Privacy Policy | Please read our Terms of Service | Signup and Troubleshooting FAQ | Problems? PM a Red or a Green GuÖ uh, User
Pages: 1 | 2 | 3 | (show all)
DHB001
Reged: 07/07/09
Loc: The Netherlands
Another CG5-GT "spikes during guiding"-thread...
      #3746083 - 04/15/10 07:23 AM Attachment (102 downloads)
Last night, I was trying out my radial guider on M51, hoping that my flexure would be a thing of the past. Well, I set up my equipment at around nine pm, went to bed around 4.30 am, and all this time in between only yielded 2 hours worth of usable data. Thatís absurdly inefficient, and was caused by 2 things, 1) sudden jumps during guiding (see accompanying screenshot), and 2) difficulty finding a suitable guide star through my OAG (lost quite some time realigning after the meridian flip).
I want to find a solution for the first issue, because it has been bugging me ever since I got my current equipment about a year ago. Iíve already read a lot of threads about these jumps, and I think Iíve done as much as I could possibly do to minimize these jumps. Besides having relubed my mount, and in the process eliminating as much backlash/slack as possible, I have taken the following precautions:
1) Polar alignment procedure via my mount. This is accurate enough not to cause significant field rotation, but is sufficiently inaccurate to ensure a little drift in the DEC, so I can guide the DEC north only or south only, which keeps constant traction on the gears.
2) Make the RA axis a little east heavy, and the DEC axis back heavy (i.e., just a bit more weight on the camera side than on the corrector plate side). Again, this should ensure constant traction between the gears on both axes.
Now, Iím only using a C6, a Rebel XS / EOS 1000D DSLR and an Orion SSAG autoguider, the combined weight of which should be well within the operational limits of the CG5 mount. Yet, I still manage to get these jumps during guiding. Whatís causing this? Does the fact that M51, when passing through the meridian, for me is almost right above me in the zenith, have anything to do with these spikes? Have I inadvertently made the imbalance on my axes too big? I only move the scope and the counterweight about 1cm (or just under half an inch) away from what I perceive to be the point of balance. Those of you who use this mount as well, do you preload your axes, and if so, by how much?
For those who want to see my guide logs, please see the links below. The first run was to determine whether to guide north or south on the DEC, and the last 3 to 5 runs I experimented a little with some settings, like dec algorithm, and aggressiveness and hysteresis combinations. But everything in between is ordinary guiding with the same settings used throughout (except after the meridian flip, when of course I switched between north only and south only dec guiding).
I really hope someone can help me combating this issue. Thanks to anyone who can offer any advice.
Guide log 1: http://www.mediafire.com/?jjeujy22mmy
Guide log 2: http://www.mediafire.com/?yjny3yii2wz
Bear in mind that guiding was done at 950-1000mm, which, with my setup, equates to a resolution of approximately 1.0 arcsec/pixel for the SSAG.
Reged: 07/06/07
Re: Another CG5-GT "spikes during guiding"-thread... new [Re: DHB001]
      #3746091 - 04/15/10 07:33 AM
If the spikes were not periodic in nature, the obvious culprit could be wind or other vibration.
DHB001
Reged: 07/07/09
Re: Another CG5-GT "spikes during guiding"-thread... new [Re: rmollise]
      #3746148 - 04/15/10 08:32 AM
Hi Rod,
Thanks for your response. The spikes were not periodic. According to the guide log, the first spike only happened after a little under a thousand corrections, but later during the night, they began to happen more frequently. Oddly enough, while most spikes were from the DEC axis, a couple of spikes were from the RA axis...
