Pages: 1 | 2 | 3 | (show all)
geminijk
Reged: 04/03/08
Loc: TN
CG5 seems to drift, not steady tracking at all
      #5760971 - 03/27/13 06:13 PM
I have an older CG5 mount head that seems to be having tracking issues. I have noticed that when video streaming, I get some drift in the views, even on a lowly setting of 8 secs with my SCB2k. That should not be my polar alignment, as I understand it, and hope someone can correct that idea if untrue.
Now I also see this drift in my SkySafari app. I'll align to say the Sun, align the app it, and over time, SkySafari will show the scope point well away from the Sun, even though it is still in my camera view?
I would really like to get another CG5 that are on sale right now, because I can use the tripod on this older mount head, and put the new mount head on my pier. I want to do limited AP, mostly video. My expectations for this mount were up to 2 min exposures, and hopefully w/o guiding. This issue however with this CG5, and not able to even to a few seconds without seeing drift, is really pushing me away.
Any ideas on what the issue is??
John
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: CG5 seems to drift, not steady tracking at all new [Re: geminijk]
      #5761007 - 03/27/13 06:29 PM
John,
95% of the time it will be your polar alignment. Video cameras with their smaller fov and corresponding "high power" do make tracking inaccuracies quite visible.
If you can verify that your polar alignment isn't causing the problem then look at things like tight clutches. Changing the balance of the scope can sometimes highlight a clutch issue.
Any idea which direction the drift is in? This will tell you what specific areas of the mount to start looking at.
geminijk
Reged: 04/03/08
Loc: TN
Re: CG5 seems to drift, not steady tracking at all new [Re: mclewis1]
      #5761039 - 03/27/13 06:53 PM
I'll try to determine the drift direction tonight Mark, its actually clear, and with a full moon, a good time to mess with this stuff.
thanks for the suggestions.
John
Reged: 07/06/07
      #5761933 - 03/28/13 08:54 AM
Why do you think it's not polar alignment? How did you polar align?
hottr6
Reged: 06/28/09
      #5762205 - 03/28/13 11:11 AM
RU using fresh batteries?
My CG5-clone tracking "slows down" when the batteries get weak. The mount will track in RA for a few more hours then quit all together, and also will not slew. However, the DEC axis will still slew!
geminijk
Reged: 04/03/08
Loc: TN
Re: CG5 seems to drift, not steady tracking at all new [Re: hottr6]
      #5762607 - 03/28/13 03:33 PM
Clouds rolled in last night, so I couldn't do much to determine direction of drift.
Unc...I used the ASPA. It selected Jupiter, then I adjusted the mount physically.
Hottr6...I have it on a pier and with AC power all the time.
I'll have to wait for my next round of clear skies to determine the direction of drift. From what I recall, it seemed to be in a single direct.
John
mclewis1
Thread Killer
Reged: 02/25/06
      #5762872 - 03/28/13 06:18 PM
John,
ASPA selected Jupiter ... really?
I would use a suitable named star ... suitable would be close to celestial equator and high in the sky but not right on the meridian.
RTLR 12
Reged: 12/04/08
      #5762905 - 03/28/13 06:32 PM
Jupiter was selected because that was the last goto that was selected in the HC. Best to use a star close to the meridian and the celestial horizon.
Stan
Reged: 07/06/07
      #5762910 - 03/28/13 06:33 PM
John
I would not advise selecting Jupiter for a polar alignment...
geminijk
Reged: 04/03/08
Loc: TN
Re: CG5 seems to drift, not steady tracking at all new [Re: rmollise]
      #5765654 - 03/29/13 08:11 PM
I'll try the actual stars than next time its clear Unc.
John
cn register 5
Reged: 12/26/12
      #5766170 - 03/30/13 05:18 AM
Whilst we use drift in dec to set the polar alignment it doesn't follow that the drift is only in dec. It can be in Ra as well. It depends on the direction the scope is pointing relative to the polar align error.
Chris
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
      #5766307 - 03/30/13 08:53 AM
Hi John,
Are you planning on using your 8" SCT as the imaging scope? If so, I think your expectations may be a little too high. I've had several (3) CG-5's and found through experimentation that the best I could do consistently unguided were 1 minute exposures at a focal length around 300mm. Since you're operating at 2000mm (or ~1260 with an f/6.3 focal reducer), you're going to start to see periodic error problems with even short exposures.
With guiding, the numbers can be much better, although I found that even with a C6 operating at 960mm f/l I had to throw out quite a few subs (approx 30%). The problem you face with guiding with an 8" SCT is that you'll need a second scope which adds to the weight placed on the CG-5. If you operate with a focal reducer (highly recommended) you can probably get away with a 9x50 finderscope guide scope setup. Otherwise, at 2000mm f/l you will want a guide scope with a little longer focal length.
I agree with the others that you need to make sure you have a good polar alignment, but I don't think that's your main problem...yet. I say 'yet', because once you get your periodic error sorted out, that will be the next issue to tackle.
