Jeff55
Reged: 04/14/05
Loc: Boston MA
Does CGE Have A Future?
#2876095 - 01/19/09 09:05 PM
With both the CGEM and soon to be available CGE PRO filling high and low end of the mount market for Celestron...what's the future of the CGE.
Strgazr27
Reged: 10/04/04
Loc: StonyHill Observatory
Re: Does CGE Have A Future?
[Re: Jeff55]
#2876133 - 01/19/09 09:35 PM
As of the last update it's fine and will continue to be offered by Celestron. It fills a gap between the CGEM (EQ6 Class) and the CGE Pro (AP900 Class) mounts and does it aamzingly well at that. I don't think you'll see it go away anytime soon. There are a few small things that could use a going over and perhaps that is what Celestron is in the process of doing. I'll tell ya this if they could fix those few small things, design it to look like the Pro I think they'd be hard pressed to keep them in stock.
HaleBopper
Reged: 01/14/08
Loc: Land of Ice and Snow
[Re: Strgazr27]
#2876689 - 01/20/09 07:07 AM
What are some of the small things that would need to be looked at, (improved), in the CGE? I have never used one, but won't rule out the possibility of getting one.
Thanks.
Reged: 07/06/07
[Re: HaleBopper]
#2876748 - 01/20/09 08:09 AM
Thanks.
Mainly the external cables--like the dec cable. Because of the cable material used and the way they are connected, these are a source of constant trouble. Also, the limit switches. Other than that, especially with the new software, not much to nitpick about.
Strgazr27
Reged: 10/04/04
[Re: rmollise]
#2876759 - 01/20/09 08:16 AM
Thanks.
I'd like to see the clutch levers redone perhaps but that is about it.
HaleBopper
Reged: 01/14/08
[Re: rmollise]
#2876762 - 01/20/09 08:20 AM
I'll assume that one can buy better quality cables from somewhere? I suppose that won't change how they are connected to the mount. Do they simply get in the way of operation?
What are the limit switches and how do they work or not work? What do you do to get them going?
Thanks.
Jeff55
Reged: 04/14/05
Loc: Boston MA
[Re: Strgazr27]
#2877053 - 01/20/09 11:26 AM
Bobby; Has there been discussion of a revised or updated GCE...I especially agree that if they changed the design to be a smaller, lower cost version of the CGE PRO...that would be a mount to want.
MichaelW
Reged: 06/03/06
Loc: Cartoon City, Nirvana
[Re: Jeff55]
#2877080 - 01/20/09 11:37 AM
Funny Jeff, I sent an email to Celestron asking more or less the exact same thing. I loved my CGE. There was some what I considered minor issues, but the mount itself was fantastic. I still think it has a great future and a little tweaking would make it a long time fixture.
Strgazr27
Reged: 10/04/04
[Re: Jeff55]
#2877115 - 01/20/09 11:53 AM
Jeff,
Not that I am aware of but it seems like a logical step with the release of the CGEM as well as the Pro. It would seem like a logical step for them to take and if any Ceelstron reps are listening.........Have at it!
Tapio
Reged: 09/24/06
Loc: Tampere, Finland
[Re: Strgazr27]
#2877133 - 01/20/09 12:04 PM
How about the meridian flip with CGE ? Can you avoid it now ?
Strgazr27
Reged: 10/04/04
[Re: Tapio]
#2877150 - 01/20/09 12:14 PM
Tapio,
Welcome to CN's!
The meridian flip can not be avoided with the CGE due to it's limit switches. Although this can be an inconvenience even the mighty Paramount ME needs to do a flip
TheMenace
Reged: 10/21/08
[Re: Strgazr27]
#2877176 - 01/20/09 12:28 PM
They would sell a lot more cge's if the price was $500 cheaper. Not many people need a $3000 mount.
Bowmoreman
Clear enough skies
Reged: 09/11/06
Loc: Bolton, MA
[Re: Strgazr27]
#2877262 - 01/20/09 01:07 PM
Thanks.
I would weigh in with a better hand control that would be more functional in really cold conditions... the LCD display is pretty much useless (and hence the entire mount) if/when temps get much below -5C or so...
I've asked my wife to knit me an HC cozy with holes for buttons and screen and into which I can easily slip a hand/toe warmer pack...
Other nits, not yet mentioned: the cable between the HC and the Pier needs to be about twice as long, and about 4 times as flexible (again in cold conditions).
Otherwise, its a great mount and pretty hard to beat in its price range...
Mine will probably ultimately get sold when I either go with an AP900/Mach1GTO or this beautiful looking CGE Pro model!
clear enough skies
bseltzer
Reged: 10/28/07
Loc: East S.F.Bay, CA
[Re: Bowmoreman]
#2878197 - 01/20/09 09:35 PM
What kind of PE are you guys getting out of your CGE mounts out of the box? Seems to me that PE would be a pretty big factor in the selection on a mount for AP. Certainly more of a factor than cables, clutch knobs, and other such issues that can be addressed with little time, effort or expense.
I have no first hand experience with CGE's, but I do have a strong interest in imaging. That's why I'm asking.
Regards, Bert
SleepIsWrong
Reged: 12/07/05
Loc: Baltimore, MD
[Re: bseltzer]
#2878254 - 01/20/09 10:08 PM
I have two CGE mounts - they run about 15-25" peak-to-valley PE uncorrected. Using the PECTool I get about 5" P-V PE.
Reged: 07/06/07
[Re: HaleBopper]
#2878712 - 01/21/09 07:25 AM
Thanks.
You can, but part of the problem is that the way they are wired means the shields are used as conductors, which causes problems, no matter what kind you use. They fail.
Limit switches are just that, microswitches used to indicate positions during setup/alignment. They tend to fail/get out of alignment.
bseltzer
Reged: 10/28/07
[Re: SleepIsWrong]
#2880143 - 01/21/09 09:41 PM
Really? Is this typical of CGE's? I've thought they'd do better than that.
Regards, Bert
LarsZ
Reged: 01/12/08
Loc: Sweden
[Re: bseltzer]
#2881512 - 01/22/09 04:51 PM
I got my CGE last summer and it had a PE of 12.6 peak-to-valley (+- 6.3) out of the box. I learned that another buyer got a PE of 12.4 which means that at least our 2 are very similar.
I have read that older CGE:s have a larger PE, so it seems that Celestron has made some improvements over the years.
Regards Lars
Lane
Reged: 11/19/07
Loc: Frisco, Texas
[Re: LarsZ]
#2882078 - 01/22/09 10:24 PM
Since I have never done astrophotography I probably should not even be commenting but I thought the amount of PE made no difference if you are using a CCD Autoguider. I thought the only problem is when you have a sudden big change in PE that can't be corrected quickly enough by the Autoguider. Isn't that true?
