Equipment Discussions >> Classic Telescopes
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | (show all)
PiSigma
Reged: 10/14/09
Loc: North Carolina
My Last Classic Scope - Unitron 145C
      #5608827 - 01/06/13 05:04 PM Attachment (121 downloads)
In the last few years, as I’ve gone about obtaining, restoring and using several classic telescopes that I have always wanted to own, one brand on my bucket list just never seemed to come along – an EQ mounted Unitron. They were either too far away, too expensive or in just too rough a condition to go after.
Last year Steve Gorton bought a Unitron 145C here on CN. I regretted not going after it myself and asked him, if he ever decided to sell it, to please give me first shot. Once he found a 4” Unitron he decided the 145C could move on so now it’s mine. It came with the original bill of sale from 1971.
So here it is – My Last Classic Scope. The bucket list is complete for me. No other telescopes need apply.
PiSigma
Reged: 10/14/09
Loc: North Carolina
Re: My Last Classic Scope - Unitron 145C new [Re: PiSigma]
      #5608829 - 01/06/13 05:05 PM Attachment (50 downloads)
It is very complete and just needed some minor repairs, touch up and a thorough cleaning. The first area I decided to attack was the tripod tray and sliders. The glue had let go on the tray ribs and the original owner decided to bolt them together with some pieces of angled bracket.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608831 - 01/06/13 05:05 PM Attachment (33 downloads)
These had to go and I re-nailed and re-glued the ribs.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608832 - 01/06/13 05:06 PM Attachment (29 downloads)
Then I worked on refilling the extra holes that were drilled to mount the brackets. I used a wood filler from Elmers in a Golden Oak color, sanded it and touched it up with a wood stain marker made by Homax in a color called Early American. Then I applied a single coat of Cabot satin polyurethane. You can still see where the holes were of course but it looks a lot better.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608835 - 01/06/13 05:07 PM Attachment (26 downloads)
Next I went to work on the sliders. The original owner had probably had one of them pop loose or had heard stories of them doing so. So he bent them so they would also wrap around the bottom of the leg pin and bolted them together. They would stay on the leg pin and he did wing nuts where they attach to the tray. I carefully worked them back to their original shape. Left is before, right is after. Two of the slider springs were missing so I fabricated some from some tension springs in 0.026” wire diameter. One of the two shown is an original and one is my copy.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608839 - 01/06/13 05:07 PM Attachment (31 downloads)
On most of my restorations I like to replace all of the hardware with stainless. But I wasn’t going to do that on a Unitron. Almost all of the hardware is nickel plated brass and is pretty unique. But some of the slider hardware was missing so I had to add some hardware store stuff here. The sliders are actually threaded for the screws. The screws go through the arm from the bottom and are left loose so the slider can slide. A jam nut goes on top to keep the screw from loosening. I had to find new nuts and washers for attaching the arms to the tray as the original owner had put wing nuts here.
I individually hand polished all of the original hardware as the nickel finish was starting to show some surface corrosion. Do not go after these with anything very abrasive like sand paper or even Brasso or you will be through to the brass very quickly. I used Mothers Mag and Aluminum Polish and it shined most items up like new.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608841 - 01/06/13 05:08 PM Attachment (17 downloads)
The sliders and arms on mine are yellow zinc plated and were too far gone to polish. Zinc plating doesn’t polish up anyway and is very thin. So I first bead blasted them. The oval parts are the stoppers for the folding legs, which were also yellow zinc and corroded.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608843 - 01/06/13 05:09 PM Attachment (21 downloads)
After plating they were reassembled.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608845 - 01/06/13 05:09 PM Attachment (21 downloads)
Next it was on to the legs. I removed the leg tips, which were really in rough shape. Some of the nails holding them in pried out OK but on most the heads just broke off they were so rusty.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608848 - 01/06/13 05:10 PM Attachment (18 downloads)
Then I bead blasted them along with the bolt, washers and nut that hold the counterweight in the EQ mount box.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608849 - 01/06/13 05:11 PM Attachment (25 downloads)
Clint Whitman had posted that Rustoleum Satin Black, #7777 was an excellent match to Unitron black. So after a coat of Rustoleum primer I applied two coats of that and it is as close a match as you are going to find.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608850 - 01/06/13 05:11 PM Attachment (22 downloads)
The legs were in good shape, the usual scuffs and such. I cleaned them up with Guardsman revitalizing wood polish. I’ve used this before on my Sears 6344 wood case but it is still amazing how well this stuff can make the wood look new again and hide the scuffs. Here is the same leg before and after.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608852 - 01/06/13 05:12 PM Attachment (27 downloads)
And another before and after.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608855 - 01/06/13 05:13 PM Attachment (19 downloads)
Then I re-nailed the tips back on using ¾ x 18 brass plated nails. I didn’t want to use solid brass nails as these tips hold a lot of weight. The brass plated ones would be much stronger. Since several of the nails had broken off I turned the tips a bit so the nails would go in at different spots. I pilot drilled the wood with a 0.039” #61 drill bit so the wood wouldn’t split. I used a nail set to tap them home so I wouldn’t damage the freshly painted tips.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608856 - 01/06/13 05:13 PM Attachment (18 downloads)
The original owner had also put a large spot of white paint on the bottom of one leg. I’m not sure why.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608857 - 01/06/13 05:14 PM Attachment (14 downloads)
I sanded it out as best as I could. There was still a little white in the grain, and gave it a coat of the Cabot polyurethane.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608859 - 01/06/13 05:15 PM Attachment (17 downloads)
The legs all reassembled with replated stops and cleaned up original hardware.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608862 - 01/06/13 05:16 PM Attachment (18 downloads)
The counterweights were a little scuffed up. But rather than stripping them and ruining the fine wrinkle finish I just dusted them with a light coat of flat black and they look perfect.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608865 - 01/06/13 05:16 PM Attachment (20 downloads)
Next I went after the wooden cases. Here is the EQ mount box before and after Guardsman. The original owner had pried out whatever nails were going into the interior parts that hold the mount, which are also glued of course. I don’t know what these looked like so I installed some 13/32” nickel plated thumb tacks.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608867 - 01/06/13 05:17 PM Attachment (23 downloads)
And the bottom.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608871 - 01/06/13 05:18 PM Attachment (10 downloads)
All the box hinges had a lot of surface corrosion. 5 of them were from the mount and OTA boxes and the other four were from older Unitron OTA boxes. The newer ones are clear zinc plated where the older ones are nickel.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608873 - 01/06/13 05:19 PM Attachment (15 downloads)
After bead blasting.
