bilgebay
Reged: 11/06/08
Loc: Türkiye - Istanbul and Marmari...
FSQ106EDXIII - Micro Touch adaptation
      #5606311 - 01/05/13 10:52 AM
Details will follow, hopefully tomorrow, but here is the video:
http://www.youtube.com/watch?v=fEVCGtBBR4A
1 count is equal to 5 microns. The total free travel is 29.58mm (5916 counts).
I discovered that my FSQ's focuser had 45 microns backlash (9 counts)
By manufacturing a bushing for the gear to fit the FSQ's fine focus shaft and an adaptor to fit the MSM30 motor to the FSQ's focuser body, I was able to use the existing motor and Micro Touch controller to drive the stock FSQ focuser.
Clear skies
Denimsky
Reged: 01/21/07
Loc: BC, Canada
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: bilgebay]
      #5606451 - 01/05/13 12:02 PM
Wow very nice clean setup!
Thank you for sharing.
bilgebay
Reged: 11/06/08
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: Denimsky]
      #5609632 - 01/07/13 04:37 AM
Thank you Donghun. Yes, it is a very neat setup indeed. I haven't seen a better motorization to date
Here are the detailed photos for those who are interested:
This is how the Tak focuser looks after removing the fine and course focus knobs.
The pinion gear is approx 1mm larger than the focuser shaft. I fixed it onto the shaft with the help of the set screw just to take the necessary measurements.
The motor will be approx at this position after the adaptation
Measuring the critical diameters
Edited by bilgebay (01/07/13 08:17 AM)
bilgebay
Reged: 11/06/08
      #5609752 - 01/07/13 08:35 AM
A week later...
Before installing the adaptor and the modified gear
I could have fit the gear with the help of a sleeve. Due to a misunderstanding I have a modified hub that fits the Tak shaft
The sleeve technique is used by Starizona
Here is the slit adaptor I produced to fit the MSM30 motor to the Tak focuser.
Motor goes in
Et voila!
The motor extends out 4-5 centimeters more compared to the knobs. Don't think this will be a problem though
I have also removed the manual focus knob on the left/port side of the scope. This is necessary to avoid the risk of damaging the motorized focusing system. Using a piece of Gorilla Band, I have sealed the cavity lest dust and other stuff should penetrate the focuser bearings
Bottom view
bilgebay
Reged: 11/06/08
      #5610079 - 01/07/13 12:03 PM
Oh! One last thing before I forget: I have fixed the lock lever in the open position with some Gorilla band until I find a better solution. To keep the lock lever disengaged is very important. Locking it can be a very costly mistake.
Edited by bilgebay (01/08/13 01:49 AM)
dflipp
newbie
Reged: 01/03/06
Loc: Central Arkansas
      #5610442 - 01/07/13 03:31 PM
Very nice!
I'd love to see the details of how you did this, but the photos aren't displaying.
-Dan
bilgebay
Reged: 11/06/08
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: dflipp]
      #5610479 - 01/07/13 03:55 PM
Thank you Dan.
According to me, the only missing information here is the drawing of the adaptor and the pinion sleeve. I hope to add those tomorrow.
The pinion gear, the MSM30 stepper motor assy and the Micro Touch Controller are sold by Starizona and Starlight Instruments.
If there is anything else you want know, please be more specific and I'll do my best to explain.
Cheers
Edited by bilgebay (01/07/13 03:58 PM)
dflipp
newbie
Reged: 01/03/06
      #5610510 - 01/07/13 04:14 PM
I see the photos now.
I already have the Micro Touch controller and MSM30 motor. I will need to get the Tak micro focuser. My scope is the older FSQ-106N, but hopefully the dimensions will be the same. I should be able to get a local machine shop to make the adaptor and pinion collar.
Thanks for posting this!
-Dan
Logan Tudor
Reged: 12/28/11
      #5610582 - 01/07/13 05:01 PM
Is it just me and my cpu, or are the pictures not visible? I only see a red 'X' in their place. Cheers, Logan.
P.S. bilgebay, if possible, could you upload high res versions to say Dropbox? Very intersted in this modification.
bilgebay
Reged: 11/06/08
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: Logan Tudor]
      #5610605 - 01/07/13 05:29 PM
Hope this link works for you. If not, pls let me know and i will load the photos to dropbox tomorrow morning.