Alph
Reged: 11/23/06
Loc: Melmac
[Re: LarsZ]
#2882396 - 01/23/09 04:29 AM
Not really. That's urban legend. I have one year old CGE and it has a PE of 20 arcsecs peak-to-valley.
MichaelW
Reged: 06/03/06
[Re: Lane]
#2882678 - 01/23/09 09:50 AM
I have done a little astrophotography and I agree with your comment to a degree. There is a point where an autoguider cannot keep up with the significant change in the image. But the severity of the impact also depends on other factors such as focal length, sensitivity of the CCD and the overall time not on target. Most autoguiders can be set to specific intervals to sample for correction and if the sampling rate is high enough I would suggest that you can overcome most PE errors up to a specific focal length. Now what an autoguider cannot over come isn't PE error perse unless it is truly radical but a mount error where the mount stops tracking and therefore when you attempt to correct, correction isn't possible due to the mount not tracking.
At least this is the premise and understanding I run under and part of my justification of being able to go from a AP1200 with freaking unbeleiveable tracking back to the CGE (soon to be purchased) for me to re-enter imaging using refractors and shorter focal lengths with my ST-2000. And to be able to do so with confidence that the CGE will do the job I will ask of it.
Jared
Reged: 10/11/05
[Re: Lane]
#2883344 - 01/23/09 04:13 PM Attachment (90 downloads)
Yes, I believe that what you say is true--and I have some evidence to back it up (though the evidence is not from the most controlled environment). Below are two separate pictures taken on different nights using the same refractor and the same camera and the same exposure duration. The only differences are the mount and the night (and therefore, of course, the seeing and the focus). In both cases the mount was autoguided, and in both cases the autoguiding appeared to work well--meaning the the guide star was never lost and the mount was not chasing the seeing conditions.
The picture taken with the Mach1 GTO is significantly sharper than that taken with the Losmandy GM-8 (itself no slouch as a mount). Now, you could attribute it to better focus in one image, or better seeing conditions on one night, but that wouldn't explain why I see the same result in image after image.
Autoguiders can adapt to mounts with very large overall periodic error--as you can see in the picture with my Losmandy GM-8, the stars are nice and round--but they can not correct for rough tracking. An autoguider is, by its nature, reactive. It adjusts for error after it has occurred. I think that a lot of us using mounts that don't have very smooth tracking are throwing away some of the resolution our scopes are capable of. We may not know it since the stars are still shaped properly, but there is more detail there to be had.
The particular guiding software I use keeps track of the RMS error that it is guiding out. With my Losmandy GM-8 on nights with average or better seeing I typically saw values in the 0.4 to 0.6 pixel range (which is 1.2 to 1.8 arc seconds with my scope/camera combination) between guide exposures. With my Mach1 GTO I typically see values in the 0.00 to 0.05 pixel range (which is so small it may well be due to rounding issues in the centroid calculations rather than any second-to-second variation in tracking). That makes for a noticeably sharper image.
BTW, I'm not suggesting that the CGE isn't capable of very good tracking. I have never used one for imaging, so I simply don't have the experience to say what it might be able to do. However, those who point to low periodic error as in indication of good tracking ability (as well as those who point to high periodic error as an indication of a good tracking ability) are missing the point that in a system that is autoguided, the major issue is not overall periodic error but smoothness of tracking.
bseltzer
Reged: 10/28/07
[Re: Lane]
#2883467 - 01/23/09 05:27 PM
Auto-guiding can only correct an error after the fact. By the time a guider sees an error and responds to it, your data has been, to one degree or another, corrupted. Recording PE and using a PEC to minimize it is an attempt to prevent errors before your data is corrupted. The smaller and more regular, i.e., predictable, the inherent PE of a mount is, the more effective PEC can be in minimizing it's effect.
In other words, no, auto-guiding is most definitely not a substitute for accurate tracking. That's why I asked about it. At least for imaging, a mount's PE is the measure of it's merit, IMHO. Things like poor cables, weak saddles, shaky tripods,gnarly knobs, or even suspect electronics can all be fixed more easily than a PE of > 25". That's not to say bad PE can't be fixed. I've done it myself on an Atlas. But... it took me several months of sometimes frustrating trial and error to get a 50% reduction. That shouldn't come as a surprise when you consider the number of components in a drive system and the huge difference teeny, tiny little imperfections in any single one of them can make.
Short version... 1) PE matters. 2) Auto-guiding doesn't change #1
Regards, Bert
Reged: 07/06/07
[Re: bseltzer]
#2883502 - 01/23/09 05:48 PM
Bert
Nevertheless, given good focus and collimation, autoguiding produces good images, just as manual guiding did before there was such a thing as PEC, and when 30-arc seconds was considered "dang good."
BUT...I do NOT think you can go wrong buying the best mount you can afford, up to and including AP and Bisque and beyond.
Edited by rmollise (01/23/09 05:51 PM)
Jared
Reged: 10/11/05
[Re: bseltzer]
#2883526 - 01/23/09 05:59 PM
Regards, Bert
That's interesting, Bert. You and I seem to have had similar experiences but drawn different conclusions. I don't worry about the total amount of periodic error--any more than I worry about absolutely perfect polar alignment--because autoguiders seem to do a nice job of correcting for both periodic error and drift as long as the error is gradual and smooth. Of course you are correct that technically some error has already been introduced before an autoguider can address it, but as long as the error remains low enough to be masked by other sources of error such as seeing conditions, I don't worry about it.
That being said, I agree with you that there is no substitute for a good mount--smoothness, I believe, is of paramount importance--and total periodic error often correlates well with the quality of the mount.
bseltzer
Reged: 10/28/07
[Re: rmollise]
#2883540 - 01/23/09 06:04 PM
You are, of course, right. I admit to getting a bit dogmatic on these kinds of things, when in fact, there is a continuum of possibilities.
Where PE is concerned, it also depends, to a large degree, on image scale. Clearly, if your set up is running at 2"/pixel, PE/auto-guiding aren't as critical as they would be with a 2m FL optic and 5 micron pixels. And your predominant seeing conditions are also a figure into the equation. In point of fact, at my most often used dark-ish site, seeing is more often than not the limiting factor. But I guess I'm just too obsessed to let it go at that. Call it a character flaw.
To try to bring this discussion back onto it's original track, for me, the CGE would be more likely to have a future if Celestron/Synta could get the out of the box PE better than what it is. When I had a $3K - 3.5K mount budget a while back, PE was the main reason I didn't buy a CGE.
Bert
Edited by bseltzer (01/23/09 06:11 PM)
Strgazr27
Reged: 10/04/04
[Re: bseltzer]
#2883652 - 01/23/09 07:12 PM
The last CGE I purchased was mid year of 2008 and the measured PE out of the box, untouched was 12 arc seconds, peak to peak. Maybe I had a good one but that thing with a few PEC runs it was under 6 arc seconds.
In reality we need to stop comparing $3000 mounts to those that are $5000 and up.
