Rob55
Reged: 12/15/12
Loc: Fort Polk, LA USA
Celestron OMNI XLT 102 First Light
      #5605759 - 01/04/13 11:23 PM
41600JAN13 44F, 25mm ep,
The telescope was in the foyer when I got home, two really big boxes. It took me a few minutes to get it together. I think the manual was excellent. The scope balanced easily with just the 7lb counter weight. I have no experience with stuff like this, but the mount seems extraordinarily substantial and smooth as silk. I set it up so it so with the eyepiece and diagonal at half focus it balances with the rear bolt head against the dovetail mount. This allows me to remove and replace the scope without having to re balance. The EQ setup was not intuitive as I assume the ALTAZ would be, but fooling around with it in the light of the living room I got use to it. When releasing the rings and taking the paper off I recommend loosing the bolts holding the rings to the dovetail mount. My rings were a little out of line. I was afraid tightening them would deform the tube. With the rings loosened on the mount I tightened the ring thumb screws on the tube snugly and then re tightened the bolts attaching the ring to the mount. I got moved outside by 1700. Polaris is hidden by the pines north of my house in Louisiana. I set the North side to north and the latitude to 31. There is a 7 story building with a light on top of it about a half mile from the house. I used it to line up the finder scope. The sky was 100% overcast. I set the scope to the South East in anticipation of Jupiter and waited for the sun to go down. At 1830 the South East was totally clouded over. Just to the North Capella, Castor and Pollux were stacked. I switched to Capella, my first light. As I brought the star into focus three meteors in formation crossed the lens from right to left or was it from right to left inverted, reversed? It was 1837. That was worth the price of admission. Im hooked. I got a few glimpses of Jupiter and Betelgeuse through the clouds and pine branches. At 2000 I had about 20 minutes of solid cloud and quit for the night. So what should be my next ep, 10mm? Until the next time. Rob
RAKing
Reged: 12/28/07
Loc: West of the D.C. Nebula
Re: Celestron OMNI XLT 102 First Light new [Re: Rob55]
      #5606166 - 01/05/13 09:16 AM
Congrats on your scope! I enjoyed my Omni XLT 102 for a few years and still have fond memories of the views.
Next eyepiece? It depends what you want to look at. If you are a planetary guy, then the higher power eyepieces are okay. If you like DSO, then lesser magnification and wider FOV is my suggestion.
You might also consider upgrading to a 2 inch diagonal. That will give you more options moving forward.
Enjoy!
Ron
newtoskies
Reged: 07/15/12
Loc: SE Ma.
Re: Celestron OMNI XLT 102 First Light new [Re: RAKing]
      #5606198 - 01/05/13 09:35 AM
Great first light Rob. The XLT102 is the scope I will be getting soon, I hope. This first light and tips on the assembly is very helpful. I look forward to hearing more on this scope, she is a beauty eh.
coopman
Reged: 04/23/06
Loc: South Louisiana
Re: Celestron OMNI XLT 102 First Light new [Re: newtoskies]
      #5606203 - 01/05/13 09:38 AM
Congrats on the new scope, Rob.
