Pages: 1 | 2 | 3 | (show all)
idahoman
Reged: 11/25/05
Loc: Idaho, USA
Autoguided PE -- how good is good?
      #2968521 - 03/06/09 08:36 PM Attachment (69 downloads)
I have a Celestron 9.25 Nexstar GPS mounted on a wedge. I image at f6.1 and so my scale is 1.06"/pixel (so, roughly 1 to 1). I use an AO-8 with a ST2000XCM. I have been thinking about deforking and going with a GEM like a CGE. But, I question whether I'll see any improvement. Using Maxim and the AO-8, binning my guider 2x2, my guiding errors are typically 0.4 pixel rms or less as reported by Maxim. Occasionally, I might get a 0.6 rms. I must rely upon the digital display of guide error since Maxim will not graph guide errors when using an AO-8. Anyway, it doesn't matter how long the sub exposure -- 5 min, 10 min, etc. But, I wonder if my stars could be made smaller by better guiding. I've attached an example image.
Some people tell me "Get a GEM". Others tell me that I won't improve over that. I sure don't want to redo my pier to mount a GEM just to match what I am already getting. Plus, there's the issue of meridian flip.
Any advice or comments would sure help me make my decision.
Thanks.
Edited by idahoman (03/06/09 09:10 PM)
LLEEGE
True Blue
Reged: 03/03/05
Loc: Cloud-chester,NY
Re: Autoguided PE -- how good is good? new [Re: idahoman]
      #2968587 - 03/06/09 09:16 PM
I don't think you will improve much over that.
Jared
Reged: 10/11/05
      #2968695 - 03/06/09 10:22 PM
You might get a little improvement. If you are binning 2x2, then your 0.4 pixels is approximately 0.8 arc seconds RMS, yes?
When imaging with my 1800mm fl scope on a very good GEM (Mach1 GTO), I typically see RMS guide errors around 0.3 to 0.4 arc seconds on a night of good seeing. That is a bit better than you are reporting, but it could just be that I have better average seeing conditions than you.
What is the typical FWHM (in arc seconds) you are getting on non-saturated stars? If it is seeing limited, then you are not going to see an improvement in results with a GEM.
idahoman
Reged: 11/25/05
Loc: Idaho, USA
Re: Autoguided PE -- how good is good? new [Re: Jared]
      #2968790 - 03/06/09 11:21 PM
Thanks for the replies. From memory (I'm still figuring all this stuff out -- ha, ha) I think my FWHM's are about 4 to 5 arcseconds. What does that mean? Is that an indication of seing?
idahoman
Reged: 11/25/05
Loc: Idaho, USA
      #2968793 - 03/06/09 11:22 PM
Oh, concerning your question about binning and guiding rms -- I would like to know the answer to that as well. That's why I mentioned that I am binning 2x2.
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
      #2968828 - 03/06/09 11:50 PM
Seeing, guiding and anything else that affects the image, like the as/pixel of your system and focus.
Since the guiding error is measured by your guider camera is may have a different scale than your main camera.
Like the others, I think your guiding errors are pretty good.
I just checked a bunch of images I took early this week using CCDInspector. They average FWHM of 3 and I image at .98 as/pixel. I would estimate my guiding error RMS is in excess of .4 most nights. And my guide camera is running at about 1.8 as/pixel through my OAG.
Miguel Lopes
Reged: 01/04/07
Loc: Portugal
Re: Autoguided PE -- how good is good? new [Re: Jaxdialation]
      #2969109 - 03/07/09 06:48 AM
Overall, IMO, you will not see an improvement, as you are already using an AO. An AO is allways faster correcting errors than any GEM. The real question is: is the poor CPC RA motor generating more errors than the AO can handle at your guide rate?
What refresh rate are you getting? An easy way to improve guide error is to guide faster. Guiding with AO should be done over 2Hz, ideally over 5Hz.
Of course that requires a bright guide star...
Also, how are you focusing? I bought a Moonlite focuser with a stepper motor for my C9.25 and it improved my focus a lot.
