cameron12x
Reged: 11/10/10
Powering the CG-5 ASGT in the field?
      #6052951 - 08/29/13 04:47 PM
What are the best options?
* cigarette lighter hookup to car battery
* dedicated 12V battery
* other
Does the CG-5 come with the first option as included equipment?
Reged: 07/06/07
Re: Powering the CG-5 ASGT in the field? new [Re: cameron12x]
      #6053097 - 08/29/13 06:19 PM
Don't use your car battery unless you like being stranded at a dark site. The mount is surprisingly power hungry and can potentially run a battery down over the course of a long run with a lot of go-tos.
The solution is a jump-start battery pack you can get from Walmart or automotive discounters.
Stelios
Reged: 10/04/03
Loc: West Hills, CA
      #6053158 - 08/29/13 06:53 PM
I've been using the same old Celestron Power Tank (the small one) since 2003.
It takes a lickin' and keeps on tickin'...
I'm sure you can find cheaper, but I like the looks of it and the big flashlight (but DON'T try that at a star party). When observing at friends' home and it's time to pack, that flashlight locates the occasional dropped filter or EP in a hurry.
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
Re: Powering the CG-5 ASGT in the field? new [Re: Stelios]
      #6053300 - 08/29/13 08:13 PM
I power my CG-5 with the Celestron 7ah power tank and I've never had it run down. My typical observing sessions at the dark site last about 4 to 5 hours.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Powering the CG-5 ASGT in the field? new [Re: Mike4242]
      #6053313 - 08/29/13 08:21 PM
interesting.. I was concerned the 7 and 17Ah power tanks were too small. bought a 24 Ah AGM battery from RS (similar to Mouser or Element14) and put it in a toolbox.
BRCoz
Reged: 10/21/05
Loc: Moreno Valley, CA
Re: Powering the CG-5 ASGT in the field? new [Re: orlyandico]
      #6053374 - 08/29/13 09:13 PM
I use two Power-Sonic PS-1270-PS-1270 12 Volt 7 Amp Hour Sealed Lead Acid Batteries. Get the lowest milliamp charger. I put them in a tool bag for about $10. I use it for the weekend without needing a recharged. I have used this setup for years.
frito
Reged: 10/05/12
Loc: Fremont, CA
Re: Powering the CG-5 ASGT in the field? new [Re: BRCoz]
      #6053438 - 08/29/13 10:04 PM
I power my CG-5, Netbook and Camera with this pack
http://www.harborfreight.com/12-volt-jump-start-and-power-supply-38391.html?c...
if you have a harbor freight tools in your area snag it while its on sale for 50 bucks.
mine will run my mount only all night long (6+ hours easily) or it will run my mount + camera + netbook for about 3 hours, if i'm smart i'll disconnect my netbook and run off its battery after 2 hours and when doing this i have managed 6 hours of imaging time on this battery pack! even then its still not dead, its just my camera's power adapter will drop below "acceptable" voltage for my camera and it shuts down. one time a month ago while doing an overnight imaging camp out i hit the sac at 3:30 am and my camera and netbook died around 4:00-4:15 AM or something but the mount was still on and tracking when i woke up at 7 AM
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Powering the CG-5 ASGT in the field? new [Re: frito]
      #6053460 - 08/29/13 10:28 PM
interesting regarding the netbook..
my problem is the TEC on my camera pulls 4 Amps...
DaveG
Reged: 12/28/03
Loc: Ohio
      #6053462 - 08/29/13 10:29 PM
I am using a Schumacher XP2260 for my Nexstar 8SE and dew heater. Had it out last weekend for over 4 hours and it was still about 95 percent charged when I got home. It has a 22 amp hour battery, which is pretty darn good for a portable power unit. Bought it at Walmart for $99.
      #6053578 - 08/29/13 11:50 PM
The battery is not someplace you want to skimp. You want a deep cycle marine battery. Among the best are the Optima Blue Tops. I'd go with 30AH minimum and 50AH to 70AH preferable. Such a battery with a single 15W amorphous solar panel gives you pretty close to indefinite, sustainable field power, including recharging phones, tablets, etc., and powering your mount and dew suppressors.