csrlice12
Reged: 05/22/12
Loc: Denver, CO
Re: Celestron OMNI XLT 102 First Light new [Re: coopman]
      #5606369 - 01/05/13 11:20 AM
Congrats! Just got mine out last night too for the first time. Didn't have a lot of time (family stuff), but it's been setting there since Christms, and dang it, there were stars in the sky! The sun had just set, so the air wasn't the most stable, so I decided to view Jupiter (an approprite first light object imo, but then, if its in the sky, its appropriate). I also was taken by how easily the scope moved around on all its axis. I haven't installed the polar scope yet, so I aligned the N leg of the tripod up with a compass. Swung the OTA around, put Jupiter in the finder (which fell off after I mounted the scope to the mount, luckily it was grass underneath). I actually then realigned the finder using Jupiter (it was also easier to align the finder as it was easier to just sight down the scope then the dob is). First view of Jupiter and its 4 readily viewable moons. As much as I've joked around here about refractors and dobs; I AM A BELIEVER! The view with the 20mm just blew me away. I was seeing 4 bands with a 20mm, with my dob (which I did not have out last night), so far the best I'd done is three bands (*BLEEP* viewing weather though). Since I didn't have a lot of time, I also took out my ES82 11, 8.8, and 6.7mm. As expected, the 11mm threw up some fantastic views, four bands again, easily, nice sharp definition between the bands. For all it's flaring problems, I'm finding I really, really like the 8.8mm. Once Jupiter was in the FOV, the flaring (minor) dissappeared, and Jupiter just WOW, filled the FOV nicely. Let me tell you, while nudging the dob doesn't bother me, and the dob does "settle down" faster (<1 sec for the dob, about 2 sec for the XLT), I just could not believe the smoothness of using the knobs to move the scope. Once I had jupiter in the scope, apparently, I had it North aligned well enough as I only had to use the one knob to keep Jupiter in view...and using the knob did NOT result in any vibration, Jupiter remained sharp and clear while turning the knob. Lastly, I tried the 6.7mm, while I could still see 4 bands, the viewing just wasn't up to par for the 6.7. Overall, while a short night, was one of the funnest nights I've had in a while.....and as I said, as far as refractors go---I AM NOW A BELIEVER. Will the XLT replace my dob? No, but it will do things my dob won't, just like the dob will bring in fainter fuzzies the XLT couldn't. I'm enjoying them both.....nothing wrong with that, right?
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
Re: Celestron OMNI XLT 102 First Light new [Re: csrlice12]
      #5606580 - 01/05/13 01:03 PM
Congrats on the new scope! My Omni 102 sees a lot of use for lunar and planetary viewing and I enjoy the scope a lot -- it gives very sharp an contrasty views. Jovian moon transit and the GRS are easy targets for the Omni 102. Last spring when Mars was at opposition my Omni 102 gave better views than my XT10i on some nights. Also, IMO, the CG-4 mount is perfect for the Omni 102 and in general an underrated mount. And as csrlice mentioned, turning just one knob to track a planet at high power is much nicer than nudging a dob.
As far as eyepieces go, I've had good results with the ES 82 eyepieces. My highest power eyepiece is a Meade 5000 HD-60 4.5mm which is about the limit of the Omni 102. The HD-60 works really well on nights of good seeing and gives nice contrasty views. On nights of average seeing my 6.7mm ES 82 is about the maximum useful magnification.
Also, a 2" diagonal is worthy upgrade to the Omni 102. I got a 2" Astro-Tech dielectric for mine. It's $119 at Astronomics, which is a very good deal for this diagonal. Looks like they're currently out of stock though.
Astro-Tech 2" Dielectric
Rob55
Reged: 12/15/12
Re: Celestron OMNI XLT 102 First Light new [Re: Mike4242]
      #5607052 - 01/05/13 06:00 PM Attachment (81 downloads)
Wow! Thanks for all of the complements and encouragement. It's raining here now, but should clear up next week. I was disappointed not to see Jupiter's moons, but I was looking through significant clouds when I got a glimpse. Now I have to decide on developing my 1.25" ep collection or springing for the 2" diagonal and starting over. I guess I have to develop a signature now. Does anyone use a Orion ST 80 as a finder scope? It would give me somthing to do with my 1.24" diagonal.
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
      #5607151 - 01/05/13 06:56 PM
The 2" diagonal comes with a 1.25" adapter so you can still use your 1.25" eyepieces. It will give you the capability to use both 2" and 1.25" eyepieces.
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
      #5607157 - 01/05/13 07:00 PM
Here's a pic of a 2" eyepiece in my Omni 102:
Gary Riley
Reged: 12/01/11
Loc: White Bluff, TN
      #5607554 - 01/05/13 11:39 PM
Congratulations Rob!
You will enjoy the 4 inch XLT. I have the same setup except I have an Orion 2 inch Crayford style 2 speed focuser, 2 inch Orion Dielectric diagonal and an Orion 9x50 RACI finder scope on it.
I, too, enjoy the smoothness of its movements on the CG-4 mount. I generally use Baader Hyperions in it and they work very well in it IMO. It compliments my 12 inch dob nicely. Its strong points are lunar, major planets, double stars, and open clusters, again IMHO.
