Jeff55
Reged: 04/14/05
Loc: Boston MA
Is CGE Worth Twice The Price Of The Orion Atlas?
      #2651281 - 09/19/08 10:10 AM
Is the quality of components and fit and finish that much higher in the Celestron CGE...be curious to hear opinions.
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: Is CGE Worth Twice The Price Of The Orion Atlas? new [Re: Jeff55]
      #2651315 - 09/19/08 10:30 AM
Heavier and larger bearings, heavier tripod, larger motors, larger worm and spur gear, larger saddle, larger diameter counterweight shaft. Mount capacity is 65lbs vs 40 for the Atlas/EQ-6. That is what you are paying for. Fit and finish? Well I can't see any difference in the dark.
Eddgie
Reged: 02/01/06
      #2651363 - 09/19/08 10:50 AM
Have owned both.. Like the packageing of the Atlas in some ways, hated it in others.
I thought that the Atlas "Fit and Finish" was nice. It is a much different design approach than the CGE though, so it makes comparisons quite difficult.
The CGE is intended for heavier loads, so most of the components are heavier duty in nature.
I owned a Generation 1 Atlas Go-To, and it was abundantly clear that the Celestron had far more refined software than the Atlas had (though I am sure that the gap has closed in later versions). But to me, "Fit and Finish" today also means things like the code under the covers.
So, a very difficult comparison to make because the Atlas design is packaged so differently. Even the dovetail arrangement defies comparison....
Having owned both, I can say that I vastly prefer the CGE though.
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
      #2651614 - 09/19/08 12:56 PM
Having owned both, I'd say yes.
Eddgie
Reged: 02/01/06
      #2652069 - 09/19/08 05:22 PM
And as to the question if it is worth twice the price, well, here is an analogy..
Suppose you want to transport an 8 Lb Cow Patty. Do you spend $1 dollar on a 5 lb carry weight bag, or $2 on a 10 Lb carry weight bag?
Most of us would Of course you will get the 10 Lb capacity bag...
So, if you have a telescope that won't hold still on an Atlas, then suddenly, the CGE doesn't seem all that expensive, does it?
Steve Fisher
Reged: 08/12/06
Loc: Utah
Re: Is CGE Worth Twice The Price Of The Orion Atlas? new [Re: Eddgie]
      #2652637 - 09/19/08 11:22 PM Attachment (82 downloads)
Since I currently own both of the mounts you mention, I'll answer you with my take on it.
First of all though you should know that I am purely a visual observer. No cameras no video.
The EQ-6 Pro (Atlas) is the perfect mount for my FLT 132. While it is a heavy mount and tripod it is quite portable, well priced and delivers deadly accurate goto's when properly aligned.
It would be overkill to insist on a CGE for this scope. It would simply be "overmounted".
Steve Fisher
Reged: 08/12/06
Loc: Utah
Re: Is CGE Worth Twice The Price Of The Orion Atlas? new [Re: Steve Fisher]
      #2652651 - 09/19/08 11:30 PM Attachment (81 downloads)
On the other hand, if you want to mount a 6" f/12 you would not want to mount it on an Atlas. I tried, just for fun. It could hardly be controlled. It is simply undermounted and you would have to sell the Atlas and move up.
Honestly the CGE does not handle the 6" as well as I would like. More work to come.
So in my opinion, the CGE MAY be worth double the price. I bought my EQ6-Pro new and the CGE used for about 140% of the price of the Atlas. Both are currently serving their purpose.
If you want to talk about AP that is probably where the biggest difference is. (at least that would be my guess)
jay52
Reged: 09/26/04
      #2652728 - 09/20/08 12:28 AM
Yes.
LarsZ
Reged: 01/12/08
Loc: Sweden
Re: Is CGE Worth Twice The Price Of The Orion Atlas? new [Re: jay52]
      #2652992 - 09/20/08 07:44 AM
I have a new CGE and last years model of the Atlas and use them only for imaging with a SCT. The total load I use on mount is about 13 kg.
The Atlas uncorrected PE out-of-the-box was 3 times as much as the CGE, but when using an autoguider camera, it's hard to see much difference on the PE-curves or the photos since the guider camera seems to have no problems with the Atlas PE-curve. The CGE gives a very slightly better performance and is not so sensitive to balance with this load.
I do prefer Celestrons software compared to the Atlas and the quality of the CGE feels better in my opinion.