It was a clear night with no wind, so although otherwise a plausible cause, in this case it certainly could not have been wind. I cannot think of anything that could have caused vibrations. My setup stands in the middle of my backyard, on a terrace of street tiles. These tiles don't sag or wobble, and are really solid. Once I'm done focusing and framing, I use USB extension cables for my guide and imaging cameras, so that I don't have to get anywhere near my scope once it's busy imaging.
seeker372011
Reged: 03/05/04
Loc: Sydney , Australia
      #3748034 - 04/16/10 03:27 AM
Wierd. I too would have said wind in fact i am Impressed it even brought it back after such huge spikes
DHB001
Reged: 07/07/09
Re: Another CG5-GT "spikes during guiding"-thread... new [Re: seeker372011]
      #3748075 - 04/16/10 05:09 AM
And what's even worse, I know my mount is able to pull off precise guiding for extended periods of time. The link below is to a guide log of last September, when I was imaging the Elephant Trunk nebula for 5 hours straight. I was also using a separate guide scope in side-by-side configuration at the time, so a more heavy and balance wise complex configuration than a single tube plus OAG. Can't think of anything I did that night that was different from other nights I have been imaging. It was the only one time everything went 100% according to plan. So I'm really puzzled by the recurrence of this spike issue...
Log of everything going perfectly with sbs config: http://www.mediafire.com/?ong2zzimduy
bardo
Reged: 09/13/09
Loc: US
      #3748099 - 04/16/10 05:42 AM
mirror flop? play in the OAG somewhere? backlash compensation on?
DHB001
Reged: 07/07/09
Re: Another CG5-GT "spikes during guiding"-thread... new [Re: bardo]
      #3748216 - 04/16/10 08:31 AM
Mirror flop? --> I was already having these spikes when I was using a guide scope (a refractor), so that seems unlikely.
Play in the OAG? --> extremely unlikely. The SSAG sits all the way down in the guider tube (no play possible), screwed tight with two screws. The screw which allows the guide tube to rotate I also screw really tight once I'm done rotating. Believe me when I say everything on the OAG is screwed down tightly.
Backlash comp? --> never ever used. Always on zero, both Dec and RA.
At first I thought perhaps my polar alignment was still too "correct" to induce sufficient drift in the Dec guiding, so that stiction might have caused the spikes, but on a few occasions, it was the RA that began to spike, so those spikes were definitely not caused by stiction...
Eddgie
Reged: 02/01/06
      #3748348 - 04/16/10 10:12 AM
I am going to venture a guess. It is ONLY a guess. I do not image, but I have had this problem with visual observing.
As the load moment on the mount shifts over the course of a session, what happens is that the loading of the worm gear against the face of the worm wheel can change. The result is that the worm wheel can "Bounce" off of the face of the worm gear and then "Catch up."
The culprit is usually too much space between the worm and the worm wheel faces.
The easiest experient to see if this is the case is to always positivly load the faces. When imaging on the eastern hemisphere, slide the counterweight down a bit so that the worm is always pushing "Hard" against the wheel.
When working on the west, raise the counterweigt so that the weight of the telescope is pullling back against the movment of the mount.
I have seen these mounts bounce many, many times even visually. As the loading moment shifts due to tracking, the pressure (especially if the scope is CAREFULLLY balanced) can change causing slight jumps.
Just a thought, but I know it happens visually. One of my mounts (my LXD-750) required a lot of fussy adjustment to get the worm tight enough but not so tight is would stall. The telescope has a VERY long weight and balance moment, and changing from a light eyepiece to something like a 31mm Nagler would cause it to start bounching if the balance changed in some attitudes.
This can also happen in both axises of course.
These mounts tend to be sloppy mechanically. I don't mean that in a negative way saing that they don't have good table manners. I mean that they are not assembled to particularly close tolerances.
Try loading both axises more positivly and see if the condiition improves.
Regards.
NewAstronomer
Reged: 09/03/04
Loc: Northeast, PA U.S.A
Re: Another CG5-GT "spikes during guiding"-thread... new [Re: Eddgie]
      #3748396 - 04/16/10 10:34 AM
Power supply? Or weight shift. I dragged out my SVP recently for quick planetary views with my new refractor and I'm using 4 D batteries , except 1 of the 4 is really a rechargable AA in a shell. Things seem to be fine for awhile them blamo, the mount shifts rsdically on the RA, then a little latter tracking and DEC movement stops working but the green light stays on...I throw in another AA and it seems fine...but keeps happening.