Enjoy!
Gary
newtoskies
Reged: 07/15/12
Loc: SE Ma.
Re: Celestron OMNI XLT 102 First Light new [Re: Gary Riley]
      #5608185 - 01/06/13 11:57 AM
Man some great pics of the 102. Now I REALLY want one. I was thinking an 8x40 RACI in place of the supplied finder and I see it can be done.
Rob55
Reged: 12/15/12
      #5608884 - 01/06/13 05:22 PM
Gary: Sounds like you think the 2" diagonal and eyepieces are worth the investment.
Gary Riley
Reged: 12/01/11
      #5609523 - 01/07/13 12:21 AM
Sure do!
Gary
csrlice12
Reged: 05/22/12
Loc: Denver, CO
      #5609816 - 01/07/13 09:34 AM
+1 on the 2" diagonal. Got the Orion 2" Dielectric and it performs great in the 102XLT. Haven't tried my 2" eyepieces in it yet (too much weight difference between my 2" and 1.25" eyepieces), but plan on it soon. Definitely have to replace that finder scope though. Oddly though, I did note with my ES82 6.7mm I had a lot of field curvature? Whatever it was, the stars appeared pin-point, but kind of curved around near the outer 10% of the FOV as it exited the FOV. Just assuming it was FC from being a 4" scope with a high power wide-field. The view was sharp all the way across the FOV.
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
      #5610056 - 01/07/13 11:51 AM
I've noticed the same thing with mine.
coopman
Reged: 04/23/06
      #5610061 - 01/07/13 11:55 AM
The weight & CG shift when going from 1.25" accessories to 2" accessories & heavy EPs might be enough to tax the CG4 some. At the very least, I would expect the dampening time to increase.
coutleef
Reged: 02/21/08
Loc: Saint-Donat, Quebec, Canada
      #5610107 - 01/07/13 12:18 PM
that is strange as i owned a f/6 scope with field curvature that was always more visible at low powers rather than higher mags. you should not have a lot of FC with a f/9 scope at over 100x.
lets ser what the experts have to say on this
csrlice12
Reged: 05/22/12
Loc: Denver, CO
Re: Celestron OMNI XLT 102 First Light new [Re: coutleef]
      #5610178 - 01/07/13 12:51 PM
Really not certain what it was, but it was only in the 6.7 ES82. The stars just curved off the edge of the FOV (i.e. didn't go straight off the edge, looked almost like it "climbed up out of" of the eyepiece. It was really strange, first thing that crossed my mind was "coma", then I remembered it was a refractor. Like I said, everything was sharp to the edge, even as it "climbed out of" the eyepiece at the edge. The 6.7 has worked fine with my Dob, no problems. Doubtful it's scope collimation as I bought the scope from the local dealer, and they put it together and collimated it. I've dealt with these people quite a bit, and they are very knowlegeable and helpful, so I very much doubt its the scope.
coopman
Reged: 04/23/06
      #5610465 - 01/07/13 03:43 PM
Sounds like it is a trait of that particular eyepiece only. Maybe you could ask if others have noticed this effect on the eyepieces forum & see if it is common.
Rob55
Reged: 12/15/12
      #5619659 - 01/12/13 07:00 PM Attachment (59 downloads)
Busy Week. Last Sunday night, 6JAN13 was crystal clear, 44 degrees F, no wind.I set up at 1955. Polaris is below the horizon, but the clear night helped me set up better. The mount tracked flawlessly. I spent the first few minutes with Capella. She is bright, at a comfortable altitude and far enough East to fit in a gap in the pine trees. Orion and Jupiter were still in the trees so I turned to Gemini. I do not know the degree seperation between the twins, but that is the field ov view of my scope with the 20mm EP. I cannot see both of them with out shifting my eye around, but they are both there just starting to deform on the edge of the view. After a few minutes playing with Castor and Pollux, wishing for a shorter EP Jupiter drifted above the Pines. I saw the moons of Jupiter for the first time, beautiful! I have got to get a diagonal finder, what a pain in the neck.Is the celestron 6x30 diagonal adequate? I have no problem finding things in my straight one.With the crystal clear condition I noticed the time the scope took to settle when focusing. At 40x it took about 15 seconds to settle. I detected no vibration turning the knob to track. Agian I want more magnification. Jupiter tracked from bottom to top right in the middle of the lense. A nudge of the knob kept everything centered perfectly. Jupiter was at near zenith. I was on my knees with a serious krink in my neck. Shoving the tube up a few more inches in the rings makes the 2" diagonal more attractive. I bought 1.25" 6.3mm and 13mm eps on the bay for less than $30 and free shipping. They should be here next week.
