What would you do? (Mount Options)
#5462179 - 10/09/12 02:03 PM
Okay, I'm about to bite the bullet on an Astro-Physics mount.
I am bouncing back and forth between the Mach 1 GTO and the AP 900. Each has pros and cons for me. The Mach 1 is small and light, with decent capacity for its mass, and would be the better traveler. The AP 900 has a higher payload capacity and analog setting circles (I'm a big fan of accurate engraved setting circles). But it's heavier and bulkier, not to mention more costly.
I understand that in addition to the basic mount bundle, I'll need to add a saddle, counterweights, potentially a pier adapter and some form of pier or tripod. Costwise, I'm flexible. That is, the extra cost of the AP 900 is not a deterrent. However, the extra bulk and mass isn't so desirable and the extra capacity isn't needed *at present*.
I'm 100% visual only - no imaging, and none planned - and my reason for looking to move to an AP mount from my less costly mounts (CG5-GT, CGE and Atlas) are (a) reliability at (very) remote sites in the field and (b) high payload capacity per unit of mount mass.
The biggest payload initially will be a TEC 140 or perhaps a C9.25 or C11. I can see it needing to carry a 160mm refractor at some point, and have seen an APM/LZOS 152/1200 on a Mach 1 and felt that it was pushing what I would feel comfortable with as the mount limits.
One thought I had was this - get a used 900 or 1200 QMD for home use/higher payload needs, and the Mach 1 for travel. Of course, getting just one mount would be simpler.
Whacha think?
Also, if anyone is using a Pelican case for either a Mach 1 or AP 900, let me know which one and how you like it.
crow
Reged: 07/09/12
Loc: BC, Canada
Re: What would you do? (Mount Options)
[Re: jrbarnett]
#5462222 - 10/09/12 02:23 PM
I'd be interested in this topic also, nothing much to add apart from I seem to be having the same issues. I recently sold a cgem dx as the damn thing was just too heavy but I actually thought it was a pretty impressive mount.
The Mach 1 is pretty light IMO 30 pounds with saddle etc, I was thinking of the berlebach planet tripod which is in the mid twenties weight wise. That to me is a high class portable set up. The 900 is on the heavy side of that. The easier to manage, the more its going to be used.
I'm visual only the only thing that has stopped me from going for the Mach 1 is I can see me getting a C14 at some point and I'm chewing on wether that would be a good (acceptable) combo, I'd mix and match with a TSA120 (still deciding) and C11.
Edited by crow (10/09/12 05:40 PM)
RAKing
Reged: 12/28/07
Loc: West of the D.C. Nebula
[Re: jrbarnett]
#5462273 - 10/09/12 02:52 PM
Jim,
If you don't need the additional payload capacity right now, why don't you just get the Mach1 and give it a go.
I haven't put a 152 triplet on mine, but I have used a TOA 130 on it and it worked fine. My C-11 was no sweat and my TEC 140 worked like a charm. A friend of mine has a TEC 160FL on his - very nice!
I use a Robin Casady saddle on mine and it sits on an Eagle tripod/pier. I leave the Eagle set at 32 inches and simply plop the 8 inch extension on it when I swap between my cats and refractors.
Anyway - if you decide you need more later, the Mach1 should be easy to swap for a 900 sometime down the road.
Counterpoint -- another friend of mine has an A-P 900 and uses a beautiful TMB 152 on it. He manages the transport/weight issues by splitting the RA and Dec assemblies. On the A-P mounts, this is a simple job and a lot of people overlook this feature. I can even do it on the Mach1 in a minute or two if necessary.
Ron
dawziecat
Reged: 10/20/10
Loc: Rural Nova Scotia
[Re: jrbarnett]
#5462401 - 10/09/12 03:56 PM
Seems to me the 900 may be EASIER to transport. It was MEANT to be taken apart . . . no Allen keys needed to detach the dec axis. Mach1 can be taken apart, sure, but not as readily as the 900.
If price is of no concern, I'd prefer a 900.
MPT
Reged: 10/23/07
Loc: Savage, MN
[Re: dawziecat]
#5462426 - 10/09/12 04:09 PM
I would go w/ RAKing's advice. Im sure the Mach1 will meet all of your needs. If you decide that an "upgrade" is needed at some point, you can either sell it (the mach1's dont last long in the classifieds), or buy a used 900 and keep both like you mentioned.
[Re: MPT]
#5462700 - 10/09/12 07:09 PM
Follow-up question:
How demanding are the A-P mounts in the polar alignment department for purely visual use?
