Midnight Dan
Reged: 01/23/08
Re: Help with iEQ45 new [Re: psandelle]
      #5670500 - 02/09/13 10:52 AM
As far as the polar offset routine, I typically can have my mount at 00-00 offset after 3, and no more than 4 iterations of the 2 star alignment? The key is to know how far to move the adjusters...I use the PHD crosshairs, the first circle is about 5 arc minutes of movement in alt or azimuth. Makes it easy to get to a perfect alignment. Four iterations of the 2 star align equates to about 10 to 15 minutes setup. For what it's worth.
This works for me too. Without Polaris, your options are to do this, use software like Alignmaster, or drift align. This is MUCH faster than drift alignment, although probably not as accurate. Alignmaster requires a computer.
When adjusting altitude and azimuth with the adjustment screws, you should be able to use your main scope, a reticle eyepiece, and any star that's not too high above the horizon to get a pretty good idea of how far you're moving things.
-Dan
22 registered and 41 anonymous users are browsing this forum.
