Hilmi
Reged: 03/07/10
Loc: Muscat, Sultanate of Oman
G11 with Gemini II acting weird
      #5566219 - 12/11/12 04:17 PM
OK, So I have not used my mount for a week and last I used it, it was perfectly fine. I traveled for a week and when I came back I hooked up my adapter to for the optec lepus reducer which pushed my camera further out. So I re-balanced the mount as per my usual procedure starting with Dec balance then RA.
I powered the gemini II and durring my first alignment slew, the RA stalls. Usually when it stalls, it will respond after for example loosening the worm gear meshing. This wasnt the case, the motor was super hot. So I disconnected everything and waitted for the motor to cool.
I tried reversing the RA and Dec cable and couldnt see a problem with the cable, so i reballance. Same issue.
After a few restarts, It agree's to slew, but it keeps on stalling on both Axis, as if it is not getting enough power. It is hooked up to a 16.5 V laptop power supply and I validated this through the gemini web interface. Any idea what's wrong?
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: Hilmi]
      #5566773 - 12/11/12 11:28 PM
Bump! Need help, I'm going to a Star party tomorrow. Also posting on Yahoo groups now
blueman
Vendor Blue Sky Accessories
Reged: 07/20/07
Loc: California
      #5566885 - 12/12/12 01:16 AM
Check the power supply for correct voltage.
Blueman
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: blueman]
      #5566926 - 12/12/12 02:09 AM
Getting 16.5 V according to the Gemini II web interface.
mega256
Reged: 05/10/07
Loc: N of Tampa
      #5566942 - 12/12/12 03:01 AM
Wonder what the power looks like under a load?..
You might look at the voltage when doing a goto, and you may even hold the scope while slewing....There may be a poor conection to the power supply,and might show up only under load..Now that its doing it in both motors the most common thing would be power or connections to power.A tarnished conector might do this.
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: mega256]
      #5566981 - 12/12/12 04:56 AM
Gonna shop for CRC conact cleaner today. Hope it works
BowmoremanModerator
Clear enough skies
Reged: 09/11/06
Loc: Bolton, MA
      #5567031 - 12/12/12 06:22 AM
I occasionally had power related issues with my Gemini I until I just broke down and bought a dedicated 80 Amp marine battery for it... Nary a problem in the year since... Ac adapters are prone to flakiness in my experience... Volts might be ok, but you might get amp issues, or vice versa... Good luck
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: Bowmoreman]
      #5567041 - 12/12/12 06:40 AM
Dave,
I actually have a brand new car battery that I had never used before to power anything, I had it on my battery tender to keep it charged. So I hooked it up to trouble shoot last night and to my disappointing it turned out to be giving out 11.2 V which is way too low to power the mount.
Hilmi
Reged: 03/07/10
      #5567447 - 12/12/12 12:10 PM
Slews now working but movements are jerky and my tracking is horrible. Im starting to really dislike this mount
gdd
Reged: 11/23/05
      #5567522 - 12/12/12 12:44 PM
Motors damaged?
Gale
Startraffic
Reged: 02/12/06
      #5567550 - 12/12/12 01:04 PM
Hilmi,
Answered on Yahoo group too but....
I'd check for either grit in drive train in you're in a high dust area IIRC. If that's clean then I'd look at the Worm mesh. Too tight will cause binding, motor overheating, burnouts, or if just a little too snug then Lagging errors, poor tracking , etc.
Clear Dark Skies
Startraffic
39.138274 -77.168898
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: Startraffic]
      #5567744 - 12/12/12 02:38 PM
I actually took your suggestion and took it a step further, I went and polished the worm gear by hand using some mild non abrasive polish, its now far smoother, The slews are quieter, but my tracking is not as good as before this saga happened. I suspect you are right and my motor is on its way to kicking the bucket. what unfortunate timing. Just when I got my focal reducer going
Startraffic
Reged: 02/12/06
      #5569768 - 12/13/12 07:14 PM
Hilmi,
You haven't had it that long & you've had "issues" with it all along, Why not email Scott or Russell & see if they'll send you a new worm? Can't hurt & they just might. If they say no then a new Brass high precision worm is $65 USD + shipping which would still probably be under $100 USD. Still worth doing.
Clear Dark Skies
Startraffic
Hilmi
Reged: 03/07/10
      #5570386 - 12/14/12 07:06 AM
Motor kicked the bucket as confirmed by the hours wasted setting up under perfect skies and finding the motor dead
Startraffic
Reged: 02/12/06
      #5570824 - 12/14/12 12:59 PM
Hilmi,
That would be Murphy paying you a visit. He happens to have a permanent place in my back pocket, right beside my wallet.
Clear Dark Skies
Startraffic
mega256
Reged: 05/10/07
Loc: N of Tampa
      #5570988 - 12/14/12 03:04 PM
I bought a new motor (hd) ,used the old for a spare..The new motor is very much stronger!So much that I bought a ($35 spare gear box,just incase)I can get a much better fit on my RA worm...works great.And runs cool compared to the old one moving mt C14..The new losmandy motors seam much better than even the maxum..Wasnt cheap,but solved my problem.I called and they had it to me in 2 days.(Florida)good luck..
Hilmi
Reged: 03/07/10
      #5570993 - 12/14/12 03:06 PM
Murphy is a secret agent of whoever is managing the US economy. It's always some gadget that dies on me and the parts need to be shipped in from the US. He probably also owns shares with Fedex, UPS and USPS.
