Hilmi
Reged: 03/07/10
Loc: Muscat, Sultanate of Oman
G11 with Gemini II acting weird
      #5566219 - 12/11/12 04:17 PM
OK, So I have not used my mount for a week and last I used it, it was perfectly fine. I traveled for a week and when I came back I hooked up my adapter to for the optec lepus reducer which pushed my camera further out. So I re-balanced the mount as per my usual procedure starting with Dec balance then RA.
I powered the gemini II and durring my first alignment slew, the RA stalls. Usually when it stalls, it will respond after for example loosening the worm gear meshing. This wasnt the case, the motor was super hot. So I disconnected everything and waitted for the motor to cool.
I tried reversing the RA and Dec cable and couldnt see a problem with the cable, so i reballance. Same issue.
After a few restarts, It agree's to slew, but it keeps on stalling on both Axis, as if it is not getting enough power. It is hooked up to a 16.5 V laptop power supply and I validated this through the gemini web interface. Any idea what's wrong?
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: Hilmi]
      #5566773 - 12/11/12 11:28 PM
Bump! Need help, I'm going to a Star party tomorrow. Also posting on Yahoo groups now
blueman
Vendor Blue Sky Accessories
Reged: 07/20/07
Loc: California
      #5566885 - 12/12/12 01:16 AM
Check the power supply for correct voltage.
Blueman
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: blueman]
      #5566926 - 12/12/12 02:09 AM
Getting 16.5 V according to the Gemini II web interface.
mega256
Reged: 05/10/07
Loc: N of Tampa
      #5566942 - 12/12/12 03:01 AM
Wonder what the power looks like under a load?..
You might look at the voltage when doing a goto, and you may even hold the scope while slewing....There may be a poor conection to the power supply,and might show up only under load..Now that its doing it in both motors the most common thing would be power or connections to power.A tarnished conector might do this.
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: mega256]
      #5566981 - 12/12/12 04:56 AM
Gonna shop for CRC conact cleaner today. Hope it works
BowmoremanModerator
Clear enough skies
Reged: 09/11/06
Loc: Bolton, MA
      #5567031 - 12/12/12 06:22 AM
I occasionally had power related issues with my Gemini I until I just broke down and bought a dedicated 80 Amp marine battery for it... Nary a problem in the year since... Ac adapters are prone to flakiness in my experience... Volts might be ok, but you might get amp issues, or vice versa... Good luck
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: Bowmoreman]
      #5567041 - 12/12/12 06:40 AM
Dave,
I actually have a brand new car battery that I had never used before to power anything, I had it on my battery tender to keep it charged. So I hooked it up to trouble shoot last night and to my disappointing it turned out to be giving out 11.2 V which is way too low to power the mount.
Hilmi
Reged: 03/07/10
      #5567447 - 12/12/12 12:10 PM
Slews now working but movements are jerky and my tracking is horrible. Im starting to really dislike this mount
gdd
Reged: 11/23/05
      #5567522 - 12/12/12 12:44 PM
Motors damaged?
Gale
Startraffic
Reged: 02/12/06
      #5567550 - 12/12/12 01:04 PM
Hilmi,
Answered on Yahoo group too but....
I'd check for either grit in drive train in you're in a high dust area IIRC. If that's clean then I'd look at the Worm mesh. Too tight will cause binding, motor overheating, burnouts, or if just a little too snug then Lagging errors, poor tracking , etc.
Clear Dark Skies
Startraffic
39.138274 -77.168898
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: Startraffic]
      #5567744 - 12/12/12 02:38 PM
I actually took your suggestion and took it a step further, I went and polished the worm gear by hand using some mild non abrasive polish, its now far smoother, The slews are quieter, but my tracking is not as good as before this saga happened. I suspect you are right and my motor is on its way to kicking the bucket. what unfortunate timing. Just when I got my focal reducer going
Startraffic
Reged: 02/12/06
      #5569768 - 12/13/12 07:14 PM
Hilmi,
You haven't had it that long & you've had "issues" with it all along, Why not email Scott or Russell & see if they'll send you a new worm? Can't hurt & they just might. If they say no then a new Brass high precision worm is $65 USD + shipping which would still probably be under $100 USD. Still worth doing.
Clear Dark Skies
Startraffic
Hilmi
Reged: 03/07/10
      #5570386 - 12/14/12 07:06 AM
Motor kicked the bucket as confirmed by the hours wasted setting up under perfect skies and finding the motor dead
Startraffic
Reged: 02/12/06
      #5570824 - 12/14/12 12:59 PM
Hilmi,
That would be Murphy paying you a visit. He happens to have a permanent place in my back pocket, right beside my wallet.
Clear Dark Skies
Startraffic
mega256
Reged: 05/10/07
Loc: N of Tampa
      #5570988 - 12/14/12 03:04 PM
I bought a new motor (hd) ,used the old for a spare..The new motor is very much stronger!So much that I bought a ($35 spare gear box,just incase)I can get a much better fit on my RA worm...works great.And runs cool compared to the old one moving mt C14..The new losmandy motors seam much better than even the maxum..Wasnt cheap,but solved my problem.I called and they had it to me in 2 days.(Florida)good luck..
Hilmi
Reged: 03/07/10
      #5570993 - 12/14/12 03:06 PM
Murphy is a secret agent of whoever is managing the US economy. It's always some gadget that dies on me and the parts need to be shipped in from the US. He probably also owns shares with Fedex, UPS and USPS.
Anyway, jokes aside. When I took the mount apart to clean it, I could not find any grit in the gears, but I did find that one of the two cubes that hold the worm gear in the OPWB was for some reason not seated properly. I find this odd, I checked it last time after assembly, I could have missed it, but I recall being rather thorough. So I guess the worm was binding and that overloaded the motor, which is why my second motor also died out when I swapped out the motors.
Anyway, I took the chance today to use a polishing wheel on my Dremel tool and I polished both the worms as per some instructions that I found online which indicated that this same process gave very good results for that user. Thing is, he used a very specific type of polish that's not available in our market. I used some liquid chrome polish, which isn't all that abrasive. Running my finger over the gears, they feel smoother, even that damaged one that I had put on my DEC axis, the scratches on it just feel a bit rounded. Now I need to budget for new motors before I can do any imaging. This time before I put on the motors I am pulling the entire mount apart for a thorough clean up.
Edit: $225 a pop without shipping! I need two of them too! I need to sell something so that I can fund these motors.
Edited by Hilmi (12/14/12 03:09 PM)
terry59
Reged: 07/18/11
Loc: Colorado, USA
      #5571181 - 12/14/12 05:14 PM
Children? Life insurance policy?
Edited by terry59 (12/14/12 05:15 PM)
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: terry59]
      #5571649 - 12/14/12 10:01 PM
Unfortunatly. I have only 1 child. The wife would notice.
Joe C
Reged: 11/29/08
      #5571687 - 12/14/12 10:23 PM
Then the wife it is
21 registered and 36 anonymous users are browsing this forum.
