Moromete
Reged: 02/15/12
Loc: Romania
AstroTortilla vs UniMap for plate solving
      #6145193 - 10/18/13 04:31 PM
Which one of these softwares is better for fast and accurate GOTOs with plate solving done with a 50mm finder guider and QHY5L-II guide cam?
I see both softwares as a free alternative to Celestron StarSense and probably with a better performance too.
I have played with both only inhouse and I like more Unimap.
Here is Unimap http://larryo.org/astronomy/software/unimap/index.html .
Unimap works without an Internet connection.
I haven't understood yet how to use AtroTortilla.
Here it is http://sourceforge.net/p/astrotortilla/home/Home/
telfish
Reged: 11/17/10
Loc: Adirondack Mountains NY
Re: AstroTortilla vs UniMap for plate solving new [Re: Moromete]
      #6145238 - 10/18/13 04:54 PM
I use AT with my T3I, C11 and hyperstar. I love it. Once you have it set up it will solve in 20 scs and realign your scope to exactly center your target.
Not sure how it would work with the hardware you have listed.
Terry
Moromete
Reged: 02/15/12
Loc: Romania
Re: AstroTortilla vs UniMap for plate solving new [Re: telfish]
      #6145968 - 10/19/13 01:18 AM
I found a very nice tutorial for using AstroTortilla herehttp://lightvortexastronomy.blogspot.ro/2013/08/tutorial-imaging-setting-... .
Moromete
Reged: 02/15/12
Loc: Romania
      #6145970 - 10/19/13 01:21 AM
Sorry, that's the correct link http://lightvortexastronomy.blogspot.ro/2013/08/tutorial-imaging-setting-up-a...
Does AtroTortilla work with Sharpcap or Firecapture?
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6146087 - 10/19/13 05:26 AM
astrotortilla will work with any software that outputs FITS, JPEG, and can even capture from the screen. internally it uses the astrometry.net blind solver, which has been proven rigorously in research to be a very robust solver.
it is not as fast as PinPoint or Elbrus but is completely blind - you don't need to provide the camera orientation, pixel scale, or even hints as to the approximate RA/DEC where it's solving.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: AstroTortilla vs UniMap for plate solving new [Re: orlyandico]
      #6146366 - 10/19/13 10:32 AM
It's not too bad, I use server to back up my SGP. If it has a hint, it's pretty fast.
Gib007
journeyman
Reged: 09/19/13
Loc: Gibraltar
Re: AstroTortilla vs UniMap for plate solving new [Re: Raginar]
      #6146428 - 10/19/13 11:04 AM
Thanks for linking to my tutorial Moromete. I'm glad you find it useful!
AstroTortilla is fantastic software and I would gladly have paid for it.
Moromete
Reged: 02/15/12
Loc: Romania
      #6146437 - 10/19/13 11:08 AM
With a 50mm F4 finder guider + QHY5L-II how accurate is Astrotortilla/Ebrus/Unimap for GOTOs when the main scope is a C11(F6)+DSLR?
I haven't played with Elbrus but Unimap looks much nicer than Astrtortilla.
Without hints both Astrotortilla and Unimap fail to solve or need very much time to solve an image, as I experimented inhouse.
Moromete
Reged: 02/15/12
Loc: Romania
Re: AstroTortilla vs UniMap for plate solving new [Re: Gib007]
      #6146445 - 10/19/13 11:10 AM
Thanks for your Astrotortilla tutorial, it's very well done!
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #6146631 - 10/19/13 12:37 PM
Why would you not just use plate solves with your C11? There shouldn't be any issues doing that. I get my images within 50 pixels of my target easily and it's usually around 8 pixels.
The main problem you have is that by doing the aiming with a different scope that isn't perfectly aligned.... Well you can figure it out. Just try the software. Or, try SGP. It has the option for a localized astrometry server too.
Tonk
Reged: 08/19/04
Loc: Leeds, UK, 54N
      #6146728 - 10/19/13 01:42 PM
Thanks for highlighting that fact. My observatory is remote and has no internet access so this sounds ideal.