Edited by Strgazr27 (01/23/09 07:13 PM)
dickbill
Reged: 09/30/08
[Re: bseltzer]
#2883679 - 01/23/09 07:24 PM
It sure would help to have an easy upgrade for the CGE.
But everybody keep saying that a CGE is not easily serviceable, as opposed to the G11.
There are at least two aftermarket possiblities to reduce PE, both around $500.
The tungsten disulfide treatment of the worm
and the Ovision worm set, both were shortly discussed on CN a while ago. I've read that changing the G11 worm for the Ovision worm is piece of cake and that after that, PE drops
drastically.
http://celestialwonders.com/equipment/OvisionVsLHPW.html
Edited by dickbill (01/23/09 07:28 PM)
bseltzer
Reged: 10/28/07
[Re: Strgazr27]
#2883922 - 01/23/09 09:34 PM
After spending a good deal of time on both the CGE and Losmandy Y! user groups, what I did buy was a G-11. Maybe I got a good one too, but based on many other G-11 users' input, I'd say it's about average. The PemPro measured PE of the box stock mount was +3.1"/-3.9" (or 7" P-V) with an RMS around 0.785. With the generated PEC uploaded to the mount, the P-V error shrank to +2.0/-1.7 (3.7" total P-V). Again, that's out of the box stock and very near the same price point as the CGE. At those levels, the OVision worm seems moot to me.
That's not to say the G-11 is without it's flaws. I'm less than crazy about the Gemini HC. It's no where near as convenient to use as EQMOD was with a wireless gamepad/joystick on my old Atlas. And I wish those outboard servo's and gear boxes were more neatly tucked in out of harm's way.
But where it really matters to me, the G-11 delivers.
In the best of all worlds, I could have both the clean design and the nice control system UI of the CGE and the performance of the G-11. Frankly, it wouldn't matter who marketed such a mount, if they sold it at the same price point, there'd be no doubt about it having a future, at least with me.
Regards, Bert
MichaelW
Reged: 06/03/06
[Re: Strgazr27]
#2884766 - 01/24/09 10:49 AM
I agree with this. Because my AP1200 was in a class all by itself but that too also had PEC correction software available. But I will add that with a tad more "effort" from Celestron the 3K mount could easily compare to a 5K mount. After all what is really done to improve PEC on a CGE when you send it off for upgrading.... A really good cleaning to remove burrs and loose chips add in a slight smoothing of edges then assemble with care paying attention to torques and add quality lubricants and you have easily removed half the PE in a factory mount of today.
I know someone stated a price reduction of $500 would be nice and that would be nice, but I would also pay the $500 for the improvement above. I guess this is why there are businesses out there to do just this.
MichaelW
Reged: 06/03/06
[Re: MichaelW]
#2886720 - 01/25/09 10:56 AM
A note to mention on the limit switches and the meridian flip issue. I sent an email to Celestron asking about some points mentioned here for an upgraded CGE and in the email I got, it was stated that the new hand controller upgrade software v4.15 allows the CGE and the CGE Pro to continue tracking to 20* past the meridian for both mounts.
They also indicated that the cables and Serial connection are still the same and gave no inclination of an upgraded communications package to upgrade or lengthen or move the cables and connections. Plus there was no indication of moving from serial communications to USB.
jrcrilly
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
[Re: MichaelW]
#2886782 - 01/25/09 11:23 AM
The writer may have been confused or may have expressed himself poorly. The meridian tracking limitation on the CGE is not a software feature - there's a mechanical stop. Software can have no effect on that.
MichaelW
Reged: 06/03/06
[Re: jrcrilly]
#2886798 - 01/25/09 11:28 AM
Thanks John and I agree the limit switches are a hardware stop. It would be *nice* if this was true and asked in the HC update thread for soemone to confirm. This would make my decision to stick with the CGE and not a CGE-Pro almost a no brainer for remote field use.
DrBuck
Reged: 12/10/08
Loc: Susanville, No. Calif.
[Re: MichaelW]
#2887132 - 01/25/09 01:49 PM Attachment (79 downloads)
I just received mine from Anacortes Telescope and I must say that I am very impressed with almost everything on this mount, (even though there was a bolt missing on the tripod leg) I was almost shocked at its size. Of all the other pictures I have seen, the size really wasn't that apparent. So I have taken a photo with a ruler balanced on the base. It should easily handle my new FS 152 Takahashi with the TV 85 piggybacked on top. The limit swith in RA works really well, stopping the declination motor housing from hitting the RA motor housing by about a millimeter. At that position, the Dec counterbalance shaft is 5 degrees past level (with the weights on the opposite , west side. However, I think that the hibernate function ceases if unplugged from the power source. Is that correct? thanks
Edited by DrBuck (01/25/09 01:53 PM)
jrcrilly
Reged: 04/30/03
Loc: NE Ohio
[Re: DrBuck]
#2887139 - 01/25/09 01:54 PM
No. The hibernate function works fine with no power applied to the mount.
DrBuck
Reged: 12/10/08
[Re: jrcrilly]
#2887170 - 01/25/09 02:18 PM
Hi John--------I set it up yesterday without a scope on it, set up a home position for it, and put it in hibernate mode. When it woke up, it thought it was yesterday 1-24-09 at 13.25.00 hrs, and when I asked it to go back to polaris, it was off by 15 degrees or so to the east.
jrcrilly
Reged: 04/30/03
Loc: NE Ohio
[Re: DrBuck]
#2887174 - 01/25/09 02:21 PM
You'll need to turn on the RTC (real time clock).
DrBuck
Reged: 12/10/08
[Re: jrcrilly]
#2887176 - 01/25/09 02:23 PM
OK---------I'll have to figure out how to do that--------
DrBuck
Reged: 12/10/08
[Re: DrBuck]
#2887194 - 01/25/09 02:35 PM
John-------your right-----the real time clock was off------
Alph
Reged: 11/23/06
Loc: Melmac
[Re: dickbill]
#2887865 - 01/25/09 08:34 PM
There are at least two aftermarket possiblities to reduce PE, both around $500. The tungsten disulfide treatment of the worm
Most of us never heard about it. Can you give us some pointers, links?
Mike28
Reged: 06/21/03
Loc: Morris County,NJ
[Re: rmollise]
#2888062 - 01/25/09 10:02 PM
Thanks.
I wasnt too keen on the CGE external cables either. They seem abit too short to my standards. But on the whole the CGE is a capable mount and handles my TOA150 with ease. I have the recent software but havent had any issues so far in my limited viewing during the past year. I do wish it had a polar alignment scope in it though....
