deltav3
Reged: 09/01/09
CG-5 Mount - Polar align, Go-To
      #3618004 - 02/11/10 03:19 AM
I have a CG-5 Mount (HC version 4.16, MC 5.16) and have yet to get any Go-To accuracy after a polar align.
My steps:
1) 2 star
2) 1 star from list, than Polar align from 'Align' button
3) Unsync
4) Re-align the same 2 stars from the First align (polar align wrecks this so it is needed)
4) From list Menu choose another star, go into Calib stars and add the new star(s). (I add 1-4 does not seem to make much difference)
This puts M42 into the eyepiece, but any other objects ie: M81/82 I have nothing.
* Note I use a C8 with a 80mm refractor which does the imaging with a wider field of view (400mm F5) so Go-Tos do not need to be in the eyepiece.
Yet it can not even do that! Please let me know your procedure after a polar align to get Go-To Functioning.
HaleBopper
Reged: 01/14/08
Loc: Land of Ice and Snow
Re: CG-5 Mount - Polar align, Go-To new [Re: deltav3]
      #3618126 - 02/11/10 07:10 AM
Well unless you're doing AP, you don't really need to do a polar alignment. It's been a while since I did polar alignment on my CG5, but this is what I do and have not had any problems. Oh and I don't use the sync functions. I'm not not sure what you were "unsyncing".
1) Rough alignment on Polaris. Sometimes I eyeball it through the polar scope bore hole and put in the centre.
2) 2 star alignment
3) 1 or 2 calib stars. I find that it does not matter too much how many you use, but the more accurate, the closer to Polaris your mount will slew when doing Polar alignment.
4) Do the polar alignment and centre polaris WITHOUT using the HC.
5) Put the scope back to the index marks and go through the 2 star alignment again and add as many calibration stars as you can. I have an old version of the software so I can only add 3.
Hope this helps.
Reged: 07/06/07
      #3618176 - 02/11/10 08:02 AM
My steps:
1) 2 star
3) Unsync
As you've been told polar alignment fwill have little or no effect on your go-to accuracy.
What you SHOULD worry about for obtaining best go-to accuracy:
1. Centering the correct stars. You can't be pretty sure, you must be SURE. Center using a medium power reticle eyepiece
2. Always use up and right for final centering.
3. Always run the mount with a fully charged 12vdc battery.
4. Add calibration stars until the next calibration star is at least in the finder center if not in the eyepiece when the slew stops.
When properly aligned, these mounts are extremely accurate go-to-wise.
freestar8n
Reged: 10/12/07
      #3618226 - 02/11/10 08:45 AM
Your step 4 statement that polar align wrecks goto should not be the case if things are working right. Even though the mount is moved, the PA routine compensates for it and should result in good GoTo after PA.
I would recommend doing a full calibration first so the mount is characterized and the GOTO ACCURACY is good - which does NOT require a good polar alignment - but IS necessary for the polar alignment to work well.
Then do the polar alignment routine carefully and immediately check to see if your GoTo is accurate enough. If it is, you are done; if not, realign on two stars but you shouldn't need calibration stars.
In short - I think your main problem is that in step 1 you only did a 2-star alignment and did not do a calibration.
Frank
deltav3
Reged: 09/01/09
Re: CG-5 Mount - Polar align, Go-To new [Re: rmollise]
      #3618439 - 02/11/10 10:49 AM
Thanks for the reply. But I would like to point out that the manual says that Go-To accuracy will be affected and is the case for me.
I have Dec,09 CG-5 (firmware already latest) so the supplied manual was reflecting an older firmware. The manual on celestron site even with revisions appears a bit off ("Addendum to the Advanced GT mount manual (firmware v.4.10). This leaves the process a bit random it seems.
In case you are wondering about the UnSync, after a polar align (All-Star) feature, this is required or you will be locked in a certain part of the sky. (polar align uses your final Finder/Center Eyepiece/Center
to sync on that part which needs to be undone)
anwsers to your questions:
My Go-To works fine, Why things do not work
after a polar align I do not know. So you at least Know My methods for a Normal Go-To work, and I get around 3 min unguided for a polar align at 400mm for imaging so my Polar align works. For power I use and Outlet not a battery.
I use a 25mm Eyepiece (yes,yes I know) I dont have all night to find stars, and you know its working because my my go-to accuracy(before polar) and polar align work (imaging time).
