EdTheEdge
Reged: 04/10/09
Loc: Lomita, CA
Re: ES Twilight I alt az mount
[Re: Shawn H]
#5377174 - 08/20/12 09:33 AM
So I finally got a chance to try the Twilight I mount head on my CG-5 tripod and got mixed results....
The alignment peg on the CG-5 tripod had to be removed to fit the Twilight I mount. Other than that it fit perfectly and was much more stable than the tripod it came with but still not ideal for larger scopes.
I was hoping that I could use my 100ED with this mount but it is just too shakey and proper focusing is a real chore. Just to be sure I tightened everything up and placed anitvibration pads under the tripod. Still stoo shakey.
So I guess in the end I have found a perfect G&G mount for my 80mm and that'll help but not exactly what I have been looking for....
Shawn H
Reged: 05/16/07
Loc: Equatorial Guinea, West Africa
[Re: EdTheEdge]
#5377185 - 08/20/12 09:42 AM
Is there any way you could add weights to the tripod
OldManInHawaii
Reged: 03/12/12
[Re: EdTheEdge]
#5378064 - 08/20/12 05:38 PM
At what magnification does the focusing become problematic for both configurations w/ and w/o the CG-5 tripod? On my Meade tripod, there are still shakes when focusing but they damp out quicker than with the ES tripod. I only went as high as 143X on my 100ED scope.
And when you are focusing your scope, are the axial brakes fully clamped down on your mount?
I guess the next step up in alt-az mounts w/ slow motion controls would be something like the Canadian Telescope Heavy Duty Duo T mount that Woodland Hills sells. But I think I can live with what I have now.
OldManInHawaii
Reged: 03/12/12
[Re: Shawn H]
#5378075 - 08/20/12 05:42 PM
I'm sure weights can be added somehow, but doing so kinda defeats the grab n go.
EdTheEdge
Reged: 04/10/09
Loc: Lomita, CA
[Re: OldManInHawaii]
#5379057 - 08/21/12 09:57 AM
I tried several mags.... highest was 194X then 134X and finally 38X all were pretty much unacceptable for me. But that's with my f/9 100ED. Like I said my ES 80mm rides quite solidly on this mount.
Edited by EdTheEdge (08/21/12 10:00 AM)
EdTheEdge
Reged: 04/10/09
Loc: Lomita, CA
[Re: Shawn H]
#5379065 - 08/21/12 10:02 AM
That would be easy to do... and I may try it at some point, but I want this mount to be as portable as possible.
OldManInHawaii
Reged: 03/12/12
[Re: EdTheEdge]
#5383864 - 08/24/12 01:11 AM
Again, let me say that I do get vibrations when I focus my ES 102ED APO (f7), but I can live with this. Tightening down the locks for both the azimuthal and altitude bearings is recommended before focusing to reduce the vibrations.
I also noticed that my ES TWI's azimuthal bearing has some detectable slop or play even after the azimuthal lock has been fully tightened down. The Orion Versago III manual does not indicate how to tighten the bearing. Perhaps this is the main source of the vibrations (?).
I think I'll send an email inquiry to ES and see if they can suggest anything.
OldManInHawaii
Reged: 03/12/12
#5385183 - 08/24/12 08:08 PM
Just received the following quick response to my inquiry from ES:
"I saw your question regarding your Twilight I mount. Unfortunately, there is not a way to tighten the azimuth bearing. It’s actually a worm gear. There is a free spinning worm shaft that is pushing, pulling on a worm wheel/gear. Let me know if you have any questions.
Marty DeBriyn
marty@bresser.com
T: 866-252-3811 Ext. 311
F: 479-717-2898
stevew
Now I've done it
Reged: 03/03/06
Loc: British Columbia Canada
[Re: Manny Myles]
#5614755 - 01/10/13 12:15 AM Attachment (14 downloads)
Came across another part that has no home, 3 hole spacing identicle to the 3 holes on altitude head since there are no directions in the box I'm guessing it's a spare cltuch bearing.
m2
I just received my ES Twilight today, and also found the extra part.
Does anyone have any idea of what its for?
I spent an hour scratching my head about it, until I found this post.
If it is superfluous it seems like a waste of materials.
Steve
desertlens
Reged: 12/06/10
Loc: 36°N 105°W
[Re: stevew]
#5615518 - 01/10/13 01:15 PM
I too experienced some vibration and traced it to the arm. There is a bit of flexure in this component. My solution was to add two steel plates and essentially fill the opening in the arm. Vibration and damping time are significantly reduced. The photo shows this mod. This entire setup (minus the Nagler) weighs 11.2lb. or about 75% the rated capacity of the mount.
stevew
Now I've done it
Reged: 03/03/06
[Re: desertlens]
#5616317 - 01/10/13 09:40 PM
I just heard from Explore Scientific about the extra part. Here is what they said.
"I apologize for the lack of a manual, or instructions for that piece. That piece is an adapter so that the tripod can be used as a camera tripod. Basically, you can detach part of the top of your mount head and place that piece on there so that you can attach a camera to your tripod. It is just an accessory, and not necessary for the mounts intended functions."
Steve
desertlens
Reged: 12/06/10
Loc: 36°N 105°W
[Re: stevew]
#5616591 - 01/11/13 01:24 AM
Thanks Steve for the info on the mystery part.
stevew
Now I've done it
Reged: 03/03/06
[Re: desertlens]
#5616660 - 01/11/13 04:05 AM
Nicely done! Looks like a great idea. I had mine out tonight with my C5, It worked really well. I used some vibration pads and dampening time after a good rap to one of the tripod legs while using 150X was only about 2 seconds. Acceptable for this class of small mount. I'm looking forward to trying my 105 F-6 achromat on it. The tripod could be a touch taller, but so far I'm very happy with it for a lightweight grab and go type mount.
Steve
desertlens
Reged: 12/06/10
Loc: 36°N 105°W
[Re: stevew]
#5617311 - 01/11/13 01:46 PM
Steve, The mod reduced my damping time to about 1/2 second (certainly under one second) and touching the focuser induced very little movement. I also found that leg vibration in this mount was virtually nil on a hard surface if the rubber leg tips are removed. I think that my AV pads work best with aluminum leg tripods. The steel legs used by ES are very stiff and don't carry much (if any) vibration in my setup.
stevew
Now I've done it
Reged: 03/03/06
[Re: desertlens]
#5618086 - 01/11/13 09:57 PM
Craig,
I was also thinking about removing the rubber tips.
I'll give it a try.
The C5 is very stable on the mount as it's a short stubby tube. There was no vibration at all using the smooth SCT focus knob. My 4 inch F-6 achromat will probably be a different story, however a fast achromat is not a high power scope anyway. I found the slow motion controls on the mount to be very smooth and responsive as well.
I'd love to hear more about your modification, as it might be something I look into in the future.
Steve
desertlens
Reged: 12/06/10
Loc: 36°N 105°W
[Re: stevew]
#5618935 - 01/12/13 12:02 PM
Steve, The mod is very simple: 2 3"x4" steel plates, clear drilled for 1/4"-20 machine screws and nuts. No tapping is necessary. The arm is sandwiched between the two. I don't know the actual gauge of the plates as they were scrap and I don't have a caliper but they're just under 1/8". Since refractors carry their weight at the ends, the longer tube of your 4" will likely have some moment arm and could benefit from the added stiffness. I like this mount. The steel legs are vibration dead. The motions are smooth with a little slop in azimuth as mentioned earlier and the wide stance and weight of the legs minimizes the "tail heavy" tendencies of this type of mount with an angled arm. Good luck and clear skies.
