Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
CGEM Edge C8 sutitable for AP at 2000mm FL?
      #3558622 - 01/13/10 04:01 PM
Is CGEM EdgeHD C8 suitable for AP with autoguiding greater than 10 minutes? I have a nice Hutech (Mitsuboshi) Off Axis Guider, so guide scope won't be used to save weight.
Anyone has 10 minutes or greater subs at 2000mm FL with C8 and CGEM? It does not have to be Edge C8. If so, please attach photos.
If CGEM is not suitable, then probably Losmandy G-11 would be the next choice even though it costs twice as much. I would rather have CGEM mainly for easier to use hand controller than G-11.
Peter
Luke Skywalker
Reged: 04/22/08
Loc: Sudbury, Ontario
Re: CGEM Edge C8 sutitable for AP at 2000mm FL? new [Re: Peter in Reno]
      #3558984 - 01/13/10 06:54 PM
Since the CGEM comes with and auto guider port, I don't see why it would not work for auto guiding over ten minutes.
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
Re: CGEM Edge C8 sutitable for AP at 2000mm FL? new [Re: Luke Skywalker]
      #3559049 - 01/13/10 07:32 PM
I am aware of that. I wanted to hear from people who actually own them.
I had C-11 with Atlas EQ-G and C-11 was too heavy for AP for the mount. Atlas EQ-G load capacity is about the same as CGEM. I wanted to know if CGEM is stable and durable for 10 minutes plus guiding for C-8 at 2000mm. The only disadvantage of Atlas EQ-G is the latitude adjustment bolt is extremely difficult to raise latitude while the heavy scope is mounted. I read from this forum the CGEM latitude requires much less effort to adjust while scope is mounted.
I am more interested in narrow field than wide field AP like M27, M57, etc.
Peter
galacticphoto
Reged: 11/12/09
Loc: Huntsville, AL and Atlanta, Ga
      #3559932 - 01/14/10 08:05 AM
I'll bet the mount will autoguide for a lot longer than 10 minutes, but the performance may not be adequate for what will be needed at the image scale you'll have at 2000mm.
If you use binning (or go with a cam that has very large pixels), so that your image scale is approaching a couple arcsec, you'll have much more success in the guiding department (though lower resolution).
Alternatively, get a good focal reducer, or try the HyperStar approach.
Robert
EricCCD
Reged: 04/14/04
Re: CGEM Edge C8 sutitable for AP at 2000mm FL? new [Re: galacticphoto]
      #3559986 - 01/14/10 08:54 AM
One other option would be to use Adaptive Optics (AO). SBIG's got its AO-8 and AO-L units, Starlight Express has one, and now Orion is coming out with one as well. From what I understand, AO units can make a marginal mount perform pretty well for imaging (e.g., older LX200's).
HTH,
Eric
EricCCD
Reged: 04/14/04
Re: CGEM Edge C8 sutitable for AP at 2000mm FL? new [Re: EricCCD]
      #3560019 - 01/14/10 09:13 AM
Sample images with adaptive optics
These were not with a CGEM, but with fork-mounted LX200's. Hopefully today's AO units can make a CGEM adequate to excellent in similar manners.
Eric
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
      #3560123 - 01/14/10 10:23 AM
Good point about AO. I was planning on using SXVR-M25C color CCD camera. It's 6 MP with 7.8uM pixels. Is the pixel size big enough for C-8? Also I am planning on using Lodestar for guiding. Lodestar is much more sensitive the SSAG. I had SSAG and didn't like the lack of sensitivity.
I am trying to minimize weight like using OAG instead of guide scope. Adding AO would add a little more weight to the rear making it more difficult to balance a back heavy and short tube C-8. It may require adding counter weight at the front.
Peter
DaemonGPF
Redonkulous
Reged: 03/22/08
Loc: Aurora Colorado
      #3560185 - 01/14/10 10:55 AM
I'd go with a larger, more refined mount before AO.
I understand your concern about long exposure on a CGEM with that much FL and weight. Celestron advertises C11s on CGEMs for AP which is scarey. The same goes for the CG5 and C10 newt. Having experienced one of those configs myself and knowing it couldn't handle real long exposure times, I'd be skeptical without seeing some examples too. Granted a CGEM is much more refined than a CG5, and does have PEC, it still will have some accuracy limitations and the payload capacity isn't much different. I'v guided a CG5 at 1200mm with 18 lbs up top close to 10 mins, but without PEC the mount would jump every gear cycle (10 mins) too far for autoguiding to iron out without losing the exposure. So I worked with 4 min subs or very short FL to compensate. My guess is that the CGEM will perform closer to a CGE than a CG5 due to the improvements in design. I've seen decent images from CGEM owners with long exposure times, but not at 2000mm or more. I'm just as curious as you are to see those examples.