Edited by Miguel Lopes (03/07/09 06:53 AM)
idahoman
Reged: 11/25/05
Loc: Idaho, USA
Re: Autoguided PE -- how good is good? new [Re: Miguel Lopes]
      #2969293 - 03/07/09 09:54 AM
I am guiding at from 2 Hz to 0.5 Hz, depending upon how bright the guide star is. At my focal length, guide stars can cometimes be few and far between.
I am focusing using a Robofocus unit and the builtin focusing algorithm in Maxim. I could use FocusMax, but haven't.
My best guiding has been at the fastest refreshrate. But, I can't always achieve that.
Thanks.
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
      #2969436 - 03/07/09 11:11 AM
Maybe Focusmax can get you a touch better results. The newest version has an enhancement which takes multiple exposures at each point in the V curve.
In my opinion you are a pretty capable imager. Can't blame you at all for wanting to squeeze all the performance you can out of your system.
Have you used CCDInspector to measure your images "in mass" ? It allows you to graph your image FWHM vs several variables like time of night, position of the object, filter etc. perhaps using the trial version on a batch of images would point out a trend you could make some conclusions about.
idahoman
Reged: 11/25/05
Loc: Idaho, USA
      #2969580 - 03/07/09 12:14 PM
Thanks, John. I've been wanting to shift over to Focusmax. In general, people seem to think it does a better job than Maxim.
Other people have assessed my images with CCDInspector. I don't have a copy. They've basically checked my curvature and collimation, both of which seem to be pretty good. I was concerned because I have a bit more backfocus than ideal (fr 6.1 versus 6.3).
Miguel Lopes
Reged: 01/04/07
Loc: Portugal
      #2969792 - 03/07/09 02:10 PM
Thanks.
2Hz seems too low. Don't settle for the first stars that come up on the guide CCD. Plan your imaging session so you can find the best guide star for each target.
Anything equal or brighter than mag 11 should give you more than 2Hz in your C9.25.
<2Hz means you are using some +400ms for each exposure. That is way too much. I've nailed a mag 9 mag star with 40ms. A rule of thumb is to multiply that time by 2.5 for each increase in magnitude.
That would give 250ms of exposure for a mag 11 star, which would yeld >3Hz.
Make an experiment. Pick a target close to a bright star, maybe mag 5-6. Use several different exposures for the guide star and look at the guide error.
Jared
Reged: 10/11/05
      #2969809 - 03/07/09 02:18 PM
As it happens, the camera in question has the same pitch for both the main chip and the guide chip.
Jared
Reged: 10/11/05
      #2969826 - 03/07/09 02:27 PM
Thanks.
You mentioned FWHM in the 4-5 range. Obviously, I don't know anything about your seeing conditions, but I suspect that your scope is capable of a bit better than that (though you're not off by much).
The real advantage you will get if you decide to switch to a GEM is not needing to find a bright, nearby guide star. Since you won't be trying to take 0.5s exposures for your AO unit, you will be able to get similar (or even slightly better) results with ordinary guiding.
Personally, it seems to me the rig you are currently using is working pretty well. I wouldn't mess with it unless I was willing to jump to something significantly more expensive--like an AP-900 class mount (or perhaps the newly announced CGE-Pro). If you don't have that kind of budget, then I would just follow Miguel's advice and be careful to plan out your imaging sessions so that you know where the brightest potential guide star is located. If you can get up to 3-4 Hz you will probably see results that are about as good as your scope is capable of.
idahoman
Reged: 11/25/05
Loc: Idaho, USA
      #2970251 - 03/07/09 06:06 PM
Thanks, everyone. What I'm hearing is:
1.) Up my AO-8 guide rate by using better guide stars
2.) Fine tune my focusing
3.) Keep what I got until Jared gives me his Mach1 GOTO. Ha, ha.
All sounds like good advice. Is anyone trying to do what I am doing with a fork and AO unit? I'd be curious how well they guide as a comparison.