I'm used to sighting Polaris through the bore hole being "good enough" in other GOTO EQ mounts. Can I get away with that with an A-P mount?
- Jim
skybsd
Reged: 02/01/08
[Re: jrbarnett]
#5462705 - 10/09/12 07:12 PM
Whacha think?
Hi Jim, As with most things in life each has its pros and cons..,
The Mach-1 GTO will definitely serve you well with your current line up of scopes for sure, but your future aperture needs will require a more considered look at the tripod options., when looking at the moment arm overhead that comes with larger refractors. In this regard, I've read lots of positive things about AP's Eagle tripod, but I can personally vouch for Rob Miller's tripods here. Rob's tripods can not only be ordered with some customizations, but their native height adjustability features to me leaves them unmatched in performance.
There are out-of-the-box Rob Miller tripods for the Mach-1 GTO as well as all other AP mounts - you merely have to specify the mount you intend to use when ordering the tripod. On the other hand, whilst superb, the AP900-GTO is simply overkill - not only for your current line up, but even the future apertures you mentioned here.., Don't read that the wrong way, I own one and its made such a huge difference to the productivity in my visual observing that I can't imagine how I got anything done with my previous mounts.., It really is true, the mount "fades into the background" and allows you to focus on getting through your objectives for any given session.
The Mach-1 GTO won't disappoint here either.
So for someone like me who is solely in the visual observing space. you can't go wrong with the Mach-1 GTO - based on your stated current and future requirements.
As for transport cases, I know that Luke here on CN uses (at least he used to) a Peli-1640 for his AP900. As I take my mount abroad regularly, I opted for ScopeGuard cases myself, but lately I'm seriously considering Thermodyne cases to replace these.
Hope that helps..,
skybsd
David Pavlich
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
[Re: jrbarnett]
#5462830 - 10/09/12 08:32 PM
Mach 1. Unless you're going to get something like a TOA150 for a visual scope, oh my back, the Mach 1 is your mount.
David
BlueGrass
Reged: 07/25/09
Loc: Wasatch Front, UT
[Re: David Pavlich]
#5462966 - 10/09/12 10:18 PM
IMHO, the Mach1 is simply the best mount in its class that you can buy. Mine is mated to an Eagle and an 8" pier extension. It sets up quickly and is extremely stable. The Mach1 and Eagle seem to literally blend together. Jim, the only 'problem' you might have is the lack of a pointing model in the GTO firmware. For imaging, it's not needed. For visual it would be a big plus.
skybsd
Reged: 02/01/08
[Re: BlueGrass]
#5462985 - 10/09/12 10:29 PM
Why is a pointing model such a big deal for visual observing? I don't find myself lacking in any way with my AP900-GTO-CP3 as far as locating targets across the sky, regardless of my observing location..,
Regards..,
skybsd
RAKing
Reged: 12/28/07
[Re: jrbarnett]
#5463407 - 10/10/12 08:24 AM
Follow-up question:
- Jim
Short answer: YES. The Mach1 is no more demanding than that. I use a polar scope simply because I have always used a polar scope, but it's not really needed. Center Polaris as best you can and enjoy.
I am also puzzled about the "pointing model" issue. I am strictly visual now and have never felt the need for a pointing model.
If I move to a new quadrant of the sky, I will typically "Recalibrate" on my first object (a very simple three-button-push) and I am good to go for a while.
I am a double star/variable star observer, so I have to punch in the RA-Dec coordinates for most of my targets. The A-P hand paddle is the easiest unit - BY FAR - to use for this task. To get to the coordinate screen, you simply push '7' on the hand paddle and punch in your numbers. No scrolling through any menus to get there. Roland had people like me in mind when he developed this.
Once you have used an A-P mount, you will be spoiled for anything else.
Ron
Cotts
Just Wondering
Reged: 10/10/05
Loc: Toronto, Ontario
[Re: jrbarnett]
#5463416 - 10/10/12 08:41 AM
Follow-up question:
- Jim
Hi, Jim. My new Mach 1 supports a 6" f/8 triplet APO with no effort for visual.
As for polar alignment, you don't have to "get away with anything". There is a 5-minute or less routine that puts you dead on in full daylight. You do have to have a level and know where your local north is....
