mish
Reged: 02/10/09
Loc: West of Astronomics
Re: What are the chances of updated Losmandy mount new [Re: chupacabra]
      #3622334 - 02/13/10 09:43 AM
I'm not generally clumsy, but moving heavy gear around when tired . . . eventually I'd ding one of those motors and possibly do some damage
Anyone clumsy enough to break a G11 motor carrying it to or from the tripod probably shouldn't be pursuing this hobby, because they'll have to carry a heavy OTA as well, and that's where the clumsiness would really cost them. A G11 is infinitely safer to haul around than a C11, so anybody likely to bust loose a motor on a G11 is much more likely to break a collector plate or destroy a brittle and expensive objective lens. This really isn't a hobby for the clumsy, and this really isn't a problem for the G11.
chupacabra
Reged: 03/26/07
Loc: Land O'Lakes, FL
Re: What are the chances of updated Losmandy mount new [Re: mish]
      #3622499 - 02/13/10 11:18 AM
So I guess the two people I've seen with rubber bands holding their motors in place need to have their astronomy cards revoked. Too clumsy = not allowed to play? Accidents happen. I appreciate your input that this is a non-issue, but just because I have other fragile gear to worry about doesn't mean I want more.
Again, so much depends on each person's needs, preferences, and time constraints. I can see this being a non-issue for a lot of people. It's an issue for me.
Re: What are the chances of updated Losmandy mounts? new [Re: pogobbler]
      #3622503 - 02/13/10 11:22 AM
      #3622520 - 02/13/10 11:31 AM
"Beyond that, I would suggest that the term "better integration" is a misnomer."
Nah, it fits pretty well. Lack of integration = the "guts on the outside". Integration = "guts on the inside". Things like internal cable routing, for example, represent a higher degree of integration between mount mechanical bits and the electronic drive bits. Losmandy is like the way Vixen used to be - guts on the outside. Many mount makers (Takahashi, A-P, Celestron, Vixen, etc.) have moved toward cleaner, more highly integrated mounts. Losmandy has not.
The question is...is it better to have the guts on the outside where you can access them easily or on the inside where they are out of the way? The answer to that may depend on the observer and his or her usage.
As for the mechanical excellence of Losmandy mounts, I would say there are some weak areas. The need to periodically adjust the worms for backlash, for example, is just plain poor design. A better mechanical design would let you set backlash and forget it until you wanted to change it. IMO whether Losmandy needs electronic integration updates or not, a little mechanical redesign work would help as well.
mish
Reged: 02/10/09
      #3622545 - 02/13/10 11:49 AM
You are always free to choose whatever "issues" you prefer. You've expressed concern about a mounting scheme that has proven to be robust and reliable. As others have pointed out already, that same "issue" also permits easy field repairs, simple drive system upgrades, and it virtually eliminates the need to ship the mount someplace far away if repairs are required.
I guess that one person's issues are another person's features.
mish
Reged: 02/10/09
Re: What are the chances of updated Losmandy mount new [Re: jrbarnett]
      #3622574 - 02/13/10 12:13 PM
Jim:
Exactly. And that's why the "better" in "better integration" is a misnomer. It presumes that "more" equals "better", and as you point out so well, whether more is indeed better depends on the context.
The same can be said of any engineered system: compromises are a necessary part of every design. I chose the Losmandy because, at its price point, the practical effect of those compromises is minimized. As an engineer, I do prefer to invest in those systems that are found right at the point of diminishing returns!
Losmandy appears to be incrementally improving their mounts. For example, I'd read that the polar alignment scope's illuminator was poorly-designed, but my G11 was delivered with a new and better design. There's currently some indications that the worm supports are being redesigned, and if so, it will be interesting to see if those improvements make it into new stock mounts, or are available as an upgrade.
The mechanical aspects of these mounts are better-served by incremental improvements than by any radical redesigns. Integration as others have described it might likely require more use of cast components, and unless those were very carefully designed and constructed, such "improvements" would compromise other, more desirable, features of these mounts.
So I suspect we'll continue to see more evolutionary improvements in the mechanical components of Losmandy products, and if revolutionary upgrades are in the works, they would likely be found in the drive electronics.
chupacabra
Reged: 03/26/07
      #3622695 - 02/13/10 01:38 PM
Mish, I think you're being defensive and you don't need to be. There are some good points being made in here and the criticism has been constructive. There are ways to indicate that you don't share someone's concerns without suggesting it's silly or ignorant to have that concern. Whether or not this mounting scheme has "proven to be robust and reliable" is certainly debatable.
Mounts I've seen with rubber bands holding motors in place: Losmandy 2 - All others 0. I've heard and read far more Losmandy owners express concern over the motors than any other brand. Are the Losmandy mounts better overall than many of the competitors? I believe they are. But I think the motors/mounts are the weakness of the Losmandy mounts.
As far as feature vs issue . . . preferring the Losmandy method of integrating parts has nothing to do with the weak mounting of the motors. The concept can be great (AP mounts are really pretty similar) and the implementation poor at the same time.
Phil Cowell
Reged: 05/24/07
Loc: Southern Tier NY
      #3622719 - 02/13/10 02:01 PM
I'm going to sit back and wait for Cardinal Fang and the Inquisition to arrive.
mish
Reged: 02/10/09
      #3622763 - 02/13/10 02:29 PM
Well, on that first point, I'm not being defensive, but no offense is taken by me for that assumption. And I will agree that there's no need to be defensive about any of this (it's a piece of metal, for heaven's sake!), so on the latter part, I agree with you. No harm, no foul.
As I wrote before, you are entitled to your opinions, i.e., one person's issue is another person's feature. To me, it's a feature I enjoy. To you, it's an issue of concern. Sounds like a healthy diversity of opinions to me!
mish
Reged: 02/10/09
Re: What are the chances of updated Losmandy mount new [Re: Phil Cowell]
      #3622774 - 02/13/10 02:37 PM
Cardinal Fang is out of the office today. He's busy replacing an EPROM in his Gemini GoTo system!
bseltzer
Reged: 10/28/07
Loc: East S.F.Bay, CA
      #3622805 - 02/13/10 03:00 PM
Seems Biggles arrived early...
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
      #3623382 - 02/13/10 10:02 PM
Rainer,
I thought it was the finance department that said that... Usually also while deciding that much of design criteria was unnecessary
zoran
Reged: 06/09/06
Loc: Zagreb, Croatia
Re: What are the chances of updated Losmandy mount new [Re: CounterWeight]
      #3626171 - 02/15/10 01:00 PM
Hello all!
Since I don't live in the U.S. for me big plus for Losmandy mounts is that I can maintain and repair them myself. With "more integrated mounts" if something goes wrong you usually have to send them back to the factory for repairs.
Zoran
6 registered and 24 anonymous users are browsing this forum.