MichaelW
Reged: 06/03/06
[Re: Alph]
#2888625 - 01/26/09 08:29 AM
http://www.arksky.org/supercharge.htm http://www.telescopestabilitysystems.com/default.htm http://lxd55.com/hypertune/
All 3 provide a hyper-tuning or supercharging service. I can not speak from experiance on any of these places and I don't know much more about them other than what I have read here. You should do your own research before jumping into any thing.
dickbill
Reged: 09/30/08
[Re: MichaelW]
#2888857 - 01/26/09 11:20 AM
Tungsten disulfide treatment:
http://www.andysshotglass.com/astromo_mod_store.html http://www.astro-motion.com/about.html
And a review about the ovision worm. For what I understand, it's justa worm made under higher tolerance precision: http://web.me.com/kenw8/Ovision/Ovision_NS_Kit.html The link to the ovision manufacturer is inside.
WadeH237
Reged: 02/24/07
Loc: Snohomish, WA
[Re: Alph]
#2891081 - 01/27/09 01:34 PM
This is not urban legend.
I have been following the CGE since the beginning. I bought an early CGE in 2003 and a second in 2006.
The early CGEs were showing PE of about 40 arc seconds, with a non-smooth curve that typically had a very steep section. I've seen data from lots of CGEs and all the early ones looked this way.
Somewhere around 2005, people started reporting a change in the PE magnitude and curve. Since that time, 20 arc seconds of PE with a very smooth curve is typical.
Both of my CGEs show PE behavior typical of when they were produced. I've collected PE data from them and posted Excel spreadsheets with the raw data and graphs. If you are a member of the Yahoo CGE Uncensored group, you can see the spreadsheets here.
I would like to point out that CGEs typically respond very well to autoguiding, even the older ones. The steep part of the slope in the PE curve on the older mounts is not so steep that it causes problems in this area.
If I were looking at a used CGE for imaging, I would (slightly) prefer one from 2006 or later - but I would definitely consider and older one in good condition. If you are considering a CGE for visual use, none of this PE stuff matters.
As long as I'm on the topic of buying a used CGE, one thing that you do want to look at is the hand controller version. The CGE originally shipped with a non-upgradable hand controller. New ones ship with a hand controller that has upgradable firmware. The newer firmware has radically improved goto performance over the older. I don't remember the dates when the switch over happened, but it is easy to tell the old from the new. If the firmware version is 3.x, it is an old hand controller. If the firmware version is 4.x, it is a newer one. Unlike the PE stuff above, this is more important to visual users than imagers. Imagers will typically run over a computer with NexRemote and skip the physical hand controller entirely. All versions of NexRemote can use both the old 3.x and newer 4.x firmware.
MikeML
Reged: 10/09/04
Loc: NJ
[Re: WadeH237]
#2891509 - 01/27/09 05:01 PM
Don't know, I can only go by the one I purchased in February 04. PE comes in about +- 7 arc seconds. I seem to remember a review by a Canadian Amateur magazine in which their sample had similar error. Without an actual survey I don't know if I was lucky or a few buyers were unlucky.
NukenGeek
Reged: 12/28/06
Loc: Richland, WA
[Re: Alph]
#2914261 - 02/07/09 09:43 PM
At least one vendor has announced the end of the CGE:
http://www.optcorp.com/product.aspx?pid=12577
watcher
Reged: 11/21/07
Loc: St. Louis, MO
[Re: NukenGeek]
#2921035 - 02/11/09 08:26 AM
If it is the end of the CGE, Celestron must have a replacement in the works. There's just too big a gap between 40 lb. and 100 lb. capacity. Losmandy would love the end of CGE!
Sundown6
Reged: 01/26/08
Loc: Palo Alto, Ca
[Re: watcher]
#2921197 - 02/11/09 10:18 AM
You'd hope with the gap in the price and capacity... maybe they are just tring to sell off the ones they have before they show off a new one that looks more like a cross between the CGEM and the PRO
NukenGeek
Reged: 12/28/06
Loc: Richland, WA
[Re: Sundown6]
#2921224 - 02/11/09 10:34 AM
Now I'm in a quandary. I've been debating whether to settle for a CGEM to meet my immediate needs for astrophotography; or go with a CGE which would provide the ultimate capability for a "portable" setup. (There's no kill like overkill.) I don't need the CGE right away, but if it's discontinued that leaves only the G-11 in that price/capacity range, and I like the design of the CGE much better. Do I grab one of the last CGEs or wait to see if Celestron will release a replacement? So far I haven't seen any evidence of a CGE successor.
MichaelW
Reged: 06/03/06
[Re: Sundown6]
#2921227 - 02/11/09 10:36 AM
I believe that the OPT statement is more than likely true.
BUT
Why would a company with people asking them directly, not provide honest and accurate information when people inquire about a product? I won't make a judgment call based upon not fully investigated information but I don't like what I have been told vs. what I am seeing and the company not owning up to it. Yes, products get to end of life and a new product comes out, all the time. So why not say so? Why not say, while supplies last as we are... a) making a newer replacement and the older one is discounted or b)this unit is being phased out and there will be no more so buy now.
On the other hand, I really hope......
That the CGE is being revised and will have some meridan control as well as a freaking USB port.
MichaelW
Reged: 06/03/06
[Re: MichaelW]
#2921235 - 02/11/09 10:38 AM
Maybe this explains why I was giving the information that the new software upgrade supports the meridian flip on the CGE??????
Ohh speculation....
Kolenka
Reged: 06/01/08
Loc: Seattle Area, WA, USA
[Re: NukenGeek]
#2921512 - 02/11/09 01:39 PM
Aye, that is a conundrum. I've been looking at a CGE as well for the past few months. I wound up buying a used one that had gotten supercharged. I figure that by saving 1/3rd of the retail price, I'm in good shape either way, as long as the mount itself keeps ticking.
I think Celestron will keep quiet about any CGE replacement until they are actually ready to start full-scale manufacturing (like with the CGEM and CGE Pro). That said, I would say that you won't be in /horrible/ shape with a CGE, seeing that Celestron will support it with parts/labor for at least another 2 years.
hapo
Reged: 03/06/05
Loc: Europe
[Re: Kolenka]
#2921705 - 02/11/09 03:21 PM
The CGE has an uncertain future. For the moment is out of production, but maybe Celestron guys will be smart enough to decide to continue it in this form or in an upgraded model because the CGE is the heaviest mount that can be setup by a single person, so it is both at the limit of portability and is a good mount for a permanent observatory. But manufacturing a new mount and mass producing it would last at least 1 year, so if you want one in the next months/year buy it now while you can.
Reged: 07/06/07
[Re: hapo]
#2922073 - 02/11/09 06:33 PM
I don't think most folks will have any trouble setting up the CGE Pro, though they have to break it down first to do it. I wouldn't be surprised to see Celestron revamp the CGE and move its manufacture to China. But, frankly, if I wanted a go-to mount in this class, the G11 Gemini is mucho similar. Only problem bein' you don't get the OTA - mount package price break you do with CGEs.