Rob55
Reged: 12/15/12
      #5619755 - 01/12/13 08:15 PM
What is your finder?
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
      #5620337 - 01/13/13 09:15 AM
It's an Orion 9x50 RACI finder. I also use a Rigel Quickfinder because sometimes it can be difficult to know exactly where you're pointed with a right angle finder. I use the Rigel to center on a bright star and then use the 9x50 and a chart to hop from that point.
newtoskies
Reged: 07/15/12
Loc: SE Ma.
      #5620674 - 01/13/13 12:22 PM
Great report. I got my 102 on Friday and now the new scope curse is in full effect...waiting to use the scope is killing me. I'll be ordering the RACI finder for sure now.
How do you mount a Telrad on the 102 ?
beatlejuice
Reged: 04/05/11
Loc: Hamilton, ON,Canada
      #5621476 - 01/13/13 07:17 PM
This is how I do it.
Eric
soliari
journeyman
Reged: 11/12/12
Loc: New Mexico, USA
Re: Celestron OMNI XLT 102 First Light new [Re: beatlejuice]
      #5622335 - 01/14/13 09:40 AM
I also recently purchased a OMNI XLT 102 and as luck would have it first light was also Jupiter on a clear New Mexico night. Since then we've seen M42 and squeezed most of M45 into the FOV.
I opted for the celestron 8-24 wide field zoom EP, which works wonderfully. I too am deciding on new eyepieces and from what I can gather it seems like some people have experienced on being able to magnify to 160 or so ... which is about a 6mm EP. Has anyone else noticed this with the XLT102? Or has anyone used a 5mm EP with it? This matters to me because if 160x is the limit then I'll opt for a 6mm & 32mm Plossl. Otherwise I think I'll go for a quality barlow and a 32mm Plossl.
Thoughts? Ideas?
Edited by soliari (01/15/13 12:31 AM)
newtoskies
Reged: 07/15/12
Loc: SE Ma.
      #5622343 - 01/14/13 09:44 AM
Sure does, thanks for the link.
Gary Riley
Reged: 12/01/11
      #5623421 - 01/14/13 08:58 PM
Soliari,
I have the XLT 102 as well and I have used a Baader Hyperion 5mm with several times. I have noticed that the image of Jupiter appeared a little "soft" compared to lower magnifications. Could have been due to the "seeing" or transparency. But more likely that I was reaching the limit of it's capacity at around 200X.
Gary
soliari
journeyman
Reged: 11/12/12
      #5623697 - 01/15/13 12:29 AM
Thank you Gary. It's nice to know someone is out there pushing the optics of this scope. From all the searching I thought I was going to have to settle for 160x. I think I'll try to push mine.
BoriSpider
Reged: 08/10/04
Loc: S.W.FLA
Re: Celestron OMNI XLT 102 First Light new [Re: soliari]
      #5624030 - 01/15/13 09:09 AM
I, too, use a 5mm UO HD ep every-so-often. Not much though.
And if I lucky I can barlow my 8mm radian for 250x.
soliari
journeyman
Reged: 11/12/12
Re: Celestron OMNI XLT 102 First Light new [Re: BoriSpider]
      #5624228 - 01/15/13 11:32 AM
250x out of this OTA? That's impressive. I keep hearing how the 102mm diameter just does not gather enough light for magnifications beyond 160 ... so happy to hear it's possible even if not very often probable.
Thank you gents.
