Rait
journeyman
Reged: 11/12/12
Triplet Apo
      #5518014 - 11/13/12 02:06 PM
Hello!
First of all, English is my second language and sorry for my bad writing advance.
I am new on this forum. Reading your post have been developed me. Thanks.
I am planning to buy refractor Triple APO 130 mm or 150 mm. As my experience is only with 85 mm I need some advice. 150 mm accumulate 30% more light than 130 mm but it is 100 % higher price. Here is my question, do anybody in this forum have experience with both sizes APO refractors. Would it be big difference for deep sky photography and for solar system viewing. Thanks advance.
Rait
Reged: 06/16/04
Re: Triplet Apo new [Re: Rait]
      #5518331 - 11/13/12 05:09 PM
Rait:
Hello and Welcome to Cloudy Nights
I have never owned a 130mm or 150mm apo, I am sure some who have will chime in...
And don't worry about your English, it is plenty good...
Best wishes
M13 Observer
Reged: 12/09/06
      #5518349 - 11/13/12 05:19 PM
For solar system viewing, larger is better if the optics are of reasonable quality. The 150mm will be better than the 130mm. The image will be brighter allowing higher magnification and the resolution will be higher.
For imaging, the focal ratio and focal length are somewhat more important. The lower the focal ratio, the more light is getting to the detector which reduces the length of exposures. The longer the focal length the larger the magnification. It all depends on what you are imaging so it is hard to determine which would be better.
Eddgie
Reged: 02/01/06
      #5518354 - 11/13/12 05:22 PM
I have not owned a 130mm, but a 127mm.
Also 80mm, 102mm, and 152mm APOs or ED scopes.
The step up from 80 for me to 102 did not seem to make much difference in performance, but this is becase both of these apertures to me seem to be a bit small for much observing unless skies are very dark.
The bump from 102 to 127 is a decent bump because you are not getting enough aperture to see into some catalog items off of the couple of hundred "Showcase" objects that are usually the limit for 4" apertures under many sky conditions.
152mm is though to me a threashold size, not just in APO, but in just about any scope. This is the size that starts to allow for much more deep sky observing in many typical suburban loccations. 8" would be better of course, but for me, a 6" refractor is about as small as I personally care to use becuase I found that it was the only size that could get me away from the showcase objects and into more deep space.
The question you want answered though is impossible for us to answer for you.
This question comes up time and time again, and you will get as many options saying that 5" is enough as you get saying "Dude, get the 6" if you can afford it!"
Only you can answer this question.
I don't even use my 6" APO much anymore because I just can't get enough light gathering from it to make me happy so I may be the wrong person to ask, but I could never be happy with a 5" refractor again in my life. It was just too small. The 6" is right at the bottom of my aperture limit for most observing.
chboss
Reged: 03/24/08
Loc: Tokyo Japan
Re: Triplet Apo new [Re: Jon Isaacs]
      #5518355 - 11/13/12 05:22 PM
Hello Rait
Welcome to Cloudy Nights.
Both a 130mm or 150mm triplet Apo would work great for AP and solar system viewing. There is of course a light gathering difference between the two but I would personally look more at restrictions in size and weight in case you want to use the telescope mobile.
The mounting needs increase exponentially with the scope size especially if you have AP in mind.
best regards
Chris
Paul G
Reged: 05/08/03
Loc: Freedonia
      #5518365 - 11/13/12 05:31 PM
I'm a lunar and planetary observer and have both 130 and 155 mm apo refractors. There is a significant difference in planetary detail between them. The only reason to choose a 130 over a 150-155 would be portability.
I don't image so I can't address that side of it.
snommisbor
Reged: 06/15/09
Loc: Cedar Park, TX
Re: Triplet Apo new [Re: Paul G]
      #5518407 - 11/13/12 05:53 PM
Depending on budget you have, also depends on scope to recommend. But the TEC 140 would be a great alternative.
Rait
journeyman
Reged: 11/12/12
Re: Triplet Apo new [Re: Eddgie]
      #5518410 - 11/13/12 05:53 PM
Eddgie,
You are correct. As we have learned from our life, we always want bigger and better. I am thinking that large than 150 mm prices will make so big jump and this will be never logical (never say never). And if I buy 130, when I can afford 150 I afraid that I will think as you pointed. I need to think more. Thanks.
Rait
journeyman
Reged: 11/12/12
Re: Triplet Apo new [Re: chboss]
      #5518426 - 11/13/12 06:03 PM
Chboss,
Thanks for replay. Your advert to weight have point. Mobility is important but I think that extra 5 kg is not big problem. Do you thing iOptron ieq45 will be good for 150 mm apo. By specifications this mount is ok for 20 kg and 150 mm apo is 13 kg. Thanks.
Ziggy943
Reged: 08/11/06
Loc: Utah
      #5518535 - 11/13/12 07:08 PM
Chboss,
I have a TEC 160 F/8 that I use on an AP900 mount. It is a very good combination. I dont recall if the iOptron ieq45 breaks into pieces like the AP900. Even with my bad back I have no problems setting it up.
SteveG
Reged: 09/27/06
Loc: Seattle, WA
Re: Triplet Apo new [Re: Ziggy943]
      #5518556 - 11/13/12 07:19 PM
Rait - which scopes are you looking at?
Rait
journeyman
Reged: 11/12/12
Re: Triplet Apo new [Re: SteveG]
      #5518597 - 11/13/12 07:55 PM
SteveG,
In 130 mm is on my attention TS Photoline 130mm and William Optics AP 132/925 but in 150 mm is in my price range only TS Optics AP 150 at the moment.
