rfr66
Reged: 12/07/11
Loc: Long Island, NY
A mount and tripod for my new TEC 180FL
#5596268 - 12/30/12 02:33 PM
I received a call from Yuri that he is in the final assembly process for my new TEC 180FL and I do not own any mount or tripod for it. My only scope is a Meade LS8 which I hope the TEC will replace. I want the lightest possible set up so that I will be more likely to haul it out to the dark site at the beach. I am strictly a visual observer and plan on viewing high power planetery and DSO with the scope. I want settling times of under a second to almost instantaneous and to be able to view in a slight breeze would be nice to. With my Meade I find the scope almost unusable if I don't use the vibration damping feet but with them it is a joy and settles almost instantly. So I can see that how a mount or tripod is set up can make a drastic difference in settling times.
After spending hours reading through all the posts on CN I would love if I got great results from an AP Mach 1 mount with a Rob Miller L tripod probably using an 8 in extension. Howard from AP thought that I could use the Mach 1 successfully for visual use with the 180FL if I follow a couple of guidelines. First he said don't use the dove tail saddle plate. It would add vibration. That I should use the 15" flat mounting plate for rigidity. Second he said that I should place the counterweights right up at the base of the mount instead of at the end of the bar and use either four 9 lb. weights or two 18 lbs. weights with the thicker shaft for 36 lbs. total. This is supposed to reduce flexing of the shaft which would otherwise introduce vibrations and increase damping times. I would like to hear your opinions on whether you think this is sound advice and would give me a stable enough visual observing platform.
M13 Observer
Reged: 12/09/06
Re: A mount and tripod for my new TEC 180FL
[Re: rfr66]
#5596304 - 12/30/12 02:57 PM
After spending hours reading through all the posts on CN I would love if I got great results from an AP Mach 1 mount with a Rob Miller L tripod probably using an 8 in extension. Howard from AP thought that I could use the Mach 1 successful for visual use with the 180FL if I follow a couple of guidelines. First he said don't use the dove tail saddle plate. It would add vibration. That I should use the 15" flat mounting plate for rigidity. Second he said that I should place the counterweights right up at the base of the mount instead of at the end of the bar and use either four 9 lb. weights or two 18 lbs. weights with the thicker shaft for 36 lbs. total. This is supposed to reduce flexing of the shaft which would otherwise introduce vibrations and increase damping times. I would like to hear your opinions on whether you think this is sound advice and would give me a stable enough visual observing platform.
You are definitely pushing the envelope on this, even for visual. All of Howard's suggestions are very valid. Whether they are enough only you will be able to say. While the scope might be around 35 pounds, adding a finder, diagonal, binoviewer (if used) and an eyepiece will add another 3-5 pounds or so. Rings and plate add another 10 pounds, so you are looking at around 50 pounds of optics, 30 pounds of mount, and 40 pounds of counterweight. I personally would go with an additional 5 pound CW which could be shifted up and down the CW shaft as necessary depending on whether you are going to use a binoviewer. So, that is around 120 pounds of gear on a TRI36L, I do not think you are going to see the damping you want with it. I personally would go with the TRI36M with an ADATRI adapter (I think Rob makes an ADATRI style adapter too but you will have to bring that up with him) and use an 8" AP extension. Another option would be two 4" Rob Miller TRI36M extensions. In either case, whether the TRI36L or TRI36M, since you are going with a fairly heavy load, I would definitely suggest the "heavy duty" levelers over the standard micro levelers. The TRI36M does add a little weight, maybe 4 pounds at most over that of the TRI36L, making it about 16 pounds, but it will be far more solid under the load you are proposing.
EDIT -
Oh, and by the way, congratulations on the TEC180FL. While I don't have one myself, I do have a similar competitor's model and it is an absolutely superb telescope, pretty much right at the limit of portability and aperture. Enjoy!
Edited by M13 Observer (12/30/12 03:12 PM)
rfr66
Reged: 12/07/11
[Re: M13 Observer]
#5596359 - 12/30/12 03:23 PM
I had read a post on here that Rob Miller said the limiting factor in stability with the Mach 1 and his L tripod was not the tripod but the mount, so if the mount can be stabilized further it should work. I think the 120 lbs. you totaled up is within the load capacity of the tripod. But if the medium version of his tripod offers better damping even though the light should be able to support the weight then I would get the medium with the heavy duty leveling feet. Of course the only way to truly know is if I try it or if someone else has already tried it and offers their opinion.