So to answer your question: Is it worth twice the money?
For me no. Not with my set-up.
With a heavier or bulkier set-up? Probably yes.
/Lars
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
Re: Is CGE Worth Twice The Price Of The Orion Atlas? new [Re: LarsZ]
      #2653094 - 09/20/08 09:17 AM
With a light load and an autoguider for imaging, the Atlas is fine. Get the load around 45lbs, then the CGE is worth double the money. I've imaged with 70lbs on my CGE, but that's nothing compared to our own Jerry Wise who is our resident CGE torturer. I'm sure he'll post a picture or two of his CGE under load.
David
Eddgie
Reged: 02/01/06
      #2653392 - 09/20/08 01:03 PM
I went to a Meade LXD 750 for my 6" f/8. I think that it might be a great value choice for your 6". If you are purely a visual observer and don't care about PE (which I think is maybe not as good as more modern mounts) the LXD is a big, stable mount.
I also put a 6" scope (Meade 152ED) and it was Ok, but not reallly OK.. I lived with it because I bought the mount for the scope, but in the end, I realized that it just wasn't enough mount.
The LXD 750s turn up used for as little as $1700.
I have to confess that I like mine so much that I even considerd getting a second on for my C14... But in the end, the CGE WORKS for the C14, and I decided to leave well enough alone..
But consider an LXD 750 for your scope.. It was built to hold a 7" f/9 refractor, and is probably about as good a mount as you can find for your long tube...
Regards.
Reged: 07/06/07
      #2653901 - 09/20/08 08:35 PM
Yep. Combine the much better HC firmware, considerably more robust tripod, better bearings and gears, and, yeah, it may be worth the extra moola. OTOH, the current Atlas is just SWEET; particularly when coupled with EQMOD. Depends on your requirements. If you are gonna be imaging with long/heavy OTAs, get the CGE.
JerryWise
Reged: 12/26/03
Loc: Lexington, SC
Re: Is CGE Worth Twice The Price Of The Orion Atla new [Re: Eddgie]
      #2653907 - 09/20/08 08:39 PM Attachment (71 downloads)
For David.....
Never had an Atlas but sure had a lot of fun with a CGE. That mount can take a load. Here are the questions I've gone through:
1: Is a CGE worth as much as my fork mounted C8 Celestron and 6 times my CG-5 Answer = Yes
2: Is a Tak NJP worth twice the CGE. For astrophotography = yes. Visual = no.
3: Is an AP-1200 worth 3 times a CGE. Astrophotography = Yes, Visual = Yes
The biggest thing I learned going through all these mounts? None of them work worth of toot for Astrophotography if you don't drift align them. Well, maybe the Tak with it's fantastic polar scope. Would I get another CGE.... shoot yes. Great mount for the money and about the cheapest way you can "get in the game" for some serious photography.
I wouldn't try some of these loads with an Atlas:
Transmographied
Reged: 05/18/05
Re: Is CGE Worth Twice The Price Of The Orion Atla new [Re: JerryWise]
      #2654896 - 09/21/08 02:43 PM
For David.....
My hero! Jerry's analysis is spot on. It's all in what you can afford, but the top line mounts are worth every penny if you're plan is to do some serious imaging. Getting something like an AP900 or an MI250 and putting, say, a Televue 127is and an 80mm TMB triplet may sound like overmounting, but with this setup, you have a seriously nice combination AND if you ever decide to replace one of the refractors with something like a VMC260L you have all the spare capacity needed.
David
jay52
Reged: 09/26/04
      #2654928 - 09/21/08 03:04 PM
Couldn't have said it better myself, Jerry!
DavidW
Reged: 09/18/07
Loc: Alberta, Canada
      #2655419 - 09/21/08 07:44 PM
Could you people, who have used a few of the mounts being discussed, comment on the 'ease' of drift aligning regarding each mount?
Where I'm coming from on this is this, I have an EQ6 Pro and other than doing the simulator at Pete's website haven't actually tried a dift align but from just doing the polar align I get the impression that the altitude bolts on the EQ6 and the way they meet the 'pressure bar' is going to make things difficult. I'm not sure how it would be done on these mounts mentioned so far, I was looking at a G-11 on the website which looks like it uses a dial knob for altitude and was thinking that might be easier.
