Naviguessor
Reged: 08/06/08
Loc: MI
So what are my options for a TV85
      #6056187 - 08/31/13 02:24 PM
I have a TV 85 that has been in storage for a year or 2, unused as I have no mount. It is pathetic to have a fine piece of equipment unused, so it is time. I would prefer tracking for visual use, as I have a family that would like to look as well. It has been a while since I looked, so wondered if anything new has popped up. It does not appear there are mid range alt/az mounts- lightweight capacity to heavy capacity.
In the Alt/AZ - its pretty much a Nexstar 6/8 mount or Ioptron mini tower, I'm not sure how much a cube pro can truly handle.
EQ - I think there are more available, but tracking can add weight and more bucks. Plus possible awkward viewing.
Tom and Beth
Reged: 01/08/07
Loc: Tucson, AZ
Re: So what are my options for a TV85 new [Re: Naviguessor]
      #6056781 - 08/31/13 09:59 PM
If you are OK with Alt/AZ, why not consider a Camera tripod with a geared head? I use my TV-76 this way, with a Coronado 60MM Solarmax on the front. Makes a nice travel setup.
Off the top of my head, A Manfrotto 3046 legs and 410 head, you should be able to pick these up for around $200 to 250.
Lost in Space
Vendor - Galactic Rocks
Reged: 11/14/04
Loc: North Carolina
      #6056861 - 08/31/13 11:10 PM
I just ordered an iOptron MT Pro after much soul searching. I believe it will give me the flexibility to go with my TV 76, as well as several other OTAs that I have. From what I gather, it will handle an Explore Scientific 127 refractor, but only if you buy the optional pier extension so the scope does not collide with the tripod if viewing at or near zenith. Granted, that poses some challenges as far as being flexible enough to get your eye on the eyepiece from a low position, but then that's part of the fun!
Naviguessor
Reged: 08/06/08
Loc: MI
Re: So what are my options for a TV85 new [Re: Lost in Space]
      #6058941 - 09/02/13 10:02 AM
I do have a question regarding alt/az? How often do you have to move the scope to track an object? Say Jupiter @ 130x? Im sure it depends on the EP but a general idea is what Im looking for.
I was looking at a Teegul and read an article on a guy who made a small wedge that converted it to a mini eq and allowed one knob tracking.
Nippon
Reged: 10/22/09
Loc: Central Florida
      #6059471 - 09/02/13 03:04 PM
I have a NexStar 8 SE and had a TV 85 and the TV 85 is too long for the NexStar SE mount. Unless you are okay with not being able to come to zenith. And I mean seriously not coming to zenith. I had a TV TelePod Alt Az mount and it was nice enough. But knowing what I know at this point I would put a TV 85 on a Vixen Porta II ( Star Guy version with HAL 130 tripod preferred) for manual or on a iOptron Mini Tower pro if you want goto.
coopman
Reged: 04/23/06
Loc: South Louisiana
Re: So what are my options for a TV85 new [Re: Nippon]
      #6059781 - 09/02/13 06:23 PM
You would have to nudge the scope every 15 seconds or so.
Quintessence
Vendor
Reged: 06/03/07
Loc: Austin, Texas
Re: So what are my options for a TV85 new [Re: coopman]
      #6059865 - 09/02/13 07:24 PM
While there is no precise answer to how often one would have to "nudge" at 130x, I think every 15 seconds is a bit pessimistic. Let's do some math. At the celestial equator, one would see a drift rate through the eyepiece of .25 degree per minute. Away from the celestial equator, the effective drift rate across the FOV will be somewhat less because the drift will follow an arc instead of a straight line. But let's assume the worst case of .25 degree per minute.
Let's also assume that one is using an eyepiece with an apparent field of view of 72 degrees -- which is not exceptionally wide by today's standards. So, the true FOV is about .55 degree. Let's also assume that for best definition one chooses to keep the object within the middle half of the field. For a moderately long focal ratio scope like a TV85, good eyepiece designs will certainly yield good definition over the middle half of the field. So -- let's say the "usable field" is restricted to .27 degree.
Doing some arithmetic, one sees that the "worst-case" need for a nudge would be about every 65 seconds -- which might also be about the smallest consistently controllable nudge that one could casually perform (without very deliberate concentration) given the relative short lever-arm provided by a TV-85.