BTW what do you use to mount your 180mm and is it easily transportable?
Edited by rfr66 (12/30/12 03:30 PM)
M13 Observer
Reged: 12/09/06
[Re: rfr66]
#5596403 - 12/30/12 03:44 PM
Well, since I wrote both of the reviews, on CN for the TRI36L and on Astromart for the TRI36M, and I have everything you are discussing, mount, tripod and scope-wise, I figure that my statements are pretty much based on absolutely solid information.
I use an AP400QMD or an APMach1GTO on the TRI36L and either the APMach1GTO or an AP900GTO on the TRI36M. I image mostly and use a heavy load of CCD equipment and guider. Personally, I limit the TRI36L to visual with a 6" class refractor and imaging to a 5" class refractor with my added imaging load. The TRI36M is significantly more stable in my opinion, (as it should be!) and is more suitable for the heavier load of the 6" or 7" refractors when imaging and using the AP900GTO mount.
If you are expecting rigid extremely quickly damped viewing, the TRI36M will be a far better option when using the APMach1GTO, and yes, Rob is correct, damping is based on the performance of the entire system, tripod, total load, mount and moment arm of the telescope.
Edited by M13 Observer (12/30/12 03:59 PM)
rfr66
Reged: 12/07/11
[Re: M13 Observer]
#5596816 - 12/30/12 07:38 PM
Sorry, I didn't realize you had all the equipment. That is exactly the feedback I was looking for. What height tripod is required for seated viewing at zenith that will not be too high when viewing the horizon with the 180fl? I think Howard said 56" or 58".
andysea
Reged: 09/03/10
Loc: Seattle, WA
[Re: rfr66]
#5597245 - 12/31/12 12:39 AM
Why not get an AP900? It can be broken down into two pieces for transportability and it will probably handle the 180mm better than the Mach1.
rfr66
Reged: 12/07/11
[Re: andysea]
#5597678 - 12/31/12 10:25 AM
I think you are right. After not much thought I am thinking of going with the AP900. It would be nice to use the focuser while viewing and not have the image jiggle. I guess folks that have used a 180 on a Mach 1 probably had the mount already and figured why not try it but if starting from scratch would have gone with something bigger. George from AP uses a 1200 mount and ATS pier with his and said he was the only one at the Winter star party that could keep viewing in high wind.
M13 Observer
Reged: 12/09/06
[Re: rfr66]
#5598098 - 12/31/12 02:37 PM
Yes, the beefier the support, the better the view. The 10" ATS, Monolith or TRI36H will give a better base to start with, and the AP1200 will provide a very solid and massive mount. Unfortunately, this also means that you will have big heavy equipment to move around. Grab and go it isn't. Even the AP900 means that there is more stuff and heavier stuff to move and it all adds up. My APMach1GTO lives in a Pelican case quite nicely. It weights about 52 pounds with almost everything mount related inside - mount, CW shaft, keypad, GTOCP3, cables, assorted fasteners, dovetail saddle, hex key set; everything except counterweights. It has wheels and an extensible handle for ease of transport. The counterweights and tripod go into a hard shell golf case with, you guessed it, wheels and a handle. I think you mentioned using the scope on a beach but unless you are operating from a hard solid surface, I think you will find that the TEC180FL is going to be "difficult" to handle. It and all the various other parts are unwieldy. The easiest portion to handle will be the TRI36M tripod should you choose to go that way.
As to the height, as far as I can tell, the eyepiece is never at the correct height. An adjustable height chair is really handy. Varying the eyepiece position via rotating the diagonal works well too. If I am planning on just going into "sky tourist" mode with quick views of objects, then bending and contorting myself works too. If I am going to sit for extended periods of time viewing Jupiter, Mars or Saturn, then being as comfortable as possible makes all the difference.
mgwhittle
Reged: 08/24/11
Loc: Chattanooga, TN
[Re: M13 Observer]
#5598414 - 12/31/12 05:21 PM
I just went through this process deciding on a mount for a 175mm refractor. I went with a 900GTO. I can't imagine you would be happy with the stability of a Mach1 based on the requirements you stated in your first post. I considered a used 1200 or the new 1600, but for visual, I think the 900 is a very good match for this size of telescope without being overly hard to transport/set up.
rfr66
Reged: 12/07/11
[Re: M13 Observer]
#5598523 - 12/31/12 06:31 PM
Your description of viewing habits sounds right in line with what I would be doing. When I said I view at the beach I don't actually go onto the sand with the equipment. I'm set up next to my car on the concrete in the parking lot. I would go down there every nice night to view with my Meade and be set up in under 5 minutes. I'd like to see myself going as often with the TEC. You're neat travel packs with your equipment seems to make that a lot easier.
