Pages: 1 | 2 | 3 | (show all)
Trebor777
Hazy
Reged: 01/04/08
Loc: Connecticut - U.S.
My AT Voyager w/ "Manny Myles" Mods!!!!
      #3093237 - 05/08/09 07:15 PM
So, I recently purchased an AT Voyager with an extension used (it was in mint/never used condition). I found that while it's a great "grab-n-go" mount there were some improvments that can be made.
I wasn't happy with the "push-to" ability of the stock mount. I'd have to grab onto the scope and mount at the same time to pan around to a different object.
Another thing I wasn't a big fan of was the way scopes are mounted to the "hockey puck" sideways and having to always turn the focuser (or diagonal) 45 degrees.
I also thought that the tripod spreader, while ok, could have been stronger and gave the mount more support. And the eyepiece tray that AT offered, 1 didn't look good, 2, didn't add support & 3, I did't like where I would have to mount it.
Enter "Manny Myles" (that's his screen name). After searching through the Mounts Forum here on CloudyNights and came across a few threads (csa/montana's specifically) that had the Manny Myles Mods done to the AT Voyager mount. his modifications answered ALL of my negatives I thought of the stock AT Voyager.
Manny (Dave) was VERY communicative and answered all my questions. I ended up ordering an eyepiece tray with 3 2" holes and 6 1.25" holes. I also ordered a PhAT RaAT w/ Pan Handle from him.
After installing everything (everything you need to install comes with the package, by the way). Boom, mount was sturdier, push-to was easy, you don't even have to touch the scope.
Manny's (Dave's) work is proffessional grade. The paint job he did matched the painton the Voyager exactly, and the eyepiece tray was light weight and fit perfectly. (the welding job was spot on also )
Manny Myles also sells another bracket, I forget the name, but it's installed at the lower end of the arm of the Voyager, which also helps with balancing and the overall sturdiness (is that a word?) of the mount. He also has a bracket with just the Pan Handle for push-to'ing.
Now my AT Voyager mount is modified exactly the way I wanted thanx to Manny Myles.
He gets a "5 bow rating from me:
Well, here are some (a bunch actually) pictures.
Trebor777
Hazy
Reged: 01/04/08
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: Trebor777]
      #3093239 - 05/08/09 07:16 PM Attachment (65 downloads)
Here's a pic of the eyepiece tray. The small piece goes under the tripod spreader - making sure the spreader is level:
Trebor777
Hazy
Reged: 01/04/08
      #3093241 - 05/08/09 07:18 PM Attachment (71 downloads)
Here's a pic of the PhAT RaAT & Pan Handle (I think he's calling that a Pan Handle - corrrect me if I'm wrong)
Trebor777
Hazy
Reged: 01/04/08
      #3093244 - 05/08/09 07:19 PM Attachment (53 downloads)
Here's the PhAT RaAT & Pan Handle together:
Trebor777
Hazy
Reged: 01/04/08
      #3093245 - 05/08/09 07:20 PM Attachment (64 downloads)
In this picture, it's the OLD WAY of mounting the scope. See how the scope is "on it's side" and you'd have to move the focuser and/or diagonal?
Trebor777
Hazy
Reged: 01/04/08
      #3093249 - 05/08/09 07:21 PM Attachment (56 downloads)
Here's the PhAT RaAT & Pan Handle installed on the Voyager. You can see on the PhAT RaAT where the stock "hocky puck" is installed = Better mounting
Trebor777
Hazy
Reged: 01/04/08
      #3093253 - 05/08/09 07:22 PM Attachment (50 downloads)
PhAT RaAT w/ stock "hockey puck" installed.
Trebor777
Hazy
Reged: 01/04/08
      #3093261 - 05/08/09 07:24 PM Attachment (71 downloads)
Now a pic with the scope mounted, not sideways. This is the perfect mounting position, IMO. It also brings the scope closer to the center of gravity. Makes mounting easier, makes balancing easier, and it improves stability.