Dave
Reged: 07/06/07
[Re: Cotts]
#5463509 - 10/10/12 10:03 AM
I think an AP is a fine piece of gear. I also think that I wouldn't choose one if I were a visual observer. I'd get a nice Losmandy G11 with Gemini II and not worry about modeling and such like as that. But that is just me. For visual use, an AP will be fine with a halfway decent polar alignment at wide-field/low power. Do NOT expect it to hit every single target dead center from horizon to horizon, especially with the SCTs, though, like mounts with more sophisticated alignment routines will.
jmiele
Patron Saint?
Reged: 12/04/10
[Re: jrbarnett]
#5463520 - 10/10/12 10:11 AM
Jim, I've mounted the AP160 and TOA150 on the Mach1GTO for photography with stunning results. While the 900 is a super mount, there's something about the Mach1 strength to weight ratio that is alluring. Given your regular trips to the dusty trail, and your defined requirements, I'd go Mach1. Take some of the money your saving and put your name on the list for one of the AP right angle polar scopes that are coming alone shortly.
Best, Joe
jmiele
Patron Saint?
Reged: 12/04/10
[Re: jmiele]
#5463537 - 10/10/12 10:21 AM
One note: Uncle Rod's point IS valid. Even with the upcoming firmware, modeling from the hand control is NOT possible with an AP mount. Super pointing is more than possible, but does require a decent polar alignment and an orthogonally mounted instrument. Not looking to start a frenzy here, but as I've posted before...my CG-5 with it's built in polar (basically modeling) routine, points dead on after 2 +3 or 4 star aligning it.
All that said the AP can point as good and way more stable. With the upcoming right angle polar scope I've no doubt solid pointing will be a couple minutes from dropping the AP on the ground. I still think you need to get the AP.
Best, Joe
[Re: rmollise]
#5464714 - 10/11/12 12:39 AM
I've had Losmandy mounts. Not a fan, though a non-Gemini G-11 would be a tolerable home-use mount. I'd not like traveling with it though, and hate having to continually adjust the worm gear mesh to control backlash.
blueman
Vendor Blue Sky Accessories
Reged: 07/20/07
Loc: California
[Re: jrbarnett]
#5464736 - 10/11/12 01:01 AM
Hi Jim, I used a G-11, GM-8, MI-250 and now the AP-900. No doubt the AP-900 is the best of the lot. If you want more capacity, I would go the AP-900. If you want light weight the the Mach-1 is a good choice. Of course the Mach-1 is not that much lighter than the AP-900. 22 lbs is not trivial though, if you need lightweight. Though some of this is the counter weight shaft, only 15 lbs difference on the mounts themselves. Both mounts are great and will serve you well. Blueman
Reged: 07/06/07
[Re: jrbarnett]
#5465043 - 10/11/12 09:42 AM
You should try to get a chance to try a Gemini II. Might change your mind.
As for "adjusting," you probably never would need to do a thing as a visual user. Hell, most imaging folks rarely have to mess with their mounts. It is a hell of a mount for a hell of a price, but, again, that is just me. If you are settled on an AP, good on you. As long as you realize the go-to performance with an SCT, especially, will be less than...uh..."stellar."
crow
Reged: 07/09/12
Loc: BC, Canada
[Re: rmollise]
#5465136 - 10/11/12 10:49 AM
That has put me out of the Mach 1 game, a 7 grand mount + Tripod that basically can only do what the cgem that I just got rid of that came with my C11 can do....
I guess it has far better tracking for AP, not my game at the moment, if it was, given my parents live in Europe I'd now look at the 10 Micron 1000hps.
Edited by crow (10/11/12 11:49 AM)
dawziecat
Reged: 10/20/10
[Re: jrbarnett]
#5465626 - 10/11/12 04:22 PM
A visual observer has to "continually adjust the worm gear mesh" of a G11?
I don't get it. I've had my G11 Gemini II for 18 months or so now. Used virtually every single clear night for imaging. I am having some difficulties that I think might, just might be remedied by adjusting the gear mesh. So, I've done it, adjusted the mesh once.
Can't say as I can see a need for a visual observer to ever do so . . . let along do so "continually" unless something is seriously amiss.
Hate the G11 for whatever reason. Hate Gemini II for whatever reason. But to declare a need to "continually" mess with the gear mesh, and for visual use, is very at odds with my own G11.
FaronD
Reged: 03/25/10
Loc: Richmond Hill, Ontario
[Re: rmollise]
#5465815 - 10/11/12 06:52 PM
Hi Rod, I'm contemplating a similar setup as Jim however, my choice will be primarily for imaging. You caught my attention stating that the AP mounts will have "less than stellar" go-to performance. Would you care to elaborate on this please? Eventually I may purchase a C14 for visual use.