EJN
Reged: 11/01/05
Loc: Highway 61
[Re: Jeff55]
#2922085 - 02/11/09 06:42 PM
Just my opinion, but I find the CGE to be a very nice clean looking mount, where as the CGEM and CGE Pro are butt-ugly.
Strgazr27
Reged: 10/04/04
[Re: hapo]
#2922102 - 02/11/09 06:51 PM
The CGE IS NOT out of production. At least as of last Friday.
hapo
Reged: 03/06/05
Loc: Europe
[Re: Strgazr27]
#2922190 - 02/11/09 07:38 PM
My local dealer told me that the CGE mounts cannot be ordered anymore, and there are only some left in stock. So that means something happens at Celestron regarding availability and OPT announcement is true. That's all I know.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
[Re: hapo]
#2922259 - 02/11/09 08:14 PM
If the CGE Pro mount head could be split into two lighter parts the way astrophysics does some of their mounts. And if they would drop the price of the CGE Pro a thousand dollars, then would anyone really care if the CGE was gone?
Kolenka
Reged: 06/01/08
[Re: Lane]
#2922573 - 02/11/09 11:08 PM
Yes. As the CGE was barely affordable to blokes like me in the first place. :P
Lord Beowulf
Reged: 10/13/08
Loc: Cedar Park, TX
[Re: MichaelW]
#2922710 - 02/12/09 12:22 AM
Thats a pretty easy one, at least as far as if there's a replacement in the works. If they announced a replacement now (ala CGE-2 with CGEM/CGE-Pro style looks and features) then all of us would sit around waiting for it and no one would buy the remaining CGEs. If indeed there's a replacement waiting in the wings, then what's happening now makes perfect sense.
Now, what does NOT make sense would be for the CGE to go away completely with no replacement whatsoever. Even if parts were obsoleted such that they had no choice but to discountinue the mount, it's definitely too big of a gap to leave in their lineup.
Now, if there's NOT a replacement forthcoming and there isn't any problem manufacturing the CGE, then even if Celestron HAD intentions to discontinue it, it's hard to believe they wouldn't make more if there is actually a market for the mount such that profit can be made by selling it. That's the only thing that worries me about OPT's claims is that in this latter scenario, they could be trying to boost their sales while other vendors are waiting on Celestron to make some more. At least they haven't jacked up the price (yet)!
Beo
MichaelW
Reged: 06/03/06
[Re: Lord Beowulf]
#2923212 - 02/12/09 09:52 AM
Beo, After reading my comment I realize what I was saying and in no way do I really mean that they HAVE TO disclose anything. But I would think a spin doctor could make any announcement look good.
If they are indeed stopping/canceling/never again to produce a CGE then I (IMHO) would think a nice spin campaign indicating the end of CGE and this could drive sales.
The gray area is if they are replacing it. Still a good spin would be get in on the "old" CGE at a great price before the wait for the new CGE.
The problem would be if the new CGE is ready to market and addresses the things we all want to see in a new mount. Then any remaining CGE's would have to be cleared from the market as much as possible before announcing the new improved version. This is where hush is important but it is the hush that creates a opening for speculation.
I agree that if the CGE-Pro broke up as easily as the AP does then the CGE-Pro would have one of it's objections negated and probably moved over to a positive. This could help push the CGE-Pro into the void left behind a NO-CGE lineup.
But the real issue is, is it being totally canceled? I agree this is a HUGE hole. But maybe what we see as a hole isn't as much of a hole from a sales standpoint. Maybe C is seeing the should have been CGE sales going to say the Atlas and since they can not compete price wise with the Atlas they elect to let the Atlas have that niche. And C is doing this to remain as a viable company in todays volatile business market. I hope that is incorrect but if it was right, I would be rolling the change in the couch and car and calling to order my CGE, NOW.
Sundown6
Reged: 01/26/08
Loc: Palo Alto, Ca
[Re: MichaelW]
#2923246 - 02/12/09 10:19 AM
That can't be it CGEM and Atlas are about the same price CGE was about 2x that and CGE Pro is about 2x the price of the old CGE. there needs to be a new one to fill the gap.
Joel
Reged: 07/08/04
Loc: Merrimack, NH
[Re: EJN]
#2926816 - 02/14/09 07:05 AM
I was hoping I wasn't the only one who thought this. I'm looking for a "high end" mount maybe later this year and the CGE Pro looked interesting. I just think it looks too "busy" or more like a prototype but if it got good performance reviews I'd consider it.
Joel
Reged: 07/08/04
Loc: Merrimack, NH
[Re: Joel]
#2926820 - 02/14/09 07:08 AM
On the other hand, I was debating about going to NEAF this year but I just may go now to get a look at a CGE Pro in person. I wonder if someone will have one on the floor?
Reged: 07/06/07
[Re: Joel]
#2927053 - 02/14/09 10:22 AM
I'd guess Celestron will...
Jeff55
Reged: 04/14/05
Loc: Boston MA
[Re: rmollise]
#2927106 - 02/14/09 10:50 AM
Note that OPT has dropped price of CGE to $2680...it appears they're attempting to move mounts.
Sundown6
Reged: 01/26/08
Loc: Palo Alto, Ca
[Re: Jeff55]
#2927293 - 02/14/09 12:24 PM
You got to move the stock of the old model out before you get the new one in inless you are going to cut prices to the point where you take a loss for each you sell.
watcher
Reged: 11/21/07
Loc: St. Louis, MO
[Re: Sundown6]
#2927561 - 02/14/09 03:16 PM
I'd bet on a baby CGE-Pro for about the same price as the CGE. It's the only thing that makes sense. Canceling the Cge with no replacement would not be done quietly. They would have let it be known to allow their vendors to capitalize on a last run with premium prices.If a replacement is going to cost subtantially more, they would have let it be known also. With the amount of vendors out of stock, and OPT begining to discount the CGE, I think it won't be long before we see the new CGE.
Joe
coopfore1
Reged: 11/23/05
Loc: il
[Re: watcher]
#2927783 - 02/14/09 05:31 PM
Here is quote from opt right off their site....Question: I heard that Celestron discontinued the CGE series in January 2009. Is this true? OPT Answer: Yes, Celestron discontinued the CGE series in January 2009.
treaves
Reged: 01/27/09
Loc: Homerville Launch Facility
[Re: coopfore1]
#2927952 - 02/14/09 07:08 PM
Celestron has apparently reversed their decision. I spoke with a sales person on Friday, trying to get a good deal on a 'discontinued' product, and was informed they'd changed their position. I can't seem to find anything official though.
Strgazr27
Reged: 10/04/04
[Re: treaves]
#2928077 - 02/14/09 08:38 PM
As I posted a few days ago, the CGE is currently not being discontinued. There may have initially been plans but as of right now it's here to stay.