Trebor777
Hazy
Reged: 01/04/08
      #3093262 - 05/08/09 07:25 PM Attachment (60 downloads)
A pic from the front:
Trebor777
Hazy
Reged: 01/04/08
      #3093267 - 05/08/09 07:27 PM Attachment (48 downloads)
And another one from the other side. You can see there's plenty of clearance between the scope and mount arm. Very well thought out by Manny Myles. And there's also room to mount a bigger scope. The TMB92SS is only about 8-9#'s
Trebor777
Hazy
Reged: 01/04/08
      #3093271 - 05/08/09 07:28 PM Attachment (44 downloads)
And my last pic of the eyepiece tray installed:
Trebor777
Hazy
Reged: 01/04/08
      #3093338 - 05/08/09 08:04 PM
Oh yeah, I probably should have cleaned my room before taking pics, there's one pic with a pile of my dirty clothes.
gillmj24
Reged: 12/06/05
Loc: PA
      #3093345 - 05/08/09 08:10 PM
Great review! Don't sweat it I have sold stuff with messier room pictures than that.
Manny Myles
Reged: 11/29/05
Loc: Far South of the flyover city ...
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: gillmj24]
      #3093527 - 05/08/09 10:18 PM
Looking good there Randy, glad everything works as they are supposed to, great set of photos too<G>
m2
Luigi
Reged: 07/03/07
Loc: MA
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: Manny Myles]
      #3094012 - 05/09/09 07:28 AM
CG of scope is quite a bit above the alt axis. This potentiates the dreaded scope flop associated with using photographic mounts. How is this an improvement?
Trebor777
Hazy
Reged: 01/04/08
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: Luigi]
      #3094289 - 05/09/09 10:58 AM
In English please.
I'm no scientist, but it's a lot easier to mount, the scope is in a better position, balancing is a lot easier, overall it's sturdier. And I have less worries now about everything falling over then I did before. What's scope flop? Sounds like something Viagra would take care of.
Are you claiming the scope is more likely to fall over in this position mounted on the bracket?
Doesn't seem like it is. The overall balance of the set up is a lot better then before. Before, EVERY time I would "push-to" another object the mount would want to fall over (I call that not being sturdy). Now with the bracket/handle it's firm on all 3 legs (I call that sturdy). Solved my problem.
Manny Myles
Reged: 11/29/05
      #3094314 - 05/09/09 11:14 AM
I think Astro Tech would have worked on this when they decided to create the extension for the mount, it does seem to add a bit of a lever to the overall height of the mount.
With the scope in the factory placement, the scope is further away from the center, with the bracket it moves it forward and inward towards the sweet spot, not exactly perfect but much better than factory.
Having the Bent Bar on there gets it even closer to the center of az rotation, helping get the scope's weight centered on all 3 legs.
m2
Luigi
Reged: 07/03/07
Loc: MA
      #3094613 - 05/09/09 02:34 PM
Scope flop: balance the scope when level and when pointed up it will tend to rotate backward(flop). It'll do the same thing when pointing down in the front but that's not too common in astro observing.
Manny Myles
Reged: 11/29/05
      #3094635 - 05/09/09 02:49 PM
The mounts have tension adjustments to help this from happening<G>
m2
Trebor777
Hazy
Reged: 01/04/08
      #3094660 - 05/09/09 03:00 PM
I can attest, with the tension knobs on the Voyager that wasn't/isn't an issue, well it wasn't for me. After your post before, I mounted my TMB92SS again and messed around with moving it, up/down/left right, tried different EP's, etc, etc. I didn't have any worries or scope flop. It was a lot sturdier then before, especially in regards to "push-to'ing".
Manny's brackets are a professionally made item and do what they say they're going to do. No worries about exacerbating scope flop.
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
      #3094680 - 05/09/09 03:10 PM
I think the brackets look very nice, but I agree with Luigi that it appears the scope CG is above the alt axis. I know from using the Celestron Heavy duty Alt/Az mount that the weight being above the alt axis doesn't work to well. I would imagine scope flop would be more likely with a heavier longer scope than yours.