Ranger Tim
Reged: 03/25/08
Loc: SE Idaho, USA
Re: Powering the CG-5 ASGT in the field? new [Re: jrbarnett]
      #6053599 - 08/30/13 12:00 AM
How much weight are you willing to carry around? That will dictate which battery you should consider. Some folks use jump packs, some wheel chair batts, and I use a pair of 100+ amp hour boat anchors that live in my trailer. Whatever you do, keep 'em charged and the cells filled. A discharged battery is one step away from a dead battery. Use an automatic charger that is smart enough not to overheat the batt. and has a maintenance cycle.
frito
Reged: 10/05/12
Loc: Fremont, CA
Re: Powering the CG-5 ASGT in the field? new [Re: Ranger Tim]
      #6053690 - 08/30/13 01:18 AM
I agree if you have lots of gear for an imaging rig to power then some boat anchor deep cell's are the ticket no doubt.
the OP is asking specifcally about just powering a CG-5, a single car battery is overkill for powering it for even a long night of observing. the harbor freight pack i linked above will run it for more than enough time and can even be pushed to running some additional gear. I already have accquired a deep cell truck battery i will be using when the need arises but until then i'd rather not lug the thing around.
Americal
Reged: 09/14/07
Loc: La Verne, CA
      #6053737 - 08/30/13 02:12 AM
I'm using a CHEEP lawnmower battery for my CG-5, 5 years and still going. Last June it did 3 nights w/o recharging just fine, thank you. It's going in a couple of days for a 5 night marathon, we'll see. I've got a 2.5w solar panel to help this time (I've got a plan B )but I'll report back. But there's some qualifiers; 1.) I keep it well charged, 2.) I typically don't run more than 20 or so goto's nightly, 3.) it's housed in a Coleman cooler so it doesn't suffer from exposure. BTW the lid's off the box while running, we don't need no H2-O2 incidents, it is a CHEEP lead/acid battery.
T1R2
Reged: 06/11/13
Loc: NeverWhere, 35*N
Re: Powering the CG-5 ASGT in the field? new [Re: Americal]
      #6053743 - 08/30/13 02:24 AM
I wouldn't recommend a 17ahr power tank, on cold nights I run my astrozap at about halfway on the C11, It pull about 5A an hr, and it drains the battery in a little over 3.5hr, even faster if its up any higher, add a camera and extra heater for ep's, guidscope, and your down to nothing real quick, works fine for a 80mm obj. all night maybe. I've ran it down with a 5" dew strap in 3-4 hrs also, This may be enough for you if its only your mount, and you don't slew around a lot. I'd go with the 24Ahr.
Edit: I never knew they made up up 100Ahr, Go with one of those like Jim said, I know what Im getting next.
Edited by T1R2 (08/30/13 02:28 AM)
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Powering the CG-5 ASGT in the field? new [Re: T1R2]
      #6053776 - 08/30/13 03:41 AM
100 Ah weighs about 70 to 80 lb. That's more than most mounts.
Now I realize my 24 Ah is too weak. Because I also have dew heaters and my 4-amp sucking TEC cooler.
Stelios
Reged: 10/04/03
Loc: West Hills, CA
      #6054330 - 08/30/13 12:22 PM
Too weak for what? Not for the original question. I've powered the CG-5 with a 7AH Power tank for 2-3 consecutive 4-5 hr. sessions without recharging.
If you are going to be adding dew-heaters, iPads, Macbooks and the Space Shuttle, then, of course, you need more power.
bierbelly
Reged: 01/23/04
Loc: Sterling, VA
      #6054361 - 08/30/13 12:39 PM
Get a Honda generator...or better yet see if you can find one with a diesel engine!
...or you could get two batteries/power sources, one for the mount and one for everything else.
cn register 5
Reged: 12/26/12
Re: Powering the CG-5 ASGT in the field? new [Re: bierbelly]
      #6054538 - 08/30/13 02:27 PM
It's quite funny how every post asking about power ends up as some sort of contest for who uses the largest array of batteries.
Chris
cameron12x
Reged: 11/10/10
      #6054623 - 08/30/13 03:18 PM
I believe that my initial imaging sessions will be anywhere from 2-4 hours. The wildcard for me, however, is how many "GOTOs" I do during a given session and how long it takes me to get a good polar alignment for AP. And I'm still very new at exploring the vast array of targets we have!
So true!
Nonetheless, I appreciate all of the candid responses based on actual experiences in the field.
Thanks everyone!
cn register 5
Reged: 12/26/12
      #6054739 - 08/30/13 04:39 PM
One of the most popular sizes of sealed lead Acid batteries is the 7Ah, it's practically a standard. These are used in all sorts of UPSs, burglar alarms and emergency lighting.
The result is that they are one of the most cost effective batteries out there in terms of pounds per amp hour. Chargers for them aren't difficult or expensive either and most are of the sort that can be connected indefinitely, once the battery is charged they switch to a float charge mode.
What I do suggest is fit some sort of polarised and fused plugs and sockets to everything. Avoid the cigar lighter connector, they are very unreliable. The cost of some decent connectors is tiny compared to the expense of connecting power the wrong way.
Chris
25 registered and 32 anonymous users are browsing this forum.