MichaelW
Reged: 06/03/06
[Re: Strgazr27]
#2928108 - 02/14/09 09:02 PM
<speculation hat on> How unfortunate. I'd be all over a baby CGE-Pro with updated interfaces. So if this is correct then we will have a gap in availability for while as it seemed C had planned to discontinue the CGE but it seems without a replacement. So there will be the time lost while not making any new ones before they make any more new ones. Because if they had planned on a replacement then one would assume some tooling etc had already been completed on the new CGE and was near production. Otherwise why plan on a year without a mount to cover the hole left without the CGE. If they can decide just like that, then there was no replacement coming down the pike and there would have been a huge hole in the C lineup. <speculation hat off>
Now I am confused as to what to do. Maybe it is best to not do anything at this point. I like the new CGE-Pro if is as advertised but like the CGE for cost and transportability. A baby CGE-Pro would have been a shoe in for sure.
FWIW Bobby, I hope you are wrong.
Strgazr27
Reged: 10/04/04
[Re: MichaelW]
#2928371 - 02/14/09 11:56 PM
I cannot see a "Baby" CGE-Pro staying at the price point of a standard CGE unless something was cut. I honestly don't know what could be updated on the CGE without it increasing the cost, even slightly. Improved Alt/Az adjustments? improved clutch lock knobs? Perhaps going with a DIN style or twist lock cable setup but in reality there is really not anything mechanically that could be changed or improved upon with raising the cost IMO. To run the wires internally, improving PE out of the box or getting rid of the electronics pier would all involve a fairly significant redesign or require hardware that would have to increase the price. The CGE is a solid, dependable mount that is hard to beat at it's price point.
I would like to see what would happen if Scott L. got off his butt and either redid the gemini system or offered a completetly new GoTo solution for the G11. If that were to happen I think that the ease of working on a G11 coupled with a GoTo system that isn't based in 1985 would kill the sales of CGE's and perhaps force an update. Celestron added the CGEM and the CGE-Pro in order to offer the public a complete line of mount capacities and features from the CG5 up to the Pro. They now offer a topped off line up of quality mounts in almost any payload range one could want.
FWIW, I kinda hope they keep the CGE the way it is.......Solid, dependable and affordable.
chboss
Reged: 03/24/08
Loc: Tokyo Japan
[Re: Strgazr27]
#2928610 - 02/15/09 05:31 AM
The Opt offer for a CGE is certainly tempting. Bad thing I have just upgraded my mount.  Good for all those that are in the market for a larger mount.
regards Chris
Lord Beowulf
Reged: 10/13/08
Loc: Cedar Park, TX
[Re: chboss]
#2928724 - 02/15/09 08:30 AM
Note that the OPT offer isn't quite as good as it sounds, as they're now charging shipping, which adds $120 back to the cost. It's basically $200 off at this point.
Beo
Alph
Reged: 11/23/06
Loc: Melmac
[Re: Strgazr27]
#2930103 - 02/15/09 10:13 PM
The Gemini controller is much more advanced than the Nexstar controller and maybe that's where the problem lies. Most folks are not that computer savvy to learn how to use it.
Strgazr27
Reged: 10/04/04
[Re: Alph]
#2930480 - 02/16/09 06:47 AM
The Gemini uses an archaic step menu controller that looks like a video game from the 80's But your right it is a pretty powerful tool. All the more reason Scott needs to update the system so that all that power can be put to use. Between the MI-250 and now my current G11 I have it down but your correct, Gemini is a great tool.
MichaelW
Reged: 06/03/06
[Re: Strgazr27]
#2930883 - 02/16/09 11:48 AM
Ok, that is just silly, Bobby. I don't think anyone was suggesting they make the mount not solid or not dependable or not affordable. I would submit that, that is suggested without saying and why the discussion was around a gap in the line up.
I enjoyed my CGE and was very pleased with it. I am in a position to be shopping for a new mount as should be apparent from my comments. The CGE is a front runner, even in it's current form, after a trip to the Doctor. The CGE-Pro is a contender for the imaging points. A new and improved CGE with everything the same but with USB and some meridian control would be a no-brainer for me. And to clarify, Would I pay $500 more for better out of box PEC and smoother operation and a no tools setup. Yes.
Kolenka
Reged: 06/01/08
[Re: Alph]
#2931159 - 02/16/09 02:13 PM
I'd consider myself plenty tech savvy, considering computer code I write puts food on the table. But, as much of a geek that I am, I don't want to fight a controller while under the stars that much. The NexStar and Autostar II handboxes provide very nice touches that the Gemini can't do with its handbox design (shortcuts to common catalogs, and quick number entry for example) which make finding and slewing to targets quick and easy.
Strgazr27
Reged: 10/04/04
[Re: MichaelW]
#2931909 - 02/16/09 09:13 PM
Michael,
I didn't say anybody was My point was, sometimes some of the good points about the CGE are lost or sacrificed when a mount is updated to include bells and whistles. KISS is still one of the best concepts going
As far as USB I would ask "For What?" Certainly not motor cables. You also loose the locking ability of RJ connectors not to mention having to use expensive USB repeaters to go over 12' if your looking to control the mount remotely.
I agree that having to fumble with an allen key in the dark to do polar alignment adjustments is a dumb engineering thought but it also offers a solid method. I can adjust the AZ or ALT with a CGE fully loaded using an allen wrench, something that just wasn't possible with my EQ6 and it's "tool less" knobs.
As for the meridian control........If a Paramount ME has to do a flip
Adding $500 to the cost of a CGE would only put it further out of reach. The CGE sits at a price point where a lot of people will go one step further up the ladder to get the improved performance of a higher priced mount, especially if buying used. A used MI-250 with GoTo or a TAK NJP can be had for around $5000 and both will walk all over a CGE from a performance and build quality standpoint. This brings up a good point though. If celestron took a little bit of time and did a rigorous QC on every CGE manufactured that included properly setting up worm mesh you'd see a big improvement in performance at a minimal cost. Improving PE by upgrading gears etc. can add significantly to the price. Quality gears cost money, even when purchased in quantity.
The best thing Celestron could do is drop the price of the Pro to $4000 for a mount only package. At that point I don't think they could build them fast enough
CS
CounterWeight
Reged: 10/05/08
Loc: Cloudyopolis, OR.
[Re: Strgazr27]
#2932271 - 02/17/09 12:44 AM
Bobby - laptops and desktops for that matter stopped shipping with serial and ports some time ago - we all know this. You ask USB 'for what' - I assume you are kidding here...
ummmm how about all your other computer periphs - you do use USB? I am not saying it is a requirement for data throughput to the mount, but really, I ask 'serial - what for?'
Just curious as you must purchase something extra to get any 'modern' computer to talk to these mounts... not as if it would be a brain breaker to have included it (USB -even slow USB) in design cycle, at least for computer connection... And of course it is not included and last I looked was abs ridiculous expensive to buy the dongle from Chinestron... (thankfully others have this for sale far cheaper with Vista drivers) and then there's the Vista issue with the drivers... this isn't a MS issue or a computer manufacturer issue, it is a mount manufacturer issue.
