laidman
Reged: 04/17/12
Loc: Jeju City, Jeju Island, South ...
Portable astrophotogrhy mount
#5301659 - 07/04/12 01:59 AM
Hi folks I've been looking at portable mounts for a while now, but have yet to settle on something. I thought I'd nailed with the Astrotrac, but now I'm not so sure. If I set myself up with everything I'd need with the Astrotrac system I'd be looking at the travel system - the one with the pier, wedge, polar scope, etc. I could maybe make due with my Manfrotto 190x proB tripod, but I figure I might as well do things properly. That set up is 1790$ CAN through Canadiantelescopes.com, which seems far and away the best price I've found so far. That set up weighs 35 pounds.
What I'm thinking of now, though, is something like the Meade LX80. It's 830$ CAN through the same site, and has more to offer, right? Granted, I'd need a polar scope, but there's a huge price difference there...
Either mount would be used primarily for astrophotography with DSLR cameras and lenses. I don't own a telescope and due to the fact I only have a motorcycle and want to hike around with this thing, I won't be getting anything anytime soon. Portability is hugely important! I see the Meade runs just over 30 pounds for the mount, and the same again for the tripod, so at 60+ pounds maybe I should rule out any kind of GEM/alt-az mount.
For portability, weight, ease-of-use, and quality, is the Astrotrac really the best out there?
Cheers...
Reged: 07/06/07
Re: Portable astrophotogrhy mount
[Re: laidman]
#5301904 - 07/04/12 09:04 AM
The LX80 might do...or it might not. I'd wait about a year on that.
Get a CG5. It will do the job at minimal expense, let you expand to a telescope later, and it will _work_.
If you must remain uber portable, I'd look at the new Vixen Polarie.
oldstargazer
Reged: 08/03/11
Loc: Western Oklahoma
[Re: rmollise]
#5301923 - 07/04/12 09:22 AM
I second the CG5-GTa mount. I use this mount all the time for my ap work and it can do 5 minutes if you spend the time to get a really good polar alingment. I bought a dovetail for about 15 dollars that I mounted my camera on using one of those little devices that lets you adjust it in az/el so you can get it aligned precisely with the dovetail. One thing though the standard weight for the mount is 11 pounds and that is too much for just a camera. Luckily I have an old super polaris mount that I still have from the early 80s and that bar and weight is just right.
Falcon-
Reged: 09/11/09
Loc: Gambier Island, BC, Canada
[Re: oldstargazer]
#5302066 - 07/04/12 11:13 AM
I use a CG5 for exactly that. Something else you might look at is the iOptron iEQ30 - from what I have read about it it looks like a good mount (step up from the CG5) and is relatively light weight.
David Pavlich
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
[Re: laidman]
#5302095 - 07/04/12 11:37 AM
Pretty tough to beat the CG5-GT at that price point. I sure enjoy mine!
David
laidman
Reged: 04/17/12
[Re: David Pavlich]
#5302403 - 07/04/12 02:56 PM
Thanks for the input everyone! The CG5 definitely looks promising, and very tempting at that price as well. I guess my only concern is the weight again. The CG5 looks like it clocks in at about 57 pounds, which is still pretty heavy. I'd like to be able to carry the mount with me hiking; for a few hours at least up some fairly steep terrain. I live on Jeju Island off the south end of South Korea (although I'm home in Canada for a bit now...) and I'd like to head up Halla Mt. (1950m) sometime to do some imaging. I'm 6''3" / 190cm and pretty athletic, but that kind of weight, coupled with my camera gear, has me a little worried. This mount would be used with a Canon 40D with battery grip, and everything from a 50mm f1.8 to a Sigma 150-500mm, potentially with an extender as well. The Vixen Polarie I read about, but it seems a little more limited versus the Astrotrac, and lacks autoguiding. Getting a GEM is pricewise a nice idea, but maybe there isn't really anything out there that's light enough for true portability. Also, I'm thinking about how I would carry this around, and I'd probably use a backpacking backpack as I could stick the mount and all my gear in it as well. For transport, I'd have to bee able to carry everything on my back while on my motorrcycle, too. Decisions, decisions! Thanks all,
oldstargazer
Reged: 08/03/11
[Re: laidman]
#5302459 - 07/04/12 03:24 PM
Sounds like you want to stay with a manual type mount. Anything you have that requires power means you are now going to have to lug around another 5-10 pounds worth of battery if not more.