Ken
Trebor777
Hazy
Reged: 01/04/08
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: 94bamf]
      #3094690 - 05/09/09 03:17 PM
Ken
Coparing those 2 mounts is apples to oranges. 2 different mounts with different designs.
If the Celestron mount you're talking about is the one I'm thinking of.
Luigi
Reged: 07/03/07
Loc: MA
      #3095996 - 05/10/09 11:23 AM
With a well balanced setup, virtually no friction is need to hold any position of the scope and the movements are very smooth and easy. This is one of the usual goals in designing a telescope mount, and one that the standard Voyager attends to by placing the center of the OTA on the altitude axis. Your mod undoes this, which might be OK if offseting benefits outweigh this consideration.
cuzimthedad
Just Be Cuz
Reged: 04/09/06
Loc: Sonoma, Northern California
      #3096065 - 05/10/09 12:02 PM
Gosh guys, if the owner/user & mod maker says it works from experience why argue.
Nice pics Randy and Kudos to M2 for coming up with the idea! My Voyager is still in the box as farm work has prevented me from doing a first light this weekend.
Trebor777
Hazy
Reged: 01/04/08
      #3096254 - 05/10/09 01:49 PM
Oh yeah, thanx for mentioning balance. The bracket makes balancing the scope A LOT easier.
Trebor777
Hazy
Reged: 01/04/08
      #3096281 - 05/10/09 02:03 PM
So, I had the Voyager out for the first time last night with the new Manny Myles Mods.
The Pan Handle is the best thing in the world. If someone out there reading was thinking about getting a mod, the Pan Handle is a MUST, IMO.
With the handle, push-to is soooooo easy and smooth. The scope/mount didn't want to fall over like it used to (pre-mods). It was also windy last night.
The eyepiece tray is perfect, nothing special, just a normal ep tray that also adds a little stability.
Now for people with concerns for the bracket: You have no reason to have any. With the bracket, the mount/scope IS better balanced. I need no scientific studies or crazy math with blue prints to know this. I know from experience and trials (of wait, that is science )
So, after the first use, I can once again confirm that with Manny Myles Mods the AT Voyager is 1) easier to use overall, 2) more sturdy, 3) easier to balance the scope 4) easier to mount the scope, 5) looks better, 6) has a place for eyepieces.
Manny Myles makes a Pan Handle alone without the bracket for mounting the scope. So you can still mount the scope side-ways, but have a Pan Handle for Push-To reasons. That Pan Handle is the best mod for this mount. I prefer it with the Phat RaAT bracket though.
Why someone would argue these mods don't work without using (having) the AT Voyager and even have the mods, is beyond me...
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
      #3096284 - 05/10/09 02:04 PM
Ken
The mounts might be apples and oranges, but the principle is the same. If you are happy with the mods and they work for you/your scope, I am happy for you. I certainly wasn't trying to degrade the mods/mod maker, just talking about the principle of balance and the center of gravity. I would imagine if those mods would work for every style/weight of scope that Astro Tech markets the mount for, they would probably use it/something like it, from the factory. It just comes down to the fact that the easiest way to make heavier scopes balance and move smoothly is to be centered on the alt axis.(or have a counter weight setup like an GEM mount).
Either way enjoy your mount, apologies for the detour..
Ken
Trebor777
Hazy
Reged: 01/04/08
      #3096304 - 05/10/09 02:16 PM
Ken
I don't know if you've used to Voyager before, but the arm on the voyager is adjustable. When you have the arm 45 degrees to the left or right, the scope gets further away from the center of gravity. The bracket actually brings the scope close to the center of gravity - when the arm is positioned at the left or right angles, and not striaght up.
That's why whenever I went to Push-to, pre mods, the mount wanted to fall over. The scope wasn't near the center of gravity. Now with the bracket, it's closer to the center of gravity. How do I know this? The mount no longer wants to fall over when I push-to something.
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
      #3096310 - 05/10/09 02:22 PM
Ken
Me and you are talking about two different things. Being that you are happy with the mount, I don't see much point in taking this any further from my end. Again, enjoy your mount..