Odd as it might seem there are quite a few people using the 180 with the Mach 1 successfully. I don't know what they use to qualify success. Even Yuri said he has viewed through the 180 on the Mach 1 at a star party he attended and it was fine. George at AP said that stability is all relative. It depends on what you are coming from. If you are used to a much more rigid setup then you probably wouldn't be happy. But if you are coming from a lighter weight setup like my Meade, I might think that the Mach 1 is the cat's meow and be blown away by how much more stable it is. No argument that the AP900 is more stable but will the extra weight cause me to make the trip out less often? Maybe I will need a mach 1 for outings with lower stability expectations and have a heavy weight setup in my backyard that I can leave setup under a cover. I would be better served doing the majority of my serious planetary observing from home and saving the dark site for lower power DSO observing which will be less critical of mount jitters. Am I making any sense with this line of logic?
mgwhittle
Reged: 08/24/11
[Re: rfr66]
#5598561 - 12/31/12 06:49 PM
Between a Mach1 and a 900GTO, I don't think the slight increase in component weights for each of these will slow you down on getting out to observe as much as the weight of that size of scope. In other words, if you are willing to lug that size scope out, the weight of the 900 isn't an issue.
rfr66
Reged: 12/07/11
[Re: mgwhittle]
#5598578 - 12/31/12 06:59 PM
Congratulations on your new scope. It is GORGEOUS! I saw it in person at the show and was very impressed. What is the height of your pier and is it optimized for seated viewing?
M13 Observer
Reged: 12/09/06
[Re: rfr66]
#5598582 - 12/31/12 07:05 PM
That sounds about right only I would just go with the Mach1GTO for both beach and back yard. If you feel the need to upgrade in the back yard later for more stability then either buy a used AP900 or pick up whatever the replacement will be called once it is released sometime late next year. Another way of upping your stability somewhat at home without changing out the mount would be a really solid concrete or fixed steel pier.
mgwhittle
Reged: 08/24/11
[Re: rfr66]
#5598616 - 12/31/12 07:22 PM
Thank you! I went with a 54 inch pier and I use an adjustable chair. I don't feel like I am sitting close to the ground with that height pier and the scope pointed at the zenith.
rfr66
Reged: 12/07/11
[Re: mgwhittle]
#5598632 - 12/31/12 07:40 PM
It looks like I would have a similar setup to you height wise. Which pier is that? It's nice that you have plenty of room for the scope to clear without hitting any legs. How much counter weight are you using? It was recommended that I use 36 lbs. pushed right up to the base of the mount to increase stability. I see you have yours close to the end. Have you had a chance to look through it yet? I'm curious to know what your settling times are, if you even have any. Thanks for your input. It's really helping me to make an informed decision.
rfr66
Reged: 12/07/11
[Re: M13 Observer]
#5598649 - 12/31/12 07:50 PM
I think I will take you up on your advice. If I plan on two mounts anyway I might as well start with the Mach 1 and see where it takes me utilizing all of the stability tricks. Are you still recommending the Miller Lite tripod for the beach?
M13 Observer
Reged: 12/09/06
[Re: rfr66]
#5598670 - 12/31/12 08:06 PM
No, get the TRI36M. I think the Miller L)ight version just isn't enough tripod for the stability you want with a heavy load. Besides, the M version can be purchased for the 900 while the TRI36L is for the Mach1 style only. The TRI36M 900 adapter also has holes pre-drilled for the ADATRI adapter and there isn't a huge amount of weight difference between it and the TRI36L. At 15 or 16 or so pounds the TRI36M will be the lightest part of the gear by far.
Edited by M13 Observer (01/01/13 06:39 PM)
mgwhittle
Reged: 08/24/11
[Re: rfr66]
#5598704 - 12/31/12 08:25 PM
It is the AP standard pier, I want an ATS pier but was unwilling to wait for one right now. I will probably order an ATS pier at the end of next year, not for any stability issues but because I want something that folds up without dis-assembly.
I am using two 18 pound counterweights. I believe the 175EDF weighs 9 pounds more than your 180FL. When I take the lens cap off the 175, I move the weights up the shaft about 5 inches....yes, it is that heavy! I would suggest starting out with the same weight set up, you should be able to get them much further up the shaft, although I suspect with the 900 versus the Mach1 this is less of an issue.