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
Re: CGEM Edge C8 sutitable for AP at 2000mm FL? new [Re: DaemonGPF]
      #3560297 - 01/14/10 11:37 AM
It looks like I may end up getting Losmandy G-11. If no one post sample pictures using CGEM and scope near 2000mm FL, then either the results were not good or no one dared to try. I have seen great pictures using CGEM but with much smaller scopes like 500mm to 800mm FL refractors.
Money is not really an issue for me. It's the software in CGEM hand controller that's seems to be much easier to use than Losmandy. I guess I just have to learn to use Losmandy's Gemini hand controller and get used to it. I read the Gemini operating manual and it has a steeper learning curve than CGEM but that's ok. It would be nice to integrate CGEM handcontroller with Losmandy G-11.
Peter
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
      #3560358 - 01/14/10 11:59 AM
Peter
A CGE would be just about that.
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
Re: CGEM Edge C8 sutitable for AP at 2000mm FL? new [Re: jrcrilly]
      #3560402 - 01/14/10 12:22 PM
CGE was another option but it does not cross the meridian without flipping. This is the major drawback for me. Is this feature part of hardware or firmware. Does the latest firmware in CGE allow the mount to cross the meridian without flipping?
Peter
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
      #3560462 - 01/14/10 12:52 PM
All gems do the meridian flip at some point ... the differences in the mounts (physical and software) just determine where in relation to the meridian they do the flip. The better question is how far past the meridian does a mount travel before it has to do the flip.
Getting 10+ subs at 2000mm is a tall order for just about any commercially available mount under $5000. It won't the amplitude of the PE that will be the most concerning it'll be the noise and the transitions on the PE curve.
A good example of a CGEM might be able to do it but a CGE or G11 is likely a better starting point. Either way you're likely into some tuning and upgrades unless you spend really big bucks ($7000+). I think you're best option would be a new G11 with a series of upgrades such as the Ovision worm. That combination won't be cheap though ($3700+). I'd also consider if possible a pier mounting to remove the tripod from the equation.
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
Re: CGEM Edge C8 sutitable for AP at 2000mm FL? new [Re: mclewis1]
      #3560480 - 01/14/10 01:01 PM
Yes, I know GEMs do meridian flips at some point. Several can cross meridian without restrictions. But is CGE more restricted than other GEMs? In other words, can you set the CGE meridian flip point like G-11 can or is the CGE "hard-coded" to flip as soon as it touches the meridian? If so, I don't want it.
Peter
Reged: 04/30/03
Loc: NE Ohio
      #3560520 - 01/14/10 01:18 PM
Yes. The reason folks talk about the CGE having issues is that it has a safety feature - it stops tracking a bit past meridian rather than cranking along until something expensive runs into something solid. My LXD750 did that also - it's a nice bit of cheap insurance against carelessness (or falling asleep).
If the flip is inevitable then it doesn't really matter where it happens - it's once per night.
Regarding shooting at sub-arcsecond resolution: none of the mounts mentioned so far in this thread make any promises whatever about periodic error. Guiding them down to less than an arcsecond may be possible but it's probably not a suitable task for a beginner. Better to use a mount that DOES specify PE at a reasonable level. For a C8 I'd recommend an EM-11. It's in the same price class as a G11 but much more precise. You can have excess capacity or extra precision for the same money - but it'll cost you much more to have both (though, come to think of it, you could probably pick up a used EM-200 for about the same money and have both). I'd vote for precision unless you are ready to reduce your expectations in terms of resolution. Just be aware that the Tak mounts (like the Losmandy mounts) lack the safety feature mentioned above.
Reged: 04/30/03
Loc: NE Ohio
      #3560551 - 01/14/10 01:30 PM
Peter
Very few mounts do an automatic meridian flip when tracking. Maybe the Paramount? The "flip point" you mention that is selectable has to do with which side the mount will use for a goto operation to a point near the meridian. If you permit a Losmandy to cross the meridian while tracking, it'll just keep going until somebody or something makes it stop. I don't remember where the stop is on the CGE; maybe 15 degrees or so past meridian? That's where the LXD750 would stop.
DaemonGPF
Redonkulous
Reged: 03/22/08
      #3560568 - 01/14/10 01:44 PM
IIRC the CGE Pro will go 20 degrees. Unsure about the regular CGE.
Konihlav
Reged: 03/05/09
      #3560578 - 01/14/10 01:48 PM
CGE goes really only a little past meridian! I'd say some 3 degrees?
CGE Pro can go as other mounts a lot more after meridian, but it's a different price range.
DaemonGPF
Redonkulous
Reged: 03/22/08
Re: CGEM Edge C8 sutitable for AP at 2000mm FL? new [Re: Konihlav]
      #3560588 - 01/14/10 01:54 PM
Yep, but he did say money wasn't a concern so I figured I'd throw it out there.