bob midiri
Reged: 06/17/04
Loc: pa 19320
      #5608875 - 01/06/13 05:19 PM
Jon awesome, you are an amazing classic telescope restorer (if there is such a word). I can't wait to see the rest. bob
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608876 - 01/06/13 05:19 PM Attachment (12 downloads)
And replated. There are three different manufacturers here. The top one, which is early and originally nickel plated, has an oval logo on the back with “Ant” in the oval. The middle one, which was also nickel plated originally, is stamped N.S.B. and Japan. The third one was originally clear zinc and is stamped Arch Japan.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608878 - 01/06/13 05:20 PM Attachment (11 downloads)
Every little original screw and latch was polished with Mothers. Here are the latches for the EQ mount box, left ones unpolished, right ones polished.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608881 - 01/06/13 05:21 PM Attachment (9 downloads)
All of the finder and guide scope adjusting screws.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608883 - 01/06/13 05:21 PM Attachment (10 downloads)
Box latches. The polishing went on for days and days.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608885 - 01/06/13 05:22 PM Attachment (12 downloads)
Unitron emblems from boxes cleaned up. The bottom one is a foil sticker and was on the OTA case.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608887 - 01/06/13 05:23 PM Attachment (12 downloads)
EQ Mount Box reassembled with polished hardware.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608889 - 01/06/13 05:23 PM Attachment (10 downloads)
Back.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608890 - 01/06/13 05:24 PM Attachment (14 downloads)
Inside. You can see the refinished bolt that holds the counterweight in place.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608891 - 01/06/13 05:25 PM Attachment (8 downloads)
OTA box with handle, clasps and Unitron sticker back on.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608895 - 01/06/13 05:27 PM Attachment (9 downloads)
Back
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608896 - 01/06/13 05:28 PM Attachment (15 downloads)
Next it was time to clean. I like using Formula 409 to clean up dirt and grime. Here is one of the mount adjusting knobs before and after a scrubbing with a toothbrush to get all of the grime out of the nooks and crannies.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608897 - 01/06/13 05:29 PM Attachment (13 downloads)
All the black surfaces were cleaned. Everything had a few nicks here and there but not enough to justify repainting. I took some of the Rustoleum satin black, sprayed in into a cup and used it for touch up paint on the satin black surfaces. The green felt was all in great shape but coming loose in a few spots. I reattached these using 3M spray trim adhesive.
The optical tubes had a few nicks so these were touched up with gloss white.
Here is the 10x40 finder and mounts.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608900 - 01/06/13 05:30 PM Attachment (8 downloads)
The components of the solar screens.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608903 - 01/06/13 05:31 PM Attachment (10 downloads)
Unibalance kit.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608905 - 01/06/13 05:32 PM Attachment (7 downloads)
Camera Mount.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608907 - 01/06/13 05:33 PM Attachment (11 downloads)
Clock Drive and mounting shelf.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608909 - 01/06/13 05:33 PM Attachment (12 downloads)
The clock drive has a hex shaped part that fits into a special version of an RA adjusting knob.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608912 - 01/06/13 05:34 PM Attachment (14 downloads)
Guide Scope and mounts.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608914 - 01/06/13 05:34 PM Attachment (11 downloads)
The 3” OTA with focuser and solar rod mounts back on. For some reason this OTA has holes and screws for the 8x30mm finder too.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608915 - 01/06/13 05:35 PM Attachment (12 downloads)
Main objective.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608917 - 01/06/13 05:36 PM Attachment (11 downloads)
3” OTA and cradle.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608918 - 01/06/13 05:36 PM Attachment (10 downloads)
Lens caps and aperture reducer. The Unitron lettering on the 3” cap needs some help.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608919 - 01/06/13 05:37 PM Attachment (16 downloads)
There we go.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608922 - 01/06/13 05:38 PM Attachment (18 downloads)
All back together and standing proud. The unfinished box on the floor is a guide scope box that a friend of Steve’s made for me, copying an original guide scope box that Steve has. I still have to stain and finish it. More on that later.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608924 - 01/06/13 05:38 PM Attachment (13 downloads)
Closer view.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608925 - 01/06/13 05:39 PM Attachment (15 downloads)
A few more accessories including a Herschel Wedge.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5608926 - 01/06/13 05:40 PM Attachment (15 downloads)
And the 220A Astro Camera.
That’s it for now. Maybe one day we’ll get some decent seeing down here.
sgorton99
Reged: 04/30/08
Loc: Wisconsin, Madison
      #5608936 - 01/06/13 05:46 PM
Amazing restoration Jon! I am very happy that you are the custodian of this beautiful Unitron. Someday I will get my 155 all together and shined up as well...
Looking forward to your next trip here for your "last" scope!
Steve
mustgobigger
Reged: 06/12/07
Loc: Michigan
Re: My Last Classic Scope - Unitron 145C new [Re: sgorton99]
      #5608966 - 01/06/13 06:04 PM
great job jon,
last scope...Ha ....
kansas skies
Reged: 12/02/12
Loc: Kansas, USA
Re: My Last Classic Scope - Unitron 145C new [Re: mustgobigger]
      #5608999 - 01/06/13 06:28 PM
Very impressive!
Bill
gelkin
Reged: 09/22/10
Loc: Western, MD.
