Pages: << 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | >> (show all)
hectar
Reged: 12/24/12
Loc: Ontario, Canada
Re: Celestron VX mount [Re: rmollise]
      #5659657 - 02/03/13 10:14 AM
Thanks for the response(s) guys.
D. Bang on. As good or better than my NexStar 11 GPS. By "stays" do you mean go-to accuracy doesn't degrade as the evening wears on, or are you talking about tracking? Go-to has never degraded over the course of the night.
I meant GOTo spot on and tracking for few hours.
Whichwayisnorth
Reged: 07/04/11
Loc: Southern California
      #5659718 - 02/03/13 10:52 AM
I too like the Orion mini.
bunyon
Reged: 10/23/10
Loc: Winston-Salem, NC
Re: Celestron VX mount [Re: Whichwayisnorth]
      #5659823 - 02/03/13 11:49 AM
I may have missed it: does the AVX come with a polar alignment scope - it looks like it has space for one (yes, I know, many of you think I'm crazy for using it. I won't argue, but I'm free to be crazy).
Also, does it fit the same tripod/pier as the CG5?
Reged: 07/06/07
Re: Celestron VX mount [Re: hectar]
      #5659828 - 02/03/13 11:51 AM
Tracking quality is dependent on your polar alignment's quality.
cn register 5
Reged: 12/26/12
Re: Celestron VX mount [Re: bunyon]
      #5659857 - 02/03/13 12:01 PM
It doesn't come with a polar align scope but the adverts say one is an option. I've never used one, I would have to demolish my house to see Polaris from where I set up.
It doesn't fit the CG5 tripod, not quite, there's details further back in this thread.
Chris
bunyon
Reged: 10/23/10
Re: Celestron VX mount [Re: cn register 5]
      #5659864 - 02/03/13 12:06 PM
Cool, thanks.
Orionis91
Reged: 03/01/10
Loc: Maryland USA
      #5659884 - 02/03/13 12:22 PM
It works, that's what matters.
Ben B
Reged: 02/03/13
Loc: GA
Re: Celestron VX mount [Re: Orionis91]
      #5661359 - 02/04/13 09:32 AM
After reading initial reviews earlier in this thread and elsewhere I decided to go for it. My Advanced VX mount should arrive tomorrow which just happens to be the same day my new StellarVue APO arrives. Time to take off work!
DXVictor
Reged: 02/01/10
Loc: Clark, CO
      #5661448 - 02/04/13 10:26 AM
I also use the Orion "Mini" setup with PHD. On the CG-5 I could get nice round stars up to about 5-6 minutes. Haven't tried the AVX yet. Temps are too low for my old bones right now (+5 to -10 most nights). I use an Orion G3 and a Canon DSLR with an Orion ED-80 and an Astro-Tech 6" CR. Both make a very light-weight setup and produce very sharp images.
powerstroke01
Reged: 06/19/07
Loc: Western Sierra Nevada Foothill...
Re: Celestron VX mount [Re: DXVictor]
      #5661544 - 02/04/13 11:10 AM
Well. I also decided to order one of these for a portable setup. Should be here in a few days.
mpgxsvcd
Reged: 12/21/11
Loc: Raleigh, North Carolina
Re: Celestron VX mount [Re: powerstroke01]
      #5663744 - 02/05/13 03:11 PM
Is there an illuminated polar finder for the new VX mount? I really wish someone would come up with one for the lower end mounts. That would make that process a lot easier in the dark.
Reged: 07/06/07
Re: Celestron VX mount [Re: mpgxsvcd]
      #5663995 - 02/05/13 05:22 PM
AllStar is a lot easier than an illuminated polar scope.
bunyon
Reged: 10/23/10
      #5664006 - 02/05/13 05:28 PM
Here we go again.
Travis, I don't know about illuminated, but the folks at Astronomics told me that the same scope that fits a CG5 or CGEM will fit the VX.
Enzino
journeyman
Reged: 01/12/07
Re: Celestron VX mount - pdf manual? [Re: bunyon]
      #5664331 - 02/05/13 09:15 PM
Is a pdf manual for the mount available? I can't find it on Celestron's website...
E.
Mkofski
Reged: 07/19/11
Loc: Greenfield, Indiana, USA
Re: Celestron VX mount - pdf manual? [Re: Enzino]
      #5664348 - 02/05/13 09:29 PM
E.
Try: http://www.celestron.com/c3/support3/index.php?dload=Download&_m=download...
mpgxsvcd
Reged: 12/21/11
      #5664671 - 02/06/13 05:50 AM
And your balance with these lower end mounts.
Enzino
journeyman
Reged: 01/12/07
Re: Celestron VX mount - pdf manual? [Re: Mkofski]
      #5664741 - 02/06/13 07:39 AM
Thanks Mike!!
E.
E.
Reged: 07/06/07
      #5664745 - 02/06/13 07:45 AM
Well, sort of. Balance if very important when imaging, but really doesn't much affect visual use.
Ben B
Reged: 02/03/13
Loc: GA
      #5664832 - 02/06/13 09:08 AM
My Advanced VX arrived yesterday so I had to try it out last night even though the skies were mostly cloudy. Polaris was continuously hidden behind clouds so I used a compass to polar align the mount as best I could then did a 2 + 1 star alignment. I intended to do 2 + 4 then the all star routine but the clouds weren't cooperating.
I was able to get a small break in the weather to test out the GOTO and tracking and I was extremely impressed. My telescope only has a focal length of 480mm but every target I asked the mount to go to ended up almost in the center of my 12mm eyepiece. Tracking seemed very accurate as well - I took a 2 minute video of Jupiter with my webcam and there was only a 1 pixel difference between Jupiter's position in the first frame and the last frame. With a proper alignment routine and decent weather I expect great things from this mount.
The only issue I've run into so far is my SV80ST scope is light enough that the counterweight is positioned in a such a way that it can hit the altitude adjustment screw in the front. I had to slightly loosen the screw so it's horizontal to prevent things from hitting. Perhaps I just need to attach a bit of extra weight to the telescope so I can move the counterweight closer to the end of the bar.
mpgxsvcd
Reged: 12/21/11
      #5664930 - 02/06/13 10:25 AM
I think it really affects the tracking when you get close to the limits of these lower end mounts with imaging scopes and equipment.
I checked and the CG-5 lists its carrying capacity as 35 pounds and the new VX mount is only rated for 30 pounds. I wonder if they backed off on that spec because it was more of a problem than they realized at first.
Capable of holding over 35 lbs of payload and slewing at 4º per second.
http://www.optcorp.com/product.aspx?pid=2060&kw=Cg-5&st=2
Edited by mpgxsvcd (02/06/13 10:30 AM)
28 registered and 22 anonymous users are browsing this forum.