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
      #3560601 - 01/14/10 02:00 PM
CGE Pro is way too heavy for portable use. Portability is important to me.
I wonder if I can open the CGE and disconnect the safety feature to keep on tracking past the meridian? Anyone done that?
Peter
Reged: 04/30/03
Loc: NE Ohio
      #3560634 - 01/14/10 02:14 PM
No, you can't.
If this meridian issue is really important to you, you might consider a CPC800. That'll track horizon to horizon without a hitch and without any collision danger, and probably with better tracking precision than anything less expensive than a CGE or G11.
If you want to be able to shoot well past meridian, and are willing to take a chance on collisions, then my EM-11 or EM-200 recomendation stands.
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
      #3560751 - 01/14/10 03:09 PM
I have already considered fork mounted with wedge but many people voted against it because it's not as stable as GEM. Also it's harder to balance fork mounts than GEMs. There may be vibration issues while tracking with fork/wedge setup.
Will CPC800 with heavy duty Mitty Proline wedge work well for AP at 2000mm FL?
Peter
galacticphoto
Reged: 11/12/09
      #3560886 - 01/14/10 04:36 PM
It looks like I may end up getting Losmandy G-11... It's the software in CGEM hand controller that's seems to be much easier to use than Losmandy.
I've used the ASGT (CG5), and now the CGE and MI250. The MI uses the Gemini controller, as does the various Losmandy mounts. The Gemini is generally more versatile than the Celestron, and in being so, has more variables. You seldomly need many of its routines, so just memorize the frequently used aspects, resort to the book for the rest.
I won't say that every 6yr old can master it, but I'll sure bet that many can. It's not that difficult.
By the way, imaging at 2000mm w/ typical cam pixels is not trivial. That's less than 1 sec/pix. The CGE was pressed to yield good results w/ the Mewlon at 3000mm using 6.45u pix binned X2 (~ same as you're discussing) w/ an OAG. The MI has yielded essentially 100% good results.
I'd still keep the AO option alive if you go w/ a G11, CGE, or EM200. It would make those stars nice and round (and keep your image resolution up).
Robert
AlexN
Reged: 08/09/08
Loc: Brisbane - Australia
      #3564160 - 01/16/10 11:00 AM
I'll jump on the AO bandwagon here... I used AO with my ST9 + C11 on my EQ6, the results even with poor seeing and a bog stock mount with no upgrades done to it were great... AO compensates for nearly any inadequacy within the mount brilliantly. You don't see many long exposure photography done with the likes of an LX200 mount on a wedge, especially not at say, 2500mm F/L or over.. Insert AO into the equation and even a fairly average mount can do 20 minute subs... A fork setup on a wedge may vibrate a little, and may have some wobble.. but if you're able to guide at 10hz, you're really not going to have guiding problems..
I suppose in that respect, why don't you just get AO and keep using the C11 on the EQ-G?
Starhawk
Space Ranger
Reged: 09/16/08
Loc: Tucson, Arizona
      #3564253 - 01/16/10 11:50 AM
I've been using a NexStar 11GPS on the Celestron HD wedge, and even using live view on a camera and holding on to the focusing knob by hand isn't causing me a vibration problem. Before that, I have been using a NexStar 8GPS with an AT66ED piggybacked using the celestron piggyback bracket which provides a standoff big enough to rotate the telescope through 360° without the focuser knobs hitting. My counterweight is a Vixen dovetail bar with a home-machined weight sled on it, and that didn't have vibration problems. I am starting to think the tales of fork mount woe are vastly overstated, if they are based on actual experience at all. Note the really big scopes (8m +) are 100% mounted on forks. If it were a flaw, that wouldn't be the case.
-Rich
Peter
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
Re: CGEM Edge C8 sutitable for AP at 2000mm FL? new [Re: AlexN]
      #3564306 - 01/16/10 12:15 PM
I no longer own them. I am looking for smaller size scope for better portability.
Peter
Tiny
Reged: 05/02/08
      #3565497 - 01/17/10 01:08 AM
Peter
This is a negative but one you simply learn to cope with by planning for the flip earlier. No matter what GEM mount you choose, be it a losmandy or celestron, you'll be doing a flip. I believe both Gemini and Celestron hand controller display a clock to let you know when a flip will be required so this makes planning your exposures a non-issue. Simply do an exposure up until you meet the meridian, flip, re-aquire and you're good for the rest of the night. Simple.
I personally favor Losmandy mounts for other reasons and yes having the option to track a bit past the meridian is nice to have [especially if you have bad LP] but i wouldnt let it deter you from purchasing a cge, especially if you feel more comfortable with the software.
At this point and time my only concern with purchasing a CGE would be the worry of Celestron significantly updating it, which will happen eventually, with some of the nicer features found on the CGE pro. Though this most likely wont happen for years from now.
18 registered and 32 anonymous users are browsing this forum.
