DrGolds
Reged: 04/06/08
Ideal mount for NP127is and (later) a C14?
      #3060228 - 04/22/09 05:48 PM
I've been trying to assemble a list of components for my new imaging system. Because of light pollution and seeing conditions at my location (Silicon Valley), I think I want to stick with wide-field imaging. Thus my selection of the NP127is. Also, for a camera, I'd stick with my modified 40D for the time being, in an effort to keep costs lower.
What would be the ideal mount for the NP127is? Later, I hope to get a C14 for DSO imaging so I'd want a mount stable enough for imaging with the C14 as well. I was considering the CGE Pro, but since I can't set up a permanent pier where I am (no good site), I think it's probably too large for me to set-up regularly... The 75 lb head is somewhat daunting. The $5000 price-point (at least that's what I can find on-line) makes it quite desirable, though, compared to the other options.
For even wider-field shots, I was planning on piggy-backing my modified 40D with various lenses on top of the NP127is.
Looking at the various choices in this class, the CGE might be an option, but I've read that it's rather difficult to set-up compared to the newer CGEM and CGE Pro, so I was going to pass on the CGE.
Thanks for any suggestions,
-Jeff
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: Ideal mount for NP127is and (later) a C14? new [Re: DrGolds]
      #3060571 - 04/22/09 08:56 PM
Looking at the various choices in this class, the CGE might be an option, but I've read that it's rather difficult to set-up compared to the newer CGEM and CGE Pro, so I was going to pass on the CGE. -Jeff
Jeff, Not sure what you've read but software wise the CGE uses identical firmware as the CGEM and CGE Pro so the procedures are exactly the same and take the same amount of time. Hardware wise I'm not aware of any issues that seriously affect setup time. Alt and Az adjustments for polar alignment are not quite as slick as on the two newer mounts but it's not a big deal to use an allen wrench (or ratchet) vs. their big knobs.
I can have my CGE wheeled into place, mount leveled and roughly polar aligned, scopes mounted and balanced, finder scope adjusted, two star alignment with 4 calibrations stars all in about 15 minutes.
For visual the CGEM would be fine for your TV127, but for imaging I'd consider the CGE. For visual with the C14 you could get away with the CGE as well, but if you want to image with that big scope I think you're going to have to consider mounts in the CGEPro category.
DrBuck
Reged: 12/10/08
Loc: Susanville, No. Calif.
      #3060573 - 04/22/09 08:57 PM
I just changed from an LX 200 to a Tak FS 152 and put it on a CGE mount in my observatory. However, the first night I had it, I set it up in the driveway and I didn't have any problems at all. It tracks very well and the go to is amazing. After not using it for 2 weeks, I used the "last alignment" feature and it dead centered Saturn on the first try. I would seriously recommend the CGE. I don't think the CGEM is heavy enough for the C-14. The CGE pro is a little much for a portable unit IMHO
DrGolds
Reged: 04/06/08
Re: Ideal mount for NP127is and (later) a C14? new [Re: DrBuck]
      #3060656 - 04/22/09 09:35 PM
My big problem is I can't use a scopebuggy or similar device to wheel out a big mount. My driveway and garage just don't have enough access for me to get the scope behind the house and I'd rather not leave a bunch of astro equipment in the front yard, if ya know what I mean
I'll take another look at the CGE. I think what I was remembering was the "difficulty" of setting up the polar alignment since you have to use a wrench. Since it's so much cheaper, it's probably the way to go.
On the other hand, maybe I could put a shed in the backyard for storing a CGE Pro on a scopebuggy...
Thanks for the replies!
-Jeff
DrBuck
Reged: 12/10/08
      #3060680 - 04/22/09 09:43 PM
Since mine is in an observatory and already polar aligned, I don't have that problem. But if I had to set it up on a regular basis, I would purchase a Socket that has an allen wrench built into it and use a longer ratchet handle. That should make the PA procedure easier.
gsmblue
Reged: 04/14/09
Loc: Portland, OR, USA
      #3060926 - 04/22/09 11:54 PM
If you are looking at the CGE, have you considered the Losmandy G11? (the CGE is a clone of the G11). For the scopes you are looking at you do not want to go for a much smaller mount.
I share you issue of the silicon Valley glow, I am hoping a summer of camping will be the cure!
Also, if portability is an issue, why not look at the NP101is and a CGEM or G-8 with Gemini? You will be surprised how much easier this will be to haul around.
DrGolds
Reged: 04/06/08
Re: Ideal mount for NP127is and (later) a C14? new [Re: gsmblue]
      #3061132 - 04/23/09 01:30 AM
Belmont! We're practically neighbors (Redwood City here.)
Thanks for the suggestion, I'll check out the G11, I don't know much about it.
I really just need backyard portability... our 5 week old twins won't let us far from the house for a while yet! I'm just trying to figure out a solid set-up that will last a good long time. Eventually, I plan to set up a pier or observatory, but probably not until we do some remodeling.
Good luck with your summer camping plans!
-Jeff
gsmblue
Reged: 04/14/09
      #3061862 - 04/23/09 11:45 AM
Redwood city! Excellent! If you need a hand with anything let me know
I am not sure how much of a hurry you are in for getting a mount/OTA, but I have a CGEM on order at scopecity in SFO, I think it will be 2-4 weeks before it come in. But if you want to wait and see try that mount you are more then welcome. I have a TV Genesis SDF (precursor to the NP) so you can get an idea of the size capabilities of that set up. But if you are just wheeling in/out of the garage then you probably are not concerned about fitting it in the trunk of the car!