Cheers
Mike Clemens
Frozen to Eyepiece
Reged: 11/26/05
Loc: Alaska, USA
      #5610633 - 01/07/13 05:53 PM
Super nice. 5 micron steps. How big is the critical focus zone for blue light on the FSQ?
Logan Tudor
Reged: 12/28/11
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: Mike Clemens]
      #5610867 - 01/07/13 08:31 PM
Thanks bilgebay, pics are now visible. Great post, thanks for sharing.
I wonder if the entire range of FT focus motors would work, namely: MSM20, MSM30 and MSM35? Anyone know?
I have a TOA-150 with the older focuser (not the 'B' version as also used on FSQ) and a new Microtouch hand controller (just like yours) sitting around unused. Would this be possible? Fingers crossed!
hytham
Reged: 12/25/12
Loc: Canadian in the US
      #5611109 - 01/07/13 10:55 PM
Very clean and very nice!
bilgebay
Reged: 11/06/08
      #5611318 - 01/08/13 02:31 AM Attachment (15 downloads)
Hi Mike, thank you.
In the case of FSQ, 5 micron steps are a bit coarse. The CFZ @ f/5 is 58 microns and @ f/3.6 it is 30 microns for blue light.
Attached is a spread sheet I put together for calculating CFZ for all scopes and here is a thread with some discussion on the subject based on a previous thread Jerry Lodriguss posted where he refers to his article on Focus Change Due to Temperature Variation.
If you follow the calculations in Don Goldman's article on New Critical Focus Zone you need to reduce the figure you find in my spread sheet by almost 60%.
bilgebay
Reged: 11/06/08
      #5611323 - 01/08/13 02:37 AM
Hi Logan,
I guess the motor selection depends on the load you are going to apply. In my case even the MSM20 would be sufficient but MSM30 was a better fit for an easier adaptation.
Hope you find the best solution for your case.
Clear skies.
Sedat
schling
newbie
Reged: 12/02/06
      #5612365 - 01/08/13 05:28 PM
Hi Sedat,
Great job. Funny, I am thinking about getting a FSQ106 and was tinkering with the idea of then doing exactly what you did, as I already have the Microtouch driving a StarlightInstruments focuser. Much neater setup like this.
I'll drop you a line if I get in trouble with my project when the time comes...
Clear skies
Robert
schling
newbie
Reged: 12/02/06
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: schling]
      #5613546 - 01/09/13 11:36 AM
Hi Sedat,
One more thing...
You mention that you discovered that the focuser has a backlash of 9 counts (45 microns). Do you think that this is due to the planetary reduction gear, or is it linked to loose tolerancing of the rack & pinion set?
Robert
bilgebay
Reged: 11/06/08
      #5613632 - 01/09/13 12:25 PM
Hi Robert,
I will be glad to be of any help.
Hope to post the drawing with dimensions as well but it is in my other computer which is 500 miles away from me now
Regarding the backlash, I can say at least 7 out of 9 counts are coming from the Tak's rack and pinion. There should be a way to reduce this but then some other problems may/will occur.
As long as I know the backlash in terms of counts or microns, it is not that important in fact. Since the load will apply a force that will push the draw tube away from the scope, I will always reach focus from the opposite direction, i.e. by moving the draw tube inwards. The software I will be using (Sequence Generator Pro) takes care of that. When adjusting the focus, if the new focus position is further out from its current position, it moves out some further distance (which I am determining, say 50 counts) then comes to the new focus point. If, on the other hand, the new focus position is further inward compared to the current position, it just moves the draw tube in by the necessary distance.
schling
newbie
Reged: 12/02/06
      #5613840 - 01/09/13 02:38 PM
If you could get around to posting the drawings and dimensions that would be great.
With respect to backlash, I actually never bothered to try to measure it on my FeatherTouch. Just like you mention, when autofocusing I always move from out to in on the final move, making sure the any backlash has been "eaten up". The question was just technical curiosity on my part.
Robert
Denimsky
Reged: 01/21/07
Loc: BC, Canada
      #5613993 - 01/09/13 04:12 PM
Hi Sedat,
Why do you say 5 micron steps are coarse even though it is way below the CFZ ?