      #5609076 - 01/06/13 07:18 PM
great job jon,
Yea what he said. Now your Unitron problems are just begining. Beautiful work as always Jon. Congrats Unitron owner.
dgreyson
Reged: 11/06/12
Loc: South Carolina
Re: My Last Classic Scope - Unitron 145C new [Re: gelkin]
      #5609089 - 01/06/13 07:26 PM
I want one of those. thats awesome.
Bob Myler
Reged: 05/18/06
Loc: St Louis, MO
Re: My Last Classic Scope - Unitron 145C new [Re: dgreyson]
      #5609180 - 01/06/13 08:26 PM
Congratulations Jon. You made a wonderful scope even better!
Kunama
Reged: 10/22/12
Re: My Last Classic Scope - Unitron 145C new [Re: Bob Myler]
      #5609231 - 01/06/13 09:07 PM
Excellent attention to detail. You have done a great job bringing another oldie up to par. Now be a champ and box it all up and send it to me n Australia. It would go so beautifully on my 1877 Gaunt Mount and Pier.
Edited by Kunama (01/06/13 09:26 PM)
starman876
Reged: 04/28/08
Loc: VA
Re: My Last Classic Scope - Unitron 145C new [Re: Kunama]
      #5609243 - 01/06/13 09:14 PM
Very nice. Beautiful scope. Last scope.???? I doubt it
Da Bear
Reged: 11/21/06
Loc: Kali-Forn-Ya
Re: My Last Classic Scope - Unitron 145C new [Re: starman876]
      #5609583 - 01/07/13 01:49 AM
What a lovely scope...but take it ftom a long time collector, there will ALWAYS be one more scope.....
Da Bear
JonH
Reged: 04/07/12
Loc: Brisbane Australia
Re: My Last Classic Scope - Unitron 145C new [Re: Da Bear]
      #5609616 - 01/07/13 02:47 AM
Thats just beautiful. It looks like it is straight from the factory. Congratulations and hope the skies clear for you soon.
bobbyt63
Reged: 02/16/10
      #5609639 - 01/07/13 04:55 AM
have you thought of how to replace the air type shutter release for your 220 model i need ideas thanks bob
mustgobigger
Reged: 06/12/07
Loc: Michigan
Re: My Last Classic Scope - Unitron 145C new [Re: bobbyt63]
      #5609655 - 01/07/13 05:40 AM Attachment (24 downloads)
i found this at a garage sale last summer.
think it will work perfect for uni camera.
i have enough for 4 ....2 foot sections.
first 4 people to pm me gets one shipped to there house.
Edited by mustgobigger (01/07/13 05:46 AM)
mustgobigger
Reged: 06/12/07
Loc: Michigan
      #5609657 - 01/07/13 05:41 AM Attachment (15 downloads)
end view
starman876
Reged: 04/28/08
Loc: VA
      #5609885 - 01/07/13 10:28 AM
brian
how will that work on the camera end? I thought some sort of small bulb is needed to raise up the actuator on the camera?
mustgobigger
Reged: 06/12/07
Loc: Michigan
      #5609963 - 01/07/13 11:05 AM
You will still have to find a bulb
But that should not be hard to
Find....just finding a red one
Of those little ones for rinsing
Your ear out....till you can find
The real thing....and that would
Most likely be the whole camera.
mustgobigger
Reged: 06/12/07
Loc: Michigan
      #5610006 - 01/07/13 11:25 AM
see here
link 1
link 2
$11.00 for this one
Link 3
shouldn't be to hard to make it look good.
Edited by mustgobigger (01/07/13 12:41 PM)
nightpilot
Reged: 02/16/12
Loc: Southern Suburbs, Chicago
      #5610153 - 01/07/13 12:38 PM
What a beautiful restore and clean up. A truly beautiful scope. An inspiration to really continue to improve on the cleaning and restoration of my "charges".
terraclarke
Reged: 05/29/12
Loc: Just South of the Mason-Dixon ...
      #5610184 - 01/07/13 12:53 PM
"So here it is – My Last Classic Scope. The bucket list is complete for me. No other telescopes need apply."- Boy I've heard that one before. Usually in my own head, and often just before I buy another,
Never say never
Sincerely though, you did a beautiful job restoring a wonderful scope.
Edited by terraclarke (01/07/13 03:16 PM)
starman876
Reged: 04/28/08
Loc: VA
      #5610228 - 01/07/13 01:15 PM
Brian
I am talking about the little bulb that goes on the cemera shutter. Maybe I am wrong, but I thought that was more than just the little hose at that end ?? I understand about the bulb and the operator end.
starman876
Reged: 04/28/08
Loc: VA
      #5610237 - 01/07/13 01:19 PM Attachment (16 downloads)
the little bulb that is shown here
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5610890 - 01/07/13 08:50 PM
Thanks for the nice words everyone. This scope really is a beauty.
There is just something about a Unitron refractor that defines the term Classic Telescope. White tubes, black attachments, wood tripod, beautiful design and workmanship, easy to use controls, Just Classic.
But....this.....is.....my......last......classic.......scope.........no, really.......
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5610908 - 01/07/13 09:07 PM
The bulb and hose for my shutter release are petrified too.
I did some searching for "air shutter release" that turned up some possibilities. Most of what I've seen for cameras have a small unit on the camera end, like a piston in a cylinder, that moves a plunger on the end, like for an old SLR. I suppose you could just cut off the end where the hose ends but, as Johann asked, what do you use for a small bulb at the camera end? Maybe the right eye dropper bulb might work. A medical supply store might be a good place to try.
mustgobigger
Reged: 06/12/07
Loc: Michigan
      #5610964 - 01/07/13 09:41 PM
maybe try the local pharmacy.
cheaper than med supply.
bremms
Reged: 08/31/12
Loc: SC
      #5610988 - 01/07/13 09:52 PM
Cole Parmer for the tube.
starman876
Reged: 04/28/08
Loc: VA
Re: My Last Classic Scope - Unitron 145C new [Re: bremms]
      #5611034 - 01/07/13 10:23 PM
Let's all try and find that little bulb. What Brian found is great. 2/3 of the way there.