Vibration is not an issue with my set up. Very little movement while focusing with the main knob, almost none with the micro focus and when I let go of the focuser there is an immediate cessation of what little vibration there is.
I considered a 1600GTO at one point just because I would have rather dealt with more weight than vibration issues. I went with a 900 based on input from other CN members and could not be happier.
rfr66
Reged: 12/07/11
[Re: mgwhittle]
#5599925 - 01/01/13 04:30 PM
It seems that you had pretty good results with your setup regarding vibration and damping times. The ATS pier looks sweet with a handle and everything. Will it give you the same clearance at zenith without hitting the legs as your current pier? I'm also curious as to how you keep your front lens clean after a night of viewing. Mine always gets covered in dried out dew.
korborh
Reged: 01/29/11
[Re: rfr66]
#5600031 - 01/01/13 05:45 PM
The Rob Miller tripod's fold easily without any dis-assembly. Why bother with the costly and heavy alternatives (like ATS) when there is the beautiful, elegant, light and cheaper Tri36M to blow away the competition.
mgwhittle
Reged: 08/24/11
[Re: korborh]
#5600125 - 01/01/13 06:44 PM
Does Miller make a 54 inch high tripod? A 36 inch tripod will not allow a large (7inch+) refractor to reach the zenith without the eyepiece hitting the ground.
Edited by mgwhittle (01/01/13 06:53 PM)
korborh
Reged: 01/29/11
[Re: mgwhittle]
#5600180 - 01/01/13 07:21 PM
He makes the tripod custom height (other than default 36") with added cost....that was about a year ago when I last corresponded with him. This is what he mentioned "Custom height units are available, between 26" and 60", at plus 30% on the basic all black price."
rfr66
Reged: 12/07/11
[Re: mgwhittle]
#5600257 - 01/01/13 08:13 PM
The Miller tripod would properly need an extension so that a long refractor will clear the legs. Maybe something like a 46" tripod with an 8" extension. Although the Miller's are light, fold for easy portability and are very strong and rigid, not much has been said on direct comparison of the damping times compared to portable piers. You gave a very good description of what the damping times with your pier are. I would like to hear that with the Miller too.
mgwhittle
Reged: 08/24/11
[Re: rfr66]
#5600334 - 01/01/13 09:06 PM
It should, there are others who are using this exact combination on CN.
Dew-not controller and heater strip located just behind the dew shield. You really should invest in a good dew control system. I don't know where you live, but where I am, I know that wet pollen from allowing dew to accumulate on the lens can wreck havoc with the coatings.
korborh
Reged: 01/29/11
[Re: rfr66]
#5600348 - 01/01/13 09:13 PM
In my case with Tri36M carrying an AP1200 with C11 EdgeHD 8mm EP, damping times were very good...slap on the tripod damped under a second and on the tube a little more...perhaps 1.5sec. I now have a very solid permanant pier and I dont see any improvement in dampening times over the Tri36M. The tripod is just incredibly stable and solid.
rfr66
Reged: 12/07/11
[Re: korborh]
#5600861 - 01/02/13 08:52 AM
That's impressive that the Miller offers the same stability as a permanent pier. Can you tell if you get any movement when using the focuser and if so how long that would take to settle down? The wrapping test is on the extreme side.
korborh
Reged: 01/29/11
[Re: rfr66]
#5601168 - 01/02/13 12:31 PM
I use robofocus motor on the primary of the SCT to focus, and have not seen any vibration during focusing in either setup. Only the un-avoidable image shift due to moving mirror. No sustained vibrations from touching the OTA either....but again that is a function of the whole system including the mount. Bottom line - this tripod is not going to be the reason for vibration - it will be the rest of your system.
I believe the Miller tripod is deliberately engineered to be a quick-damped support. All this with so little weight - its really one of a kind design.
ASTERON
Reged: 11/24/07
Loc: ISRAEL
[Re: korborh]
#5617485 - 01/11/13 03:44 PM
Hi Korborh,
I dont wish to hijack the thread but I have similar questions
I will be getting a DM6 Mount soon. I want to use it with my 12" LX200R OTA ( about 45- 50 pounds, depending on the particular setup). Do you recommend the Miller Tri36H, Tri36M or the Tri36L with it ?
(I may also use a couple of Miller extensions on the tripod for use with a ES 127ED refdractor, so moment may be larger but OTA mass may be much smaller.
