Pages: 1 | 2 | 3 | (show all)
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: Trebor777]
      #3094680 - 05/09/09 03:10 PM
I think the brackets look very nice, but I agree with Luigi that it appears the scope CG is above the alt axis. I know from using the Celestron Heavy duty Alt/Az mount that the weight being above the alt axis doesn't work to well. I would imagine scope flop would be more likely with a heavier longer scope than yours.
Ken
Trebor777
Hazy
Reged: 01/04/08
Loc: Connecticut - U.S.
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: 94bamf]
      #3094690 - 05/09/09 03:17 PM
Ken
Coparing those 2 mounts is apples to oranges. 2 different mounts with different designs.
If the Celestron mount you're talking about is the one I'm thinking of.
Luigi
Reged: 07/03/07
Loc: MA
      #3095996 - 05/10/09 11:23 AM
With a well balanced setup, virtually no friction is need to hold any position of the scope and the movements are very smooth and easy. This is one of the usual goals in designing a telescope mount, and one that the standard Voyager attends to by placing the center of the OTA on the altitude axis. Your mod undoes this, which might be OK if offseting benefits outweigh this consideration.
cuzimthedad
Just Be Cuz
Reged: 04/09/06
Loc: Sonoma, Northern California
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: Luigi]
      #3096065 - 05/10/09 12:02 PM
Gosh guys, if the owner/user & mod maker says it works from experience why argue.
Nice pics Randy and Kudos to M2 for coming up with the idea! My Voyager is still in the box as farm work has prevented me from doing a first light this weekend.
Trebor777
Hazy
Reged: 01/04/08
      #3096254 - 05/10/09 01:49 PM
Oh yeah, thanx for mentioning balance. The bracket makes balancing the scope A LOT easier.
Trebor777
Hazy
Reged: 01/04/08
      #3096281 - 05/10/09 02:03 PM
So, I had the Voyager out for the first time last night with the new Manny Myles Mods.
The Pan Handle is the best thing in the world. If someone out there reading was thinking about getting a mod, the Pan Handle is a MUST, IMO.
With the handle, push-to is soooooo easy and smooth. The scope/mount didn't want to fall over like it used to (pre-mods). It was also windy last night.
The eyepiece tray is perfect, nothing special, just a normal ep tray that also adds a little stability.
Now for people with concerns for the bracket: You have no reason to have any. With the bracket, the mount/scope IS better balanced. I need no scientific studies or crazy math with blue prints to know this. I know from experience and trials (of wait, that is science )
So, after the first use, I can once again confirm that with Manny Myles Mods the AT Voyager is 1) easier to use overall, 2) more sturdy, 3) easier to balance the scope 4) easier to mount the scope, 5) looks better, 6) has a place for eyepieces.
Manny Myles makes a Pan Handle alone without the bracket for mounting the scope. So you can still mount the scope side-ways, but have a Pan Handle for Push-To reasons. That Pan Handle is the best mod for this mount. I prefer it with the Phat RaAT bracket though.
Why someone would argue these mods don't work without using (having) the AT Voyager and even have the mods, is beyond me...
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
      #3096284 - 05/10/09 02:04 PM
Ken
The mounts might be apples and oranges, but the principle is the same. If you are happy with the mods and they work for you/your scope, I am happy for you. I certainly wasn't trying to degrade the mods/mod maker, just talking about the principle of balance and the center of gravity. I would imagine if those mods would work for every style/weight of scope that Astro Tech markets the mount for, they would probably use it/something like it, from the factory. It just comes down to the fact that the easiest way to make heavier scopes balance and move smoothly is to be centered on the alt axis.(or have a counter weight setup like an GEM mount).
Either way enjoy your mount, apologies for the detour..
Ken
Trebor777
Hazy
Reged: 01/04/08
      #3096304 - 05/10/09 02:16 PM
Ken
I don't know if you've used to Voyager before, but the arm on the voyager is adjustable. When you have the arm 45 degrees to the left or right, the scope gets further away from the center of gravity. The bracket actually brings the scope close to the center of gravity - when the arm is positioned at the left or right angles, and not striaght up.
That's why whenever I went to Push-to, pre mods, the mount wanted to fall over. The scope wasn't near the center of gravity. Now with the bracket, it's closer to the center of gravity. How do I know this? The mount no longer wants to fall over when I push-to something.
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
      #3096310 - 05/10/09 02:22 PM
Ken
Me and you are talking about two different things. Being that you are happy with the mount, I don't see much point in taking this any further from my end. Again, enjoy your mount..
Ken
Trebor777
Hazy
Reged: 01/04/08
      #3096318 - 05/10/09 02:27 PM
Ken
But you said you were; "just talking about the principle of balance and the center of gravity"
Which I and Manny addressed. The bracket moves the scope closer to the CG.
Charlie HeinAdministrator
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
      #3096329 - 05/10/09 02:32 PM
Easy does it guys...
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
      #3096349 - 05/10/09 02:41 PM
Ken
Last one, I promise..
You are talking about the weight being centered over the tripod legs. To have clearence for a longer scope to be pointed at the zenith and not hit the tripod, they move the scope away from the center of the tripod. I am talking about the weight of the scope being centered on the alt axis, they do this to provide the scope smooth movement with minimum tension on the clutches. As you move the scope away from the alt axis, more weight is either above or below the alt axis, requiring more tension or a counter weight to keep the scope from moving while being pointed higher towards the zenith or lower towards the horizon.
