mypontiac
Reged: 09/06/07
Loc: Austin, Tx.
Please recommend mount for TV102 or TV85
      #3101456 - 05/12/09 11:16 PM
Looking at one or the other based on grab and go.
Sean
Psyire
Reged: 06/24/07
Loc: 55* North
Re: Please recommend mount for TV102 or TV85 new [Re: mypontiac]
      #3101469 - 05/12/09 11:22 PM
My vote: AstroTech Voyager w/ Celestron CG5 tripod (2") & a couple of Manny Myles' mods. (works very good)
Mike Sandy
Reged: 08/29/03
Loc: SF Bay Area, CA
Re: Please recommend mount for TV102 or TV85 new [Re: Psyire]
      #3101513 - 05/12/09 11:50 PM
There are several threads discussing the Half Hitch mount right now. It may be the prefect G&G for the 3-4" class scopes. Check out the other threads.
Al Canarelli
Reged: 12/06/07
Loc: Central New Jersey
Re: Please recommend mount for TV102 or TV85 new [Re: Mike Sandy]
      #3101935 - 05/13/09 08:28 AM
If you want grab and go, you want something that sets up easily and is compact and easy to move around. There is nothing that fits the bill better than an Ioptron Mini Tower. I just bought one of these and I love it! I also own a Celestron CG5 Advanced GT, which is considerably heavier than the Mini Mount...and this is why the Mini Mount excels in the grab and go department!
By the way, if you should buy a Mini Mount, consider buying it from Trapezium Telescope, as these people actually test the mount for hours before selling to you...for FREE!
mypontiac
Reged: 09/06/07
Loc: Austin, Tx.
Re: Please recommend mount for TV102 or TV85 new [Re: Al Canarelli]
      #3101993 - 05/13/09 09:20 AM
The Half Hitch looks nice, but it almost as much as the scope. Don't think I can afford that now.
The mini looks nice too. I assume it follows the goto object allowing more freedom in viewing?
Sean
antilles72
Reged: 03/06/07
Loc: Rhode Island
      #3102017 - 05/13/09 09:36 AM
I love my WO EZ Touch. I am sure it will handle either. The TV102 is longer than my ED80, but the weight is similar.
wsuriano
Reged: 11/13/07
Re: Please recommend mount for TV102 or TV85 new [Re: antilles72]
      #3102107 - 05/13/09 10:33 AM
The iOptron MiniTower is designed for portability. Everything except the tripod comes in metal case. You grab the case, grab the tripod and your scope and you're good to go. It is a go-to mount and its go-tos and tracking are spot on. Plus, the mount can handle 2 scopes simultaneously. I concur with the advice of buying from Trapezium.
JimWaterford
Reged: 01/20/09
Re: Please recommend mount for TV102 or TV85 new [Re: wsuriano]
      #3102131 - 05/13/09 10:45 AM
I agree on the MiniTower as being a good grab and go mount for a 102mm refractor. Using the internal 8 AA batteries for power the mount operates quite long (8ish hours?). TV telescopes are a class act. Regards, Jim
SkyscraperJim
Reged: 07/29/07
Loc: Providence, RI
      #3102169 - 05/13/09 11:01 AM
Sean
I also recommend the Half Hitch. If you don't think you can swing it, consider possibly going down a size on the Tele Vue by getting the TV-76, then upgrade to the -85 or -102 later on.
The Half Hitch is made right in your town, maybe you can get a hands-on look at one and try before you buy?
mypontiac
Reged: 09/06/07
Loc: Austin, Tx.
Re: Please recommend mount for TV102 or TV85 new [Re: SkyscraperJim]
      #3102250 - 05/13/09 11:40 AM
Yeah,
Not too far from me.
Just afraid to go see it as I might like it too much!
I like that the Mini will goto and track.
My other scope is also a tracking mount.
Is it a pain to have to keep manually tracking at high mags?
What is the control box on the half hitch?
Sean
Starlighter
Reged: 08/03/07
Loc: Sunny California
      #3102266 - 05/13/09 11:48 AM Attachment (25 downloads)
Sean
I use the Portamount that I replaced the aluminum legs with wooden ones. When used with the TV-85, it's a marriage made in heaven:
Starlighter
Reged: 08/03/07
Re: Please recommend mount for TV102 or TV85 new [Re: Starlighter]
      #3102273 - 05/13/09 11:51 AM Attachment (33 downloads)
If you can live without slow motion controls, then consider the Orion Skyview AZ mount. Extremely stable. Once a scope (or scopes) is perfectly balanced, just a light push on the diagonal and the scope slews with ease.
mypontiac
Reged: 09/06/07
Loc: Austin, Tx.
      #3102867 - 05/13/09 04:17 PM
I like the Orion Skyview AZ mount but would also want the slow mo controls.
Sean
zjc26138
Loved By All
Reged: 02/24/05
Loc: Mingo Junction, Ohio
      #3102877 - 05/13/09 04:21 PM
I owned one of the earlier version on the Skyview AZ mount and found that I didn't need slow-mo controls. It was very easy following objects at higher powers with my AR5 mounted on it.
Deep13
Reged: 01/25/05
Loc: NE Ohio
Re: Please recommend mount for TV102 or TV85 new [Re: zjc26138]
      #3102932 - 05/13/09 04:41 PM
Good mounts are pricey and I would not skimp. I have a TV101 and it is heavier than it looks. I have a SV Nighthawk 80mm I put on a really big camera tripod, but the 101 is just too heavy. I have a TV Gibraltar for that.
Having said that, I do not recommend the Gibraltar, at least with the TV pan head. While it tracks easily in azimuth, it is a pain to track in altitude. The alt. bearings are small and rely on adjustible friction. So either the scope will be hard to balance or else it will be too jerky to move smoothly because of the tension.
mypontiac
Reged: 09/06/07
Loc: Austin, Tx.
Re: Please recommend mount for TV102 or TV85 new [Re: Deep13]
      #3102952 - 05/13/09 04:49 PM
Recommendations then for a TV85?
Trying to keep costs at about $500
Sean
Starlighter
Reged: 08/03/07
      #3103113 - 05/13/09 06:05 PM
Either the Portamount (with wooden legs) or the Orion Skyview AZ.
zjc26138
Loved By All
Reged: 02/24/05
      #3103114 - 05/13/09 06:05 PM
With that budget in mind I would go for:
1. Astro-tech Voyager- Easily will handle the TV and if you want you can get some wooden legs from Hands on Optics. Cost: 300 for mount + 75 for new legs(if you think you need them) 375.00 with money left over to spend on whatever. Plus it has slo-mo controls
2.Orion Skyview Alt-Az. Doesn't have slo-mo controls but can handle a big scope(easily handled my AR5 fully loaded), in case you ever upgrade to a bigger apo. Its very smooth and therefore, I think, doesn't need the slo-mo cables. Price is 420.00
Hope this helps.
mypontiac
Reged: 09/06/07
Loc: Austin, Tx.
      #3103127 - 05/13/09 06:12 PM
I like the Astro-tech Voyager.
Thanks guys!
Sean
Jim7728
Reged: 04/10/05
      #3103198 - 05/13/09 06:44 PM Attachment (24 downloads)
Sean
Telepod head on a Oberwerk wooden tripod or heavy duty Bogan tripod 3026,ect.
Edited by Jim7728 (05/13/09 06:53 PM)
25 registered and 38 anonymous users are browsing this forum.