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
      #5624803 - 01/15/13 05:00 PM
On nights of good seeing I get very good views with the Omni 102 at 222x using a 4.5mm Meade HD-60. On nights of average seeing 150x-180x is about the max I go.
greyfox
Reged: 08/29/10
Loc: Jacksonville, Florida
      #5625136 - 01/15/13 08:30 PM
Hey everyone:
As an OXLT 102ED owner, I read this thread with great interest. I'm curious - the OP says three meteors crossed the field of Capella in formation....is it possible he viewed those spy satellites (forget the names) that cruise around in formation? I would look myself but I forget what those things are called....but I'm wondering if they crossed the field at his exact moment of first-lighting.
Otherwise, great report. I enjoyed reading it.
Brad
csrlice12
Reged: 05/22/12
Loc: Denver, CO
      #5625141 - 01/15/13 08:33 PM
Haven't really taken mine below the 6.7mm yet (nice views with it though). I believe the scope is more than capable of higher mag, it's the weather that's been the problem.
Zamboni
Reged: 01/03/05
Loc: Colorado Springs
Re: Celestron OMNI XLT 102 First Light new [Re: greyfox]
      #5625228 - 01/15/13 09:28 PM
Hey everyone:
Brad
I think the name of those is "Whitecloud" satellites.
greyfox
Reged: 08/29/10
Re: Celestron OMNI XLT 102 First Light new [Re: Zamboni]
      #5625339 - 01/15/13 10:26 PM
Yeah...not spy sats (per se) but NOSS ELINT "triplets"....
If I had to venture a guess, thats what he saw. Talk about luck!
Zamboni
Reged: 01/03/05
      #5625403 - 01/15/13 11:00 PM
No kidding! I've seen these before, but not crossing the FOV. Must be a heckuva sight!
newtoskies
Reged: 07/15/12
Loc: SE Ma.
      #5627181 - 01/16/13 10:42 PM
Great to hear the question and comments about pushing mag with this scope. I got mine on Friday and it's been cloudy since. I was thinking today of what would be the highest mag with this OTA. I'll be ordering the Paradigim ED 12 and 18mm and will be getting the TMB 9mm. I can 2x Barlow the ED EP's but wasn't sure if it would be worth trying the 9mm and Barlow.
GOLGO13
Reged: 11/05/05
Loc: St. Louis area
      #5628322 - 01/17/13 03:34 PM
The general rule of thumb is 60x per inch of aperture as a max. That would require perfect conditions (seeing, cooldown, etc.). Your 1000 focal length scope with the 9mm would be 111x (nice medium mag). With a 2x barlow you are looking at 222x. Pretty much maxes out your scope. But it's within the 60x per inch range. I'd say it should work in perfect conditions. In general with that scope you'd probably want to stay around 180x for high magnification.
I think the moon handles magnification well...so certainly try 222x on the moon...and planets on a good day of seeing (not much twinkling in the stars).
newtoskies
Reged: 07/15/12
Loc: SE Ma.
Re: Celestron OMNI XLT 102 First Light new [Re: GOLGO13]
      #5628771 - 01/17/13 07:57 PM
ah thanks for the great info. I'll be seeing my friend this weekend who lives at a dark zone and will take the scope with me just in case.
With the 12 and 18mm and barlow I'll be at 166 and 110, still below the 200+ mag. These and the 9mm barlowed on my Dob will be way too much.
GOLGO13
Reged: 11/05/05
Loc: St. Louis area
      #5628966 - 01/17/13 09:59 PM
Think it's about the same for your dob. 133x and 266x. Your dob's theoretical is 300x, but again I would stay closer to 200-240x most of the time.
Always worth a try to go high power, but in general low to medium power is best. A larger scope can handle more mag...but unless it's got tracking, it can be a pain to manually track (such as a non-motorized dob).
Rob55
Reged: 12/15/12
      #5629547 - 01/18/13 09:28 AM
Appreciate your post. It gives me a much better plan for developing my EP collection.
Rob55
Reged: 12/15/12
      #5629564 - 01/18/13 09:45 AM
Earlier poster uses 4.4mm on a good night.
