Equipment Discussions >> Classic Telescopes
actionhac
Reged: 08/09/08
Loc: Seattle
Motorize Your Focuser with a Tasco 1603EF
      #4529006 - 04/19/11 12:24 PM Attachment (178 downloads)
I purchased this focus motor to test on a few telescopes. Mainly those with feeble mounting and the annoying shimmy that accompanies this. My Sears 6345 is a prime example and my OC Discoverer is guilty also.
Telescope Warehouse has the 1603EF for $19.95:
http://stores.ebay.com/Telescope-Warehouse?_trksid=p4340.l2563
actionhac
Reged: 08/09/08
Loc: Seattle
Re: Motorize Your Focuser with a Tasco 1603EF new [Re: actionhac]
      #4529023 - 04/19/11 12:28 PM Attachment (179 downloads)
Test subject is a 1970's after market Japanese focuser found on a lot of our classics.
actionhac
Reged: 08/09/08
Loc: Seattle
      #4529042 - 04/19/11 12:33 PM Attachment (198 downloads)
The mount is universal and adjustable for a variety of focusers. This application was a no-brain. Some may require modifying the bracket.
actionhac
Reged: 08/09/08
Loc: Seattle
      #4529052 - 04/19/11 12:36 PM Attachment (202 downloads)
You can see how it clamps to the pinion block.
actionhac
Reged: 08/09/08
Loc: Seattle
      #4529065 - 04/19/11 12:39 PM Attachment (201 downloads)
I removed a knob and replaced it with a sheet metal U to couple with the 1603EF's U. This works well with 0 backlash.
actionhac
Reged: 08/09/08
Loc: Seattle
      #4529089 - 04/19/11 12:47 PM
This unit has a clutch if you wish to focus manually.
A little zippy for focal ratios f6 and faster, requiring tapping the controller buttons but much more precise than manual especially if you are under mounted. I feel it's more suited to f10-15 with their greater depth of focus but still it is very nice to focus "hands off". A person could add a potentiometer to have the 3V AA battery supply voltage variable. I thought I would see how the unit acts as the batteries become depleted and decide.
If you've never used an electric focuser before this would be a very good introduction. I find after using them I'm spoiled. I have a much more expensive Meade version on a scope and this little cheapy ain't much different in function.
Robert
eric_zeiner
Phoenix's Dad
Reged: 12/09/06
Loc: Georgia USA 34 31'57.18N 83 53...
      #4529158 - 04/19/11 01:18 PM
Nice
actionhac
Reged: 08/09/08
Loc: Seattle
Re: Motorize Your Focuser with a Tasco 1603EF new [Re: eric_zeiner]
      #4529875 - 04/19/11 05:57 PM
I thought since I've completely finished the installation I should read the instructions and noticed the copyright is 1993 which could mean these are no longer made and TW has some new old stock. These are new but no box. No sign of being returns or refurbished, at least my example.
Robert
albert1
Reged: 01/01/07
Loc: Southern New Jersey
      #4530295 - 04/19/11 09:04 PM
Thanks for the photos Robert. Think I'm gonna try one. Nice idea with the U joint.
actionhac
Reged: 08/09/08
Loc: Seattle
Re: Motorize Your Focuser with a Tasco 1603EF new [Re: albert1]
      #4530465 - 04/19/11 10:37 PM
It's a very good deal. I'm having a great time with it on my newt, never have I had such a luxury before on a scope that I like to use all the time, I usually prefer the stripped-down models.
The "U" driver on the 1603EF is meant to engage slots in some of the Tasco scope knobs, after you pry off the decorative cover. The mating sheet metal U works great especially if a good fit. Or I have seen others use a square wood driven knob.
Robert
bob midiri
Reged: 06/17/04
Loc: pa 19320
      #4547481 - 04/27/11 11:22 AM
Robert I may be slow, but how did you make that reverse U joint. I bought two of these focusers and want to use one on my Sears 6344 76mm refractor OTA. One fit perfectly on my classic Tasco 11TR, obviously made for that scope. But the Sears has metal focuser wheels. Thanks Bob
actionhac
Reged: 08/09/08
Loc: Seattle
Re: Motorize Your Focuser with a Tasco 1603EF new [Re: bob midiri]
      #4547564 - 04/27/11 12:05 PM Attachment (115 downloads)
Hi Bob,
I removed a knob from the focuser and replaced it with a sheet metal "U" that I bent to fit inside the "U" of the motor and drilled a hole exactly in the center to mount to the focuser shaft. I replaced the knob screw with one better suited to hold the flat sheet metal, the knob screw is a countersink head.
If you prefer using wood you can make a square hardwood knob to replace the original focuser knob that will fit inside the Tasco motor "U" and if made the same thickness the original screw can be used.
In this photo you can see the brass "U" inside the chrome motor "U". Just a strip the same width bent to shape with pliers. I backed it up with a washer because it is bearing against the end of the tapered focuser shaft. The chrome half of the U joint comes with the 1603EF.
actionhac
Reged: 08/09/08
Loc: Seattle
      #4547703 - 04/27/11 01:12 PM
I've been using the motor focuser for a week now viewing Saturn which is a very demanding job for the focuser and it works beautifully.
To slow down it's movement if your focuser has a tension/lock screw you can tighten it or tighten the pinion block screws to increase drag on the focus, the 1603EF has sufficient torque to keep working but at a slower speed. Tightening up the focuser to a level that would be unbearable manually also removes all play and absolutely no image shift, and the motor doesn't seem to mind.