Vostok
Reged: 03/23/08
Loc: Finland
Re: AstroTortilla vs UniMap for plate solving new [Re: Tonk]
      #6146814 - 10/19/13 02:40 PM
AstroTortilla runs without an internet connection too.
telfish
Reged: 11/17/10
      #6148035 - 10/20/13 08:56 AM
The only reason I can think of is for visual use. If you wish to use it as a means to get really accurate goto's then use the main scope.
It's an interesting idea.
Phillip Easton
Reged: 12/24/10
Loc: DFW
      #6148248 - 10/20/13 11:27 AM
Unimap doesn't appear to be in development anymore. That download file is pretty old. I had trouble getting it to solve sometimes.
In my experience AT is much better plus if has mount integration. With AT connected to the mount (AT gets hints for RA and DEC) and the right parameters I can get a plate solve in under 10s. Then it will re-sync the scope.
My next attempt will be to use the databases it installs with SGP.
Cheers!
Coastal
Reged: 04/23/09
Loc: Vancouver island, Canada
      #6148384 - 10/20/13 12:57 PM
AT not as fast as Pinpoint? On my system it totally smokes Pinpoint and Elbrus. If you are doing every solve as a blind search with no pixel scale or centre coordinates then indeed it is slower. With the right command line arguments to the astrometry.net engine you'll be impressed with the speed. A SSD is a recommended location for the index files. Better yet, if you have a lot of ram, having them in a ram disk is fantastic! I never have to wait for solves now.
Wmacky
Reged: 11/24/07
Loc: Florida
Re: AstroTortilla vs UniMap for plate solving new [Re: Coastal]
      #6148515 - 10/20/13 02:30 PM
That tutorial came at just the right time as this weekend was for getting AT setup. Is sync to scope only for EQMOD? I'm using a CGE mount with Stellarium.
Coastal
Reged: 04/23/09
Re: AstroTortilla vs UniMap for plate solving new [Re: Wmacky]
      #6148527 - 10/20/13 02:40 PM
Sync to scope should work with any ASCOM driver that supports sync (I seem to recall a few drivers not supporting sync, possibly early Ioptron ones).
Sean
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6149060 - 10/20/13 08:39 PM
Sean, if you can pass on your settings this would be much appreciated.
On my system solves take about 20-30 seconds. It is getting RA/DEC hints, and constrained to a 30-degree area around the reported RA/DEC. I have also pruned down the indexes.
Coastal
Reged: 04/23/09
      #6149084 - 10/20/13 09:02 PM
What is your imaging scale, and do you have that properly set in AT? Have you tried reducing the search radius as well? The site listed in this thread has a lot of details that can really help. I tend to omit the -sigma 1 as my ccd image is pretty clean. Anyway if you save a fits file and for example place it in your cygwin home directory you can play around with the arguments (use --overwrite) to see what works best with your setup. I might be seeing a slight boost because I compiled a 64 bit recent snapshot of astrometry.net versus the much older one that is included in the AT package.
Sean
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6149220 - 10/21/13 01:42 AM
Yup as I mentioned I limit the search radius to 30 degrees. I have set a lower and upper bound for the image scale that matches my sensor (my sensor is about 2x1.5 degrees and I limit to 1-2 degrees).
It's possible that a large fraction of my solve time is due to file I/O. My fits are 35mb. But that camera is gone. Guess I'll try Binning with my new camera... The old one was an OSC and didn't bin well.
anat
Reged: 06/03/04
      #6149243 - 10/21/13 02:25 AM
I use the Astrometry.net engine in Linux for solving images with plate sizes of about 1 deg or slightly less. It takes less than 5 sec on PC. And it takes about 15 sec or less on Arm Linux devices.
I always use downsample = 2 or 3. And I put the minimal number of index files having the largest sky diameter down to the sky diameter of about a half of the camera coverage (30 arcsec). If you put all index files in the index folder, the computation will be slow even though scale-low is specified. The engine still tries to use some of index files with small sky diameters.
Edited by anat (10/21/13 02:28 AM)
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: AstroTortilla vs UniMap for plate solving new [Re: anat]
      #6149263 - 10/21/13 04:11 AM
hi Anat,
yup i have also pruned my indexes. What i noticed was even with downsampling the solve time was still high. i think downsampling itself consumes CPU so it would be better to bin.
anat
Reged: 06/03/04
      #6149275 - 10/21/13 04:29 AM
If you convert your original image file to a compressed format (JPG) first, it may help. Plate-solving doesn't need a big raw file
Edited by anat (10/21/13 04:41 AM)
Phillip Easton
Reged: 12/24/10
Loc: DFW
      #6149423 - 10/21/13 08:42 AM
hi Anat,
Have you tried adjusting sigma? I set mine to around 7 and get around 20-40 stars to search. Much quicker than if you are searching on several hundred.