Falcon-
Reged: 09/11/09
[Re: oldstargazer]
#5302527 - 07/04/12 03:57 PM
As to the CG-5 weight - most of that weight is the tripod and counterweight. If you make your own mini-tripod of some sort and if you make a smaller counterweight suitable for the the weight of your camera w/ sigma lens you could cut that weight down a lot.
Still though, not going to be SUPER light and you will need a power source usually in the form of a lead-acid battery to run it.
I see the iOptron iEQ30 lists a wight of 15lb (I am guessing that is mount-head only...?). That may be the lightest-weight AP capable full GEM mount you are likely to find. The Astrotrac and Losmandy Starlapse are likely the ones that are TRUELY back-pack friendly (especially the astrotrac).
Sounds like it may come down to all-round capability (regular GEM) vs ultra light (Astrotrac, etc)
Falcon-
Reged: 09/11/09
[Re: Falcon-]
#5302547 - 07/04/12 04:07 PM
oh, BTW, if you limited your backpack-AP rig to things like the 50mm lens then you can get away with some rather inexpensive equipment normally considered beneath notice.... a RA motor equipped EQ1 or EQ2 such as this one from Orion should be able to do at least as well as my very beat up 40 year old EQ2 managed to do for me.
Now such a mount is NOT going to be a work of amazing mechanical precision, I have to note that my own ancient EQ2 had a fairly high rejected frame rate even at 50mm, but it's cheaper then a Polarie!
(This conversation now has me wondering about replacing the tripod legs on my CG-5 for easier camping/short-hike portability... those 2" steel legs are an advantage of the CG5, but they are not small!)
laidman
Reged: 04/17/12
[Re: Falcon-]
#5302695 - 07/04/12 06:01 PM
Thanks Falcon, Stargazer...
I do like the idea of a GEM, and the idea of mounting one atop a smaller, lighter tripod is appealing. However, once I've found something sturdy and portable enough, it'll most likely cost me a bit anyways...
The whole Astrotrac travel setup runs about 35 pounds, so coupled with my camera gear will still require a bit of sweat, but will be easier than anything I might be able to come up with otherwise. In addition, the price on Canadiantelescopes.com seems to be much, much cheaper than anywhere else I've come across, so that might be a sign in itself!
The idea of getting something smaller, lighter, and cheaper is valid, but coming from photography and already having a deep interest in astronomy as well, I know I wouldn't be satisfied if I was always at the limits of what my equipment could provide. Better to buy right the first time (as it fits your needs) than always be cursing your equipment and wishing you'd gone another route!
In terms of simplicity, practicality, and weight, it seems that the Astrotrac is the way to go for me. I also looked the the Fornax 10, but couldn't find a dealer that would ship to me. The Losmandy starlapse was also tempting, as I like to do timelapse photography, too, but I've read that its tracking isn't as good as the Astrotrac.
ghataa
Reged: 06/20/11
Loc: Central, NJ
[Re: laidman]
#5302704 - 07/04/12 06:07 PM
I have a Vixen Polarie and it is incredibly lightweight. I can easily get 5 min subs using a 85 mm lens. Sets up in 5 min and tracks great for just a few pounds.
