Francisco S.
Reged: 01/08/09
Loc: Bay Area, CA
Re: Oberwerk wooden tripod blem special new [Re: Jim7728]
      #2883494 - 01/23/09 05:45 PM
What is the size of the Oberwerk "tray" screw hole? it looks less then 3/8.
Jim7728
Reged: 04/10/05
Re: Oberwerk wooden tripod blem special new [Re: Francisco S.]
      #2883513 - 01/23/09 05:54 PM
The center hole(s) in the spreader on the legs?
1/4" in the center and on the 3 spreader bars. Those Vixen/Synta triangular accessory trays can attach through those holes.
Starlighter
Reged: 08/03/07
Loc: Sunny California
      #2883577 - 01/23/09 06:24 PM
Interesting.
How well would the 501HDV head on that tripod work as a mount for one of my larger refractors? I assume the head can be looked down. Can one point towards zenith? And if so, what adaptor would I need to hook a dovetail plate to the mount head?
Francisco S.
Reged: 01/08/09
Loc: Bay Area, CA
Re: Oberwerk wooden tripod blem special new [Re: Starlighter]
      #2883582 - 01/23/09 06:29 PM
Jim,
That's the one. Is it 1/4-20 size?
Edited by Francisco S. (01/23/09 07:15 PM)
Jim7728
Reged: 04/10/05
      #2883655 - 01/23/09 07:15 PM
Interesting.
Pointing towards zenith with long ota tube would require a extension or elevating type column to avoid contacting tripod legs. Bogan 475 tripod would be a good match with the 501 head. The head would have a 1/4"-20 bolt on the quick release shoe and could attach to the 1/4" threaded hole of the dovetail. May not be the best way to go with a heavy refractor.
Jim7728
Reged: 04/10/05
      #2883662 - 01/23/09 07:17 PM
Jim,
Yes, a 1/4"-20 bolt will slip through. 3/8" , too big.
alanon
Nobody tells me anything
Reged: 06/29/07
Loc: Las Vegas
      #2883682 - 01/23/09 07:24 PM Attachment (66 downloads)
Here is a very sturdy mount. It is a Helix Hercules on an Oberwerk tripod. Very sturdy indeed! Also it is one of the smoothest operating mounts I have ever felt.
Jim7728
Reged: 04/10/05
Re: Oberwerk wooden tripod blem special new [Re: alanon]
      #2883714 - 01/23/09 07:41 PM Attachment (68 downloads)
Cool setup, Dan.
Yep! I use to a have Hercules fork on the Oberwerk, too.
Very capable alt/az!
alanon
Reged: 06/29/07
Loc: Las Vegas
      #2883742 - 01/23/09 07:56 PM
I highly recomend the combo.
Starlighter
Reged: 08/03/07
      #2883816 - 01/23/09 08:37 PM
Can the Hercules be totally locked down?
alanon
Reged: 06/29/07
Loc: Las Vegas
      #2883828 - 01/23/09 08:44 PM
Oh yes. Note the size of the tension nobs. Lots of surface area to adjust from butter snooth to lift the rig up tight.
Starlighter
Reged: 08/03/07
      #2883840 - 01/23/09 08:50 PM
This might be the ideal alt-azimuth mount I've been looking for. What would I need as far as mounting a Vixen style dovetail to the base of the Hercules?
alanon
Reged: 06/29/07
Loc: Las Vegas
      #2883861 - 01/23/09 09:00 PM
The oberwerk is the tripod and has a 3/8 16 threaded post.
The Hercules is the helix brand mount. It takes either a 3/8 16 or a 1/4 20 stud
Starlighter
Reged: 08/03/07
      #2883882 - 01/23/09 09:12 PM
But is there a way to mount a standard dovetail bracket to the swivel base of the Hercules so I can attach my scopes using the rings and dovetail shoe?
alanon
Reged: 06/29/07
Loc: Las Vegas
      #2883886 - 01/23/09 09:14 PM
Oh. Sorry. No you need a saddle plate to put on the mount.
alanon
Reged: 06/29/07
Loc: Las Vegas
      #2883889 - 01/23/09 09:17 PM
Or if you have a threaded set of holes in the dove tail, you could screw a couple of thumb screws to the dovetail from underneath. My WO ZS80 has a L bracket I will get you a close up pic if you like.
Edited by alanon (01/23/09 09:20 PM)
Jim7728
Reged: 04/10/05
      #2883897 - 01/23/09 09:24 PM Attachment (64 downloads)
Yes. I used this dovetail clamp on my Helix 8" fork.
http://www.scopestuff.com/ss_ds13.htm
alanon
Reged: 06/29/07
Loc: Las Vegas
      #2883907 - 01/23/09 09:28 PM Attachment (59 downloads)
I only put one thumb screw in but should get the Idea. Sorry my photography skills leave a lot to be desired.
Francisco S.
Reged: 01/08/09
Loc: Bay Area, CA
      #2883987 - 01/23/09 10:06 PM
My Oberwerk tripod came arrived today.
First impressions - solid, sturdy, heavy, looks good, no Oberwerk engravings anywhere. I found no blems. One little scratch doesn't count, I am sure I will make some more with usage. $75 with $14 shipping to CA. Took 4 days.
alanon
Reged: 06/29/07
Loc: Las Vegas
Re: Oberwerk wooden tripod blem special [Re: Francisco S.]
      #2883999 - 01/23/09 10:10 PM
Your gonna love that tripod! I do mine.
21 registered and 44 anonymous users are browsing this forum.