That is also a great Unitron.
starman876
Reged: 04/28/08
Loc: VA
      #5611068 - 01/07/13 10:38 PM
http://www.thomassci.com/Supplies/Pipets/_/LATEX-BULBS?q=Rubber%20Bulb
This place also had other types of bulbs. What you guys think about the one in the link working for an shutter release bulb. I have no idea what size it needs to be.
astro140
Reged: 01/28/08
Loc: Mayhill, New Mexico
      #5611269 - 01/08/13 01:02 AM Attachment (10 downloads)
Hi Jon,
I suspect that the 75 mm tubes were drilled for the 8 x 30 mm finder so that they could be used on the model 142 also. My model 145 photoequatorial also had holes and screws for the 8 x 30 finder. But since I had an extra set of 8 x 30 finder brackets, I put one on (albeit with a Criterion finder, until I can find a Unitron) BTW, beautiful restoration job on your scope!!
Steve,
NM
astro140
Reged: 01/28/08
Re: My Last Classic Scope - Unitron 145C new [Re: astro140]
      #5611275 - 01/08/13 01:09 AM Attachment (16 downloads)
Just one more picture of my 145. BTW, Jon, are you sure you don't want to find one with a weight drive
starman876
Reged: 04/28/08
Loc: VA
      #5611996 - 01/08/13 01:54 PM
I really think it is a beautiful scope. However, I think it needs one more finder scope.
astro140
Reged: 01/28/08
      #5612650 - 01/08/13 08:28 PM
Good point
mustgobigger
Reged: 06/12/07
Loc: Michigan
      #5612674 - 01/08/13 08:44 PM
Looks great astro...
astro140
Reged: 01/28/08
      #5615931 - 01/10/13 05:37 PM
Thanks Brian,
Steve
NM
bobbyt63
Reged: 02/16/10
      #5616095 - 01/10/13 07:25 PM
could you tell me if there was ever instructions for the astro camera and where can i see it thanks bob
starman876
Reged: 04/28/08
Loc: VA
      #5616119 - 01/10/13 07:33 PM
Company seven website I think has one
http://www.company7.com/library/unitron/unitron_astro_camera.html#operation
gelkin
Reged: 09/22/10
Loc: Western, MD.
      #5616360 - 01/10/13 09:59 PM
Definetly one here . Look near the bottom of the page in the manuals section. Great site by the way in case you didn't know about it.
akman1955
Reged: 09/07/09
Loc: Alaska, USA
      #5620341 - 01/13/13 09:22 AM Attachment (9 downloads)
nice telescope.. mines a earlier version. no rings . brackets bolted directly to tube and it has aluminum knobs/super focuser.
akman1955
Reged: 09/07/09
Loc: Alaska, USA
Re: My Last Classic Scope - Unitron 145C new [Re: akman1955]
      #5620344 - 01/13/13 09:24 AM Attachment (9 downloads)
nother view
Joe Cepleur
Reged: 03/18/10
Loc: Dark North Woods
      #5620473 - 01/13/13 10:40 AM
Inspiring restoration! No worthier a Unitron owner exists on this planet.
PiSigma
Reged: 10/14/09
Loc: North Carolina
Re: My Last Classic Scope - Unitron 145C new [Re: Joe Cepleur]
      #5620800 - 01/13/13 01:29 PM
Thanks everyone. She is a beauty.
I really want to find one of the Deluxe focusers. Steve is killing me with the pictures of the one he just found. It looks like this focuser was optional even on the 145C prior to 1972. Then the 1972 catalog lists it as standard on a 145C.
terraclarke
Reged: 05/29/12
      #5620865 - 01/13/13 02:01 PM
Absolutely gorgeous!
PiSigma
Reged: 10/14/09
Loc: North Carolina
Re: My Last Classic Scope - Unitron 145C new [Re: terraclarke]
      #5631931 - 01/19/13 05:43 PM Attachment (7 downloads)
Well, like Gerald said, my Unitron problems are just starting. And, like Steve (astro140), I couldn't just leave those 8x30mm finder mounting screws with nothing to hold so....I added an 8x30mm finder and brackets.
I had to think a bit about how to re-arrange things. This OTA is getting crowded. Since the 60mm guide scope has only one focuser knob on the right side of the focuser, I decided to move the guide scope to the right side of the main OTA and move the 10x40mm finder to the left. Everything seems a bit more natural to use this way.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5631932 - 01/19/13 05:44 PM Attachment (8 downloads)
Anyone notice something else new?
I placed a couple of ads looking for a 75mm Deluxe focuser and one nice CN member responded with one for sale. It has Italic lettering which was perfect for my 145C. Shown with the optional 1.25” / 0.965” reversible eyepiece holder.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5631940 - 01/19/13 05:47 PM Attachment (7 downloads)
A shot of the Deluxe focuser on the left vs. the standard focuser on the right.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5631946 - 01/19/13 05:50 PM Attachment (9 downloads)
Another shot of the business end.
mustgobigger
Reged: 06/12/07
Loc: Michigan
      #5632065 - 01/19/13 07:17 PM
Sweet jon,
you can always turn that focuser
Knob around..
I found that tripod nut if you still
Need it....just let me know and ill
drop it in the mail.
starman876
Reged: 04/28/08
Loc: VA
      #5632127 - 01/19/13 07:48 PM
Nice looking scope. Looks like it is missing something. Cannot put my finger on it though.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5632151 - 01/19/13 08:05 PM Attachment (5 downloads)
Thanks Brian. That 8x30mm has a good home.
I thought about turning the focuser shaft but I'm right handed anyway so...
That's great about the nut. We're talking about the round 1/4"-20 one that goes in the leg for the tripod tray right? You already sent me the hex nut up at the base of the mount. I do still need the round one. If you could send one that would be excellent.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5632160 - 01/19/13 08:11 PM
Thanks Johann.