Kolenka
Reged: 06/01/08
[Re: CounterWeight]
#2932320 - 02/17/09 01:26 AM
There is a downside to making it USB: Proprietary drivers.
Right now, I've got the option of getting a Linux/Mac friendly serial adaptor and using that to talk to the CGE. If they built a USB port into the electronics pier, a couple things happen.
1) They need to go with a more expensive chipset which would raise the cost a bit. This probably isn't that big a deal. 2) You introduce driver issues as either the mount vendor now has to write them, or they pick a single serial device chipset which may or may not have driver support at the right time.
Right now, there /is/ an advantage to using serial, despite the age. It is simple, and avoids going down the rabbit hole of operating system dependence.
CounterWeight
Reged: 10/05/08
[Re: Kolenka]
#2932349 - 02/17/09 01:57 AM
I could not disagree more, but that's just me.
The fact I need to buy a dongle and contend with even more esoteric driver issues I find ridiculous and really cannot think of a parallel in any of my other interests. That NO computer I can buy will work 'out of the box'...
We are talking ZERO. I think if every other manufacturer of every other gadget available even very inexpensive ~$15 can do it - mount manufacturers at several thousand $$ per pop could pull it off.
We need to stop making excuses for them. Interesting that we require so much of all our software and gadget providers and yet when it comes to this hobby - we just make excuses for them. I suppose it could be even more ridiculous... thank goodness it doesn't use two cans and a string
pull harder I'm having trouble getting M42
Charlie Hein
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
[Re: Kolenka]
#2932493 - 02/17/09 07:35 AM
One way to beat that is to carry a small laptop or PDA with your favorite planetarium software loaded on it and drive the scope from the laptop or PDA. That would give you "point and click" slewing to your target. It doesn't get any easier than that.
Once I caught on to how the Gemini system actually works I honestly haven't found the menu structure getting in the way of finding targets at all. Admittedly, for a casual visual observer who only brings a telescope and mount out into the field it would be nice to have a section of the menu that references the common names of non-stellar objects so that those folks could find things easier.
However, after having worked with the Gemini now since November of last year, I really don't think that the system was ever designed with that kind of user in mind at all - and that's perfectly okay by me. It is designed very well indeed for the way I use it.
I use the G-11 primarily as an imaging platform. I always have at least one computer with me out in the field, even when I'm not imaging. My choices for targets are generally planned out well in advance, so I almost always know the designations of the objects I want to look at before I even get outside. Once you know the menus and also your destinations, getting there is a snap.
It's not often mentioned, but one advantage the "80's video game" design brings is that the Gemini handbox is about as tough as it can be - I think that it would be very hard to damage it in the field even dropping it onto concrete or pavement from a reasonable height. I believe this because I've done it more than once. That handbox is way tougher than my old SynScan handbox or any Meade or Celestron for that matter.
But I'm way off topic now - this thread is actually about the CGE. I came very close to buying the CGE when choosing the next step up from my Atlas mount. There's a lot of things to like about it.
I thought that the rumors about the CGE being discontinued were just myth. Is there official confirmation of this?
Charlie
Kolenka
Reged: 06/01/08
[Re: CounterWeight]
#2932935 - 02/17/09 12:35 PM
Not that I disagree that it is absurd that they haven't done it... but as a non-Windows user, I am also kinda glad. How much support does the Linux/Mac guy get from the mount vendors? ZERO. I'm actually surprised the Argo Navis actually even has Mac instructions, despite being a serial port device too.
Right now, I know I can connect up to a mount that uses a serial port connection and control it via a third-party app (or write my own if I have to). The moment they switch to a proprietary USB protocol, or proprietary internal USB->Serial chipset, I'm screwed. Because now I am suddenly beholden to Celestron/Meade/etc for drivers to run the bloody thing.
There is no USB standard for serial devices, or for mounts, and ASCOM isn't gonna come to the rescue here. You will have a wonderful soup of drivers for years until they sort it out, and expect bugs that currently aren't as big of a problem. If Meade can't get Vista drivers sorted out for the LPI in a timely manner, etc... why should I trust them to get it right consistently for mounts?
This isn't about me making excuses for them, it is about making sure I don't get lost in the shuffle as a 'second-class consumer' for functionality that works for me today, but may not tomorrow if they go USB.
If they went USB, I'd demand that the USB protocol they use be open and free so we aren't beholden to their drivers, and can support the mounts in 3rd party apps as we see fit. Otherwise, I'm gonna have to go right back to running the mount via a Handbox and not via my laptop.
Chris Rowland
Reged: 02/28/05
[Re: Kolenka]
#2933219 - 02/17/09 03:06 PM
I'd rather ask why the computer manufacturers fail to put serial ports on laptops. It isn't difficult.
As a developer of the ASCOM driver I find supporting USB a nightmare. Some USB drivers don't work, some only work with some operating systems, some will work with one application and not another. Serial ports - and PCMCIA adaptors - just work.
Would fitting a USB port into the HC help? Maybe but there will be a number of challenges. Drivers will be more difficult to write. I've used USB and anything more complex than emulating a serial port gets complex and needs much more support from the HC developer. The HC software will be more complex; USB needs more setup and software in the HC. The developer might be doing this instead of something else, sync or precise goto maybe. When the HC was designed USB was a lot less pervasive than it is now. Th drivers in the HC and supplied would need updating as new operating system versions come along. This isn't trivial. Celestron aren't a software company, I think we'd all rather they concentrated on providing good, bug free, scope firmware.
Personally, if we move away from Serial, I'd go for Ethernet. It's a little more expensive in hardware and support software but you would potentially have a scope that could be controlled from a browser.
Chris
MichaelW
Reged: 06/03/06
[Re: Chris Rowland]
#2933547 - 02/17/09 05:37 PM
5v VS. 12V. Green vs. Non-Green. Many laptops don't have the reserve to last powering 12v to a device.
I hear what you are saying Chris but from a end user standpoint, what you are saying is greek and borders on gibberish to the casual user. (Not dissing what you said by the way).
I know about the USB issues and Serial is so clean to talk to but until a replacement comes about I would think the hardware guys will have to support the interfaces that are being sold, in the millions. Particularly when the serial, despite its simple beauty, isn't being supported by the computer assemblers. Quite frankly I'd like to see the basic parallel come back or HP-IB or some other always worked system.
As a side note, I think serial died because of the OS and not the hardware. Windoze likes to "own" everything and serial ports don't work well being owned and turned on and off whenever.
So I guess I agree with you but what is the answer? Maybe having the mount mfg's provide a serial/USB cable as part of their package and provide their own set of drivers based upon the mount requirements.
Ahh what do I know?
Kolenka
Reged: 06/01/08
[Re: MichaelW]
#2933610 - 02/17/09 06:04 PM
I don't think anyone has brought up any bad points on the Serial vs USB argument here (ignoring the earlier argument that someone debating against USB is an 'apologist').