Miguel Lopes
Reged: 01/04/07
Loc: Portugal
      #2970265 - 03/07/09 06:22 PM
A fork with a wedge is +/- the same as a GEM. High-end observatories work like that. The issue is that most cheap fork mounts are not created for AP, so the RA motor and gears are not the best...
But one of the main reasons to buy an AO unit is to avoid buying a Paramount-like mount! So your ideia to ditch the fork to buy a GEM...
idahoman
Reged: 11/25/05
Loc: Idaho, USA
      #2970874 - 03/08/09 12:42 AM
Miguel -- I take it you think I should keep my setup? The AO is definitely a miracle for fork-mount-imaging.
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
      #2970980 - 03/08/09 03:43 AM
Luke has an AP900GTO that he is trying to give away I heard.
Miguel Lopes
Reged: 01/04/07
Loc: Portugal
      #2971864 - 03/08/09 03:36 PM
Ask JPM! He has made amazing images with a fork-wedge 12" scope:
http://astroanarchy.blogspot.com/
DeanS
Reged: 07/12/05
Loc: Central Kentucky
      #2972287 - 03/08/09 06:53 PM
I think you are getting very good results, however a good quality GEM will amaze you at how much easier it can be overall. Plus you will have the option of mounting different OTA's.
I struggled with forks a long time, of course without AO's, and don't see myself ever going back. Only downside is the flip, which is not too big of a deal.
Jared
Reged: 10/11/05
      #2972913 - 03/09/09 12:12 AM
Sorry, I still owe my wife two to three hundred favors before the Mach1 is fully paid off.
By the way, while I have never tried imaging with a fork mount (or at least not recently), I used to use an AO-7 with a Losmandy GM-8 that had periodic errors that were too fast to be guided out very well. In practice, I never got quite as much resolution with the AO-7 and mediocre mount/tracking as I have been able to get with the Mach1. It certainly came pretty close, though... And it was dramatically less expensive.
As one or two others have said, I think the real advantage to the high end mounts is not that you will necessarily get better results, but that you will get them with less effort. With the Losmandy and AO-7 (admittedly loaded to 25 pounds) I would need to make sure worm was adjusted perfectly, balance was perfect (a few ounces East heavy), backlash set correctly, guide star was bright enough for a high sampling rate... With the better mount I can skip all that. Is the balance vaguely correct? Cool. Just turn on the autoguider, and I can be assured that I am limited only by seeing.
freestar8n
Reged: 10/12/07
      #2973741 - 03/09/09 01:34 PM
Hi-
For guiding quality the fwhm of raw frames of decent length - say 5-20 minutes - is a key thing to go by. It is affected by seeing, focus, guiding, and pixel scale to some extent.
If seeing is decent and guiding is good, I think fwhm's should be down around 2.5". If you have AO and a brightish guidestar, it should go to 2.0" and below.
I don't know of a fundamental difference between GEM and fork - I would think it mainly depends on the quality of the bearings and gears.
I am in the northeast U.S. not known for great seeing, and I guide a CGE and C11 to get regularly 2.5" and below fwhm - sometimes even to 1.5" - and that is without AO.
Examples are at:
MetaGuide C11 CGE images
Another thing is - guiding errors can be misleading and much smaller than the true error seen at the imaging camera. So fwhm's always tell the full story.
I think you should be able to get smaller fwhm's with AO, especially on a night of good seeing. But if seeing is really bad - maybe it is a fundamental limit for you. Even then - watch for nights of steady air.
Frank
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
Re: Autoguided PE -- how good is good? new [Re: freestar8n]
      #2975516 - 03/10/09 10:52 AM
I think there are too many variables, which are unknown to give 2" as an expected outcome.
freestar8n
Reged: 10/12/07
      #2975690 - 03/10/09 12:48 PM
One thing to look at is if someone nearby with an AP1200 is getting below 2" fwhm, then seeing isn't a fundamental limit. And a medium grade mount plus AO with a bright guidestar should make the mount less of an issue if things are tuned right.