Anyway, jokes aside. When I took the mount apart to clean it, I could not find any grit in the gears, but I did find that one of the two cubes that hold the worm gear in the OPWB was for some reason not seated properly. I find this odd, I checked it last time after assembly, I could have missed it, but I recall being rather thorough. So I guess the worm was binding and that overloaded the motor, which is why my second motor also died out when I swapped out the motors.
Anyway, I took the chance today to use a polishing wheel on my Dremel tool and I polished both the worms as per some instructions that I found online which indicated that this same process gave very good results for that user. Thing is, he used a very specific type of polish that's not available in our market. I used some liquid chrome polish, which isn't all that abrasive. Running my finger over the gears, they feel smoother, even that damaged one that I had put on my DEC axis, the scratches on it just feel a bit rounded. Now I need to budget for new motors before I can do any imaging. This time before I put on the motors I am pulling the entire mount apart for a thorough clean up.
Edit: $225 a pop without shipping! I need two of them too! I need to sell something so that I can fund these motors.
Edited by Hilmi (12/14/12 03:09 PM)
terry59
Reged: 07/18/11
Loc: Colorado, USA
      #5571181 - 12/14/12 05:14 PM
Children? Life insurance policy?
Edited by terry59 (12/14/12 05:15 PM)
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: terry59]
      #5571649 - 12/14/12 10:01 PM
Unfortunatly. I have only 1 child. The wife would notice.
Joe C
Reged: 11/29/08
      #5571687 - 12/14/12 10:23 PM
Then the wife it is
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: Joe C]
      #5571797 - 12/14/12 11:47 PM
I'm saving that for when I decide to buy an AP1600 and the kid for when I want to put a 6" AP refractor on it.
But with all seriousness, I'm still confused as to what caused the motor burn out. I'm not convinced it is to do with the with the cubes holding the worm blocks as I am very sure I had them installed properly after I last took them off. I even remember checking for gaps to confirm I had proper seating. After this, I used the mount for at least a week with smooth performance, so that can't be it. When I balance the mount, it does not move all that freely, could it be that I thought it was balanced but it wasn't?
I think my warranty is out, but I will attempt to request a goodwill replacement of the motors, because as mentioned earlier my mount never really worked up to expectations.
Hilmi
Reged: 03/07/10
      #5572173 - 12/15/12 08:48 AM
Scott is a great guy, I told him my motors where burnt out and he offered to send me new ones if I sent him the old ones back.
terry59
Reged: 07/18/11
Loc: Colorado, USA
      #5572381 - 12/15/12 11:09 AM
You can't beat that
mega256
Reged: 05/10/07
Loc: N of Tampa
      #5572708 - 12/15/12 02:52 PM
still BUILT in the USA..........with USA service.
Hilmi
Reged: 03/07/10
      #5618555 - 01/12/13 07:52 AM
Just got my replacement motors from Scott. Communication was poor throughout the process as I was left in the dark for almost a month with no idea what's going on, but... I am still very very very happy. I just got a package in the post today with the brand new high torque motors. That's actually a paid for upgrade for the mount and I got it as a warranty replacement for my old motors. I'm a happy man Going upstairs to install these new babies right now!
Hilmi
Reged: 03/07/10
      #5618609 - 01/12/13 08:46 AM
Found the cause for failure while installing the new motors indoors. It was the new gearbox that I had gotten just 2 months before the problem to replace one which had a rounded screw thread for the motor. it had seized up
Dan Finnerty
Reged: 09/11/11
Loc: Pasadena, CA
      #5619446 - 01/12/13 04:58 PM
Hilmi,
What was the problem with the bad gearbox? I'm curious to know for future reference.
The gearboxes seem to be the Achilles heel of the G11. Otherwise an excellent mount, but I have had repeated problems with the gear boxes. Mostly my fault (bonking the RA motor and breaking the plastic pins on the gear box for example).
Are the new high-torque motors any longer than the stock motors? I am thinking of upgrading, but am leery of making the RA motor project out even further and increase the chance of me hitting it again...
I'm very interested in hearing how this works out for you.
wasyoungonce
Reged: 06/07/07
Loc: Land Downunder
      #5619846 - 01/12/13 09:35 PM
Jeez Hilmi...you're having a bad run of late...were you hexed by a gypsy or somethin?
Edited by wasyoungonce (01/13/13 07:01 PM)
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: wasyoungonce]
      #5619917 - 01/12/13 10:18 PM
cup half full
I got a free upgrade.
Gear box had seized somehow
Edit: In response to the motor length, since I don't have them side by side, I cant compare the size. Visually when not next to each other they look about the same size. Somebody did a comparison online on the Gemini II yahoo group and it was mentioned that they are slightly longer, can't recall how much longer.
They are also louder while slewing, but I never did find this a big deal, because unless you are sitting very close to your sleeping neighbor, it shouldn't make a difference.
Edited by Hilmi (01/12/13 11:30 PM)
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #5620149 - 01/13/13 02:53 AM
So, do you need to replace your gearboxes now?
Chris
Hilmi
Reged: 03/07/10
Re: G11 with Gemini II acting weird new [Re: Raginar]
      #5620190 - 01/13/13 05:13 AM
Nope. I had a spare I'll find out tonight if the clouds clear up. It is abnormally cloudy, that's a good sign, it indicates that something good related to astronomy equipment just happened.
23 registered and 56 anonymous users are browsing this forum.
