. My second scope will be a big fast achro, for wide fields, and the Cass would be for everything that works in a narrow field of view, not just the planets. Hunting down small galaxies with a 14 inch F/20 can be pretty tedious without goto.
highfnum
Reged: 09/06/06
Loc: NE USA
      #5625670 - 01/16/13 05:56 AM
I agree with edgggy its more sbout seeing conditions
The break point is about 10 inches
pstarr
Reged: 09/17/04
Loc: NE Ohio
      #5625804 - 01/16/13 09:03 AM Attachment (27 downloads)
I'm one of "those"
10" F-6 Zambuto mirror, 1/30 wave secondary, 18% obstruction, curved spider, fan, big eq. mount 2" shafts w/tracking, solid, fully flocked tube.
Reged: 06/16/04
Re: Ultimate planetary scope? new [Re: Rick Woods]
      #5625853 - 01/16/13 09:32 AM
What it, 1/4 inch of focus between the colors?
Sunspot
Reged: 03/15/05
Loc: Surprise, AZ
      #5625858 - 01/16/13 09:33 AM
For me I guess the question is if one is doing visual viewing of the planets or imaging. The best visual view of the planets I ever had was with a 16" F/12 Newtonian but no way I'd do imaging with that beast. My Mewlon 250 has given me (inch for inch) the best images of the planets I've ever gotten. BTW, the 24" Clark at Lowell Observatory wasn't bad either except I never seemed to have good seeing when I used it.
Paul
31 registered and 30 anonymous users are browsing this forum.
Moderator:  Cotts, Starman27