I guess another question is, what are the fwhm's without AO? If they are also around 4", then the AO may not be operating correctly.
A basic thing is just to make sure it is well focused in the first place. What are the fwhm's in a 0.5 second exposure of brightish stars without AO?
Frank
TxStars
Reged: 10/01/05
Loc: Lost In Space
      #2979359 - 03/12/09 10:11 AM
The problem is not your mount, it is the scope.
If you want smaller stars get a Refractor...
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
Re: Autoguided PE -- how good is good? new [Re: TxStars]
      #2979377 - 03/12/09 10:27 AM
All the guys with RCOSs would probably take exception to your recommendation.
Which refractor would you suggest to replace a 9.25" at f6? Would it drop right into his existing fork mount?
I don't know that there is a "problem".
Miguel Lopes
Reged: 01/04/07
Loc: Portugal
      #2979648 - 03/12/09 01:08 PM
The problem is not your mout, it is the scope.
This guy (spoiler: great images!) might disagree with you:
http://blog.deepskycolors.com/gear.html
Also a SCT is very good for photometric stuff.
TxStars
Reged: 10/01/05
Loc: Lost In Space
      #2982007 - 03/13/09 05:08 PM
This is what I was looking at...
OP " I wonder if my stars could be made smaller by better guiding?"
1)Find a mountain top and still dry air
2)Faster f/ ratio scope
3)___________
Fill in the blank..
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
      #2982591 - 03/13/09 11:26 PM
So, after repeating his question, you didn't answer it?
Strgazr27
Reged: 10/04/04
Loc: StonyHill Observatory
      #2982695 - 03/14/09 12:16 AM
3)___________
Fill in the blank..
1. Some of the best seeing in the US is 3' Above sea level and about 20 yds from the gulf of Mexico
2. Although this will allow for shorter exposures it does NOT guarantee smaller stars
3. Hmmm.....Some of the best images I have seen taken have come from mirror based systems so there are several choices I could use to fill in #3.
I don't see how this helps the OP.
idahoman
Reged: 11/25/05
Loc: Idaho, USA
Re: Autoguided PE -- how good is good? new [Re: Strgazr27]
      #2986832 - 03/16/09 11:07 AM
Thanks for all the really good input. One thing about my setup is that I am imaging at something like 1600mm focal length. Which is more demanding and will lead to "bigger" stars than imaging at, for instance, 800mm. Nonetheless, I've considered swapping the 9.25 out and mounting one of those new, cheap, RCs in the forks instead. But, I am not convinced if I will see a noticeable improvement since the focal length will be about the same.
I think where I am at is:
1.) I may be able to slightly improve my focusing
2.) Up my AO-8 guide rate by using better guide stars (if I can find them!)
3.) Wait until Jared sends me his Mach1 (I haven't given up on this one, yet)
4.) Live with what I've got until I can make a significant upgrade (not certain this can happen).
This upgrade would have to be more than just a CGE or Losmandy mount. My guess would be that I would have to consider an AP mount and possibly different optics as well.
The worse thing I could have done, at this point, is shell out $3K for a CGE or Losmandy, modify my pier, defork my C9.25, debug the new system, and have no noticeable difference other than meridian flips to deal with.
I've learned a lot. But, as with everything else in this hobby, it is a frustrating learning process.
Maybe a new high quality mount will appear out of China?
Oh -- I will check with some of my astro buddies to see what fwhm's they are getting.
Miguel Lopes
Reged: 01/04/07
Loc: Portugal
      #2987262 - 03/16/09 04:01 PM
Forgot to add this:
a color camera allways has worst FWHM than a mono. Not only because of lack of resolution but also because you need more time to get the same quantity of photons...
Psyire
Reged: 06/24/07
Loc: 55* North
      #2987332 - 03/16/09 04:39 PM
idahoman, I think you nailed it. If I were in your shoes, I think a CGE-PRO might be the answer... but the jury is still out on those. You'll have to wait and see I guess.