It isn't an easy problem. No matter what solution you pick, you introduce problems for some segment of your market. Right now, keeping the status quo requires no effort on their part, and it isn't like people are locked out from communicating with the scope (although you do need a dongle).
Go USB, and you risk locking out customers in a low-volume market. Include a serial dongle, and you risk wasting your money on parts people may not even want or need (granted, not enough to matter in a lot of cases). Go ethernet, and suddenly your code gets even more complex to handle TCP/IP (and maybe even forced to run some flavor of Linux/etc on it). USB does have one huge advantage over ethernet as a connection: core USB support is getting built into a lot of embedded CPUs these days.
My only real complaint with USB is that unless third parties work with the vendors on an open protocol, and hold the vendors to it, we will just get a mess out the other end.
Strgazr27
Reged: 10/04/04
[Re: CounterWeight]
#2934086 - 02/17/09 10:08 PM
One should never assume. No I am not kidding actually. I am curious though as I just built 2 machines and both MB's had serial ports on them. One can also buy, very cheaply, a serial add on card.
Yes I do use USB for all my COMPUTER peripherals but the last time I looked my mount wasn't considered a desktop peripheral Why serial you ask? Maybe it's the ease of programming for it. Not needing a driver for it. Unequaled compatibility. Not hampered by 12' cables and the need for expensive repeater cables.
I'm sorry you feel so upset about the situation. I'm sorry to tell you though that your Vista issues ARE MS issues. Have you wondered why MS is starting to act like Vista is the "Red headed step child"? Why serial you may ask? Well you just answered that question yourself with your above rant. I've never heard of a "Driver" issue with serial ports or OS compatibilty issues with it either.
As far as the "dongles" go I assume you mean a serial to USB cable? I paid $9 for mine and it worked fine. Than again, I satyed away from the "Kool Aid" and never went to Vista. XPPro works perfectly fine for me.
Lord Beowulf
Reged: 10/13/08
Loc: Cedar Park, TX
[Re: Chris Rowland]
#2934130 - 02/17/09 10:33 PM
Hah! I was considering dropping my  on this yesterday, but held off. Ethernet (i.e. 10/100-base-T) is certainly a great way to go. Sockets are pretty easy to program on any OS these days, and little net modules aren't all that expensive (though typically more than the cost of a USB to serial adapter, on whichever side of the cable you choose). At any rate, it would definitely resolve some of the concerns related to USB drivers, although it might require a bit more savvy for those connecting to it, especially if they have to switch between that and a normal network connection. Still, longer cable lengths, locking cords, etc. would address a number of the other complaints mentioned as well. Of course once you take that step, why not just embed Wi-Fi?!!
Beo
MichaelW
Reged: 06/03/06
[Re: MichaelW]
#2947116 - 02/24/09 02:32 PM
I sent an email to Celestron to get a straight answer about the future of the CGE.
I got this email:
The CGE is still offered. It will likely be discontinued, as the CGE Pro has succeeded it.
Since it has been succeeded, it's a good year to pick up the CGE. I've heard of them bieng sold for less than 2500.
We will support the mount for years after it is discontinued.
Clear skies, Name removed Celestron Technical Support
There it is direct from Celestron. The CGE does not have a extended future in Celstron's lineup. So a great time to get some great prices on the CGE and C will continue to support it.
So the speculation is over and there will not be a change to the CGE to update the mount.
Kolenka
Reged: 06/01/08
[Re: Strgazr27]
#2947361 - 02/24/09 04:26 PM
I've got two dongles that work fine in Vista and Win7. One won't work with the CGE for upgrades, or for the programming cable, but that is the dongle's fault. Both work great on the Mac via Starry Night to control the CGE as well.
As for the topic...
While I am sad that this means the G11 is now alone in its class, I've been very pleased with the CGE so far. The one I got will probably be kept around until it dies.
DaveJ
Reged: 01/07/05
Loc: NE Ohio
[Re: MichaelW]
#2947506 - 02/24/09 06:24 PM
I got this email:
The CGE is still offered. It will likely be discontinued, as the CGE Pro has succeeded it. Since it has been succeeded, it's a good year to pick up the CGE. I've heard of them bieng sold for less than 2500. We will support the mount for years after it is discontinued. Clear skies, Name removed Celestron Technical Support
Actually, that isn't an answer at all! With the qualifying words, "...will likely be discontinued..." the person that answered the question has provided ample wiggle-room so that anything that happens is covered. Now, if they'd said "...is definitely discontinued..." then you'd have a definite answer. But they didn't say that. We're right back to where we were, in my opinion.
Astronomics
Vendor if you must, AKA The Mighty Kong.
Reged: 06/07/04
Loc: Right Here
[Re: DaveJ]
#2947625 - 02/24/09 07:14 PM
The CGE is still in production and should be for quite some time. Celestron originally got rid of it, then thought better when they looked at the gaping hole they created in their lineup. I would suspect they will give the CGE a year and look at sales to see if it is worth keeping around. I for one hope the answer is yes.
Bowmoreman
Clear enough skies
Reged: 09/11/06
Loc: Bolton, MA
[Re: Astronomics]
#2948418 - 02/25/09 07:26 AM
The way this seems to be playing out pretty much ensures that those of us WITH CGE's will actually have our "investment" maintain more value this way; especially so if the "hole" in the line does formally come to pass...
If/when they finally do replace it, it will almost certainly be at/above the $3K mark, pretty much ensuring that used CGEs in good condition should stay around $2-2.2K... - where there's nothing else that can compete IMO...
I'm ok and reconciled either way... until I get my AP900 or 1200...
clear enough skies
Jeff55
Reged: 04/14/05
Loc: Boston MA
Re: Does CGE Have A Future?
[Re: DaveJ]
#2948594 - 02/25/09 09:48 AM
OK I'll bite...so where can you buy a CGE for less than $2500.
CounterWeight
Reged: 10/05/08
[Re: Jeff55]
#2948661 - 02/25/09 10:29 AM
They are starting to go 'used' here and elsewhere for less than $2.5k. Dealer prices are pretty varied, lowest I've seen is ~$2.7k for new and near new (demo's)
Arbacia
Reged: 04/18/07
Loc: Madrid, Spain
[Re: CounterWeight]
#2948867 - 02/25/09 12:12 PM
Respect to the conection of the serial cable to a Laptop, a friend is using a USB-TTL cable. I will try it soon
Data sheet 1 (PDF) data sheet 2 (PDF)
other link
t.r.
Reged: 02/14/08
Loc: Upstate NY
[Re: CounterWeight]
#2948878 - 02/25/09 12:19 PM
Something is definately going on, several dealers are now advertising a lower price for "demo" units @ $2680 and they have "several" demos each...the push to sell is on...why now?
Edited by t.r. (02/25/09 12:21 PM)