What's it missing? Two Unihexes? Leg box? Duetron Model A? A 160 big brother?
mustgobigger
Reged: 06/12/07
Loc: Michigan
      #5632197 - 01/19/13 08:38 PM
That's the one....looking around
For a bolt...there it was ....
Ill put it in the mail Tuesday.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5632252 - 01/19/13 09:34 PM
Thank you Brian! One more item on this scope put back to the way it should be.
starman876
Reged: 04/28/08
Loc: VA
      #5632910 - 01/20/13 10:28 AM
If you need something PM me. I am always willing to help out.
gelkin
Reged: 09/22/10
Loc: Western, MD.
      #5635607 - 01/21/13 07:39 PM
That is a beauty for sure. I thought you would be hard pressed to get a deluxe focuser. And such nice condition too. Congrats to you.
GeneT
Ely Kid
Reged: 11/07/08
Loc: South Texas
      #5635784 - 01/21/13 09:48 PM
OK--I lived for several years in Las Vegas. My money is on the line. The only question is -- when and what is the next telescope that will show up on your bucket list. I have found that it is quite easy to add items.
PS--what other classic telescopes that were on your bucket list do you own?
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5636498 - 01/22/13 09:42 AM
Thanks Gerald. I didn't have much hope for finding a Deluxe focuser either. Sometimes you get lucky.
PiSigma
Reged: 10/14/09
Loc: North Carolina
Re: My Last Classic Scope - Unitron 145C new [Re: GeneT]
      #5636502 - 01/22/13 09:45 AM
Hi Gene,
The bucket list was:
Sears 6344
Celestron C8 Orange tube
Criterion RV-6
10" Cave
8" Cave
Unitron 145C
Unitron 155 or 166
Oh geeez, did I just add another one?
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5644726 - 01/26/13 04:59 PM Attachment (8 downloads)
I finally got around to finishing the reproduction guide scope box. The one for this scope was missing and the chances of finding one were probably slim and none.
So a friend of Steve's, who had also made him a EQ mount box, dupicated one from an original that Steve had. Here it is next to Steve's and still un-stained.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5644736 - 01/26/13 05:04 PM Attachment (7 downloads)
I'm not a wood worker at all. I haven't stained anything in 35-40 years. So I headed to Lowes and picked up the supplies I needed. I picked out what I thought would be a close stain match, a Cabot stain called Brown Mahogany. Unitron stain colors seem to be a bit different on various cabinets I've seen. This color looked like it would match well but turned out a bit too red for my taste. It is fairly close to my original EQ mount box though.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5644742 - 01/26/13 05:07 PM Attachment (4 downloads)
The hardware on this box is all original restored Unitron from a dilapidated 114 OTA box.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5644745 - 01/26/13 05:08 PM Attachment (7 downloads)
Original hinges replated.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5644754 - 01/26/13 05:11 PM Attachment (7 downloads)
The inside with the grey felt I applied. The woodworker even undercut the area where the felt lies flat, just like an original box. One of the mounting rings is shown on its storage disk.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5644756 - 01/26/13 05:12 PM Attachment (6 downloads)
The guide scope in place in its new home.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5644758 - 01/26/13 05:13 PM Attachment (5 downloads)
Better view of the mounting ring storage.
gelkin
Reged: 09/22/10
Loc: Western, MD.
      #5644801 - 01/26/13 05:41 PM Attachment (4 downloads)
Very nice box Jon. I probably have a dozen little cans of stain in my search for a match. About as close as i have yet is golden oak from Zar. Still a little too dark and too golden. Even tried straight shellac and amber shellac. Still not too close to an original.
Box on the left is refinished (was in bad shape). The others are original. I stained, stripped, restained a tripod section once many times to try and match. Still isn't quite right. Do you know what kind of wood he used? Looks great.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5644890 - 01/26/13 06:43 PM
Thanks Gerald. I believe it is African Mahogany. The stain company's samples are usually shown for pine and oak and I'm sure the shades are different for other kinds of wood, how long you leave it on before wiping it off, etc., etc. I probably should have had him send a scrap piece of wood I could practice / test on.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5644897 - 01/26/13 06:47 PM Attachment (5 downloads)
Accessories! You gotta love 'em.
Here are the two lens caps along with aperture reducers for both the 75mm and 60mm.
sgorton99
Reged: 04/30/08
      #5644898 - 01/26/13 06:47 PM
Looks good Jon. You could re-stain the original boxes to match your new one .
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5644900 - 01/26/13 06:48 PM Attachment (5 downloads)
Two different versions of the reversible 0.965" / 1.25" EP adapter.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5644904 - 01/26/13 06:51 PM Attachment (6 downloads)
Filters. On the left a 0.965" Sun filter, in the middle a 1.25" Sun filter and on the right a 0.965" Moon filter.
I didn't even know until recently that the 1.25" version of the Sun filter existed.
Standard Disclaimer: Do not use the Sun filters. For collectable use only.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5645232 - 01/26/13 10:40 PM Attachment (5 downloads)
Unitron Herschel wedge.
akman1955
Reged: 09/07/09
Loc: Alaska, USA
      #5647383 - 01/28/13 03:15 AM
one on the right is older one cause of the slits..
turk123
Reged: 07/09/10
Loc: N.E. Ohio
      #5648233 - 01/28/13 01:46 PM
Beautifully made wooden box. My father was a wonderful wood worker. Master class. I wish I had learned from him. Too bad when we're young, we just don't realize some of the important things in life.
starman876
Reged: 04/28/08
Loc: VA
Re: My Last Classic Scope - Unitron 145C new [Re: turk123]
      #5648324 - 01/28/13 02:20 PM
Thats what I tell my two boys who are now 24 AND 26. However, they still know everything so I cannot teach them anything yet.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697336 - 02/23/13 09:10 PM Attachment (5 downloads)
Here are some updates on a few things I’ve been working on for the 145C.
