Choosing a Surveyor's Tripod...
      #5573940 - 12/16/12 11:00 AM
Let's say you were picking up n alt-az head with a 5/8-11 fitting. Would *any* surveyors tripod that supports 5/8-11 likely work with the mount head or are there other considerations to take into account?
Also, does anyone have any faves on the surveyor's tripod front? The surveyor's tripods relabeled by the mount makers are ridiculously overpriced. You can generally find the same, low end surveyor's tripods on engineering supply sites for less than half what the mount head makers are asking for them, and as I said, they look to be low end tripods.
Any preference for wood or fiberglass over aluminum for such a mount? Any other features to look for or avoid?
- Jim
MrJones
Reged: 09/15/10
Loc: Indiana
Re: Choosing a Surveyor's Tripod... new [Re: jrbarnett]
      #5573999 - 12/16/12 11:30 AM
I don't know if this will help but I have had 2 CST Berger cheapo surveyor's tripod link that I put my LT6 on.
There were some unexpected problems.
1) No crossbars between legs and they are free to move all the way past vertical. I put mine on a hardwood floor and the little pointy things on each leg slipped and it went kersplat on the floor.
2) The aluminium hinge area is pretty weak and 2 of them broke with my first tripod when this happened.
3) The top face of this one is curved, apparently so surveyors can fine tune the tilt. You can see the curve better in this photo link. This might be a problem.
4) Do you really want the little pointy things on the bottoms of the legs? They're great in some situations, not so good with others.
I've given up and will try to fit a Meade standard tripod to the LT6 as better surveyor's tripods will still have the same issues and the LT/LS tripod by itself seems impossible to find.
Jim7728
Reged: 04/10/05
Re: Choosing a Surveyor's Tripod... new [Re: MrJones]
      #5574025 - 12/16/12 11:42 AM Attachment (39 downloads)
I did not know some of the Surveyor's tripods top base were curved.
Agree, in regards to the pointy leg tips and lack of a tripod spreader, but both can be remedied.
My preference would be a all wood surveyors tripod with double leg locks. I think Manfrotto sells a spreader that can be affixed to the legs and furniture leg pads or rubber tips can make the tripod floor friendly.
Universal Astronomics sells 5/8" adapters for his mounts to work with surveyor tripods and his heavy duty surveyor tripods are not a that expensive compared to a Berlebach.
http://www.universalastronomics.com/SurveyorTripods.html
Edited by Jim7728 (12/16/12 11:54 AM)
Midnight Dan
Reged: 01/23/08
      #5574032 - 12/16/12 11:46 AM
There are two styles of top - dome top and flat top. Be sure and get the flat top.
As a general rule, wood legs will dampen out vibrations much faster than aluminum. The trade off, of course is that wood weighs more and usually costs more.
If you're looking at the surveyors tripods on the Desert Sky site, one reason they're more expensive is that they've added their own custom spreader to reduce vibrations. The question is, how much do those really help. There are lots of places you can get an inexpensive CS/Bergen tripod for about $60-70 that seems pretty solid on it's own. I've seen them online and at my local Home Depot. Not sure how much better the 2x-priced Desert Sky tripod will perform with the spreader. People who have used the Desert Sky tripod seem to report that they are very solid.
-Dan
Midnight Dan
Reged: 01/23/08
Re: Choosing a Surveyor's Tripod... new [Re: Midnight Dan]
      #5574042 - 12/16/12 11:53 AM
Here's another thread regarding the value of spreaders:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/1,2,3,4,5,8/Number/3432349/Main/3421250
A quote from it: "I originally bought a tripod without the bars because it was cheaper ... big mistake. If I could do it over today I'd defiantly spend the extra money."
-Dan
Agatha
Reged: 06/04/12
Loc: Coulee Region, Wisconsin
      #5574093 - 12/16/12 12:30 PM
This is a very interesting thread. I have a couple of Berlebach tripods, but have been looking for a long time at the surveyor tripods also. I checked many sites for info. The Dutch Hill site was fairly helpful as far as the anatomy of a tripod (shown under parts/access).
The most confusing part for me has been the attachment at the top. I've been also on Universal Astronomics site many times doing some "window shopping." For some reason, I keep coming back to the Sokkia tripod. You know, the beautiful green one. I'll be watching this thread with interest.
Thanks for bringing this up Jim.