Strgazr27
Reged: 10/04/04
      #2987661 - 03/16/09 07:40 PM
Forgot to add this:
A OSC camera produces a MONO image until it is debayered so how does this increase the FWHM? Wouldn't pixel size play a larger role than the fact your using a OSC camera.
Miguel Lopes
Reged: 01/04/07
Loc: Portugal
      #2987765 - 03/16/09 08:32 PM
Forgot to add this:
Well, FWHM, as the name says, is the full width at half maximum of a star bell-shape. Due to resolution loss from the debayering (compared to a mono camera), the star will have a smaller SNR, the peak value will be minor, therefore the FWHM will be higher.
Strgazr27
Reged: 10/04/04
      #2987828 - 03/16/09 09:07 PM
But for arguments sake most stars are composed of mainly "White" light. in other words, they are an RGB object. That being true, am I not using all of the pixels in the image of my OSC to compute my FWHM? You would be correct if we were shooting through a single color filter but we're not. Correct me if I'm wrong but a 6 MP mono camera and a 6 MP OSC camera should have the same resolution if the pixels are the same size and we're shooting an RGB object no?
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
      #2987835 - 03/16/09 09:11 PM
They would, if you were looking at the raw data from the chip instead of the interpolated data that is actually used.
Strgazr27
Reged: 10/04/04
Re: Autoguided PE -- how good is good? new [Re: jrcrilly]
      #2988038 - 03/16/09 11:06 PM
So resolution is lost in the interpolation John? And by that I guess you mean the debayering process? When we speak of OSC cameras are we talking about strictly OSC CCD cameras or are we grouping DSLR's in that group also? I ask as I would think the AA filter in todays DSLR's would have more of an impact on FWHM numbers due to the slight blurring of the image. What if one were to take the FWHM before debayering? I know this is possible in ImagesPlus V3
I would think that image scale would play a bigger part. If my image scale is 2.5 AS/Pixel. If I'm testing on a good night and my seeing is at or better than that my stars would fit on a single pixel making an accurate FWHM reading inaccurate correct?
Sorry if I got off track I'm trying to digest all the info.
Strgazr27
Reged: 10/04/04
      #2988042 - 03/16/09 11:08 PM
Frank,
Can METAGUIDE be made to work with an Orion Starshoot? It looks incredibly promising for guiding and was curious.
Miguel Lopes
Reged: 01/04/07
Loc: Portugal
      #2988317 - 03/17/09 05:31 AM
IMO the problem is not in the debayering, it's just because you have less resolution. Interpolation tries to compensate that.
You are right, for a pure white star, if the FWHM algorithm only looks at luminance data, it should be very similar.
But then when we look at the small details, it is not the same.
For example, a mono camera without IR block will be very sensitive in the IR, which is less affected by turbulence.
Also, as you can take a sub frame in 1/3 of the time, the PSF will be smaller.
freestar8n
Reged: 10/12/07
      #2988426 - 03/17/09 08:20 AM
Hi-
Sorry - but it is video-based and only works with cameras that have a DirectShow driver. The centroiding it uses is very different from other apps, and it requires realtime processing of several successive frames to take advantage. My standard guide camera is a Lumenera, and I guide with OAG at 8-30 frames per second on stars down to mag 10 with a C11.
On the topic of fwhm - in order to get the smallest fwhm in the image, all errors will contribute - and I find there is enough error in the guide star centroiding that there is benefit in doing things differently. So focus, guide tuning, latency, etc. all need to be addressed - and even then the centroiding algorithm can be improved, which is why I wrote MetaGuide.
Frank
idahoman
Reged: 11/25/05
Loc: Idaho, USA
      #2988589 - 03/17/09 10:15 AM
Some more info to throw into the stew! A friend of mine images at a site 50 miles from my house. He is a bit higher and darker. Anyway, he reports that he usually sees FWHM of 1.5 to 2.5 on a "steady night", but 2 - 3 is more typical. His opinion is that the atmosphere around here is too unstable for anything over 1500mm focal length. I'm imaging at around 1440mm or so.
