ppfilbert
Reged: 02/03/11
Builng a pier
      #5455598 - 10/04/12 07:27 PM
ok. i fixed my CG5 that celestron put back together wrong, so i dont have to buy a new mount. its running So well that im looking at possibly permanatly mounting the cg5 and C8. i dont know much about piers. so little help if possible
1) i dont have much money, so budget is very tight.
2) my new house we just bought has a back deck with a LIMITED line of sight, and the only real location to put the scope is on the deck, or directly next to it.
3) the house is on a good slope surrounded by trees. at the point where i wnat to do this, it is 5 feet form ground to the bottom of the deck, then i need another 4 feet on top of that to get LOS over the roof.
i am not opposed to construction, or even if necessary cutting a ahole through the deck to run a pier, im just not sure how to make a distance like im looking? if anyone has ideas, or info or things i should try, feel free to advise
Thanks Bret
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Builng a pier new [Re: ppfilbert]
      #5455684 - 10/04/12 08:26 PM
Build a pier out of either water pipe (large PVC, 8-12 inch) or out of wood. There are several examples on here that would provide you with a sturdy example. I built my pier out of a single 6x6 PT, and I've been really happy with it. Is it 'rock solid'? No. But it dampens out movement in about 1-sec and it's removable when I decide to sell the house.
I would put it in the ground if possible. I tried just doing visual on my deck with the CGEM and it was a complete fail... every step was magnified in the eyepiece. If I could stand still it was almost possible.
Good luck! And you might want this moved to the Observatories section, it will get a better response there.
ppfilbert
Reged: 02/03/11
Re: Builng a pier new [Re: Raginar]
      #5455825 - 10/04/12 10:12 PM
sadly i dont know nhow nto do that lol
wolfman_4_ever
Reged: 07/15/11
Loc: El Segundo, Ca, So. Cal
      #5455943 - 10/04/12 11:50 PM
Your going to have to build the pier footing out of concrete and either use concrete to construct the pier or buy a steal pier.
I perm mounted my CG5 on a pier tech2. I used the 16" extension you can get from orion as my pier base. I cut the 16" extension to the height i liked and drilled new holes to mount the mount too.
Here is a link to the extension.
Orion SkyView Pro Telescope Mount Extension
This extension can also be used on the CG5
mich_al
Reged: 05/10/09
      #5456250 - 10/05/12 09:07 AM Attachment (34 downloads)
There is a well documented wooden pier, thru a deck, project over in the observatoty forum. Its about 3 years old. A guy in Ohio, named Patrick, built a pier out of 4 6x6 PT timbers. I built a clone of his pier and overall have been quite happy with it.
My CGEM sits atop a wooden pier (4 6x6) that is 10 feet above grade. The timbers are embedded 2 feet into a 3' x 3' x 56" block of concrete. There is a caveat. My pier has some twisting movements. Over the course of a couple of weeks this spring I monitored where the scope pointed. Initially I pointed the scope at a stationary marker about 300' away and nearly horizontal. Thought the days I looked thru the scope and see where it was pointed and noted movement mostly left and right a few inches max and up and down an inch or so. I suspect humidity and temperature where the cause. The movements where not predictable and sometimes there was no movement.
My mount/scope has been on the pier for over 2 years. Often there is no need to realign and when there is simply recentering the 2 alignment stars is sufficient.
If I had it to do over I would probably build the pier from chimney blocks to the bottom of the deck and use a steel pier the last few feet.
Al
*skyguy*
Reged: 12/31/08
Loc: Western New York
      #5456297 - 10/05/12 10:07 AM Attachment (33 downloads)
Hi Bret,
Probably the cheapest, strongest and easiest to build tall pier is one made out of chimney block. I built a 12.5' chimney block pier 12 years ago to hold a 12" SCT ... used exclusively for imaging ... and this type of pier is "rock solid", virtually vibration free ... and did I mention, CHEAP! Send me a PM if you're interested in the construction details.
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: Builng a pier new [Re: *skyguy*]
      #5456305 - 10/05/12 10:14 AM
Hi Bret,
Agreed. My chimney block pier has been in use (imaging only) since 2003. I expect it to outlast me.
lawrie
Reged: 01/31/06
Loc: Okanagan Valley
Re: Builng a pier new [Re: jrcrilly]
      #5456322 - 10/05/12 10:33 AM
Just remember to put the block or sonar tube ( that is what is used to pour concrete pillars ) on a footing. If you live where it freezes, then the footing should be under the ground below frost level.
ppfilbert
Reged: 02/03/11
Re: Builng a pier new [Re: lawrie]
      #5458960 - 10/07/12 09:05 AM
wow great ideas. now i need to think wether wood or block. i kinda like the through the wood aspect so ill be on the deck. with the wood pier i figure id have to join the wood together with lag bolts or equivilant. with block im figuring the cost still would be more having to purchase block and build a footer, but ill look into both typoes and see which would work best. living in TN. it can freeze, though not as bad as real northern states
donnie3
Reged: 12/15/04
Loc: bartlesville oklahoma
      #5459207 - 10/07/12 12:07 PM
mich, are you sure it was 4 6x6. when i looked at his pier in his photos, it looked to me like it was 4 4x4's i might be wrong. 4 6x6 would be a massive pier and very heavy to handle. donnie
avarakin
Reged: 07/13/09
Loc: Parsippany NJ, USA
Re: Builng a pier new [Re: donnie3]
      #5459606 - 10/07/12 05:20 PM Attachment (35 downloads)
Let me introduce an idea, never saw it implemented before, but it should work really well:
Instead of a pier, build a tripod.