Patrick
dickbill
Reged: 09/30/08
Re: CG5 seems to drift, not steady tracking at all new [Re: Patrick]
      #5766778 - 03/30/13 12:20 PM
yes, 2 min is too much to ask, expect more like 1 min unguided at around 1000 mm focal lenght, IF and only IF you are well polar aligned, your mount is well balanced AND you have a good power supply.
Even with that, GOTO mounts can be misleading somehow: a cg5 that has been correctly put in station, but barely polar aligned, will have good, sometimes even very good GOTOs, which might let you believe that your polar alignement is good too. That is why people in this forum endelessly repeat that polar alignement and GOTOs accuracy are separate things.
Nobody has ever quantified the thing, that is, how far off the north polar pole can you be and still get good GOTOs?
My guess is you can probably be 1 degre off the north celestial pole and still have good GOTOs, but your tracking, while OK visually, will be horrible on a ccd.
The sure thing is that without good GOTOs, you can't expect to have an accurate POLAR ALIGN routine.
So i will say like others: check your battery, balance well in RA and Dec, then do a 2 or 3 STAR ALIGN, stay away from the Meridian and then test you goto accuracy with stars or objects away from the meridian. Only then attempt a POLAR ALIGN routine.
NOTE here: the polar align routine of the cg5 originally used Polaris and was different of the cgem-related ASPA routine. But now you can have both for the cg5.
Which one is best, or lets say 'safer' (as opposed to 'easyer') for a cg5? I don't know.
I would say anyway that if your polar alignment routine shows a big error in alignment, you are probably safer to iterate the entire process once more.
Reged: 07/06/07
Re: CG5 seems to drift, not steady tracking at all new [Re: dickbill]
      #5766859 - 03/30/13 01:13 PM
Quantify? OK. One night at the club dark site one of our members, Joe Novice we'll call him here, came over to ask for Unk's help. He'd got his new C8/CG5 setup OK, but he was having a problem: "Unk, the go-tos are great, but everything drifts out of my eyepiece." Turned out he'd "polar aligned" on Kochab...
Edited by rmollise (03/30/13 01:14 PM)
mclewis1
Thread Killer
Reged: 02/25/06
      #5767158 - 03/30/13 04:52 PM
A minor point that is really semantics ... ASPA isn't related, oriented or in anyway specific to the CGEM. It was released in firmware gem4.15 which was common across the CG-5, CGE, and the then new CGEM (the CGEPro hadn't been released at that time). There's nothing about ASPA on the CGEM that's any better or worse than on the CG-5 (other than the mechanicals of the mounts being less or more accurate).
cn register 5
Reged: 12/26/12
      #5767177 - 03/30/13 05:05 PM
An alt az mounted scope can be up to 90 degrees off being polar aligned and still do gotos accurately. The conversion, after a two star alignment, is the same. The difference is that the AltAz mount tracks in both axes while the polar aligned scope tracks in hour angle only.
Chris
Reged: 07/06/07
Re: CG5 seems to drift, not steady tracking at all new [Re: cn register 5]
      #5767221 - 03/30/13 05:32 PM
That's true, but _it depends on the software_ quite a few GEMs' go-to accuracy ain't worth pea-turkey without a good polar alignment...
SkipW
Reged: 02/03/11
Loc: Oklahoma, USA
      #5767842 - 03/30/13 11:12 PM
This is true, but with small alignment errors (a degree or two) the drift in RA is so small it's typically swamped by other errors, so we don't notice it.
Drift in Dec is order sin(alignment error).
Drift in RA is order 1-cos(alignment error)
sin(1 degree) is about 0.01745 (1.7%). cos(1 degree) is about 0.9998, so 1-cos(1 degree) is about 0.0002 (0.02%), about 100 times less.
If the alignment error is 90 degrees, the drift in RA (sin(90) = 1) could be as large as the drift in dec (cos(90) = 0, so 1-cos(90) = 1)!
If we're pointing to the wrong pole (error is 180 degrees), all the drift is in RA.
Edited by SkipW (03/30/13 11:14 PM)
geminijk
Reged: 04/03/08
Loc: TN
Re: CG5 seems to drift, not steady tracking at all new [Re: SkipW]
      #5767965 - 03/31/13 12:43 AM
Still clouds, so further clarification to which direction is taking longer. But I'll keep you all in the loop.
John
geminijk
Reged: 04/03/08
Loc: TN
      #5771353 - 04/01/13 05:52 PM
Ok, from what SkySafari shows today when broadcasting on NSN, the drift is in BOTH RA and Dec. That REALLY surprises me. When a GEM, the only motor used during normal tracking is RA isn't it? now if SkySafari shows drift in both, that may mean my DEC is off as far as polar goes perhaps?
I'm thus open to suggestions? Oh, and tonight I plan on doing an ASPA on something OTHER then Jupiter, so I'll test again tonight and post up the results.
John
PS. I pulled the trigger on another CG5 since they are on sale. I needed a mount for outreach that I can setup 2 scopes on, so I'll use the new tripod on this older mount head I have, and put the new head on my pier for my AP and broadcasting.
17 registered and 53 anonymous users are browsing this forum.