Just wondering do you have the same firmware version?
deltav3
Reged: 09/01/09
Re: CG-5 Mount - Polar align, Go-To new [Re: freestar8n]
      #3618458 - 02/11/10 11:01 AM
Do you mean Normal Go-To + 2-3 Calib stars than polar align? I gave this a try before same result. Oddly enough once I can actually find another Messier object than Add that as a calb Object it seems to goto the other objects no problem, very strange. (This is after a polar align + 2 calib stars)
I will give it another try tonight.
Thanks.
Frank
Reged: 07/06/07
      #3618514 - 02/11/10 11:25 AM
Point out if you will, but 'tain't so.
Let me tell you a story. Just a couple of months back, one of the new guys in the club brought his CG5 out for the first time to our darksite. I was busy, so was the other guy out there who uses a CG5. We kept an eye on him and helped when we could. Several hours later NG comes over to my observing position:
"Unk Rod, can you help? My go-tos are great, but whatever I find don't stay in the eyepice long."
I gave his setup an eyeball. Yep, the CG5 put whatever I requested in the field of the C8 (at f/10). But the trackin' sucked. Hmmm... Then it dawned on me: Bubba had "polar aligned" on _Kocab_ instead of Polaris.
I have used all the firmware versions containing AllStar. If your go-to is good normally, but not after an AllStar Polar Alignment (which is NOT what I got out of the initial post), your problem is in syncing/realigning. In order to see if that is the problem, forget all the cotton-pickin' unsyncing and yadda-yadda-yadda.
Turn the mount off after you run Allstar and do a go-to alignment. Just a normal alignment with Cal stars.
Not exactly sure what you are doing firmware-wise, either. 4.10 DID NOT HAVE ALLSTAR. That began with v4.15. If you do indeed have 4.10 YOU CANNOT use Allstar--your HC don't have it--and you shouldn't follow those instructions in the manual. You will polar align using Polaris only and will follow the procedure in the polar alignment procedure in the Utility menu.
deltav3
Reged: 09/01/09
      #3618625 - 02/11/10 12:22 PM
Forgot to say I am very sure I got the correct stars (in Eyepiece and Finder) I use a Skyscout and I know a few of them by name. (yes the skyscout does screw up sometimes, easily fixed)
I use the latest firmware, no I did not downgrade.
As for the Unsync option, you need to or you will be warned when you polar align to unsync. (depending on how you aligned w/ calib stars or not)
Thanks for the advice anyways.
freestar8n
Reged: 10/12/07
      #3618636 - 02/11/10 12:28 PM
I would do the alignment and calibration carefully with 3 or 4 calibration stars. Do it carefully with crosshairs if possible. Don't align on Messier objects - only stars - and do it carefully, finishing with up/right.
That should make your GoTo as accurate as possible, so that your PA is then more accurate.
It sounds like your centering may not be as accurate as it could be, and your calibration isn't as good as it could be.
Frank
deltav3
Reged: 09/01/09
      #3618700 - 02/11/10 01:02 PM
Frank
I make sure every time my stars in dead in the finder cross hairs (6x30) and in the eyepiece. I will give this another try tonight.
Thanks.
mike174
Reged: 01/04/05
Loc: Central, NJ
      #3618908 - 02/11/10 02:45 PM
I'll be getting a SW EQ-5P and wonder if the setup is similar to the CG-5?
Tnx,
Reged: 07/06/07
      #3619327 - 02/11/10 06:23 PM
One last time and then I'll move on. If the polar alignment routine messes up the go-to, you are doing something wrong afterwards with regards to unsyncing. Polar align the mount. Turn it off. That won't harm your polar alignment. Then turn it back on and do a normal 2+4 alignment.
freestar8n
Reged: 10/12/07
      #3619369 - 02/11/10 06:43 PM
Rod-
He is talking about unsyncing AFTER doing AllStar polar alignment. In order to do AllStar you must sync on the polar alignment star. After you complete AllStar, you are still sync'd to that star. If you then go far from that star, you may be better off unsync'ing to improve GoTo accuracy. If you find your GoTo is still not great, you may choose to replace alignment stars - which requires an unsync anyway.
I think there is a misunderstanding here. You don't need a good polar alignment to have good GoTo - but you do need to do the polar alignment well, and ACHIEVE a good polar alignment, for GoTo to be good immediately after doing AllStar. The alignment should, and must, be good after allstar in order for you to have accurate GoTos without a new alignment - and good GoTos right after doing AllStar is a big advantage of AllStar.