Cheers!
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: AstroTortilla vs UniMap for plate solving new [Re: Phillip Easton]
      #6149509 - 10/21/13 09:38 AM
i just checked and i was at sigma 30!
scale minimum 0, maximum 200 (arc-minutes). well i'll try again with tighter limits.
Phillip Easton
Reged: 12/24/10
Loc: DFW
      #6149579 - 10/21/13 10:22 AM
That should help. Just a FYI I am imaging at 0.887 arcsec-pix. I set my limits too 0.75 - 1.0 arcsecperpix. Field is set to 45 and sigma 6 or 7. My exposure is 10sec. It solves in about 10 sec.
Cheers!
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6149630 - 10/21/13 10:52 AM
i've been using arcminwidth - but you can also use arcsecperpix?
Coastal
Reged: 04/23/09
      #6149655 - 10/21/13 11:05 AM
If I understand correctly, you're using arcminwidth with a range of 0-200. Certainly doesn't sound ideal. Use Pinpoint to calculate your actual image scale and try 0.1 lower and 0.1 higher (ie I use 1.6 and 1.8 for my 1.8"/px scale) using arcsecperpix.
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6149665 - 10/21/13 11:17 AM
Well Astrometry itself tells me my correct pixel scale. which (was) 2.68"/pixel as opposed to... 2.68"/pixel according to the Starizona calculator (http://starizona.com/acb/ccd/calc_pixel.aspx)
I don't have PinPoint, and I have no interest in Elbrus (you need to set the camera angle correctly every time?!?!?!?!?!) but I will try being very exact.
BTW nice idea with the USB power box.. I went with a similar method (R78B05 DC-DC converter to provide 5V for my USB hub form a battery). Thankfully I don't need 7.5V, but the camera cooler sucks power like there's no tomorrow...
Moromete
Reged: 02/15/12
Loc: Romania
      #6149677 - 10/21/13 11:26 AM
Why don't you try Unimap if you are using hints already?
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6149745 - 10/21/13 12:03 PM
astrometry works for me (if a bit slow), I like their development model (and the fact there's a lot of published research that uses their engine), etc. etc.
the reality is I only do 1-2 slews per session, so that's 1-2 solves per session. 20-second solves barely annoy me. I would like things to go faster, but the current scheme isn't killing me.
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
      #6159901 - 10/26/13 10:19 PM
I have an MI250 controlled by SiTech. Since it's an ASCOM driven program, I'll assume that it'll work with this setup. Is there anything that in the SiTech system that may cause a problem with the mount interfacing with AT?
David
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: AstroTortilla vs UniMap for plate solving new [Re: David Pavlich]
      #6160064 - 10/27/13 12:54 AM
Dave, not that I know of. AT only knows how to talk to ASCOM (and nothing else) on the mount side, so anything with a working ASCOM driver that supports resyncs will work.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #6160340 - 10/27/13 08:43 AM
Dave, it works good
Transmographied
Reged: 05/18/05
      #6160524 - 10/27/13 11:00 AM
Dave, it works good
That's all I needed to read! Thanks, Chris.
David
Transmographied
Reged: 05/18/05
      #6160528 - 10/27/13 11:01 AM
Well, I'll have to download it and give it a try. Thanks for the quick reply!
David
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #6162164 - 10/28/13 10:12 AM
One thing to consider, what are you imaging with? You might try out Sequence Generator Pro. It can use the localized astrometry.net server you install with AT. Free plate solving included with acquisition automation kis really me. And, they're adding dome/roof support this version.
Gvs
Reged: 05/19/11
Loc: Texas
      #6176843 - 11/05/13 06:43 AM
It is possible to refactor Astrotortilla to point to http://nova.astrometry.net/ which is up an running.
live dot astronomy dot net has issues.
25 registered and 48 anonymous users are browsing this forum.