Thank Faron
Dan G
Reged: 06/27/06
Loc: Minisink, NY, USA
[Re: FaronD]
#5466053 - 10/11/12 09:55 PM
Maybe it just me but I have no issue finding objects with my Mach1 and C11. Took them out in the field in June. Quick polar align and had objects in my eyepiece both nights without fail. To be fair my CGEM does this too but the AP mounts really do fade into the background during use.
Dan in NY
[Re: crow]
#5466140 - 10/11/12 11:16 PM
It's actually having a mount that does NOT do what many CGEM's do that attracts me to the A-P mounts.
CGEM DX Clicking Sound, Antibacklash Set Above 30:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5450384/page/3/view/collapsed/sb/5/o/all/fpart/1
CGEM tracking issues:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5435834/page/5/view/collapsed/sb/5/o/all/fpart/1
Really Stumped!:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5441302/page/4/view/collapsed/sb/5/o/all/fpart/1
CGEM Response 17 Fix - DEC connection reseated:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5440409/page/6/view/collapsed/sb/5/o/all/fpart/1
CGEM help:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5434630/page/7/view/collapsed/sb/5/o/all/fpart/1
CGEM RA runaway advice:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5417399/page/7/view/collapsed/sb/5/o/all/fpart/1
CGEM DX dec balance issue:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5402024/page/10/view/collapsed/sb/5/o/all/fpart/1
CGEM Not Tracking:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5411099/page/10/view/collapsed/sb/5/o/all/fpart/1
CGEM RA motor making loud jolty noises -emergency:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5407324/page/10/view/collapsed/sb/5/o/all/fpart/1
Etc., etc.
I could find you many similar posts for my Atlas, CG5 and CGE. As stated in my original post, I want rock solid reliability in harsh environments. If I am going to drive 10-20 hours to a dark sky site for a week of off-the-grid observing, the last thing I want to do when I get back is post something like one of the posts linked above.
What can I say; quality costs.
[Re: dawziecat]
#5466152 - 10/11/12 11:26 PM
I detest backlash. Designs that do not resist backlash creeping into the system are deficient, IMO. It's pretty simple. When I push a slow-mo button to center an object, I like the mount to move when I press the button, not seconds later. The Losmandy mounts I've had have all needed backlash removed every couple of months. These are mounts that have been around for decades without major modification. They really should have addressed this issue long ago. I've never used Gemini II. Gemini I was enough to cure me of any interest in that particular firmware family. Notice that I did not state "Gemini II".
As a consequence, I'm not a fan. Is my negative opinion of these mounts based on the backlash issue and dislike for clunky, kludgy, inelegant Gemini I any less valid than your generalized "Losma-love"?
Somehow, I don't think so.
- Jim
Edited by jrbarnett (10/11/12 11:29 PM)
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
[Re: jrbarnett]
#5466335 - 10/12/12 04:42 AM
Sounds like you've determined you need a high quality mount! When is your AP arriving?
Reged: 07/06/07
[Re: FaronD]
#5466450 - 10/12/12 07:42 AM
Thank Faron
Long focal length + mirror movement if not locked down = hard nut for the AP HC to crack.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
[Re: rmollise]
#5466547 - 10/12/12 09:25 AM
Rod, if you're going to use a long focal length scope with mirror flop, couldn't you use syncing/platesolving to correct for any error in the initial point model?
[Re: Raginar]
#5466832 - 10/12/12 12:32 PM
Hi Raginar.
That's just it. AP-900 or AP Mach 1 GTO?
I'm still a bit paralyzed by the pros and cons of each, but am leaning toward the Mach 1, (and also possibly later putting up a "want ad" for a used AP-900 QMD, though I'll probably wait until the AP-900 is obsoleted by a new AP mount (AP-1000?)).
Because I'm not a good "waiter", I'll probably order a tripod or pier from A-P to be able to use the mount upon arrival, but for travel I'm really considering one of those Rob Miller units.
Reged: 07/06/07
[Re: Raginar]
#5466980 - 10/12/12 03:54 PM
You can do any number of things with a cotton picking PC, but most visual oberservers--like the OP--probably don't want to.
crow
Reged: 07/09/12
Loc: BC, Canada
[Re: rmollise]
#5467016 - 10/12/12 04:18 PM
The Mach 1 from all the reports can do it all. The weight of the thing is a big plus, there's nothing really in that class IMO. combined with a light weight tripod you'd be able to pick the whole thing up and move it easily if necessary. I know I'd be very happy with it but for now Ill hold off. I see the 10 micron in my future perhaps, just to be different...