P.S. I can easily cary the Tri36H and I may also need to mount a much heavier mount on it at one time or another for doing AP.
Edited by ASTERON (01/11/13 03:46 PM)
korborh
Reged: 01/29/11
[Re: ASTERON]
#5617844 - 01/11/13 07:31 PM
Asteron, I recommend you get in touch with Rob with your specific requirements and he will be able to tell you exactly what you would need, cost, adapters and future proofing the tripod. He is very knowledgeable and great to deal with although slow in responding to email.
mmalik
Reged: 01/13/12
Loc: USA
[Re: rfr66]
#5618506 - 01/12/13 06:29 AM
How about this... kind of tripod setup for 900GTO; courtesy of D. Perry (CNer...). Thx
mmalik
Reged: 01/13/12
Loc: USA
[Re: rfr66]
#5618516 - 01/12/13 06:46 AM
No argument that the AP900 is more stable but will the extra weight cause me to make the trip out less often? Maybe I will need a Mach1 for outings with lower stability expectations and have a heavy weight setup in my backyard that I can leave setup under a cover. I would be better served doing the majority of my serious planetary observing from home and saving the dark site for lower power DSO observing which will be less critical of mount jitters. Am I making any sense with this line of logic?
TEC 180FL being fairly large scope (not just size, possible susceptibility to wind gusts, etc.) I think you'll be better off with 900GTO; no need to think two mounts, one for home one for remote. With 180mm scope you are already setting yourself up for bigger stuff; no need to scrimp on the mount. Goodluck
Paul G
Reged: 05/08/03
Loc: Freedonia
[Re: rfr66]
#5618581 - 01/12/13 08:17 AM
As George said, stability is relative. I have a 175 EDF and both a Mach1GTO and a 900 GTO. The Mach1 easily carries my 155 EDFS or 10" Mak-Cass, but I much prefer the 900 for the 175. The weight isn't the issue, it's the amount of weight at the ends of the moment arm. IIRC your scope is lighter in weight than mine. Your choice depends on how much observing you will do in less than perfect conditions (how well protected from the wind) and your tolerance for vibration.
Weight of the mount shouldn't affect your setup time as neither axis of the 900 weighs more than the Mach1, just one more step putting it together, takes about 15 seconds extra.
ASTERON
Reged: 11/24/07
Loc: ISRAEL
[Re: korborh]
#5618618 - 01/12/13 08:50 AM
Thanks Korborh,
I already e-mailed him with my questions. I hope his e-mail has not changed as the e-mail I used was from an add posted on AM on 2011 ( I used robmiller1950@comcast.net)
With such beautiful products I really don't understand why he has no website (I tried the catamount website, but there is only archived stuff there and no clue abount the new tripods.
I guess when you are a one man show you don't have time for building and maintaining a website) .
Edited by ASTERON (01/14/13 02:48 PM)
rfr66
Reged: 12/07/11
[Re: mmalik]
#5621608 - 01/13/13 08:34 PM
I would love a setup like that with the ATS pier but I am hearing that the Rob Miller tripod is more stable and much lighter. I'm also wondering why no one mentions the Paramount MX as an option instead of the AP900. The Paramount MX is a little lighter (50 lbs vs 54 lbs.), has a higher payload capacity (90 lbs. vs 70 lbs) and is about the same price as the 900 ($9000 vs $8750). So what's the deal there?
EDIT: Nevermind. I found the answer in another thread. That the requirement for a computer all the time is a put off.
Edited by rfr66 (01/14/13 09:04 AM)
mmalik
Reged: 01/13/12
Loc: USA
[Re: rfr66]
#5622314 - 01/14/13 09:25 AM
I have used ME and elCapitan. I know not a direct answer or direct comparison, just using them as an “example” to answer your question. Besides physical differences, some things I like about elCapitan are ease of use (simple keypad hand controller operation in comparison of ME requiring software/computer/joy stick [joy stick being not so handy]), tracking/guiding past meridian (ME has hard meridian stop), interoperability (is a breeze to use iPad/SkySafari Pro with elCapitan, never got it working with ME given all the software/computer, hardware interface, and other requirements), etc. Controller on elCapitan is simple and straightforward; to me ME seems quite busy and cumbersome when it comes to its electronics and interfaces. Again, not saying I didn’t like ME, just didn’t get it quite going for my needs while elCapitan just simply works without a glitch, every time. Thx
