DuiA1
Reged: 05/07/12
Loc: Ontario, Canada
1/8 " LX80 Play in AZ axis acceptable?
      #5504558 - 11/04/12 08:57 PM
Folks, I am a visual observer and have had reasonably good success with this mount. My issue is that I have discovered that the az axis has a bit of play after I lock the az lock. If I grab the counterweight bar I can move it approx. 1/8 of an inch. Is this considered acceptable and if not how do I adjust it. Dealer in Canada has told me that it is under warranty but I would have to ship it to Meade at my cost. Thoughts or guidance please.
Mkofski
Reged: 07/19/11
Loc: Greenfield, Indiana, USA
Re: 1/8 " LX80 Play in AZ axis acceptable? new [Re: DuiA1]
      #5504627 - 11/04/12 09:38 PM
Have you talked to Meade tech support yet? You shouldn't have any play in either axis. Your dealer may be correct about Meade's policy, but they have made several exceptions with the LX80. I'd also consider returning it to your dealer for a replacement. I have an LX80 with no play.
There are a few members that have taken the mount apart to work on other problems. Maybe one of them will have a better answere for you.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: 1/8 " LX80 Play in AZ axis acceptable? new [Re: Mkofski]
      #5504670 - 11/04/12 10:03 PM
that much play isn't too bad. most/all mounts have some degree of backlash on both axes with the axes locked. your expectations may be too high.
Axle
Reged: 04/19/12
Loc: Lake Powell
Re: 1/8 " LX80 Play in AZ axis acceptable? new [Re: orlyandico]
      #5505258 - 11/05/12 11:11 AM
I just recently received the LX80 that I ordered last April. I have had a chance to play with it during the day to watch balloons in our local hot air balloon festival. I was using the mount as a manual Alt/AZ mount. It worked really great in this application.
I noticed some slop in the AZ mount also. But, there are two locking levers on opposite sides of the mount that must be slid into place to remove the slop.
The lowest lever simply pushes all the way over once you are finished making the fine-tine AZ alignment with the supplied allen wrench tool. This is the AZ alignment that is adjusted using the manual worm gear.
The other AZ slider lever is more like a clutch that applies resistance to the upper mount head assembly rotation. You can partially push this lever over to increase clutch pressure for manual Alt/AZ use of the mount or you can push the lever all the way tight for motorized use of the mount.
Once both levers are pushed over on the mount, all the AZ slop is gone.
Is this what you are talking about?
DuiA1
Reged: 05/07/12
Re: 1/8 " LX80 Play in AZ axis acceptable? new [Re: Axle]
      #5505748 - 11/05/12 05:50 PM
Yes, but I have both levers in the locked position and I still get the slop in the az clutch. I will contact Meade support soon. I thought one year warranty covered shipping. Does Meade not allow the issue to be resolved at the dealer under warranty? Any suggestions ?
jgraham
Reged: 12/02/04
Loc: Miami Valley Astronomical Soci...
      #5505763 - 11/05/12 06:04 PM
If it doesn't bother the mount's performance why bother? The R.A. axis on my LXD75 has about that much play. On my first mount I fussed over it, on the second I just left it alone (I own two LXD75s).
neilson
Reged: 08/22/10
      #5506010 - 11/05/12 09:27 PM
The play is from the spring loaded wormblock. If you have a light ota it shouldn't be a problem but if you have an ota around 15 or 20lbs it might be a problem. If the movement is stiff it should be alright but if it bounces around you might have problems viewing. I would contact Meade if your going to send it back, they were paying shipping both ways because that has been a problem with some of the mounts. If it bounces around easily it will cause a problem if you decide to try imaging later. If its excessive it should be obvious and make the mount difficult to use. If you haven't had any problems viewing and didn't even know the movement was there until you looked for it then it should be ok. There is supposed to be a small amount of movement but usually its not noticeable with a small, light ota. You will just have to use your judgement and decide if its effecting your viewing. The movement is the worm disengaging from the ring gear and the spring keeps it engaged.
neilson
DuiA1
Reged: 05/07/12
Re: 1/8 " LX80 Play in AZ axis acceptable? new [Re: neilson]
      #5506363 - 11/06/12 06:22 AM
Thanks Neilson. The play is there with no scope mounted and also there with my TV 85. Have not tried it yet with my Meade AR6. The dovetail on the AR6 fits the lx80 mount but not as snug as i would like. are they not compatible?
Jack Huerkamp
Vendor - Waning Moon
Reged: 10/13/05
Loc: Louisiana
      #5506447 - 11/06/12 08:08 AM
I complained to Meade about the exact same issue in my LX80 and they paid to ship it back to their service facility. A month later I received it back in basically the same condition. When I called yesterday to complain, I was told that due to the spring loaded worm/worm gear assembly, a little movement is normal.
I contacted my dealer, who contacted his dealer rep at Meade. The dealer rep contacted the head of Meade service who called me. I directed him to the videos I posted on YouTube showing the issue. He asked me to try the mount out under the night skies as opposed to testing it in my living room and to report back to him. I told him that I would do so in from of 100+ plus people at a star party this weekend and if the mount continued to perform poorly with my C9.25" OTA and MallinCams, the group would see that first hand.
More to follow.
Jack
Starhawk
Space Ranger
Reged: 09/16/08
Loc: Tucson, Arizona
Re: 1/8 " LX80 Play in AZ axis acceptable? new [Re: Jack Huerkamp]
      #5506542 - 11/06/12 09:35 AM
Jack, it's a continuing adventure and an honor to know you.