I'm going to buy 4 new D's before next session to see if that is in fact the problem. What do you use for power?
Edited by NewAstronomer (04/16/10 10:35 AM)
DHB001
Reged: 07/07/09
Re: Another CG5-GT "spikes during guiding"-thread... new [Re: NewAstronomer]
      #3748668 - 04/16/10 12:52 PM
Eddgie,
Thanks for your suggestion and explanation. I know exactly what you're referring to. I did preload both axes last week, and I thought I had imbalanced them enough, but now I'm not entirely sure anymore.
By the way, how much preload is enough, and when is it too much? What will happen then? Will it not constantly overshoot if the mount is too much out of balance?
At this point, I too believe a balance issue is the most likely cause of all this.
NewAstronomer,
I use a celestron powertank. I bought all my current equipment about a year ago, and although scope and mount are secondhand, the powertank is brand new. I'm pretty sure that it's working fine. I haven't had any trouble in the power department to date. Slewing, tracking etc. all goes just fine, never a glitch or anything, so although theoretically it is possible that it's not working 100%, I have no real suspicions at the moment that that is in fact the case.
DaemonGPF
Redonkulous
Reged: 03/22/08
Loc: Aurora Colorado
      #3748768 - 04/16/10 01:34 PM
1+ for load shift/balance. My CG5 was very picky about balance.
Eddgie
Reged: 02/01/06
      #3748949 - 04/16/10 03:22 PM
I would think just enough to ensure that the worm faces stay in contact.
The fact is that the gearing in these mounts provides a HUGE amount of torque magnification. These mounts will drive in even severely out of balance conditions. Now, I don't recommend using more pre-load than you need, but just having the mount SLIGHLY out of balance is sometimes not enough.
As the telescope's angle changes, and this is ESPECIALLY true with refractors, them load moment often changes. This is because the load is often very assymetric.
Many people balance with the OTA level to the ground and the polar shaft level to the ground. What you MIGHT find is that the mount is ONLY fully balanced in this ONE position.
As you change orientations, the moments of leverage get all twisted around.
The suggestion I would make is to balance in the orientation similar to where the mount will be when it is actually in use.
How much? I would expect that for imaging, a little more pre-load is a bit better than a not. Again, the motor torque is hugely magnified and you are NOT going to hurt anything.
This may cause the current drain on your power supply to go up a hundred milliamps or so, but you aren't going to hurt anything.
I could be wrong, but if it is irregular, then I think that this is one of the most likely issues.
Of course you may have some other slop somewhere. The spur gears between the motor gearbox shaft and the RA shaft should be checked for mesh along with the worm, but again, if you pre-load, it should not matter.
Try preloading with enough load that the mount is CLEARLY out of balance and let us know if it solves the problem.
If it does, and later you decide you want to attack the issue of the slop, let me know and I will walk you though how to check and what to do.
Regards.
Eddgie
Reged: 02/01/06
      #3748958 - 04/16/10 03:25 PM
Oh, and of course it would be unfair to not to mention this. You COULD have binding becuase of too much pre-load already, but this is unlikely unless your gears are dry. If the worm gears DO get dry, the teeth can chatter against one another. Unlikely, but not out of the question. If the mount is very old and has never been greased, it could be an issue.
DHB001
Reged: 07/07/09
      #3749288 - 04/16/10 06:38 PM
Thanks DaemonGPF and especially Eddgie for your input.
Eddgie,
As far as gear slop and potentially dry worm gear teeth are concerned, one of the first things I did after buying my equipment last year, was re-lubing the mount (with Super Lube, which I've read so many good things about here on CN) and ensuring that backlash/slack between the gears (both worm and spur) was minimized. I did this by following the instructions of Tim Doucette (see here), which is based on the well known instructions of Astronomy Boy, but for the newer CG5-GT.
