Sky Muse
Reged: 10/26/12
Loc: De Soto County, MS
Tak or Starlight micro-fine focuser for FS series?
      #5531069 - 11/20/12 09:24 PM
Which, in your opinion, is the best micro-fine focuser for the Takahashi FS series refractors, the Takahashi...
http://www.adorama.com/catalog.tpl?op=detailsdisc&sku=TKTFF0002
...or the one by Starlight Instruments...
http://www.harrisontelescopes.co.uk/acatalog/Starlight_Instruments_Feathertou...
Also, would there be a noticeable improvement over the stock focuser for visual?
Alan
Re: Tak or Starlight micro-fine focuser for FS series? new [Re: Sky Muse]
      #5531169 - 11/20/12 10:16 PM
Honestly, Alan, at f/8 you're better off with the stock, buttery Takahashi 1-speed unless you're imaging. The downside of a two-speed microfocuser is that they can be finicky to tune. The Starlight Instruments, in particular, can bind if not adjusted "just right".
Are you having troubles finding perfect focus with the scope? If not, if it ain't broke, don't fix it.
Edited by jrbarnett (11/20/12 11:33 PM)
AJT12
Reged: 09/19/09
Re: Tak or Starlight micro-fine focuser for FS series? new [Re: jrbarnett]
      #5531219 - 11/20/12 10:40 PM
I have used both. I definitely preferred the Starlight. I may have got lucky with mine. No issues at all.
plyscope
Reged: 11/23/06
Loc: Perth, West Australia
      #5531287 - 11/20/12 11:16 PM
I have the Takahashi version on my TSA and it is fine. I definitely like have the two speeds for visual.
I have not tried the Starlight version but it seems people that have tried both tend to prefer the Starlight.
M13 Observer
Reged: 12/09/06
Re: Tak or Starlight micro-fine focuser for FS series? new [Re: plyscope]
      #5531311 - 11/20/12 11:26 PM
Can't say much about the FS series but on my Sky90, the Tak fine focuser felt like a rubber band and was very quickly replaced with the Starlight Feathertouch focuser which feels and works, well, just like a Starlight Feathertouch focuser. I would think it would be an incredible improvement over the original single speed focuser on your FS.
Joe C
Reged: 11/29/08
      #5531312 - 11/20/12 11:27 PM
I have used the stock single speed Tak focuser and have used many 2" and a few 3.5" Starlight focusers. Also have one on my SCT. I personally would not use anything other than one from Starlight Instruments.
As far as adjusting them, all I have had were new and needed zero adjustments. Even after extensive use, they were and are still buttery smooth.
I also agree with having at the least some sort of fine focuser whether for visual or astrophotography. Fine adjustments make it a lot easier to summon that last bit of focus needed for crisp images.
chboss
Reged: 03/24/08
Loc: Zurich Switzerland
Re: Tak or Starlight micro-fine focuser for FS series? new [Re: Joe C]
      #5531485 - 11/21/12 03:13 AM
I have both and would go with the Starlight.
Both work well but the price difference is small and the Starlight has definitely the edge. The adjustment is pretty simple I did not have any issues during installation.
Short time ago they offered the micro upgrade at a special price directly at Starlight:
http://starlightinstruments.com/store/index.php?route=product/product&pro...
best regards
Chris
RAKing
Reged: 12/28/07
Loc: West of the D.C. Nebula
      #5531576 - 11/21/12 06:37 AM
I am solidly on the Starlight bandwagon. I replaced the stock focuser on my FS-128 after the first night and never had any issues with the Feathertouch.
The FT is not that hard to adjust. I used a small Allen head screwdriver and never had any issues with binding.
Ron
RGM
Reged: 09/15/03
Loc: Burks Falls, Ontario, Canada
Re: Tak or Starlight micro-fine focuser for FS series? new [Re: RAKing]
      #5531630 - 11/21/12 07:47 AM
I have the Tak micro-focuser and have never tried anything else. I knew that it had to be set up "just right" to work well. Mine is, after taking the time to understand how it works and the adjustments required.
If the Starlight is easier to set up, then that might be the best way to go.
Traveler
Reged: 08/19/07
Loc: The Netherlands
Re: Tak or Starlight micro-fine focuser for FS series? new [Re: RGM]
      #5531645 - 11/21/12 08:09 AM
I am using my FS-60CB a lot. Never felt the need to use a micro focusser.Focus is there or not. Maybe certain EP's are more difficult to get the scope in focus?
coopman
Reged: 04/23/06
Loc: South Louisiana
Re: Tak or Starlight micro-fine focuser for FS series? new [Re: Traveler]
      #5531661 - 11/21/12 08:20 AM
I am for the most part satisfied with the stock focuser on my FS-102 and the scope snaps into focus pretty well, but I will admit that there are times when I have thought about doing the FT upgrade. Please let us know how that works out for you if you buy it.