Best,
George
laidman
Reged: 04/17/12
[Re: ghataa]
#5303178 - 07/05/12 01:26 AM
Thanks George. The Polarie is attractive except I'd like to be able to use my longer lenses and be able to try autoguiding in the future as well. I've heard a lot of good things about the Polarie, though. Cheers, Mike
Midnight Dan
Reged: 01/23/08
[Re: laidman]
#5303454 - 07/05/12 09:42 AM
You might want to take a look at the new SmartEQ portable Goto GEM from iOptron: http://ioptron.com/index.cfm?select=productdetails&phid=03c86716-b870-417b-8beb-0c0ba49ddf1d
The mount head is only 6.2 pounds, the counterweight is 2 pounds, and it has a rated capacity of 11 pounds of gear. It has an internal battery compartment that becomes part of the counterweight, holds 8 AA's, and lasts for 16 hours of tracking. At $400, it seems like a pretty attractive price too!
-Dan
TopherTheME
Reged: 02/11/11
Loc: Rochester, MI
[Re: Midnight Dan]
#5303551 - 07/05/12 10:50 AM
I've been looking at a portable mount for AP as well and have been looking at the SmartEQ pretty closely. Unfortunately its a new mount so there's practically no information available on it. The website says its good for wide field astrophotography who knows how well it actually works.
Midnight Dan
Reged: 01/23/08
[Re: TopherTheME]
#5303572 - 07/05/12 11:09 AM
Here's a recent thread here on CN for the SmartEQ: http://tinyurl.com/bqerz7n
Seems like mixed reviews, with some of the usual new-mount issues.
-Dan
themos
Reged: 04/01/08
[Re: Falcon-]
#5303714 - 07/05/12 12:40 PM
You might want to check out my review of the "Orion Adventures in Astrophotography Bundle" mount where I describe my autoguiding modification. It produces 8 min exposures at a scale of 8 arcsec/pixel with a tracking error of about 1 arcsec rms.
http://tech.groups.yahoo.com/group/autoguiding/message/9007
http://www.amazon.com/Orion-Adventures-in-Astrophotography-Bundle/dp/B003ZDBY36
Themos Tsikas
Hikari
Reged: 01/05/11
Loc: Maine, USA
[Re: laidman]
#5303735 - 07/05/12 12:59 PM
Cheers...
Yes, but with a tripod, not with the Astrotrac pier. A GEM is so much heavier and bulkier. They are not even in the same league. The Astrotrac is going to give really great results.
ghataa
Reged: 06/20/11
Loc: Central, NJ
[Re: themos]
#5303738 - 07/05/12 01:00 PM
Mike,
Can't go wrong with the Astrotrac. Different niches of the portable market. I am pleased we have so many choices depending on need. Please let us know how it goes.
Dan,
The SmartEQ looks really interesting but as you noted some of the early feedback is mixed. I am intrigued by these portable mounts. The ability to do 5 min subs with small apos or lenses with a lightweight footprint is sometimes just what the doctor ordered!
George
Falcon-
Reged: 09/11/09
[Re: ghataa]
#5303827 - 07/05/12 01:53 PM
Only problem with the SmartEQ is that (currently) they claim no auto-guiding ability. I HOPE this just means no ST4 port rather then inability to guide via the hand controller pulseguide/ascom. *If* it can be guided it is sure hard to beat the price for a wide-field portable AP GEM.
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
[Re: Falcon-]
#5303869 - 07/05/12 02:27 PM
Laidman,
I can't help but think that what you really want doesn't exist in one setup. You want it to be portable (under 35 lbs), but you want autoguiding capability and the ability to carry a 500mm photographic lense. You do understand that you'll need TWO scopes and TWO camera's to autoguide, right? There are some lightweight autoguiding setups out there now, so that's a plus, but all those widgets and gadgets start to add up, if not in weight, at least in bulkiness.
I think you should focus on one task at a time, breaking it down into imaging focal lengths. If you're going hiking, the Astrotrac sounds great, but you may want to limit the focal lengths to 200mm and under, for example. If you want to image at longer focal lengths, you may have to forgo the hiking part, and go with a more robust setup that will allow you to autoguide. Is there anywhere you can image that doesn't require you to hike to it?
Just a thought.
Patrick
Edited by Patrick (07/05/12 10:51 PM)