This 145C came with the Styrofoam lined cardboard box for the Unihex. I obtained a wooden box for the Unihex that was in nice shape. Here it is after clean up and some Guardsman polish.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697337 - 02/23/13 09:11 PM Attachment (6 downloads)
A previous owner had replaced the bottom wood panel but didn’t get it quite square when gluing it together. I carefully detached it, squared it up, and re-glued it back on. Then I finished it with two coats of Cabot Satin polyurethane.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697340 - 02/23/13 09:11 PM Attachment (5 downloads)
Here it is with the Unihex in place.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697341 - 02/23/13 09:12 PM Attachment (7 downloads)
Here is a picture of the Unihex Achromatic Amplifier in place in the end of the drawtube that screws into the Unihex.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697342 - 02/23/13 09:13 PM Attachment (4 downloads)
Next I went to work on the Model 220A Astro Camera. First I cleaned up the cabinet hardware. Here are the front latches with the left one polished.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697343 - 02/23/13 09:14 PM Attachment (5 downloads)
The inside of the cabinet is in excellent condition.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697345 - 02/23/13 09:15 PM Attachment (4 downloads)
The cabinet with cleaned up hardware back on and the outside polished with Guardsman. Note the “A” printed on the right rear corner indicating a 220A camera for Unitron drawtubes.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697359 - 02/23/13 09:20 PM Attachment (4 downloads)
Three film holders, which each hold two pieces of film, come with each kit.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697365 - 02/23/13 09:22 PM Attachment (3 downloads)
The camera itself was in very nice condition, just requiring cleaning and a little touch up.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697369 - 02/23/13 09:23 PM Attachment (6 downloads)
Another view. This camera uses a Thornton Pickard shutter mechanism. The shutter speed is set with the knob toward the bottom and wound up by turning the wing nut shape on top of the shutter spool towards the top. It is tripped by an air operated rubber bladder under the black lever.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697378 - 02/23/13 09:25 PM Attachment (5 downloads)
Everything back in the cabinet. Also shown are the drawtubes along with a 30mm eyepiece for projection photography. The eyepiece fits into an adapter which then goes in the drawtube. The adapter also comes with a removable yellow filter.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697379 - 02/23/13 09:26 PM Attachment (5 downloads)
As discussed earlier in this thread, the shutter is operated by a squeeze bulb which expends a small bladder under the shutter release lever. Most of these at this age seem to be fairly well petrified. Below is the original bulb, bladder and hose. The bulb and bladder are hardened and would probably crumble if squeezed. The hose and barb fittings on each end are in great shape however.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697381 - 02/23/13 09:26 PM Attachment (5 downloads)
So I went to work looking for a solution that was as close to the original as I could find. Per some of the earlier posts I bought just about every rubber bulb I could find on the Internet. Shown below in the top row are bulbs in 60ml, 30ml, 15ml, and 12ml sizes. The next row shows a bag of 2ml bulbs, three types of 5ml bulbs and another 30ml bulb. The upper 30ml type would be about the best choice for the squeeze bulb. I didn’t consider it ideal as it is fairly stiff, has a ¼” hole for the hose, which is much larger than the 3/32” fittings on the ends of the hose, and doesn’t look much like original. None of these bulbs was going to work for the expanding bladder under the camera shutter release lever.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697382 - 02/23/13 09:27 PM Attachment (4 downloads)
The original squeeze bulb has a distinctive lateral and longitudinal rib pattern and was probably much more flexible than the bulbs shown above. So I headed to eBay to search for an “air shutter release”. Several possibilities turned up. The first one I got, from seller ID photogearfinder, turned out to be made in China and did not look like the one in his picture, which was ribbed like the original. I checked with another seller who claimed his was the unit in his picture, which had ribs, and was made in Japan, which was a good sign. This one is shown below with the long hose and spool it comes with. Other than being black, it is almost exactly like the original Unitron bulb. It has the same flexible ribbed outlet as the original and the small green barbed fitting is the same as the originals except for color of course.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697384 - 02/23/13 09:28 PM Attachment (3 downloads)
Here is the original hose on the new bulb. The green barbed fitting didn’t want to come out of the new bulb so I left it rather than breaking it. If your hose is also petrified or missing, a comparable red silicone hose is available from McMaster-Carr and is shown on the right. Their part number is 5236K62 and is $0.85 per foot.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697389 - 02/23/13 09:30 PM Attachment (4 downloads)
What to do about the shutter release bladder? This was the big question earlier in this thread. It turns out that Johann’s link to Thomas Scientific was the right track. 1ml (not 2ml) latex bulbs for Pasture pipettes are about the closest thing I can find for the release bladder. I bought a bag from The Science Fair (thesciencefair.com). They call them 1ml Latex Dropper Bulb Teats and are part number 3826-15. They sell for $0.36 each but they have a $10 minimum.
The two shown on the left are as received. I wanted to remove the ring at the end without making them too flexible at the end. I ruined a couple with razor blades and flush cuts. Then I tried sanding one down on a belt sander with a mandrel inserted into the end of the bulb to support it and this worked pretty well. The other problem is they are white. I picked up a package of Rit dye, #10 Wine color, and dyed a couple. I mixed a couple of teaspoons of the dye with ½ cup of hot water. I soaked the red bulb that still has the ring for about ½ hour but didn’t like the purple shade. The trimmed down bulb was in for nearly an hour and it came out a little better. There may be a better Rit color but they didn’t have any other reds at any stores I checked.
This bulb has a 5mm opening in the end, which is much larger than the 3/32” barb fitting. Luckily a small piece of the McMaster hose works perfectly as an adapter.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697391 - 02/23/13 09:31 PM Attachment (4 downloads)
Here it is on the end of the hose.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697392 - 02/23/13 09:32 PM Attachment (5 downloads)
And installed on the camera. Guess what? It actually works.