Sky Muse
Reged: 10/26/12
      #5531773 - 11/21/12 09:29 AM
Thanks, guys!
The stock focuser is adequate, "buttery smooth" indeed, as I've been using it for nine years, although I've yet to see the true "snap" as described by many in reading, and perhaps due in part to the average quality of my oculars. I can't help but suspect that such might be just the thing to coax said "snap" out and before my eye, especially with the finer oculars, the orthos and whatever other I decide on in future.
My considering the Takahashi focuser was based on the desire to keep it all "oem", understandably, and if the integration of either proved to be a bust, I could always revert to the original configuration...
The Starlight it is!
Thanks again!
Alan
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #5531970 - 11/21/12 10:59 AM
No opinion on which is better but I definately like and use the fine focus on my WO-ZS-110, Lunt 60 and cats especially for high power. As to snap to my experience is that if the eyepiece you're doesn't have it your scope isn't going to either. My 5000 18 Meade UWA is a case in point being a ease into it proposition in my scopes. With XWs, Delos and such it's snap to with all of them. David
tomcody
Reged: 07/06/08
Loc: Titusville, Florida
Re: Tak or Starlight micro-fine focuser for FS series? new [Re: dscarpa]
      #5532018 - 11/21/12 11:20 AM
I have and use both on my scopes.
One point you should know is that the Starlight uses your original shaft and pinion in it so all you are getting is a two speed knob and new housing for the shaft.
As to which is better? the Starlight is definitely smoother, but not by much, but adds weight to the scope (heavy housing) and does not allow the use of a robo focus unit on the other end.
The Tak is a simpler install, is the lighter of the two and allows for a robo focus on the other end of the shaft.
For visual only, I would go with either, although the starlight does have a little better feel.
Rex
delgado39
Reged: 11/13/07
Loc: Glen Ellen, California
      #5532169 - 11/21/12 12:31 PM
In my experience, I could never adjust the Starlight well enough on my TAK FS-128. Especially when the scope was at zenith, my heavier eyepieces would drag the focus tube down. No amount of adjusting could provide the right degree of tension to hold the focus tube and eyepiece in place. I spent way to much time dealing with it. So decided to stick to my TAK one speed OEM. Works quite well and for me less frustrating. But I do admire the quality of the Starlight. It's beautifully machined and smooth. If you can tune it right, I'm sure you'll enjoy it.
Sky Muse
Reged: 10/26/12
Re: Tak or Starlight micro-fine focuser for FS series? new [Re: delgado39]
      #5532818 - 11/21/12 07:01 PM
I put the 2" 32mm Astro-Tech "grenade" in the stock focuser one night, and near the zenith while observing Andromeda it seemingly had the same effect, dragging the focuser out and downward. Perhaps the focuser has loosened up a bit over the years, though not out of excessive use.
Now I'm back where I started; not only debating between the stock and the upgrade, but in addition to purchasing either the Takahashi, in the interest of keeping it all oem, or the Starlight.
tomcody
Reged: 07/06/08
      #5532921 - 11/21/12 08:28 PM
If you want the best for your FS? go for the Feathertouch FTF3035B-A,
See this article:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/3784411/page...
Yes it costs more but it has the advantage of having a built in angle adjuster so you don't need the Tak CAA (that saves you about 26mm of in-focus)
which matters on that scope if you use binos.
Note the 3035 costs about as much as a two speed fine focuser and a CAA combined. (this will be my next focuser upgrade for my FS)
Rex
ThomasWos
Reged: 02/10/07
Loc: Bellingham WA
      #5533175 - 11/22/12 12:03 AM
Hi Alan,
I have the FeatherTouch Microfocuser on my FS 102.
It needs to be installed such that it is "parallel" with the curve on the bottom of the scope. No sweat.
It does for the most part use the Tak focuser, only provides a "geared down" fine focus.
My FeatherTouch carries a Televue 2" diagonal with a Televue Nagler 17mm 2" eyepiece.....with zero slippage when pointed straight up.
I also felt the need for a fine focus, and would'nt have it any other way!
Sky Muse
Reged: 10/26/12
Re: Tak or Starlight micro-fine focuser for FS series? new [Re: ThomasWos]
      #5533195 - 11/22/12 12:25 AM
Thanks, guys! Now all that's left is to pour over the variables, one versus the other, and make my decision.
Alan
plyscope
Reged: 11/23/06
Re: Tak or Starlight micro-fine focuser for FS series? [Re: Sky Muse]
      #5533264 - 11/22/12 01:35 AM
There are some good pictures of the Takahashi version on this UK website.
web page
41 registered and 39 anonymous users are browsing this forum.
Moderator:  Scott in NC, FirstSight, panhard, star drop