Best, Linda B.
neotesla
Reged: 11/18/10
Loc: Canada
Re: Choosing a Surveyor's Tripod... new [Re: Agatha]
      #5574123 - 12/16/12 12:52 PM
Try looking at the Oberwerks ones... They have the spreader included and are pretty rigid. As well they have their "seconds" on sale right now for $100. Extra mounting plates are available as well for pretty cheap.
http://bigbinoculars.com/obwtri.htm
or
http://bigbinoculars.com/tradeins.htm
Re: Choosing a Surveyor's Tripod... new [Re: neotesla]
      #5574168 - 12/16/12 01:29 PM
Thanks.
Great tip.
It looks like the short version did not sell for binoculars. For an alt-az head, though, and a telescope, the standard and tall versions are too tall, and the shorty looks to be perfect. Figure the unextended height is 32" plus 10" to 14" for an alt-az head, and that should be about perfect of an SCT or apochromat.
Moonglum
Reged: 06/01/08
      #5574959 - 12/16/12 11:12 PM
These types of tripods are probably a lot more stable if one does not extend their legs fully. I would plan to have their legs pulled in about 10 inches, so a 55 max height would be about 45 or so. I tried my UA Macrostar(10 inches) on my surveyor's with legs fully retracted- top of tripod was 42 inches, and with a 4inch f8 apo aproaching zenith ya basically gotta sit on the ground. For that length OTA I would think 55 inches max is minimum. I might even end up ordering a extension from Dessert Sky.
VectorRoll
Reged: 11/27/12
Re: Choosing a Surveyor's Tripod... new [Re: Moonglum]
      #5575161 - 12/17/12 04:32 AM
You all are luckier than me having the 5/8x11 connection for your surveyor's tripods. My two tripods have the 3-1/2x8 connections. Picture below.
http://i253.photobucket.com/albums/hh41/WarbNull/Random%20Pics/IMG_3797_zps0c...
Since I have that 3-1/2x8 connection I have to do a little more to get mine to work. Maybe even buy that adapter to convert it to a 5/8x11 before I try anything, but I'll figure it out. I do not think it will be to much of a problem for me though as I made a thread the other day asking for suggestions so I could figure something out, and thankfully I got some replies with good suggestions. The people here have been great and very helpful.
I just now need to wait for my new scope to get here so I can see what I am working with before I move forward on the suggestions I got.
I will say that I did think about some bracing bars and a trey to go under it. Like sort of mentioned here the regular Surveying Tripods do not carry that. Which is mainly do to the fact that it would get in the way as they use a plumbob to center the tripods over the spots they are doing the measures from, and that it is just harder to get a fixed tripod to work on the many different surface contours out in the field. So I was planning on making my own. What ever I make, it has to be easily removable as I use my Surveying Tools. It is going to be easy to make. I already have some ideas and even thought of adding a cup holder.
hottr6
Reged: 06/28/09
      #5575342 - 12/17/12 08:31 AM
I picked up an unused but shop-worn made-in-Germany surveyors tripod on fleabay for half the price (including shipping) of a new made-in-China tripod. The details of the German mount (fittings, castings, hinges etc) appear to be leagues ahead of the Chinese stuff.
Wood tripods are renown for damping vibration, but are considerably heavier than the alloy models.
roscoe
curmudgeon
Reged: 02/04/09
Loc: NW Mass, inches from VT
Re: Choosing a Surveyor's Tripod... new [Re: hottr6]
      #5575375 - 12/17/12 08:53 AM
On some of the better ones, the metal pointy tips screw in, so they can be replaced when they get battered, and this would be a feature to watch for, because at Grainger's or Mcmaster-Carr, you can get rubber feet with imbedded bolts that would be way more slip-proof. Surveyors' suppliers sell better-grade tripods and also sell adapters to go both ways from 3-1/2 to 5/8 threads, and you can take the whole adjustable 5/8 post out if that's the kind you have, and put a big washer and bolt to fit your mount in instead.
I have an old military wood one that I got for free that was OD green, that I stripped and re-varnished, that is a rugged tripod. That's another place to look around - at military surplus places.....
Russ
Jim7728
Reged: 04/10/05
      #5575388 - 12/17/12 09:02 AM
Thanks.
Great tip.
The short version collapsed height is still 38", but extends 6" less than the standard is what I'm reading.
http://www.bigbinoculars.com/tradeins.htm
I like the Oberwerk wooden tripods (own two), but think they are medium duty and may not be robust enough, as far as dampening, to handle a TEC-140.(If that's you intention.) The fixed spread is also a little narrow, imo, when handling top heavy loads.