I don't have CCDInspector, but when focusing Maxim reports around 4 or 5 as my FWHM (if I remember correctly). So, my guess is that the best I can achieve is 3 to 4 and thus I have some room for improvement.
dickbill
Reged: 09/30/08
      #2988659 - 03/17/09 11:02 AM
Frank
Which brings us back to the mount accuracy. Since the purpose of guiding is to correct tracking errors AFTER the errors are made, good mounts will produce less errors that won't need to be corrected and so the centroid produced by an average mount, even in perfect focus and seing conditions, cannot be as small as a good mount with small PE.
If I understand well however, Permanent Periodic Error Correction, such as implemented in the new CGEM or CGE-pro, is supposed to prevent tracking errors before they happen and so the pictures obtain with these mount should show an improved resolution...But, in practice, I suspect that the correction made under PPEC, being automatic, can be also inaccurate and to a certain point it remains to be seen how a middle range mount like a CGEM really needs PPEC when it is also autoguiding.
Strgazr27
Reged: 10/04/04
Re: Autoguided PE -- how good is good? new [Re: dickbill]
      #2988690 - 03/17/09 11:21 AM
Although PEC can and does help, depending on the situation and the mount there is still as you say an error to it. Wether by eye or by camera, the errors will be corrected for either as they happen or after they happen. In the case of my G11, until I get the new worm block I have an issue with the 76 sec error. This makes using PEC a non issue as the error occurs at a different point in each worm cycle. Other mounts do show a marked improvement with PEC. The NXGPS, CPC, and CGE models have always had PPEC.
idahoman
Reged: 11/25/05
Loc: Idaho, USA
      #2988741 - 03/17/09 12:00 PM
My Nexstar GPS does not learn PEC for some reason. That was why I got the AO-8. I had more than 80" periodic error, and there was no way to program the PEC into the mount. Apparently this was a problem with the Nexstar's (at least, the one I have). So, I run with NO PEC. I think it is amazing that the AO-8 improves my mount the way it does.
Miguel Lopes
Reged: 01/04/07
Loc: Portugal
      #2988757 - 03/17/09 12:06 PM
Frank
+/- true. If you SBIG examples, they do make a test on a Paramount and there is a slight improvement...
Also... Paramount = 14.000€, AO = 850€ - 1800€
freestar8n
Reged: 10/12/07
      #2988794 - 03/17/09 12:28 PM
Hi-
My CGE is like most mid-range mounts and also has noise that isn't commensurate with the worm, so it can't be removed by PEC. But PEC does remove the fundamental and harmonics effectively, and has no downside that I can see, so it does remove a lot of the work for the autoguider and helps reduce the fwhm. But there is still a range sources from 1s to 50s that I deal with by low latency corrections and short guide exposures.
Although autoguiders tend to be reactive, MetaGuide is I think unique in that it can lock onto an error frequency and proactively correct it - independent of PEC. This was largely done as an experiment, but it sounds like a 76 second G11 would be a good candidate. You just enter 76 seconds as the period and begin autoguiding. It will sense that frequency in its corrections and determine its phase and amplitude - then begin applying it proactively rather than reactively. Normal autoguiding continues on to correct remaining errors.
I never saw a real benefit of this with my cge so I haven't used it much - but it's there.
Frank
idahoman
Reged: 11/25/05
Loc: Idaho, USA
      #2988842 - 03/17/09 12:58 PM
Miguel brings up a good point. The new Paramount is $14500. The AO is under $1000. The AO, however, does occupy a significant amount of backfocus. Especially the AO-7. And, adds weight. But, it sure improved my life! Before the AO (I had an AO-7 before my AO-8), I could not take subs longer than a couple of minutes since I had to throw so many away.
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
      #2989176 - 03/17/09 04:32 PM
You can get a trial version of CCDInspector.
It might also find some optical issues with your system which are affecting your FWHM.
11 registered and 27 anonymous users are browsing this forum.