Charles
Naviguessor
Reged: 08/06/08
Loc: MI
      #6060100 - 09/02/13 10:01 PM
Thank you for the info on the nexstar. With my craptacular horizons, zenith is where I most likely will be at. Looks like the minitower for goto and tracking or a eq mount. I will have to mull the nudge and look.
Edited by Naviguessor (09/02/13 10:04 PM)
astrophile
Reged: 06/30/13
Loc: Chaise-lounge, 18x50s in hand
      #6060508 - 09/03/13 05:45 AM
For the intended use you describe, I recommend seeking out a simple eq or an alt-az mount with manual slo-mo tracking controls. Saves all the precision polar and star-alignment hassle; and I have personally found that once they quickly get the hang of it, using manual controls to track something engages a non-astronomer with the sky and with the object far more than just stepping up and "looking not touching."
The Porta II suggested above might work well. I'd look hard at the upcoming Mini Hitch II for a higher-end alternative.
Whatever you do, get that TV85 back under the stars!
wormstar
Reged: 11/23/09
Loc: Central Ct
Re: So what are my options for a TV85 new [Re: astrophile]
      #6060685 - 09/03/13 09:28 AM
Have you seen the Nova Hitch? There is a smaller version coming out with many of the same features(Mini Hitch II), also a simpler model too. Do a web search for Half Hitch Telescope mount
Starhawk
Space Ranger
Reged: 09/16/08
Loc: Tucson, Arizona
Re: So what are my options for a TV85 new [Re: wormstar]
      #6060760 - 09/03/13 10:02 AM
Put the NexStar SE mount in equatorial mode and you will find it works well, especially for the zenith. The tripod has a tilting plate to allow for this.
-Rich
Nippon
Reged: 10/22/09
Re: So what are my options for a TV85 new [Re: Starhawk]
      #6060834 - 09/03/13 10:55 AM
The NexStar 6/8 SE mount does not have a built in ability to set it up in EQ mode. ie, no tilting plate. Some of the smaller NexStar scopes do.
Naviguessor
Reged: 08/06/08
Loc: MI
      #6060835 - 09/03/13 10:55 AM
I have and the price is a little steep
Naviguessor
Reged: 08/06/08
Loc: MI
      #6060865 - 09/03/13 11:12 AM
I believe there is/was an optional wedge(no longer produced?) No idea on how well it performs
Nippon
Reged: 10/22/09
      #6060885 - 09/03/13 11:23 AM
The beauty of the Porta II is it will perform well with your TV 85 and it is not expensive. No matter how serious you get with the hobby The Porta will fit in. Like my usage of my Porta with a PST. I would suggest that you go a low cost route like the Porta, get out under the stars and enjoy your TV 85. Who knows where using the 85 will lead you. So save the serious outlay of cash for when you really know where you want to go with this hobby.
Starhawk
Space Ranger
Reged: 09/16/08
      #6060997 - 09/03/13 12:44 PM
Huh- the last one I looked at did. I know they have a mini-wedge for it.
-Rich
Naviguessor
Reged: 08/06/08
Loc: MI
      #6061073 - 09/03/13 01:42 PM
-Rich
There are some out there, it is now a discontinued product.
Stelios
Reged: 10/04/03
Loc: West Hills, CA
      #6061107 - 09/03/13 02:01 PM
What he said!
I might add that if you want a bit of extra stability for your Porta II, get the eyepiece tray from Agena Astro. It adds a *lot* of extra rigidity to the mount, not to mention room for a ton of eyepieces, at the expense of needing more time to collapse the mount for storage (as it now attaches with four metal screws rather than a single plastic one). In most grab-n-go situations this will not be a serious problem.
Rick M.
Reged: 03/16/13
Re: So what are my options for a TV85 new [Re: Stelios]
      #6061644 - 09/03/13 08:54 PM
Why not a TV Panoramic or Gibraltar alt/az with handle.
wormstar
Reged: 11/23/09
Loc: Central Ct
Re: So what are my options for a TV85 new [Re: Rick M.]
      #6062456 - 09/04/13 10:50 AM
There is a Quarter Hitch for sale in the CN classifieds reasonably priced, Charles at Half Hitch makes a real nice mount.
12 registered and 35 anonymous users are browsing this forum.