Turning off the mount and starting over would defeat a lot of the purpose of AllStar, but you could do it if you want.
Frank
Chris Rowland
Reged: 02/28/05
      #3619370 - 02/11/10 06:43 PM
This is what I do after an AllStar polar align:
That's it, nothing.
I don't realign, replace alignment stars, replace calibration stars, undo sync, anything. I just use it - and I've no complaints about goto accuracy.
What I do do is a good alignment to start with, with two alignment stars and two or three calibration stars, using a reticle EP.
AIUI, if your gotos are good before you polar align they should be good afterwards. That's as long as the polar alignment adjustments are basically in azimuth and altitude and you centered the star both at the sync and polar alignment stages.
Chris
joec33
Reged: 06/13/09
Loc: Orange County, NY
Re: CG-5 Mount - Polar align, Go-To new [Re: Chris Rowland]
      #3619506 - 02/11/10 07:53 PM
If you find you have to adjust the mount quite a bit during All-star polar align you should always shut the mount off and redo your 2 star alignment. Moving the mount to much using the alt and AZ adjustments will totally throw your goto's off. Your mount has no idea that it's being moved when you play around with anything but the controller simple as that. I just bought my mount in Dec also so we have the same firmware. If you just follow the steps I'm about to give you you'll be ready to image with perfect goto's. Going through the whole unsync and resync is a waste. 2 star align, 4 calibration stars, polar align, shut off mount and do it again. After your second polar align shut off the mount and do a 2 star align and 4 calibration stars and you will be ready to image. In no way do you have to go through all of this if your not imaging but since you are I highly recommend you do! This works great for me and most of the people I have talked to on this site that image using the cg5-gt mount.
deltav3
Reged: 09/01/09
Re: CG-5 Mount - Polar align, Go-To new [Re: joec33]
      #3619613 - 02/11/10 09:11 PM
Just wondering where are you getting this idea that the mount needs to be powered off realigned/ than polar aligned than powered off again. Was this a step of an older revision of the Cg-5 mount? (Mine is December 2009)
The manual for both the CG-5 and the CGEM mount (funny enough the CGEM lists exactly my aliment procedures under the polar align section) say BOTH contain NOTHING about powering off the mount and still retaining any alignment (which is why it is necessary to realign and add calib stars after a polar align)
joec33
Reged: 06/13/09
      #3619879 - 02/11/10 11:42 PM
You can reference the manual all you want friend. You can also use CAPITAL LETTERS all you want but it's not going to change the fact that your the one with the problem not me. Time and time again I have seen threads about how people set up this mount for imaging and it seems to always come down to this method. Take it or leave it. Night after night I use this method and my goto's place the objects I want to image right on my DSI's little ccd chip. Just give it a try next time your out, if it doesn't work then you can use your capital letters all you want.
ps. I bought my mount in December of 09' just like you.
joec33
Reged: 06/13/09
      #3619900 - 02/12/10 12:02 AM
Also I would stay away from using calibration stars that are to close to the east or west horizons, zenith or celestial pole.
deltav3
Reged: 09/01/09
      #3619958 - 02/12/10 12:37 AM
I just tried a 12mm Illuminated eyepiece and it appears to work better than before, go-to is now in the eyepiece after a polar align.
My steps:
2 star align, polar align, unsync, realign 2 stars, 1 calib star. puts m36,m37 NGC 869 into a 25mm eyepiece.
Thank You all for the help!
freestar8n
Reged: 10/12/07
      #3620198 - 02/12/10 07:52 AM
The AllStar polar alignment procedure knows exactly how far the mount is being moved, because it knows how far off the alignment star is when it asks the user to adjust the mount. As long as the user does the physical work that AllStar requests, and theoretically it could be many degrees of motion, the mount knows where it was before the alignment, and where it is after the alignment - all without powering down and realigning.
But it's important that the mount be well aligned (but not well polar aligned) before the PA procedure, so the mount really does know how far off PA it is. This means the alignment/calibration prior to PA should be accurate and have many calibration stars.
After PA, check goto accuracy and, as needed, try unsyncing (if doing GoTo's far from the PA star) and then replacing alignment stars.
Powering down and starting all over should work fine - but the idea of AllStar is to avoid this.
Frank
23 registered and 43 anonymous users are browsing this forum.