- Have 3 concreted footings, ideally reaching below frost line. You don't need anything massive, just 10" diameter, 3' deep should be good enough
-Put wooden legs on top of footings in tripod shape. Again, legs don't have to be massive. I think even 2x4 may work.
-On top of legs, put a plate. Plate can be below floor, in this case you need some regular pier to extend above the floor. Other option, if having 3 holes in the deck is ok, is to extend the legs above the floor.
I think this arrangement should be infinitely more stable than a one foot pier and should be easier to build.
Attached is a smaller version of the same idea, works very well.
Alex
Edited by avarakin (10/07/12 05:22 PM)
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: Builng a pier new [Re: avarakin]
      #5459732 - 10/07/12 07:06 PM
Alex,
That's an interesting idea. If you look at some of the pier manufacturers they are essentially doing the same thing ... ie. building a triangular shaped support. The gusset reinforcements start off wider at the bottom and travel right up the whole length of the pier.
We tend to build piers and supports as a single long rectangular object rather than the more rigid triangular shape. If you build the more rigid triangle then you can use different materials (like wood) which wouldn't be appropriate in other shapes.
mich_al
Reged: 05/10/09
      #5460292 - 10/08/12 09:43 AM
The cost of the hardware (bolts,nuts,washers, foot long drill bit) to bolt my 12' 6x6's together was substantial.
Al
roscoe
curmudgeon
Reged: 02/04/09
Loc: NW Mass, inches from VT
Re: Builng a pier new [Re: mich_al]
      #5461103 - 10/08/12 06:56 PM
For any scope you can sensibly put on a CG-5, I think a single 6x6 would work fine. 5" under the deck, 4' over the deck, 3' in the ground, a 12' piece will do the trick. If you don't have access to a truck (this thing will be too heavy for roof-racks) you can get local-type lumber yards to deliver it for a small sum. If you dig a hole a bit over 3' deep and perhaps 18" in diameter, and put your post on a rock, through your hole in your deck, with wedges in the hole to hold it centered and straight up, and fill the hole with concrete, you'll be fine! You can add bricks or clean rocks to the concrete to make up volume if you want.
I susprect folks will post their opinion that this isn't possibly enough, but for visual and perhaps limited photo work, you'll be fine. If you had a big scope, or an open-sky place, or were planning an observatory, bigger would be better, but this will be worlds better than a tripod, and not a lot of money.
Russ
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Builng a pier new [Re: roscoe]
      #5464381 - 10/10/12 08:23 PM
My 6x6 worked really good... did exactly what roscoe is saying. It isn't 'rock solid' like a concrete pier but it dampens out before you can put your eye to the piece.
mich_al
Reged: 05/10/09
      #5465387 - 10/11/12 01:26 PM
If you're refering to Patricks pier then Yes it was 6x6. Mine is also 6x6's (really 5.5"). I put them together to drill for connecting bolts then disassembled and moved each 12' 6x6 to the hole then reassembled in place. From memory each 6x6 was about 100lbs.
Al
mich_al
Reged: 05/10/09
      #5465391 - 10/11/12 01:31 PM
Something to consider is that over time wood will warp. Part of the idea of joining numerous pieces together is to counteract the warping.
Al
D_talley
Reged: 07/07/05
Loc: Richmond VA
      #5465428 - 10/11/12 01:59 PM
Thanks to you guys I have made this my next project using 4 6x6 posts for a pier in the back yard. Already got the metal plates the mount will attach to. Just need to pickup the posts and dig the hole.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Builng a pier new [Re: D_talley]
      #5465953 - 10/11/12 08:28 PM
9 months and counting, still straight as an arrow. If/when she warps, the bottom plate is well adjustable, and if I need to dig it out and re-set the post, I will. I think if I could do it again, I'd think about doing 4 x 4x4 and bolting them together. I don't think the amount of wood is nearly as important.. Make sure you take your time at the lumber yard and find a nice, straight piece.
Good luck!
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
      #5466112 - 10/11/12 10:55 PM Attachment (10 downloads)
(4) 6x6's glued and bolted together. The general idea for using a laminated structure is to help reduce twisting in any one column by counteracting it with the other columns. I am quite happy with my pier and it has served me well over the last several years. I'm not that concerned about pier movement over the course of a season because I don't leave my scopes set up outside anyway. Consequently I just plan on doing a polar alignment every time I setup to image. If I'm not imaging, polar alignment is not that critical. Any wood movement is not going to occur that fast regardless.
Here's a Meade SN6 on a Vixen GP2 mount sitting on the Backyard Observatory's pier plate sitting on top of the pier. I currently have a CGEM sitting on the pier and have also put my CPC1100 and Mitty wedge on it with no problems.
I went with a wooden pier mainly for aesthetics. If I were building a dedicated observatory I would most likely build the pier using concrete block.
Patrick
16 registered and 35 anonymous users are browsing this forum.
