Deven Matlick
Vendor - Criterion Machine Co. LLC
Reged: 12/31/05
Loc: Moatsville, WV
Re: AHHH! Broke my CGEM new [Re: andysea]
      #6327555 - 01/22/14 02:11 AM
Hmm there's an opportunity. Someone should come up with a magsafe type connector for a mount, just like my mac laptops.
Would be great but, there's a patent!
austin.grant
Reged: 10/18/10
Loc: Shreveport, LA
      #6327607 - 01/22/14 03:51 AM
In theory it's nice, but then you have a major headache of the power being easily disconnected. No big deal on a laptop, where you just plug it back in. When a polar aligned mount in the middle of a session is unplugged, somebody is likely to get killed.
I always tie the power cord around a leg and then run to the power connector. Never had a mount unplugged, despite my clumsiest efforts.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: AHHH! Broke my CGEM new [Re: austin.grant]
      #6327674 - 01/22/14 06:28 AM
The way I do it is ty-wrap a power strip to a tripod leg then run power cord into that, then camera, mount, etc run off power strip.. always stays with the mount
Kasey
nemo129
Reged: 01/03/10
Loc: WMass
Re: AHHH! Broke my CGEM new [Re: dragonslayer1]
      #6327765 - 01/22/14 08:08 AM
I do what Kasey aka dragonslayer1 does but I use these to attach the power brick to the upper portion of the a tripod leg. The tool box with the power strip installed is directly under the mount so the cord drops straight down and I take up slack with Velcro ties. I might stub my toe on the extension cord leading away, but that is not going to cause a power outage or other mayhem.
Wrecking gear is a hard way to learn a le$$on, but you never forget after that!
Best of luck to the OP in getting his mount fixed!
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
Re: AHHH! Broke my CGEM new [Re: nemo129]
      #6328247 - 01/22/14 12:20 PM
I would have to agree with using nothing stronger than Velcro to attached the power cord or brick to the mount and tripod. We have already seen the problem with using the screw-in power connector and the use of a power connector that can be easily pulled out is a bother. But it would be preferable to have the power connector come out over either tipping the mount over, falling on your face with your hands full of expensive eyepieces, or at best knocking the mount alignment way out. Solidly connecting the cable and power source to the mount and/or tripod runs the risk of an even worse accident. Using Velcro will help to keep the plug in place on the mount and the cables from the mount out of the way while minimizing the chance of substantial damage to you or your mount by allowing the cables to pull away from the mount if they are tripped on or otherwise pulled. As nice as the screw-in plug is, I am hesitant to use it myself or recommend it for just what we have seen here except when the cable can be connected to a battery that is located right below the mount or all cables are covered as one poster suggested so that either way there is no tripping hazard.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: AHHH! Broke my CGEM new [Re: EFT]
      #6328488 - 01/22/14 02:09 PM
I've been bedeviled by power plugs coming out, that I rewired my battery box to have screw-in plugs on both my mount and camera. Certainly there is the risk of what the OP experienced happening to me, but I keep the power cables as short as possible, and my battery pack is underneath the tripod to keep it out of the way of wayward feet.
WesC
Reged: 02/06/13
Loc: La Crescenta, CA
Re: AHHH! Broke my CGEM new [Re: orlyandico]
      #6329010 - 01/22/14 05:58 PM
I too keep my battery centered under the tripod, and I keep the cord wrapped to be a short as possible. I've never come close to getting caught up in it.
The power cable for the TEMPest fans is a different story, being at the back end of my OTA. I need to work something out for that.
18 registered and 26 anonymous users are browsing this forum.