Rob55
Reged: 12/15/12
      #5629581 - 01/18/13 09:57 AM
Spy satellites?! never even considered it. But what are the chances three meteors would be moving in the same direction at the same time close enough to be seen through the eyepiece. And, yes, this was the very first time and target for my scope. I an an absolute complete novice. The sighting was pure unplanned accident.
csrlice12
Reged: 05/22/12
Loc: Denver, CO
      #5629765 - 01/18/13 11:32 AM
When beginning, a lot of the things I saw was pure unplanned accident...........
...and sometimes it still is......
Rob55
Reged: 12/15/12
      #5629822 - 01/18/13 11:59 AM
The 1.25" 13 mm arrived in the mail yesterday, and not a moment too soon. Social obligations prevented my setting up the scope last night, but viewing conditions were beautiful. Luckily the trash can filled three times and I took my time taking it out. The moon was awesome. Orion fully visable. I was praying conditions would be good in the morning as Saturn should be lurking in the sky.
180545FEB13 35 F hazy and dawn's light is rimming the East. The big dipper is fully visable. Sighted Dubhe and Merak for the first time with the 25mm and switched to the 13mm. It wasn't too impressive a difference. The lens did increase the size of the stars slightly and I noticed no significant dimming of the ep. Stars go right to the edge of the FOV without any significant change when they drop off. The lens has a few darker spots on it. Makes me wonder about cleaning. I'll have to research that. It did give me opportunity to fine tune the finder scope and observe the impact turning the knobs had at higher magnification. Anyhow fished it out of D Bay for $15 and free shipping, and it is zero calories, sodium and fat free.
I didn't think the 13mm was going to make the dipper that interesting and I set up to see Saturn.
When I turned South there were only two bright objects in the Graying sky: Spica? and Jupiter? I'm still stumbling around here. Some other stars are visable, but fading fast. Well, Left, East is bigger and brighter; Let's see. The transition from looking over the tube to the finder was easy. In the 8x finder it looks like a star.I have my doubts. Then to the 25mm. I see rings, well ring, and there was definite separation between the ring and the planet. I cannot believe how happy this makes me. Then I switch to the 13mm, Wow! That made a difference, twice the size. Barely visable lines of separation fade in and out in the rings defining the outer third. No noticable color. Two companion stars are visable to the left through the finder, West? I tracked Saturn for about 45 minutes while occasionally scanning the SSE horizion looking for Venus or Mercury to no avail. Well maybe next month. When I quit Saturn and stars were still easily visable through the scope but Saturn was barely visable to the naked eye.
This could become addicting. Predicting clear skies tonight. Happy MLK weekend.
csrlice12
Reged: 05/22/12
Loc: Denver, CO
      #5629867 - 01/18/13 12:22 PM
"This could become addicting."
Nah, it's just habit forming.......
newtoskies
Reged: 07/15/12
Loc: SE Ma.
      #5630012 - 01/18/13 02:08 PM
Very cool to read this report.Now I can't wait to use my 102 and the two new ep's. Looking forward to seeing Saturn too.
Rob55
Reged: 12/15/12
      #5630863 - 01/19/13 12:12 AM
First look at the moon tonight. Used the lens cover to stop the scope. It really helped contrast. My wife looked through for the first time. She loved it. After the moon we went to Jupiter. Seeing was good and I put in the 13mm ep then told my wife to have a look. She bent to the ep and not being one given to hyperbolic statement she said. "holy s*it!" I think she liked it.
newtoskies
Reged: 07/15/12
Loc: SE Ma.
      #5633087 - 01/20/13 12:15 PM
Very cool Rob. My wife said the same when I first bought my dob and showed her the moon and then Jupiter. I had my first ( real) light last night with the 102 and loved it. I'm waiting for my paradigm ep's to arrive, hopefully on Tuesday,and see how those work out. I posted my first light in the beginner forum.
Rob55
Reged: 12/15/12
      #5635779 - 01/21/13 09:43 PM
I will check out the first light. Let me know how you like the EP.
Glen A W
Reged: 07/04/08
Loc: USA
      #5637281 - 01/22/13 04:25 PM
So glad to read these posts and hear of people seeing Saturn through a refractor! The 102 is a really great scope. It often surprised me and seemed much bigger - refractors are hard to beat. I still use mine a lot, and by the way it works great with a solar filter, which is what I use it most often for these days. Good luck and keep us posted. GW
newtoskies
Reged: 07/15/12
Loc: SE Ma.