I have a G-11 mount back in the UK so I will be able to tell you the differences pretty quickly... I think getting hold of a G-11 over here is pretty easy. I have not used the Gemini goto but I hear good things about it. There are plenty of threads on the Losmandy G-11 on these forums so have a look around.
Congrats on the twins!
DrGolds
Reged: 04/06/08
      #3062181 - 04/23/09 01:43 PM
Yeah someday I want to go to a dark site. I was at Yosemite about 10 years ago and was amazed and what you could see just with your eyes.
I am not in too much of a rush right now. I really don't have time for astronomy at the moment, but want to get prepared for when I do have some free time. Also, I need to sell my LX200 first!
I did some quick reading on the Losmandy site. Is the max slew rate of the G-11 really only 16x sidereal? Seems like it would take a long time to do a big slew.
-Jeff
gsmblue
Reged: 04/14/09
      #3062412 - 04/23/09 03:28 PM
The figure you quote is for the non-goto system.
You would be looking for the G-11 with Gemini. Gemini is the goto system for Losmandy. The GM8 can manage 10deg/S, I would expect the G-11 to be a bit slower then this, should be in the manual somewhere.
I am pretty new to the Bay area (I am British don't you know!), so I have not found a place to go observing yet, although CSM has an awesome planetarium and there is a society that meet monthly there and hold star parties etc.... I am planning on making the next one, if you are interested I can pm you some details...
Reged: 07/06/07
      #3062796 - 04/23/09 06:32 PM
-Jeff
With the C14 in the mix it goes like this:
Ideal: AP1200
Very good indeed: AP900, CGE Pro, Losmandy Titan
Bearable (for visual use or shorter exposures): G11, CGE.
Edited by rmollise (04/23/09 06:33 PM)
DrGolds
Reged: 04/06/08
Re: Ideal mount for NP127is and (later) a C14? new [Re: rmollise]
      #3062828 - 04/23/09 06:53 PM
Thanks for the input, Rod.
Does the CGE Pro head break down into anything smaller than 75 lbs? I noticed that the Titan head break down into two pieces of 37.5 lbs, which is a lot more tolerable than a single 75 lb head.
-Jeff
Dan G
Reged: 06/27/06
Loc: Minisink, NY, USA
      #3062944 - 04/23/09 07:53 PM
Jeff -
If later, for the C14, is a few years you might consider a Tak EM-200. The polar alignment scope is great and allows you to be well aligned within minutes. It's lightweight -easier to set up often means more frequently used - and carries 35 lbs of gear for imaging with no problem. Used ones can be had for <$4k.
Dan in NY
Strgazr27
Reged: 10/04/04
Loc: StonyHill Observatory
      #3063000 - 04/23/09 08:24 PM
Jeff,
Yes it does but they are not quite as light as the Losmandy. The side cradles that the mount pivots on in Alt and AZ can be left bolted to the electronics pier. You loosen the upper two lock knobs and remove the lower two. You can than lift the mount section up and out of the lower cradle setup. Hope that is a clear description.
Alex Ranous
Reged: 09/05/07
Loc: Redwood City, CA
Re: Ideal mount for NP127is and (later) a C14? new [Re: Strgazr27]
      #3063072 - 04/23/09 08:56 PM
A MI-250 can handle the C14 pretty well. Like the AP mounts, it breaks down into two pieces, the heaviest being 38 lb. Larry has updated it recently, and is now rated for 85 lbs imaging.
I'm in the same boat as you as I'm starting with wide field first before moving onto deep sky. I'm currently using a NP-101is on a MI-250. I'd be happy to have you come over for a look. As I'm in Redwood City also, that shouldn't be too tough.
DrGolds
Reged: 04/06/08
      #3063382 - 04/23/09 11:55 PM
Thanks for the info, Dan and Bobby. More things to think about!
-Jeff
DrGolds
Reged: 04/06/08
Re: Ideal mount for NP127is and (later) a C14? new [Re: Alex Ranous]
      #3063388 - 04/23/09 11:57 PM
Awesome, thanks for the data, Alex! I'd done some research on the MI-250, but didn't know much about it.
-Jeff
Reged: 07/06/07
      #3064006 - 04/24/09 10:02 AM
-Jeff
Yep...I'd have to check and see what the minimum weight is...but yeah, lighter than 75.
Timber
Reged: 11/08/08
Loc: SW foothills of Mt. St. Helens
      #3065373 - 04/24/09 11:47 PM
My vote inorder to mount everything on one mount at the same time, C-14, NP 127, camera's and all the rest;
For GoTo, AP 3600 ElCapitan
For Non GoTo, Beyers Series II
Both in the same weight carrying and quality league and both indestructable
Richard
DrGolds
Reged: 04/06/08
Re: Ideal mount for NP127is and (later) a C14? new [Re: Timber]
      #3065393 - 04/25/09 12:02 AM
The AP is certainly a beautiful mount, but I think that's a bit out of my budget at the moment... Maybe if we do some "home improvement" and I build an observatory What else are HELOC loans good for??
By the way, with the amount of light pollution here, I think GoTo is a must-have. Star hopping, while educational, would be quite frustrating I think. I can't even make out the Little Dipper visually, aside from Polaris :/
Rod,
Good to know about the CGE Pro. It's a pretty tempting solution.
Thanks all!
-Jeff
18 registered and 26 anonymous users are browsing this forum.