-Rich
Jmax
Reged: 09/28/10
Loc: Alabama
      #5506558 - 11/06/12 09:42 AM
Jack,
Please do keep us posted. I am one of the "lucky" ones who still is waiting for my LX80, so I have been following the saga very closely. Since I did get it ordered at the $799 price, I haven't cancelled. I wanted it for photography, initially, but I have held on thinking even if it proves to be less than acceptable for taking pictures, it is still cheaper than the Minitower for a dual scope Alt/Az. Anyway, I have a C9.25 as well, so I really am eagerly awaiting your star party report. Thanks so much!
neilson
Reged: 08/22/10
      #5506718 - 11/06/12 11:32 AM
Try it out at night and if the play is excessive then it will bounce around or jiggle when you try looking through the eyepiece and you wont be able to look at things. If you can look at things fine then it should be ok.
If you try imaging with a large ota like a 9.25 or an AR-6, a 20 or 30 second unguided image should come out fine. If the play is excessive it wont.
In my experience, I have a 9.25 and an AR-6 and my mount couldn't handle the weight of either ota. Some people get mounts who can. But expect some movement. Its the way they designed it. But if that movement is excessive and/or it moves too easily you will know it when you try to look through the eyepiece or try to image. It will jiggle around alot. But if it doesn't jiggle or the jiggle stops right away and stays stopped then its fine. I don't know why Meade won't address that springy problem because the mount will never live up to the rating of 40lbs max unless they do.
I would be weary if your AR-6 isn't tight when you clamp it in the saddle. Mine would pop out easily just by twisting it. or leaning my ota to the side. I think it was odd that Meade made their own saddle where you could not mount their older ota's. I think it's another attempt to try to get you to buy a new ota from them. But you can just buy a new dovetail. I would call and complain but they probably wont care. But call anyways because if you don't say something they will never address the problem. They had recently changed the design of their dovetails that come on their refractors.
So anyone who is using a Meade ota with the old style dovetail should be very careful because it can pop off the mount and your ota will be on the ground. I haven't even seen a warning about this from Meade. They just let you find out the hard way.
neilson
brokenwave
Reged: 05/10/11
Loc: Scottsdale, AZ
      #5506895 - 11/06/12 01:18 PM
DuiA1,
I just bought a FarPoint Vixen Type Saddle which locks my scopes in tight on my LX80, an improvement. Also bought some 10mm 1.5 set screws to replace the Meade Knobs.
Farpoint Astro Product Number: FVS - cost $65.
Mkofski
Reged: 07/19/11
Re: 1/8 " LX80 Play in AZ axis acceptable? new [Re: brokenwave]
      #5507196 - 11/06/12 04:35 PM
DuiA1,
Not a bad price on the saddle. Which knobs did you replace with set screws?
DuiA1
Reged: 05/07/12
      #5507229 - 11/06/12 04:57 PM
Talked to Meade customer service today (Christopher)and was told that a little play in the az clutch is okay. They did confirm that they would pay the return shipping if I decide to send it back. They also confirmed that the dovetail saddle on the lx 80 is compatible with the AR6 Meade scope I presently have. I would eventually like to get to AP. It is bugging me a bit so I will give it another go before I decide to send it back. Especially after Jacks experience above. Any other advice?
brokenwave
Reged: 05/10/11
Loc: Scottsdale, AZ
      #5507237 - 11/06/12 05:00 PM
The Meade knobs on their so-so saddle, you can keep the Meade knobs in but need to mount the new saddle with it's knobs pointed down, the Meade spacing is similar to the Farpoint knob spacing so the knobs interfere with each other if you try to mount it with knobs pointed up. Set screws lock it in solidly. I believe they were 20mm long.
Mkofski
Reged: 07/19/11
      #5507358 - 11/06/12 06:33 PM
Talked to Meade customer service today (Christopher)and was told that a little play in the az clutch is okay. They did confirm that they would pay the return shipping if I decide to send it back. They also confirmed that the dovetail saddle on the lx 80 is compatible with the AR6 Meade scope I presently have. I would eventually like to get to AP. It is bugging me a bit so I will give it another go before I decide to send it back. Espe [/list] cially after Jacks experience above. Any other advice?
I really like the mount but for AP, I'd look elsewhere. I'm still trying to work that out for my mount. I like it enough that I'll get a second mount for AP if I need to.
Mkofski
Reged: 07/19/11
      #5507364 - 11/06/12 06:35 PM
I must be a bit dense! Do you replace the original saddle with the new one? Could you post a picture?
neilson
Reged: 08/22/10
      #5507451 - 11/06/12 07:37 PM
Don't take their word that your dovetail is going to stay. If the dovetail is flat on the bottom from one end to the other and its beveled the entire length then it should be good. But if its the kind that's only beveled in the middle about 3 1/2" and its notched on the bottom in the same spot. You should try to pull your ota out of the saddle. Or tilt it to the side. It will probably pop out like both of mine did.
I think they just recently started using the normal looking vixon type dovetails, maybe because of the new mount. Although I am not sure which kind they used many years ago.
neilson
brokenwave
Reged: 05/10/11
Loc: Scottsdale, AZ
      #5507736 - 11/06/12 11:52 PM
The Farpoint saddle has a Vixen rail (male) that goes into the Meade Saddle (female).
My Meade saddle has a cutout in it so you better have at least a 5" long Vixen scope rail to put into the Meade saddle. The new Farpoint saddle will accomodate most any length Vixen style rail because it has no cutout.
18 registered and 38 anonymous users are browsing this forum.