Ken
Trebor777
Hazy
Reged: 01/04/08
      #3096318 - 05/10/09 02:27 PM
Ken
But you said you were; "just talking about the principle of balance and the center of gravity"
Which I and Manny addressed. The bracket moves the scope closer to the CG.
Charlie HeinAdministrator
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
      #3096329 - 05/10/09 02:32 PM
Easy does it guys...
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
      #3096349 - 05/10/09 02:41 PM
Ken
Last one, I promise..
You are talking about the weight being centered over the tripod legs. To have clearence for a longer scope to be pointed at the zenith and not hit the tripod, they move the scope away from the center of the tripod. I am talking about the weight of the scope being centered on the alt axis, they do this to provide the scope smooth movement with minimum tension on the clutches. As you move the scope away from the alt axis, more weight is either above or below the alt axis, requiring more tension or a counter weight to keep the scope from moving while being pointed higher towards the zenith or lower towards the horizon.
Ken
Manny Myles
Reged: 11/29/05
      #3096412 - 05/10/09 03:20 PM
Then why would AT bother putting tension adjustments on the mount, they could have saved ooddles of $$ by not putting it on there ;-)
m2
Trebor777
Hazy
Reged: 01/04/08
      #3096413 - 05/10/09 03:20 PM
Ken
Ken
You are correct. If you're planning on mounting a longer/heavier scope, (13-16 lbs & longer than 24"-30"), the Voyager mount isn't for you.
This is my grab-n-go set up, by the way. I have a CGE and Atlas also to mount my SN10.
Even though the Voyager says it handles up to 20 lbs, I wouldn't mount anything more then 15 lbs on it. If you're mounting longer & heavier scopes you better invest more then $300 on a mount, IMO. That'd be like buying a $40,000 car and putting the least expensive wheels on it. Not a good idea. The only thing keeping your $40k investment from the ground are $60 wheels, when you should have the $150 wheels. Same with mounts, why would someone put a $2000 investment on a $100 mount, isn't the best idea.
I found the mods here seem to jump the gun. Me and 94bamf were having a civil discussion. But jumping the gun is a good thing sometimes. Thanx Charlie, you're one of the good mods.
Edited by Trebor777 (05/10/09 03:22 PM)
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
      #3096445 - 05/10/09 03:37 PM
m2
I believe the tension knobs are there to make up for slight differences in balance based on different eyepiece weights, accessories, wind, etc.. If you had to move the scope forward or back to balance it everytime you changed eyepieces, I doubt many people would like the mount..
I think ANY mount design is a compromise of some sort, none are perfect that I have seen yet..
Ken
Edited by 94bamf (05/10/09 03:38 PM)
Manny Myles
Reged: 11/29/05
      #3096451 - 05/10/09 03:41 PM
My first complaints about the parts I make and not from owners of the parts,, a first for me.
I would not even bother making these if they did not work, they do and owners of the parts get to try them first before even shelling out a thin dime.
I do appreciate everyones concern but so far they go unfounded.
Its by some freak of nature the parts work, I'm not an engineer by any means but for some dumb reason I was the one to figure out the parts and EVEN before AT or Vixen, why??? Just lucky
I have never adjusted the clutch tension( hate to admit this but I did not even know these mounts were capable of being adjusted for clutch tension till almost a year after I had my Porta) on either mount and before the parts the tripods wanted to fall over due to the unbalanced weight being out where it should not be and could never leave a scope on a AT Voyager or Vixen Portamount without the weight being over a leg.
Once the parts are installed you could give either mount a good shove and the tripod wants to fall back on its feet rather than fall backwards.
This is when the legs are collapsed as far as they will go which is what I based my testing on, now once the legs are extended the weight stays well inside the tripod legs.
I sat there with 3 scales checking the weight transfer and from what I could tell by doing that the weight does move forward, moving the scope around its range of circular (az)motion I could see the weight go from less on one leg to more on another yet the weight still was transfered forward.