I wonder how many years it has been since this camera shutter was last tripped? Apparently the original owner did take quite a few pictures with this back in the day. His family kept the photos he took.
I think I’m going to obtain some film for this camera and give it a go sometime.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697395 - 02/23/13 09:33 PM Attachment (10 downloads)
Installed on the 145C.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697396 - 02/23/13 09:33 PM Attachment (8 downloads)
And a shot with the ground glass focusing plane window open and a film holder in place with the slide pulled out to expose the film to the shutter.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697397 - 02/23/13 09:34 PM Attachment (7 downloads)
Another accessory I obtained is a Porro prism for terrestrial viewing. This one was advertised as having something wrong with the optics but I thought I’d get it anyway and see if it just needed a cleaning.
But the view showed something more than a cleaning was needed.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697400 - 02/23/13 09:35 PM Attachment (7 downloads)
After opening it up I found that the Canada balsam that held two of the prisms together had let go. This shot also shows the green felt used as shims on either side of the central prism along with small pieces of cardboard at the top and bottom keeping the prism assembly from moving. Note that the lower piece of cardboard at the peak of the central prism is painted black.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697401 - 02/23/13 09:35 PM Attachment (7 downloads)
Here’s a shot of the separated prisms.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697403 - 02/23/13 09:36 PM Attachment (8 downloads)
This looks bad but all of the old Canada balsam will clean off easily with acetone. While I’ve never needed to take a cemented lens or one of these prism assemblies apart before, if you need to separate some parts joined with Canada balsam, I’ve read that soaking them in hot water or putting them under a heat lamp will soften and release the balsam.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697404 - 02/23/13 09:37 PM Attachment (7 downloads)
Canada balsam seems to be a bit hard to find these days. I remember a small bottle coming with a microscope I had in my younger days. Surplus Shed carries it in raw form. I found a 30 ml bottle at Cynmar Corp. (part number CHB80916).
After cleaning both surfaces I applied a few drops and pressed the prisms together. The balsam oozed out of all the edges so I must have used just enough. It takes a while for the balsam to cure. I set this aside for a week on the point of the center prism so that the one that came loose would sit level. After a week I cleaned off the excess balsam with acetone being careful not to use too much nor put too much pressure on the prisms. The balsam probably never cures in the center.
Now we have a pretty clear view through the prism assembly.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697406 - 02/23/13 09:37 PM Attachment (8 downloads)
Here are all the pieces ready to go back together.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697407 - 02/23/13 09:38 PM Attachment (7 downloads)
A nice clear view again.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5697409 - 02/23/13 09:39 PM Attachment (8 downloads)
Another cool accessory ready to go again.
gelkin
Reged: 09/22/10
Loc: Western, MD.
      #5697418 - 02/23/13 09:46 PM
As always, very informative. Excellent work. Thanks for posting.
terraclarke
Reged: 05/29/12
      #5698044 - 02/24/13 10:51 AM
The porro prisms are cool. I was fortunate to get one mint that I traded a Parks eyepiece for. Do you have a dark room to go with the camera? What size sheet film do they take? Can you still get it?
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5698090 - 02/24/13 11:16 AM
Terra,
I don't have a dark room so I'm going to have to put something temporary together for that. I can't see doing film more than a couple of times just for the sake of saying I tried it.
The sheet film is 4" x 5" and is still readily available.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5698101 - 02/24/13 11:19 AM Attachment (6 downloads)
Thanks Gerald. I wish we were doing NEAF again this year so I could bring it up for the display. Maybe next year.
gelkin
Reged: 09/22/10
Loc: Western, MD.
      #5698208 - 02/24/13 12:47 PM
Is that official? No NEAF. I didn't get that memo.
You know you can get what is called a changing bag that is light tight with hand holes. Once the film is in a tank chemicals can be poured in in daylight. Photos through that set up had to be a tough way to go.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5769657 - 03/31/13 08:38 PM Attachment (3 downloads)
Well, you just can’t resist continuing to accessorize these Unitrons.
I was recently able to get a leg cabinet for the 145C. The top and bottom veneer on these cabinets is incredibly thin. The survival rate on these is probably quite low and some legs appear to have originally shipped in cardboard boxes.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5769658 - 03/31/13 08:38 PM Attachment (3 downloads)
Back. The sides of this cabinet look like pine.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5769659 - 03/31/13 08:39 PM Attachment (3 downloads)
Legs in place.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5769660 - 03/31/13 08:39 PM Attachment (3 downloads)
A rare Duetron Model A.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5769661 - 03/31/13 08:40 PM Attachment (3 downloads)
Installed, with a pair of R25mm eyepieces.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5769662 - 03/31/13 08:41 PM Attachment (15 downloads)
A second Unihex Model A in a satin lined box.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5769665 - 03/31/13 08:41 PM Attachment (19 downloads)
Installed.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5769667 - 03/31/13 08:42 PM Attachment (14 downloads)
The classic skyward shot. Time to cut down some trees!
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5769670 - 03/31/13 08:44 PM Attachment (17 downloads)
Go away clouds!!
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5769672 - 03/31/13 08:44 PM Attachment (14 downloads)
Don’tcha just love wooden cabinets?
starman876
Reged: 04/28/08
Loc: VA
      #5769682 - 03/31/13 08:50 PM
I do have another set of rings that will fit your scope so can install one more scope you install a 40mm unitron like a 127 that would complete your set up.
Besides teasing you that is a beautiful set up
Dave M
Reged: 08/03/04
Loc: Ohio
      #5769718 - 03/31/13 09:11 PM
Wow! Jon, Thats a Beautiful setup..
gelkin
Reged: 09/22/10
Loc: Western, MD.