Edited by Jim7728 (12/17/12 09:13 AM)
huckabuck
Reged: 02/18/07
Loc: statesboro, ga
Re: Choosing a Surveyor's Tripod... new [Re: Jim7728]
      #5575431 - 12/17/12 09:33 AM
most surveyor tripods have a "stop" to keep the kersplat problem at bay. these stops are incorporated into the top of the legs. fully extended these stops rest against the base, keeping the legs from over extending.
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
Re: Choosing a Surveyor's Tripod... new [Re: huckabuck]
      #5575485 - 12/17/12 10:26 AM
One thing that I think you need to keep in mind is the load that surveyor's tripods are designed to take. Having used them for their intended purpose, they are generally not used with equipment that is anywhere near as heavy as most astronomy equipment, much less a longer, heavier OTA. For truly light weight use they may be fine, but I would not risk anything heavy on one. The Oberwerk tripods are rated at 35 pounds and I would say that is the max for sure. There is a reason why heavy wood astronomy tripods are as expensive as they are.
Rich V.
Reged: 01/02/05
Loc: Lake Tahoe area, Nevada, USA
Re: Choosing a Surveyor's Tripod... new [Re: EFT]
      #5575567 - 12/17/12 11:36 AM
A while back I was considering a heavy surveyor tripod for use with my Unistar Super 8. ISO test results were available on a number of tripods. At the time only the Crain Tri-Max tripod exceeded the ISO 12858-2-H tripod stability standards. IIRC, those who didn't were Sokkia, Dutch Hill, CST Berger and SECO to name a few. The Crain Tri-max exceeded them all clearly.
Those test results are no longer on the web as far as I can find. I found the URL but it's no longer available.
Leica now has made test results available showing that their tripods exceed the ISO standard performance of the Tri-Max. Many aspects of the ISO specs don't necessarily apply to telescope use but certainly the tripod's ability to maintain a stable orientation over time and withstand torque loads would be appropriate. Heavy tripods were tested with a 30kg load and light tripods with a 10kg load; twice the rated load.
Leica's results are available here; take the results as you may...
Surveyor tripod white paper
Rich
MrJones
Reged: 09/15/10
Loc: Indiana
Re: Choosing a Surveyor's Tripod... new [Re: Rich V.]
      #5575609 - 12/17/12 12:17 PM
Those Oberwerks do look good - nice tip for sure!
SteveG
Reged: 09/27/06
Loc: Seattle, WA
      #5575783 - 12/17/12 02:12 PM Attachment (33 downloads)
I agree that the Oberwerk site look like the best option today. I have a UA surveyors, with their adapter. Mine came with a hinged spreader, but I removed it and instead I use an eyepiece tray mounted directly to the tripod. I made these items myself and it made the tripod even more rigid. Mine has the combo spike/rubber feet. The rubber feet are perfect and stay out at all times. The legs are wood and the poles are fiberglass. This tripod turned my GP into a GPDX, and damp times on my 4.7" scope are less than 1 sec.
Tons of tripod feet here:
http://www.bhphotovideo.com/c/buy/Spikes-Rubber-Feet/ci/10830/N/4289955530
Tons of spreaders:
http://www.bhphotovideo.com/c/buy/Spreaders/ci/3929/N/4200777867
neotesla
Reged: 11/18/10
Loc: Canada
Re: Choosing a Surveyor's Tripod... new [Re: SteveG]
      #5575820 - 12/17/12 02:34 PM
FYI, the Oberwerk tripod does not have spiked feet. The tip is a rounded platic cover for the legs.
Reged: 06/16/04
      #5576761 - 12/18/12 02:27 AM
I recently purchased a StellarVue MG-2, it's a dual sided alz-az mount with geared slow motion controls rated for 20-25lbs. It came with aluminum surveyors tripod with a custom spreader assembly. I primarly use it with my NP-101 which fully out fitted with a heavy eyepiece weighs about 13 lbs. I was very skeptical that it would be stable but it is rock solid with the NP-101, I can focus and track up to the limit of the scope (~300x) without any vibration. It is definitely sufficient for a scope this size.
I have used it with my 8 inch F/5 Newtonian, it goes about 20lbs with a lot of bulk. I handled it reasonably well.. there was some vibration when tracking or focusing but it was acceptable.
I am not sure what Jim is planning to use a surveyors tripod for but I will say I was impressed with the StellarVue. Currently it sells for $250 with the custom spreader. That's a fair amount of money, I am sure there are better values out there.
28 registered and 51 anonymous users are browsing this forum.