By the way, what exactly do you mean by binding, Eddgie? I know what stiction (static friction) is, but I'm not sure I understand what you mean by binding. Don't think it's the same, or is it?
I will definitely test pre-loading my mount "excessively" asap, and as soon as I've got results, I will let you all know. The weather forecast is very favorable for the weekend, so unless this Icelandic volcanic ash is seriously blocking the sky (which I think it won't), I should be able to report back very soon.
Thanks again to all you guys who came up with ideas the last couple of days. I've got a good feeling we'll soon have this issue sorted out.
Eddgie
Reged: 02/01/06
      #3749468 - 04/16/10 08:22 PM
Well, the "Binding"would simply be tiny momentary chattering of the worm wheel/worm gear teeth or if the mesh is not correct on the spur gears, you can have a tiny amount of hitching of the gears as the successive teeth come into contact.
Anyway, look forward to the results.
DHB001
Reged: 07/07/09
      #3751129 - 04/17/10 08:51 PM
Well, it's now 2.50 am here, and I just finished what turned out to be a very disappointing test session. It seems the spikes at best were just as bad as earlier this week, but it was mostly worse. Tomorrow I'll post the guide logs of last night, plus the notes I made of the things I tried and at what time I tried them, so that you can see the effects (or lack thereof) they had on the guide graph.
Eddgie
Reged: 02/01/06
      #3751189 - 04/17/10 09:39 PM
Well, I am sorry that my suggestions were not helpful.
Don't know if it is elelctrical or mechanical now. Wish I had another idea.
Hopefully someone else will have some ideas.
DHB001
Reged: 07/07/09
      #3751645 - 04/18/10 06:22 AM
I've processed the guide log in Excel, and also provided it with comments about what I did, for those interested.
The guide log in Excel, with comments: link
I think one or more of the issues below could be causing my problems.
1) the DEC is too stiff, causing stiction.
I already regreased my mount once before, before I got hold of Super Lube, and it doesn't matter what lubricant I use, the Dec axis won't spin as easy as the RA does. I think it has a lot to do with the fact that the Dec has no bearings whatsoever, unlike the RA.
2) as a consequence of 1), the net result of scope preload and deliberate polar misalignment to induce permanent drift in the dec was insufficient to prevent stiction to occur, creating spikes during guiding.
3) preloading works, but not when imaging in zenith.
M51 is very high above the horizon for me, so I'm always imaging this object very near zenith. With the scope pointing nearly straight upward, there's almost no lever arm for the force, created by the preload, to exert torque on the dec gears.
4) preload in dec and deliberate drift from slight polar misalignment are in opposite direction.
This is something I just thought of.
Could it be that if the drift caused by polar misalignment is south in the dec, but the scope preload on the dec axis is to the north, that guiding the dec becomes hard to do for PHD (or any guiding software for that matter), because corrections tend to overshoot?
Maybe I should do only one of two things: either balance the scope in Dec and do a rough polar alignment so that there's a slight unidirectional drift in Dec, or do an accurate polar alignment and preload the Dec axis....
bardo
Reged: 09/13/09
Loc: US
      #3751718 - 04/18/10 08:21 AM
just put the motors on a vixen and be done with it
Richard Scott
Reged: 07/25/06
Loc: Tampa FL
Re: Another CG5-GT "spikes during guiding"-thread... [Re: bardo]
      #3751764 - 04/18/10 09:00 AM
I worked for years with a CG-5 and I got a few spikes but nothing like you are experiencing.
Two thoughts,
#1 Try lapping the gears by dry running both the RA and DEC without any OTA the 10 or 20 full 360-degree rotations. If there is a bit of crud or two on one or more of the gear faces, that may rub it off.
#2 Try a AC/DC power converter. I found that my CG-5 ran a lot happier at 14/15 volts than it did at 11/12 volts. The extension cord is something of a pain, but after I went the converter route I never went back.
Good luck
Richard
13 registered and 36 anonymous users are browsing this forum.