Thanks in advance,
Another Dave
BowmoremanModerator
Clear enough skies
Reged: 09/11/06
Loc: Bolton, MA
Re: Is CGE Worth Twice The Price Of The Orion Atla new [Re: DavidW]
      #2656246 - 09/22/08 10:40 AM
I find doing polar (whether drifting), or just general polar cause I've been an idiot and bumped things out, etc... of the CGE to be quite easy.
I think it was David Pavlich (yet another, another Dave) that suggested to me to use a 1/4" small ratchet for both Alt and Az.
I also use replacement knob/bolts (I think originally from McMaster Carr? - that I got from Dave) for the altitude lock bolts.
You MUST loosen these (one on each side) before adjusting Altitude!!!
Anyways, I bought 2 1/4" socket/hex sets, one for the Alt adjust, the other for the Az adjust.
That way in the dark, while watching, all I have to do is push (or pull) on the socket wrench handle just a smidge. (Its way easier in the dark than trying to find, and fumble, with an allen wrench!.
A great combo/idea that I can't take credit for...
(from yet ANOTHER "Dave W")
clear enough skies
blueman
Vendor Blue Sky Accessories
Reged: 07/20/07
Loc: California
      #2656634 - 09/22/08 02:27 PM Attachment (44 downloads)
I use the "Polar Alignment Correction" routine that is programmed into the Genini on the G-11 after doing a regular polar alignment with the polar scope and then a 3 star alignment and it does a pretty good job of the Polar Alignment, without drift aligning. If I feel the need I repeat the process a second time and it makes it 2x more accurate. This takes only a couple of minutes to perform each time. So, I do not have too much time invested in the Polar alignment. I have yet to drift align and with guiding my pictures come out quite nicely.
However, if you wish to drift align, the G-11 knobs make it pretty easy to do.
Blueman
Ed B
Reged: 08/29/07
Loc: Geneva, Illinois, USA
Re: Is CGE Worth Twice The Price Of The Orion Atla new [Re: Bowmoreman]
      #2656663 - 09/22/08 02:44 PM
Let me chime in on the post. The drift alignment is a snap with a program called WCS ( http://wcs.ruthner.at/index-en.php ). You point the scope on the E/W line and put a star in the middle of the screen. Turn on the acquisition and let it go 5 minutes. You click on a "correction" button and the program tells you where to move the star to with the hand controller and then how far to move it with the mount adjustment. It even tells you how many time to move it over that distance if you are way off. Then you move it to the N/S direction and repeat. Again it will tell you exactly how much you need to move the mount. If I am way off on the first time I usually do the E/W once and then the N/S once. I repeat the cycle one more time and then check for the last time. If I am close when I start (which I am because I use the polar scope to start with) I usually on have to do the cycle once.
I love the program. I couldn't tell you which way to move the mount based on which way the drift is all I have to do is follow the instructions.
I just purchased an Atlas (upgrading from a ASGT) so I just answered the Atlas vs CGE question. To me the comments concerning the CGE being the minimum to get into serious imaging are a little bit of a stretch. I have seen some absolutely high quality images produced using "lower" grade mounts. The big difference to me was the capacity. Yes the CGE has higher weight capacity and if that was the determining factor in image quality I would agree that the CGE is better. We all know that there is more to it than that. The skill of the operator is a much larger factor. I personally did not need the capacity at this time. Since astronomy equipment holds its value exceedingly well (>80%), I don't need that much capacity and my skill is still growing, there was no reason to spend that much money. In addition my imaging targets are wider field where I don't need the super high accuracy.
I bought a used Atlas. If I need to step up in terms of capacity then I can sell the Atlas without taking a huge hit and buy the CGE.
As with most of these things there is never a right or wrong answer. It all depends on money and what you want to do.
Ed
http://www.freewebs.com/stardaddyed/
http://tech.groups.yahoo.com/group/QHYCCD/
Transmographied
Reged: 05/18/05
      #2656800 - 09/22/08 03:54 PM
clear enough skies
I can't take credit for the ratchets or the Alt knobs. I believe I got the ratchet idea from Joe, gimme that Giordano's pizza, Cipriano and I know Joe gave me the link to McMaster for the knobs. Changing the grub Alt grub screws to the knobs is one of the single best and simple modifications that can be made to the CGE, by the way.
David
27 registered and 37 anonymous users are browsing this forum.