[Re: crow]
#5520128 - 11/14/12 08:50 PM
So...
I choked. I've sold off enough stuff generate funds sufficient for either a Mach 1 GTO or an A-P 900, but have shelved the idea of spending that kind of cash on a new mount. At least for now.
Though my Synta (Orion and Celestron liveried) mounts are battle-weary and threadbare in some cases, they work for what I use them for - visual observation with small and medium refractor and catadioptric OTAs. If it ain't broke...
Instead, I've put some of the dough raised in savings, left some in Paypal, and will instead finish downsizing on the mount, OTA and eyepiece front, and just enjoy what I keep for awhile. The intermediate term purchases I'm considering are a new, smaller "travel" Dob for multi-day dark sky trips (probably a Teeter again; I love Rob), and perhaps a swap of my old, very tired, abused, but steadfast Atlas for one of the new EQ6 AZs when they actually arrive and there are some user reports.
The only other plans that I have are (a) get a kayak (because I have a beautiful slough a mile from my house with easy put-ins, and 30+ miles of slough/river and shallow bay to explore) and (b) replace all of my cases for eyepieces and mount heads with Pelican cases.
I'm feeling like "I'm good" on the gear front, or will be when I finish shedding, and I'm really enjoying using the stuff for short mid-week sessions now that I have an unheated shed at my observing site.
I won't say "never" but I'm more likely to go for a used AP-900 QMD if one pops up than a new A-P mount. I like analog setting circles and paper observing lists with RA and Dec coordinates printed on them. It's not a race, after all.
delgado39
Reged: 11/13/07
Loc: Glen Ellen, California
[Re: jrbarnett]
#5522645 - 11/16/12 10:49 AM
Did you just pitch a "change up"? And just when I thought you were destined for a new mount. For a guy who loves the in's and out's with this hobby; I thought the AP was in the bag. You are challenging me to think (dare say re-evaluate) my spending habits.
andysea
Reged: 09/03/10
Loc: Seattle, WA
[Re: jrbarnett]
#5523502 - 11/16/12 09:39 PM
Seems like you made your decision. However if you still want a good mount I can vouch for the Mach1. It just works and it's very light. I use the PASILL4L and it seems to be accurate enough for precise goto's and for guided AP. I have only had the mount out once with my TAK scope. The TOA with all the accoutrements weights in at about 34lbs. Here is my first light http://www.flickr.com/photos/andyinsea/8184013748/ It seems like the Mach1 didn't have any trouble carrying the TOA. For transport I use a Pelican 1600.
Andy
tomcody
Reged: 07/06/08
Loc: Titusville, Florida
[Re: jrbarnett]
#5533731 - 11/22/12 10:52 AM
Jim, Have you checked with Astro-Physics to see if the 900 QMD is still serviceable? The reason I ask is that , as old technology, the parts (chips and such ) for the drive system may not be made any more or available and AP has said that the older QMD systems can not be upgraded to the newer drive systems, so if it breaks? I wonder if they can still fix it?  Rex
orlyandico
Reged: 08/10/09
Loc: Singapore
[Re: tomcody]
#5533902 - 11/22/12 12:46 PM
The 900QMD uses the AP 9000 quartz micro drive. Same one on my AP600QMD.
AP says they no longer have any stock but they have the older 8001 which works but doesn't micro-step hence the tracking is less smooth.
That said the 9000 QMD controller is fairly basic (I've cracked open mine to do some repairs). Wally from AP will repair it if it breaks, or basically most competent electronics guys can repair it.
The old 900QMD can have its declination axis upgraded so it becomes comparable to a 900GTO, but AP does this very rarely and only if enough QMDs come in for the service because it is a loss-leading service for them.
The 600QMD (and I imagine the 900QMD, since it uses the same controller) uses a very common Nippon Pulse stepper that is also used (with a different gear ratio - 120:1 instead of the 150:1 in the AP) in the Vixen MT-1 motor. So the thing is eminently serviceable.
In my case I put a German Littlefoot drive on my 600QMD, so I have GoTo. Had to replace the motors as well.
I was almost going to buy the AP900QMD that went for $3750 a month ago on the other site. That one was pristine, and drool-worthy. But... word is that the 900QMD without the declination upgrade is "similar" to the 600QMD in terms of DEC guiding performance - and I want to get away from that DEC guiding performance.
So.....