Re: Celestron OMNI XLT 102 First Light new [Re: Glen A W]
      #5638458 - 01/23/13 09:08 AM
Rob the supplied ep works out good fr me since I used mostly the 25mm plossl with my dob. The Celestron 25mm has a wider fov which I found nice for the clusters. My two paradigm ed's arrived today but it will be too cold tonight for viewing. But who knows, I may just haul the scope out for a quickie.
bigj4708
Reged: 06/08/13
      #5933843 - 06/21/13 10:32 PM
Is it a worthy upgrade because it allows you to use 2 inch eyepieces? or do you actually see more with it?
bigj4708
Reged: 06/08/13
Re: Celestron OMNI XLT 102 First Light new [Re: bigj4708]
      #5933850 - 06/21/13 10:38 PM
This is one of my favorite threads because I'm getting my omni XLT 102 in just over a week and I have two eyepieces the ES 8.8 82 and the 20 68 just waiting to plop in. I am looking at a meade 2 inch diagonal so I can get a fat 82 piece for it.
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
      #5933985 - 06/22/13 12:35 AM
Yep, it will let you use 2" eyepieces. The 2" eyepieces are for low power wide fields of view. You can get a much larger field of view with a 2" eyepiece than a 1.25" eyepiece at certain focal lengths. They are great for large open star clusters like M7 in Scorpious or M45, the Plieades, in Taurus. They're also good for just panning around the Milky Way and finding stuff.
csrlice12
Reged: 05/22/12
Loc: Denver, CO
      #5934579 - 06/22/13 12:54 PM
An Omni 102XLT, a 2" diagonal, and a 24mm ES82, dark skies (and an OIII filter if you have one)....and you're set for the night. You can bring the other stuff...but it might not get much use.....Just picked up an ES100* 14mm....gonna try that out on the moon tonight. It'll make a great companion eyepiece to the ES82* 24mm.
audioaficionado
Reged: 05/24/12
Loc: Medford, Orygun, USA
      #5935297 - 06/22/13 08:31 PM
I can get 200x with my Celestron 102-GT f/10, but it is a little soft. Not bad though.
bigj4708
Reged: 06/08/13
      #5936956 - 06/23/13 06:58 PM
Awesome! Let us know what the 100 EP is like for that scope. I'm super interested in what your impressions are.
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
      #5937059 - 06/23/13 08:24 PM
I just realized I answered a very old question in my last post. I looked too quickly and thought bigj4708 was asking about the 2" diagonal. Doh!
Glen A W
Reged: 07/04/08
Loc: USA
Re: Celestron OMNI XLT 102 First Light new [Re: audioaficionado]
      #5941511 - 06/26/13 02:27 PM
Mine gets soft around 400x, but that's on the lunar terminator. For a low-cost four incher, that is awesome. GW
bigj4708
Reged: 06/08/13
      #5956648 - 07/05/13 07:49 PM
Awesome!
I have the 20mm ES 68 already and it's a great view. (scope came in July 3rd) What do you think about an ES 34mm 68 for the 102 omni? I did the math and supposedly it will get 2.34 FOV which would be just awesome.
pdxmoon
Reged: 06/27/13
Loc: Oregon
      #5956802 - 07/05/13 10:03 PM
How is this scope for lunar observation? CA present?
Widespread
Reged: 05/11/11
Loc: Bowling Green, Kentucky
      #5956910 - 07/05/13 11:24 PM
Awesome!
I have the 102GT (f/9.8). My 24ES68 gets the most use for low power. I haven't used the 34ES68, but you might also consider the Baader Hyperion 36mm (72* AFOV) for very wide views.
Best,
David
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
Re: Celestron OMNI XLT 102 First Light new [Re: Widespread]
      #5956938 - 07/05/13 11:43 PM
It's very good for lunar observation. There is CA around the limb of the moon, but it is very minimal.
10 registered and 32 anonymous users are browsing this forum.
Moderator:  Scott in NC, FirstSight, panhard, star drop