Without the bracket the weight on the back legs was greater than the front, with the bracket the weight on the 3 legs was close to being even.
If one really wants to complain about these buy a Porta or Voyager get my mods then you can have a legit beef, if they did not work for you, send them back and you are out the postage for returning the mods.
Pretty good guarantee for something working if you ask me.
Check my ratings for any complaints as well.
m2
Manny Myles
Reged: 11/29/05
      #3096460 - 05/10/09 03:46 PM
It sounds like clutches are provided to serve a function that is needed no matter what you would do with it,different eyepiece weights, accessories, wind,ect...
maybe even attaching a bracket to it to make the mount more user friendly, heaven forbid :-0
m2
Trebor777
Hazy
Reged: 01/04/08
      #3096481 - 05/10/09 03:55 PM
I think this is a great thread, lets not get it locked.
Some non-owners of Voyager or Porta mounts had some concerns, I hope their concerns were answered by people who have owned & used the mounts both with and without the mods.
I've only had my mods for a few days. Maybe if other owners of Manny's mods could chime in with their experiences (a lot longer then mine) with his mods would be good too... I know from looking through Manny's profile ratings that all of his customers are happy and find the mods an improvement. There are also other threads with his mods and people's comments...
EDIT: I should add dampening times.
On concrete, legs extended, w/ vibration suppression pads, PRE mods: 3-4 seconds
On concrete, legs extended, w/ vibration suppression pads, POST mods: 2-3 seconds
On grass with the same set-up is probably a bit better.
Edited by Trebor777 (05/10/09 04:12 PM)
Manny Myles
Reged: 11/29/05
      #3096513 - 05/10/09 04:10 PM
Randy,
Did you have to adjust the tension +/- of the alt clutch???
m2
Trebor777
Hazy
Reged: 01/04/08
      #3096522 - 05/10/09 04:17 PM
Randy,
m2
No, I've always kept it (well both actually) tight - and even with them tight there's no problem Push-To'ing, but the Pan Handle made Push-To'ing a lot easier.
I balance the scope/mount with a 31T5 Nagler, since it's a heavy EP. And even when I switch to a Pentax 7XW, I don't have to adjust anything. The scope doesn't fall forward at all.
The At Voyager is a great alt/az mount, the mods just improved it's performance.
k5apl
Reged: 05/19/06
Loc: Arkansas
      #3097122 - 05/10/09 10:24 PM
M2
I sent you a PM.....don't know if it went through to you or not. Tried again.
Wes
Manny Myles
Reged: 11/29/05
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: k5apl]
      #3097556 - 05/11/09 05:54 AM
I'll get back to you this PM.
m2
mischief
Reged: 04/26/08
Loc: Northern California
      #3098998 - 05/11/09 07:21 PM
Randy (and also Manny with whom I corresponded earlier). Randy your review and pictures have me thinking again about getting Manny's mods. I had seen other posts earlier and "talked" with Manny about them. I like the ability to mount the scope right side up so to speak instead of on its side. So, Manny, back to you. I have forgotten what you said; I remember I said something about installing your mods since I am very mechanically challenged. If you could be so kind to explain to me again what has to be done. For now I am mounting my Lunt 60 T scope on the Voyager. You can send an IM if you want or not.
Thanks. Dorothy
Trebor777
Hazy
Reged: 01/04/08
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: mischief]
      #3099055 - 05/11/09 07:52 PM
Thanks. Dorothy
I'm sure Manny will get back to you soon, but installing the mods is as easy as unscrewing a bolt.
There are 2 bolts that hold the "hockey puck" to the voyager.
1) You simply unscrew those 2 bolts and remove the black hockey puck (save the bolts for a rainy day, you don't need them anymore).
2) Manny includes 2 new, longer bolts for attaching the bracket. You use those 2 new longer bolts and simply hold the bracket up to where the hockey puck used to be and then screw the new bracket on.
3) Then you screw the hockey puck onto the rounded part on the bracket. There's supplied bolts for that also.
