Ira
Reged: 08/22/10
Loc: Mitzpe Ramon, Israel
Good, classic, reliable, EQ mount
      #5704208 - 02/27/13 08:29 PM
It seems like everyone wants the latest and greatest, cutting edge mount, many of which have teething problems or cost a fortune or weigh a ton or something else is an issue. Is there a good, reliable classical EQ mount for mainly visual use, time proven, spare parts abound, or is this just as rare as a unicorn?
/Ira
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Good, classic, reliable, EQ mount new [Re: Ira]
      #5704243 - 02/27/13 08:47 PM
G11 non GoTo.
Atlas / EQ6 non GoTo.
gonzosc1
Reged: 11/08/12
Loc: South Carolina
Re: Good, classic, reliable, EQ mount new [Re: orlyandico]
      #5704244 - 02/27/13 08:48 PM
I believe theres an Atlas non goto on ebay now!
mdowns
Reged: 06/12/10
Loc: Englewood,FL
      #5704267 - 02/27/13 09:00 PM
I second orlyandico comments.The non goto versions of the losmandy g8s and g11 are solid,reliable performers.Replacement parts are readily available.The g11 that carries my c11 is sweet!Several years earlier I had a g8,again sweet.Just power it up and track.
frozen.kryo
Reged: 01/28/11
Loc: East of the Sun, West of the M...
Re: Good, classic, reliable, EQ mount new [Re: mdowns]
      #5704344 - 02/27/13 09:46 PM
Good, classic, reliable?
The Vixen GP/GPDX springs to mind.
comets4tom
Reged: 02/08/05
Loc: Texas
Re: Good, classic, reliable, EQ mount new [Re: frozen.kryo]
      #5704356 - 02/27/13 09:56 PM
I agree with the mention of the GP/GPDX. Parts should be available since it is still currently sold.
Tom H.
JMW
Reged: 02/11/07
Loc: Nevada
Re: Good, classic, reliable, EQ mount new [Re: comets4tom]
      #5704593 - 02/28/13 12:40 AM
I think you can find an used Atlas for well under $900. They are a nice step up from the CG-5 and can be used for imaging also.
RogerRZ
Whatta you lookin' at?
Reged: 01/09/06
Loc: West Collette, NB, Canada
Re: Good, classic, reliable, EQ mount new [Re: JMW]
      #5704819 - 02/28/13 07:44 AM
How much of a pain would an older G11 be for imaging at or less than 1200mm fl? I have an EQ6 pro that kind of works, but has a PE curve about a mile wide (20 seconds max unguided with a 200mm lens).
t.r.
Reged: 02/14/08
Loc: Upstate NY
Re: Good, classic, reliable, EQ mount new [Re: RogerRZ]
      #5704825 - 02/28/13 07:51 AM
Yep, Vixen Super Polaris/Great Polaris/Deluxe are the workhorse mounts!
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Good, classic, reliable, EQ mount new [Re: t.r.]
      #5705029 - 02/28/13 10:08 AM
Roger,
I'm pretty sure an old G11 can manage much better than 20 seconds unguided with a 200mm lens!!
But a much cheaper option, although not as appealing, is to simply buy an Aeroquest worm for the Atlas/EQ6. It's only a little over a hundred bucks. You will get a worm that is at least 15" p-p and probably better. That's about what you'd get with an old G11. My Aeroquest worm (on my CGEM) is about 16" p-p.
However.. if your PE is that big (sounds like hundreds of arc-seconds), it might not be in the worm, but could be some non-concentric bearings or something. Ed Thomas would be in a better position to know if this is possible or not.
RogerRZ
Reged: 01/09/06
      #5705064 - 02/28/13 10:34 AM
I bought it brand new, and it's been like this from day one. I suppose I could have returned it, but I didn't really care for the hassle. As big as the PE is, it seems to be quite smooth, as it autoguides out quite well, up to 1000-ish mm...
Tom and Beth
Reged: 01/08/07
Loc: Tucson, AZ
      #5705746 - 02/28/13 04:58 PM
/Ira
How about Cave with the 1.5 inch shafts? Further up the chain would be G11, and don't forget about the Push To Astro Physics. I put hundreds of hours annually on my circa 1994 AP1200DA. Can still get service with a phone call, replacement parts in a week or so.
For grab-n-go, the Vixen SP and GP
Geo.
Reged: 10/01/08
Loc: Upstate NY
Re: Good, classic, reliable, EQ mount new [Re: Tom and Beth]
      #5705998 - 02/28/13 07:01 PM
Yes, many parts for the Vixen GP can be obtained from one of the U.S. Vixen distributors. When Orion was a dealer they kept a lot of spares. I got a large flat rate box of 'em off eBazy. Need any motor covers One thing I'm hanging onto are those spreader hinge pins!
coopman
Reged: 04/23/06
Loc: South Louisiana
Re: Good, classic, reliable, EQ mount new [Re: Geo.]
      #5706759 - 03/01/13 08:47 AM
I would not buy a used Orion mount due to the fact that if you ever need parts, they will not sell them to you.
Reged: 07/06/07
Re: Good, classic, reliable, EQ mount new [Re: coopman]
      #5706892 - 03/01/13 10:01 AM
Well, that's true to some extent. Orion doesn't make a single mount...and parts for the mounts they sell are generally available from other sources.
NealC
newbie
Reged: 12/27/11
Re: Good, classic, reliable, EQ mount new [Re: rmollise]
      #5722678 - 03/09/13 05:15 PM
Please do tell identities of these sources.
Reged: 07/06/07
Re: Good, classic, reliable, EQ mount new [Re: NealC]
      #5722786 - 03/09/13 06:33 PM
SkyWatcher is one.
Hikari
Reged: 01/05/11
Loc: Maine, USA
      #5723279 - 03/10/13 12:55 AM
Takahashi EM2S. Only a RA motor and manual dec. Built like a tank.
rzep8
Reged: 09/11/10
Loc: Flemington, NJ
      #5724762 - 03/10/13 09:10 PM
I don't know about spare parts (as the thing has never broken), but my Byers 812 is probably the best "push-to" mount around. Solid, transportable (but it ain't light) and reliable. Uses 120VAC synchronus motors so you'll need a frequency chopper drive corrector (an old Accutrak still show up on A-mart now and then). A good one costs about $2K or so.
orion61
Reged: 10/20/07
Loc: Birthplace James T Kirk
      #5725569 - 03/11/13 10:51 AM
+1 on the SP/GP
hottr6
Reged: 06/28/09
      #5725624 - 03/11/13 11:25 AM
OP never stated payload.... I guess everyone here are better mindreaders than I.
As an owner, I have had experience with the following for visual work:
- Byers or Schaeffer for heavy payloads > 40lbs
- Losmandy G8/G11 for middle-weight payloads 14-35 lbs
- Vixen Polaris for light stuff < 12 lbs.
Shane in gray-zone NM
15 registered and 33 anonymous users are browsing this forum.