      #5769720 - 03/31/13 09:13 PM Attachment (15 downloads)
Yes, love those wooden boxes. Excellent find on the tripod box Jon. I have a 60mm tripod box that is the same, pine sides and 1/8" laminate top and bottom. If you ever need material, there is luan plywood available from Winfield Collection that i used for restoring a bad unihex box that matched very well. Shipping was very reasonable as well. Excellent Unitron you have there Jon.
terraclarke
Reged: 05/29/12
      #5769740 - 03/31/13 09:36 PM
Yes. Some of us love the little 127 and have high hopes of adding one to our collection
terraclarke
Reged: 05/29/12
      #5769742 - 03/31/13 09:37 PM
Wonderful collection of all things Unitron Jon.
Terra
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #5770821 - 04/01/13 01:27 PM
Thanks everyone. I'm definitely proud to be the caretaker of this classic.
Johann - I could add another couldn't I? Well, actually not as I don't have enough counterweight now as it is.
Anyone have a threaded Unitron counterweight they want to part with?
starman876
Reged: 04/28/08
Loc: VA
      #5770835 - 04/01/13 01:35 PM
You need more counterweights? Should should have said something earlier.
Jim Curry
Reged: 10/29/07
Loc: STL
      #5770844 - 04/01/13 01:40 PM
Pi/Jon:
For those of us enamored with refractors, those two photos of the scope, equatorial mounted, festooned with rings, finders, guide telescopes and accessories, is wonderfully evocative. It suggests far more than a mere telescope. No, this suggests a scientific instrument even if only for the personal exploration of the universe. The instrument looks busy, with a purpose, just waiting for its owner to take a seat. Very cool. Thanks.
pbealo
Reged: 10/12/06
Loc: New Hampshire
Re: My Last Classic Scope - Unitron 145C new [Re: Jim Curry]
      #5770958 - 04/01/13 02:37 PM
I could use a weight for the mechanical clock drive...
Peter B.
starman876
Reged: 04/28/08
Loc: VA
Re: My Last Classic Scope - Unitron 145C new [Re: pbealo]
      #5770997 - 04/01/13 03:00 PM
I will trade you a 4" unitron for the clock drive.
Bonco
Reged: 04/17/06
Loc: Florida
      #5771284 - 04/01/13 05:23 PM
What a wonderful thread. Loved all the pictures. This telescope was my dream scope in the early 60's. Impressive to see all the wooden boxes. Today those boxes to be built and sold would cost a thousand bucks alone. Thanks for sharing.
Bill
Jetmo
Reged: 01/22/11
Loc: Lansdale, Pa.
      #5771480 - 04/01/13 07:06 PM
My friend has a restored one, same model. I love the turret eyepiece.
Vince
sgorton99
Reged: 04/30/08
Re: My Last Classic Scope - Unitron 145C new [Re: Jetmo]
      #5771498 - 04/01/13 07:17 PM
Pretty nice Jon, glad you have it!
sgorton99
Reged: 04/30/08
      #6230167 - 12/02/13 08:35 PM
Jon, just enjoyed re-reading this thread. Nice scope and nice job! I'm speculating the original owner put this white dot on the leg to mark which leg was oriented to North.
Steve
terraclarke
Reged: 05/29/12
      #6231444 - 12/03/13 01:25 PM
starman876
Reged: 04/28/08
Loc: VA
      #6231575 - 12/03/13 02:27 PM
It is an outstanding 145C
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #6232246 - 12/03/13 09:27 PM Attachment (11 downloads)
Thanks everyone. It is my pride and joy Unitron at the moment. As beautiful to look at as look through. And all the bells and whistles too.
I agree Steve, that spot probably indicated which leg he wanted pointing north.
I have since been able to upgrade the main cabinets. I now have a nicer mount cabinet and nearly mint leg cabinet. And the guide scope cabinet is now an original Unitron box.
starman876
Reged: 04/28/08
Loc: VA
      #6232267 - 12/03/13 09:35 PM
The most expensive 145C on the planet
terraclarke
Reged: 05/29/12
      #6232404 - 12/03/13 10:56 PM
And quite possibly, the most beautiful. You have done a truly amazing job Jon. What a Unitron!
Terra
nightpilot
Reged: 02/16/12
      #6232581 - 12/04/13 01:34 AM
Always a pleasure to look back at this scope. Makes me want to add a 30mm finder to the crowded tube of my 145C, seems like the thing to do. Actually what I really need to do is buy some of that Guardsman wood revitalizer. Looks like it works wonders on the tripod legs. Any trick to using it? Is there a cleaner to use first?
Bob
rcwolpert
Reged: 08/13/12
Loc: San Jose, CA
Re: My Last Classic Scope - Unitron 145C new [Re: nightpilot]
      #6232917 - 12/04/13 09:31 AM
Jon, you have me salivating! I want to set up a chair on you deck and just stare at that 145C for a few hours.
javago
Reged: 11/02/04
Loc: Geldrop-Netherlands
Re: My Last Classic Scope - Unitron 145C new [Re: rcwolpert]
      #6233084 - 12/04/13 11:22 AM
I think most classic telescope owners do just that........staring and enjoy their collection....staring...turn the focuser knob a few times,some more staring........wiping some dust of the ota,and more staring......yes they look great !.......and when the sky is clear some even bring them out under the stars.....
starman876
Reged: 04/28/08
Loc: VA
Re: My Last Classic Scope - Unitron 145C new [Re: javago]
      #6233102 - 12/04/13 11:32 AM
It gives a clear example what those 142 mounts will carry.
PiSigma
Reged: 10/14/09
Loc: North Carolina
      #6233382 - 12/04/13 01:33 PM
Thanks everyone. I do get pleasure from it just looking at it sometimes. But it's nice to get it out under dark skies too. There has been precious little of that here this year. My Cave Custom Super Deluxe is the same way. It sits at the front of my garage so even if I don't get to take it out that night it still puts a smile on my face every time I pull into the garage.
Bob, the Guardsman doesn't have any cleaner that I'm aware of. It will dissolve most organic residue though. I just spray it on a soft cloth and polish the wood. It does a great job on the storage cabinets too. Really like night and day in some cases.
13 registered and 17 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), Brian Risley