Rait
chboss
Reged: 03/24/08
Loc: Tokyo Japan
      #5519038 - 11/14/12 03:34 AM Attachment (35 downloads)
Chboss,
I use a 155mm telescope on the iEQ45 which works for visual observation but my feeling is that is the absolute maximum, this also because it is a long focus (f/9) telescope. I am using the mount on a permanent pier, which helps the stability. With the original tripod I do not think the iEQ45 is enough for a 6" class telescope.
A shorter focus 130-140mm telescope would be no problem.
Below an image of my setup with the smaller 4" Apo.
best regards
Chris
Emanuel
Reged: 08/30/09
      #5519094 - 11/14/12 06:03 AM
Hi Rait, hows going?
I have a WO 132mm FLT, wich i love. I got it at a very good price, second hand, and for deep AF its awesome, not sure about planetary, didnt made a real test with it, but i saw very nice photos on the net made with it on planets. I use it on a Celestron Cgem mount, so, i dont know nothing about the iEQ45.....
I assume that you from Europe, by speaking on the TS telescopes, but, i think that you should think better; i explain:
I was going to buy the TS 130mm triplet, and i only didnt buy it, because of the very good deal that i had with the WO; anyway, i think that is a very good option on this price range; but, if you are thinking of a 150mm Apo, i say, dont go for the TS 150 triplet, go for a better one; in Europe, at TS website, this scope costs 5190 euros, and for this price, for me, it would be better to go for a APM 130mm or even better, a TEC 140mm. They maybe be more expensive, but, im sure that the quality is worthy. And why not a doublet? Did you saw the new scope from APM? Its a 150mm, doublet, and it will be delivered from this December. Check it out on APM website: http://www.apm-telescopes.net/en/Telescopes-/Refracting-Telescopes-OTA/Apochr...
Cheers
Rait
journeyman
Reged: 11/12/12
      #5519110 - 11/14/12 06:45 AM
chboss,
Thanks, you made point. 150mm can be too much for ieq45. Tube plus accessories can be near maximum. And mount is same important as tube.
Rait
chboss
Reged: 03/24/08
Loc: Tokyo Japan
      #5519116 - 11/14/12 07:02 AM
In this price range you need to be sure that not only the optical quality but also the lens cell and the rest of the mechanics are first rate.
APM LZOS, TEC, AP or Takahashi are the long term proven scopes but come with a high price tag.
The scope from APM that Emanuel mentions is an interesting option, but brand new and manufactured in China. There is no long term experience with this scope yet. This ED Doublet was designed for visual observers. Here I would personally wait for first reports from users before buying. There should be an optical bench test from Germany in the coming months.
best regards
Chris
Emanuel
Reged: 08/30/09
      #5519128 - 11/14/12 07:23 AM
Yeah, Chris, you got a very strong point on that, something that i tend to forget. The APM doublet is a new scope, and yes, manufactured on China. With no reports yet, about the scope, the best thing is to go for a brand that as all kind of good states about them. Any of the brands that you mentioned is excellent, and if i had that kind of investment......it would be one of those.
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
      #5519147 - 11/14/12 08:00 AM
For deep sky photography, the aperture difference is not as important as the focal length. The focal length determines the size of the field of view and therefore the size of the object in that view, and then the imaging time can be varied to compensate for the aperture difference. Resolution between the two sizes is not that significant either. If it were my decision I'd have a hard time justifying paying 2x the price for 20mm aperture gain.
For solar system viewing, aperture is more important because you can increase magnification as the seeing conditions permit. Again, I don't think the resolution difference between a 130mm and 150mm aperture is that significant, however. For myself, I've found that larger instruments like 8-10" Newtonian's or SCT's will perform better on planets than smaller refractors (at far less cost). The added advantage of those larger instruments is that they perform better visually on deepsky objects as well. The down side is that they are not as easy to use for astrophotography.
So, the bottom line for me would be to determine what focal length instrument you want for astrophotography based on what objects you want to capture. If you're going after small faint galaxies you'll want an instrument with a large aperture and longer focal length. If you want to image wide field objects, your current 85mm scope could possible serve you well.
You might want to take a look at the SEDS Catalog to get an idea of the sizes of various objects and download a copy of the CCD Calculator available at The New CCD Astronomy website. I've also used The Sky 6 software program to help me understand the FOV of various size instruments with various camera's for image framing.
In the end imaging is not just about the OTA...a lot of other factors are important as well.
Patrick
Rait
journeyman
Reged: 11/12/12
Re: Triplet Apo new [Re: Emanuel]
      #5519152 - 11/14/12 08:07 AM
Emanuel,
Thanks, I will check. Your replay put new questions in my mind. Have you compared your WO 132 with TS or AMP? Are they in different in image quality level? How you would compared triplet and doublet, is it better image quality? Yes, I am from europe country where unfortunately weather conditions are very unpleasant for sky lover.
Rait
Rait
journeyman
Reged: 11/12/12
Re: Triplet Apo new [Re: Patrick]
      #5519187 - 11/14/12 08:44 AM
Patrick,
As I understand you would prefer 8-10" SCT or newtonian additionally to 85 mm APO than new 130 or 150 mm. I thought in beginning same but I do not like to have two mounts (double work to set up) so I think easy way will be upgrade my refractor. You need heavy mount to use both on one. I see that you are experienced and here is my question, what would you purchased if you have to spend 5000 eur ( 6500 use) for new tube and you have ieq45 (max 20 kg) and 85 mm apo (ed) refractor (10 kg with dslr and other accessories). Thanks.
Rait
35 registered and 43 anonymous users are browsing this forum.
Moderator:  Scott in NC, Bowmoreman, KWB