Quarkroscoe
newbie
Reged: 01/08/13
Loc: Wisconsin, USA
      #5614283 - 01/09/13 06:54 PM Attachment (7 downloads)
What an elegant solution. I have just started my search for a remote focusing solution for my TOA-130. My TOA was built in 2004 and the 4" focuser is a bit different from what I see in your pics (see attached). I have looked at JMI and RoboFocus and your solution is by far the best. It also uses the fine focus shaft and the JMI does not. I have heard about a lot of slipage issues with the RoboFocus. By the looks of the attached pic, do you think your solution would work on my TOA?
Dennis
www.RoscoeSkies.com
bilgebay
Reged: 11/06/08
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: Quarkroscoe]
      #5614788 - 01/10/13 12:52 AM
Thank you Dennis. My answer will be "yes" to your question
bilgebay
Reged: 11/06/08
      #5614820 - 01/10/13 01:43 AM
Hi Sedat,
Maybe it was a bit early to utter my judgement on this. However, we have a very limited CFZ to start with. Let's say the temperature has dropped 1 degree and this means that your tube will contract by 13 microns. With this setup you have the ability to move either 10 or 15 microns, not 13. This may look unimportant at first look but if you consider all you have is 30 microns only, it is a bit tight to fit in.
Additionally, I have heard from other users that there is a hysteresis problem with the Micro Touch system. So, more steps could help me to land in this tiny CFZ slot with better precision.
I need to do some testing on the accuracy of the system. I hope to find the time for this before the end of this month.
Clear skies.
Quarkroscoe
newbie
Reged: 01/08/13
Loc: Wisconsin, USA
      #5615534 - 01/10/13 01:25 PM Attachment (12 downloads)
Hi Sadat,
Looks like I am going forward with your solution. In reviewing your pics, I see two different gears with respect to what is mounted on the fine focus shaft (see your attached photos). The brass gear looks more like the one shown in the Micro Touch Manual (see attached). What am I missing here?
Dennis
bilgebay
Reged: 11/06/08
      #5615597 - 01/10/13 01:59 PM
Dennis, the brass gear and the bushing/sleeve is just there to show the original Starizona delivery for the MSM20 motor. Has nothing to do with this mod other than to demonstrate the sleeve technique is used by Starizona in this kind of application. Sorry for the confusion.
Hope it is clear now.
Sedat
Quarkroscoe
newbie
Reged: 01/08/13
Loc: Wisconsin, USA
      #5615657 - 01/10/13 02:39 PM
NP, so the gear used with the MSM30 motor (shown in your solution) is that much larger than the brass gear used in the MSM20. Got it!
In an old post you said that you were going to post drawings and dimension. Is that post still around? Thanks.
Dennis
bilgebay
Reged: 11/06/08
      #5615678 - 01/10/13 02:51 PM Attachment (6 downloads)
Dennis, I will post the drawing as soon as I get to my other computer. Please bear with me.
This is the gear that should be used with MSM30 motor
It was like the following before the modification, that is without the bronze hub
Edited by bilgebay (01/10/13 03:22 PM)
Quarkroscoe
newbie
Reged: 01/08/13
Loc: Wisconsin, USA
      #5615762 - 01/10/13 03:48 PM
Sedat, take your time with the drawings. I am just glad that there is such an elegant solution available. My Paramount MX mount just arrived and I have a lot of work to do with it. My observatory will not see first light until spring, but I am building everything indoors first before moving it all outside.
Dennis
bilgebay
Reged: 11/06/08
      #5616818 - 01/11/13 08:21 AM
Hey Dennis, this is great news. Congratulations on your new mount!
Cheers
Sedat
bilgebay
Reged: 11/06/08
      #5631159 - 01/19/13 08:37 AM
Here is the promised dimension drawing:
I had to redo it on the photo. For some strange reason, the original drawing is lost
Hope this helps
Clear skies
bilgebay
Reged: 11/06/08
      #5633538 - 01/20/13 04:44 PM
The followers of this thread might also want to have a look at the new thread I have started in the equipment forum.
I have tested the accuracy of the Micro Touch system in combination with the FSQ's stock focuser and put 2 videos together to demonstrate the results.
Sedat
dflipp
newbie
Reged: 01/03/06
      #5633553 - 01/20/13 04:53 PM
Sedat, thanks for taking the time to document this!
-Dan
bilgebay
Reged: 11/06/08
      #5635193 - 01/21/13 03:20 PM
You are welcome Dan.
Clear skies
Sedat
29 registered and 42 anonymous users are browsing this forum.
Moderator:  Jason B, Scott in NC, Bowmoreman, KWB