So it's as simple as unscrewing 2 bolts, and then screwing in 4. Oh yeah, and the Pan Handle just screws into the bottom part of the bracket.
I've got a Lunt LS60T too. Great Ha scope. I love it - even more so after Manny's Mods.
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
      #3099058 - 05/11/09 07:53 PM Attachment (41 downloads)
Dorothy, not to worry, Manny's Mods are extremely easy to install! I had them on my PortaMount, & now have them on my Voyager, only took minutes to install.
BTW; I am extremely pleased with the improvements of my Voyager with Manny's Mods!
Trebor777
Hazy
Reged: 01/04/08
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: csa/montana]
      #3117344 - 05/20/09 06:36 PM
2 weeks and over 7 times being used and still no "scope flop" issues with Manny's Mods.
As long as it's balanced correctly, there should be no issues. The AT Voyager is such a pleasure to use, especially after the mods. I can get the mount set-up and I can be at the eyepiece within 5 minutes. Perfect for grab-n-go.
mypontiac
Reged: 09/06/07
Loc: Austin, Tx.
      #3117642 - 05/20/09 09:36 PM
So as is has problems with Scope Flop? When changing EPs?
Sean
Manny Myles
Reged: 11/29/05
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: mypontiac]
      #3118191 - 05/21/09 05:47 AM
No , not at all.
Some one brought up the design was flawed but had no substantiated proof of it producing this effect and no one yet to chime in with the bracket producing this for them.
m2
Trebor777
Hazy
Reged: 01/04/08
      #3118853 - 05/21/09 01:16 PM
Sean
No, "as is" (stock voyager) I didn't have have any scope flop issues. And post Manny Mods, I didn't have scope flop issues. Proper balance is all you need - and the tension knobs on the voyager help also.
No issues when changing EP's either.
TONGKW
Reged: 01/16/07
      #3119731 - 05/21/09 09:32 PM Attachment (32 downloads)
I have carried out different modification to the Voyager for my use.
I find the Voyager in the original configuration with the long arm is not stable enough for my heavier OTA such as the C8 (12.5 lb) and the MK67 (10.7 lb). I make a shorter arm and now the set up is much more stable and zenith can still be reached though I have to revert to using the long arm when mounting long refractors.
I have also adapted a heavy duty photo tripod to mount the Voyager. The tripod is a Gitzo 1415 and is only 19.5 inches long. The whole set up is now very portable.
K W TONG
C8 + CG-5GT, TSA102 + HEQ5 PRO, MK67 + Voyager Mount, WO ZS 80FD + Kenko NES, NexStar 6SE, WO Megrez 72 + Mizar K Mount, Mini Borg 50, C5, PST
Phil Frederick
Reged: 12/19/05
Loc: Seattle, WA & La Paz MX
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: TONGKW]
      #3120019 - 05/22/09 12:07 AM
Nice mod KW!
It's now looking a lot more like the Tak Teegul/Lapides which eliminated the original long arm similar to the Voyager and made a major improvement in stability.
As far as reaching the zenith, what if you redesigned the bracket to make it stiffer and angled it back (45+ degrees?) to move the alt axis further from the mount but not a far as the Voyager arm. Perhaps with a mount extension this may solve the alt problem yet still keep the COG more directly over the mount. just a thought!
Nice job!
Phil
Manny Myles
Reged: 11/29/05
Re: My AT Voyager w/ "Manny Myles" Mods!!!! new [Re: Phil Frederick]
      #3120298 - 05/22/09 06:17 AM Attachment (37 downloads)
I made a set of brackets that turned my Voyager into a VoyagEQ, did not work all that well in declination if this is what you are refering to Phil.
In Acesnion it was great but took a while to slo mo it back to a start postion to track the item again or another object, due to it not really working that great I kinda gave up on the project but saved the brackets to mess with another day.
m2
Manny Myles
Reged: 11/29/05
      #3120300 - 05/22/09 06:18 AM Attachment (39 downloads)
Another view
7 registered and 31 anonymous users are browsing this forum.