Ken
Manny Myles
Reged: 11/29/05
Loc: Far South of the flyover city ...
      #3096412 - 05/10/09 03:20 PM
Then why would AT bother putting tension adjustments on the mount, they could have saved ooddles of $$ by not putting it on there ;-)
m2
Trebor777
Hazy
Reged: 01/04/08
      #3096413 - 05/10/09 03:20 PM
Ken
Ken
You are correct. If you're planning on mounting a longer/heavier scope, (13-16 lbs & longer than 24"-30"), the Voyager mount isn't for you.
This is my grab-n-go set up, by the way. I have a CGE and Atlas also to mount my SN10.
Even though the Voyager says it handles up to 20 lbs, I wouldn't mount anything more then 15 lbs on it. If you're mounting longer & heavier scopes you better invest more then $300 on a mount, IMO. That'd be like buying a $40,000 car and putting the least expensive wheels on it. Not a good idea. The only thing keeping your $40k investment from the ground are $60 wheels, when you should have the $150 wheels. Same with mounts, why would someone put a $2000 investment on a $100 mount, isn't the best idea.
I found the mods here seem to jump the gun. Me and 94bamf were having a civil discussion. But jumping the gun is a good thing sometimes. Thanx Charlie, you're one of the good mods.
Edited by Trebor777 (05/10/09 03:22 PM)
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: Manny Myles]
      #3096445 - 05/10/09 03:37 PM
m2
I believe the tension knobs are there to make up for slight differences in balance based on different eyepiece weights, accessories, wind, etc.. If you had to move the scope forward or back to balance it everytime you changed eyepieces, I doubt many people would like the mount..
I think ANY mount design is a compromise of some sort, none are perfect that I have seen yet..
Ken
Edited by 94bamf (05/10/09 03:38 PM)
Manny Myles
Reged: 11/29/05
      #3096451 - 05/10/09 03:41 PM
My first complaints about the parts I make and not from owners of the parts,, a first for me.
I would not even bother making these if they did not work, they do and owners of the parts get to try them first before even shelling out a thin dime.
I do appreciate everyones concern but so far they go unfounded.
Its by some freak of nature the parts work, I'm not an engineer by any means but for some dumb reason I was the one to figure out the parts and EVEN before AT or Vixen, why??? Just lucky
I have never adjusted the clutch tension( hate to admit this but I did not even know these mounts were capable of being adjusted for clutch tension till almost a year after I had my Porta) on either mount and before the parts the tripods wanted to fall over due to the unbalanced weight being out where it should not be and could never leave a scope on a AT Voyager or Vixen Portamount without the weight being over a leg.
Once the parts are installed you could give either mount a good shove and the tripod wants to fall back on its feet rather than fall backwards.
This is when the legs are collapsed as far as they will go which is what I based my testing on, now once the legs are extended the weight stays well inside the tripod legs.
I sat there with 3 scales checking the weight transfer and from what I could tell by doing that the weight does move forward, moving the scope around its range of circular (az)motion I could see the weight go from less on one leg to more on another yet the weight still was transfered forward.
Without the bracket the weight on the back legs was greater than the front, with the bracket the weight on the 3 legs was close to being even.
If one really wants to complain about these buy a Porta or Voyager get my mods then you can have a legit beef, if they did not work for you, send them back and you are out the postage for returning the mods.
Pretty good guarantee for something working if you ask me.
Check my ratings for any complaints as well.
m2
Manny Myles
Reged: 11/29/05
      #3096460 - 05/10/09 03:46 PM
It sounds like clutches are provided to serve a function that is needed no matter what you would do with it,different eyepiece weights, accessories, wind,ect...
maybe even attaching a bracket to it to make the mount more user friendly, heaven forbid :-0
m2
Trebor777
Hazy
Reged: 01/04/08
      #3096481 - 05/10/09 03:55 PM
I think this is a great thread, lets not get it locked.
Some non-owners of Voyager or Porta mounts had some concerns, I hope their concerns were answered by people who have owned & used the mounts both with and without the mods.
I've only had my mods for a few days. Maybe if other owners of Manny's mods could chime in with their experiences (a lot longer then mine) with his mods would be good too... I know from looking through Manny's profile ratings that all of his customers are happy and find the mods an improvement. There are also other threads with his mods and people's comments...
EDIT: I should add dampening times.
On concrete, legs extended, w/ vibration suppression pads, PRE mods: 3-4 seconds
On concrete, legs extended, w/ vibration suppression pads, POST mods: 2-3 seconds
On grass with the same set-up is probably a bit better.
Edited by Trebor777 (05/10/09 04:12 PM)
Manny Myles
Reged: 11/29/05
      #3096513 - 05/10/09 04:10 PM
Randy,
Did you have to adjust the tension +/- of the alt clutch???
m2
Trebor777
Hazy
Reged: 01/04/08
      #3096522 - 05/10/09 04:17 PM
Randy,
m2
No, I've always kept it (well both actually) tight - and even with them tight there's no problem Push-To'ing, but the Pan Handle made Push-To'ing a lot easier.
I balance the scope/mount with a 31T5 Nagler, since it's a heavy EP. And even when I switch to a Pentax 7XW, I don't have to adjust anything. The scope doesn't fall forward at all.
The At Voyager is a great alt/az mount, the mods just improved it's performance.
23 registered and 30 anonymous users are browsing this forum.