The U joint coupler must be a tight connection, any slop would mean poor response when moving between Forward and Reverse, you want zero backlash. The 1603EF has no backlash in it's gear train and actually a well made unit.
It's surprisingly easy to hit best focus and make small precise corrections with the R and F buttons.
Robert
bob midiri
Reged: 06/17/04
Loc: pa 19320
      #4547789 - 04/27/11 01:47 PM
Robert thanks so much. Now I see what you did. Bob
Geo.
Reged: 10/01/08
Loc: Upstate NY
      #4548371 - 04/27/11 07:16 PM
Yes, I saw these and wondered. However, I went for the Tasco 1606 RA drive for $50. These are made for use on the Vixen Polaris mounts that Tasco Sold in the '80s.
pjac
newbie
Reged: 01/14/12
Loc: Scotland, UK
Re: Motorize Your Focuser with a Tasco 1603EF new [Re: Geo.]
      #5584331 - 12/22/12 04:28 PM
I just got one partly encouraged by this thread, and I'm pleased to say the Tasco 1603EF appears to need no modification at all to use with the SkyWatcher Explorer 130M (also known as the SK1309EQ2), so thank you for sharing those images.
Here's my blog post with photos of the Tasco 1603EF - I'm looking forward to trying it out
desertrefugee
Reged: 08/06/07
Loc: Arizona
Re: Motorize Your Focuser with a Tasco 1603EF new [Re: pjac]
      #5584602 - 12/22/12 07:47 PM
I must be crackin' up. Pjac comes in (welcome by the way!), digs up an old thread and has me saying, "Why not?"
Yeah, I ordered one. I think I'll put it to good use doing some lunar photography.
Thanks pjac.
tim53
Reged: 12/17/04
Loc: Highland Park, CA
Re: Motorize Your Focuser with a Tasco 1603EF new [Re: desertrefugee]
      #5584622 - 12/22/12 08:01 PM
I put one of these on the 14F about a year or so ago. Mine had a broken solder connection on it, so initially it didn't work. When I fixed that, though, it's been great. Next thing I need to do is figure out how to stiffen those metal legs. I hate em!
-Tim.
pjac
newbie
Reged: 01/14/12
Loc: Scotland, UK
      #5584721 - 12/22/12 09:19 PM
... The U joint coupler must be a tight connection, any slop would mean poor response when moving between Forward and Reverse, you want zero backlash. The 1603EF has no backlash in it's gear train and actually a well made unit.
Robert
That's the only thing I'm considering tweaking for using the 1603EF motor on my SkyWatcher - the spokes on my focus knob give a couple of millimetre's slack meaning fine control F/R suffers from a delay when switching direction. That's what you meant by "slop" I assume Robert? When it stops raining, I'll try it as is, but a tighter fit shouldn't be too hard to improvise...
Update: Putting a bit of blu-tack into the focus wheel slots where the U-piece inserts seems to have done the job.
Edited by pjac (12/23/12 06:38 PM)
pjac
newbie
Reged: 01/14/12
Loc: Scotland, UK
      #5584726 - 12/22/12 09:20 PM
Thanks pjac.
Enjoy - I think my own thought process when ordering this was quite similar
Update: It was a bit windy tonight making wobble more of a problem than usual, and incoming cloud cut short my viewing session of Jupiter and the moon - but my first impressions are very favourable. At high magnification (eg with a Barlow) even when using an eyepiece focusing via the motor was convenient to avoid wobble, but I found this really payed off when used with my webcam.
Edited by pjac (12/23/12 06:42 PM)
actionhac
Reged: 08/09/08
Loc: Seattle
      #5584889 - 12/22/12 11:40 PM
Robert
Yes no slop. Because you are shifting forward and backward hunting for a sharp focus. You will overshoot and back up sometimes and you will find slop is intolerable. Once you get the hang of it you can zoom on in and nail it first try, and that's a great feeling, especially at extreme high power.
The motor's tines, where they to plug into the focuser knob should be coupled tightly. Possibly silicon tubing on the "U" tines where they plug into the knob recesses, so everything is tight.
Robert
dgreyson
Reged: 11/06/12
Loc: South Carolina
      #5585043 - 12/23/12 02:25 AM
Ive seen those focusers for sale before but alwats wondered if they were worth the bother.
Karl Fabian
Reged: 11/02/11
Loc: Illinois
Re: Motorize Your Focuser with a Tasco 1603EF new [Re: dgreyson]
      #5593009 - 12/28/12 05:37 PM
Adapted one of those Tasco 1603 units to my Meade DS2090AT-TC about a year ago. Before the mod focusing at anything over 100x was hit or miss. I simply replaced the focus knob with rectangular flat stock and remounted the entire assembly on aluminum bar stock to line things up.
Karl Fabian
Reged: 11/02/11
Loc: Illinois
Re: Motorize Your Focuser with a Tasco 1603EF new [Re: Karl Fabian]
      #5593042 - 12/28/12 05:55 PM Attachment (22 downloads)
Here it is mounted up.
Karl Fabian
Reged: 11/02/11
Loc: Illinois
      #5593055 - 12/28/12 06:03 PM Attachment (20 downloads)
The square plate to take the place of focus knob.
Karl Fabian
Reged: 11/02/11
Loc: Illinois
      #5593065 - 12/28/12 06:10 PM Attachment (18 downloads)
Aluminum flat bar stock & shims to re-position motor box assembly to line things up.
14 registered and 8 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), Brian Risley
